consumption_price_base: "0.1415"
consumption_price_hc: "0.0984"
consumption_price_hp: "0.1315"
justement
consumption_price_base: '0.2276'
consumption_price_hc: '0.1828'
et tes heures met les en simple pour commencer …
23H30-7H30
j’ai un doute sur le " : "
offpeak_hours_0: 01H00-07H30;12H30-14H00
offpeak_hours_1: 01H00-07H30;12H30-14H00
offpeak_hours_2: 01H00-07H30;12H30-14H00
offpeak_hours_3: 01H00-07H30;12H30-14H00
offpeak_hours_4: 01H00-07H30;12H30-14H00
offpeak_hours_5: 01H00-07H30;12H30-14H00
offpeak_hours_6: 01H00-07H30;12H30-14H00
voilà comment ils sont mis
autand pour moi j’étais remo,nter trop haut dans le post …
[14:42:30] FATAL: The app has crashed. Are you sure you entered the correct config options?
toujours ce message
heu , c’est plus la même erreur là !! ??
a force de voir des erreurs elle y ressemble
voilà ce qui se dit quand je lance MED
Starting...
/etc/cont-init.d/00-banner.sh: executing
Add-on: MyElectricalData
Use Enedis Gateway API to send data in your MQTT Broker (latest channel)
Add-on version: 0.9.2
You are running the latest version of this add-on.
System: Home Assistant OS 11.1 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2023.10.5
Home Assistant Supervisor: 2023.10.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums
Provided by: https://github.com/alexbelgium/hassio-addons
/etc/cont-init.d/00-global_var.sh: executing
CONFIG_LOCATION='/config/myelectricaldata/config.yaml'
TZ='Europe/Paris'
mqtt_autodiscover='true'
verbose='true'
/etc/cont-init.d/01-custom_script.sh: executing
[14:46:15] INFO: Execute /config/addons_autoscripts/enedisgateway2mqtt.sh if existing
[14:46:15] INFO: ... no script found
/etc/cont-init.d/32-nginx_ingress.sh: executing
/etc/cont-init.d/91-mqtt_autodiscover.sh: executing
TZ='Europe/Paris'
verbose='true'
[14:46:16] INFO: mqtt_autodiscover is defined in options, attempting autodiscovery...
[14:46:16] INFO: ... MQTT service found, fetching server detail (you can enter those manually in your config file) ...
MQTT_HOST=core-mosquitto
MQTT_PORT=1883
MQTT_SSL=false
MQTT_USERNAME=addons
MQTT_PASSWORD=reiphu5gohkiezi9iechekah8eatohth2oow0xo4aen7Ohquoowei6theete0joY
/etc/cont-init.d/99-run.sh: executing
creating symlink
[14:46:18] INFO: Using database file found in /config/myelectricaldata
[14:46:18] INFO: Using config file found in /config/myelectricaldata/config.yaml
1:13 error wrong new line character: expected \n (new-lines)
63:56 error no new line character at the end of file (new-line-at-end-of-file)
[14:46:19] FATAL: Config file has an invalid yaml format. Please check the file in /config/myelectricaldata/config.yaml. Errors list above. You can check yaml validity with the online tool yamllint.com
je suis perdu
on dirais un probléme de caracteres …
je ne vois pas où car j’ai fais un copie coller et j’ai remis uniquement mes identifiants et mot de passe
copier coller de où ? tu est sûr de ta source ?
sur le forum j’ai copié et remis sur mon fichier myelectricaldata/config.yaml avec mes codes à moi
essaye de mettre les heures en simple …
22H24-06H24
au lieu de :
là il te dis qu’ily a des caracteres qu’il n’aime pas … il faud les trouver , … simplifi au max
je viens de le faire et pareil
cela pourrais t-il provenir de l’un de mes mots de passes qui ont des sigles ???
ca me rapelle quelque chose … j’ai déja eu des probléme avec des caractere cachés … j’avais fais un copie collé dans notepad et remis le copié de notepade , pour virer ce qu’il se voyait pas …
c’est sûr qu’il vaud mieux eviter !!!
je vais modifier les mots de passe et voir ce que cela dit
quand tu vois que même un espace en trop il t’engeule … sinon je vois pas trop … il faud attendre les spécialistes …
ok merci du coup de main et toi ta config elle fonctionne
elle a fonctionné , mais je l’avais arréter … au fait a tu redemarré completement ton systeme … physiquement …
