ah , la il cause ..
2023-07-06 18:07:43.551 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 18:07:43.551 - INFO : [041XXXXXXXX62] EXPORTATION DES DONNÉES "CONSUMPTION" DANS INFLUXDB
2023-07-06 18:07:43.568 - INFO : - 2023-07
File "/app/models/jobs.py", line 228, in job_import_data
ExportInfluxDB(self.influxdb_config, self.usage_point_config).daily()
File "/app/models/export_influxdb.py", line 42, in daily
app.INFLUXDB.write(
File "/app/models/influxdb.py", line 176, in write
self.write_api.write(bucket=self.bucket, org=self.org, record=record)
File "/usr/local/lib/python3.9/site-packages/influxdb_client/client/write_api.py", line 378, in write
results = list(map(write_payload, payloads.items()))
File "/usr/local/lib/python3.9/site-packages/influxdb_client/client/write_api.py", line 376, in write_payload
return self._post_write(_async_req, bucket, org, final_string, payload[0])
File "/usr/local/lib/python3.9/site-packages/influxdb_client/client/write_api.py", line 509, in _post_write
return self._write_service.post_write(org=org, bucket=bucket, body=body, precision=precision,
File "/usr/local/lib/python3.9/site-packages/influxdb_client/service/write_service.py", line 60, in post_write
(data) = self.post_write_with_http_info(org, bucket, body, **kwargs) # noqa: E501
File "/usr/local/lib/python3.9/site-packages/influxdb_client/service/write_service.py", line 90, in post_write_with_http_info
return self.api_client.call_api(
2023-07-06 18:07:43.573 - ERROR : ═══════════════════════════════════════════════•°• :ERREUR: •°•════════════════════════════════════════════════
File "/usr/local/lib/python3.9/site-packages/influxdb_client/_sync/api_client.py", line 343, in call_api
return self.__call_api(resource_path, method,
File "/usr/local/lib/python3.9/site-packages/influxdb_client/_sync/api_client.py", line 173, in __call_api
response_data = self.request(
File "/usr/local/lib/python3.9/site-packages/influxdb_client/_sync/api_client.py", line 388, in request
return self.rest_client.POST(url,
File "/usr/local/lib/python3.9/site-packages/influxdb_client/_sync/rest.py", line 311, in POST
return self.request("POST", url,
File "/usr/local/lib/python3.9/site-packages/influxdb_client/_sync/rest.py", line 261, in request
raise ApiException(http_resp=r)
influxdb_client.rest.ApiException: (401)
Reason: Unauthorized
HTTP response headers: HTTPHeaderDict({'Content-Type': 'application/json', 'Request-Id': '3d70e29f-1c17-11ee-80ab-0242ac1e2104', 'Www-Authenticate': 'Basic realm="Hass.io InfluxDB"', 'X-Influxdb-Build': 'OSS', 'X-Influxdb-Version': '1.8.10', 'X-Request-Id': '3d70e29f-1c17-11ee-80ab-0242ac1e2104', 'Date': 'Thu, 06 Jul 2023 16:07:43 GMT', 'Content-Length': '33'})
HTTP response body: {"error":"authorization failed"}
2023-07-06 18:07:43.574 - ERROR :
2023-07-06 18:07:43.574 - ERROR : Erreur lors de l'exportation des données dans InfluxDB
2023-07-06 18:07:43.574 - ERROR : (401)
2023-07-06 18:07:43.574 - ERROR : ═══════════════════════════════════════════════════════════════════════════════════════════════════════════════
2023-07-06 18:07:43.574 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 18:07:43.574 - INFO : ▌│█║▌║▌║ ___ _ _____ _ _ _ _ _ _ ║▌║▌║█│▌
2023-07-06 18:07:43.574 - INFO : ▌│█║▌║▌║ |_ _| _ __ ___ _ __ ___ _ __ | |_ | ___|(_) _ __ (_) ___ | |__ | || || | ║▌║▌║█│▌
2023-07-06 18:07:43.574 - INFO : ▌│█║▌║▌║ | | | '_ ` _ \ | '_ \ / _ \ | '__|| __| | |_ | || '_ \ | |/ __|| '_ \ | || || | ║▌║▌║█│▌
2023-07-06 18:07:43.575 - INFO : ▌│█║▌║▌║ | | | | | | | || |_) || (_) || | | |_ | _| | || | | || |\__ \| | | ||_||_||_| ║▌║▌║█│▌
2023-07-06 18:07:43.575 - INFO : ▌│█║▌║▌║ |___||_| |_| |_|| .__/ \___/ |_| \__| |_| |_||_| |_||_||___/|_| |_|(_)(_)(_) ║▌║▌║█│▌
2023-07-06 18:07:43.575 - INFO : ▌│█║▌║▌║ |_| ║▌║▌║█│▌
2023-07-06 18:07:43.575 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
je viens de re re re re revérifier il y a toutes les autorisations
qu'est ce qu'il veux de plus ?
j'ai ca aussi :
HTTP response headers: HTTPHeaderDict({'Content-Type': 'application/json', 'Request-Id': '15afb8f8-1c18-11ee-80de-0242ac1e2104', 'X-Influxdb-Build': 'OSS', 'X-Influxdb-Error': 'database not found: "myelectricaldata"', 'X-Influxdb-Version': '1.8.10', 'X-Request-Id': '15afb8f8-1c18-11ee-80de-0242ac1e2104', 'Date': 'Thu, 06 Jul 2023 16:13:46 GMT', 'Content-Length': '53'})
HTTP response body: {"error":"database not found: \"myelectricaldata\""}
2023-07-06 18:13:46.464 - ERROR :
bon , déjà ca c'est fait :
2023-07-06 21:19:09.798 - INFO : Connect to MQTT broker core-mosquitto:1883
2023-07-06 21:19:09.801 - INFO : => Connection success
2023-07-06 21:19:09.802 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 21:19:09.802 - INFO : Connect to InfluxDB 192.168.0.55:8086
2023-07-06 21:19:09.820 - INFO : => Connection success
2023-07-06 21:19:09.820 - INFO : => Méthode d'importation : SYNCHRONOUS
2023-07-06 21:19:09.821 - INFO : => Aucune durée de rétention de données détectée.
sauf que maintenant, il reste figé dans les journaux ... et l'add on reste a l'arrêt, et n'a plus le bouton redémarrer , ni arrêt . Si je clique sur démarrer il se passe rien !! ni l'add on , ni les journaux ..
pour tout faire repartir 1 fois je dois désinstaller et réinstaller , ... je clique sur démarrer ca suis sont cour et ca se fige au même endroit ..
SUITE ...
mon problème de myelectricaldata "figé" s'est résolut en redémarrant toute l'installation ,.. pas que home assistant .. et c'est reparti ..curieux ..
mon problème restant se résumerait à un problème d' "erreur 401" .. error:"authorization failed"
C'est pas gagné
SUITE ...
alors de mieux en mieux , j'ai changé
donc :
#method: synchronous
method: asynchronous
j'ai plus d'erreur !! . . . .
2023-07-07 01:00:00 1
2023-07-07 02:00:00 1
2023-07-07 03:00:00 1
2023-07-07 04:00:00 1
2023-07-07 05:00:00 1
2023-07-07 06:00:00 1
2023-07-07 07:00:00 1
2023-07-07 08:00:00 1
2023-07-07 09:00:00 1
2023-07-07 10:00:00 1
2023-07-07 11:00:00 1
2023-07-07 12:00:00 1
2023-07-07 13:00:00 1
2023-07-06 22:18:02.510 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 22:18:02.510 - INFO : EXPORT TERMINÉ
2023-07-06 22:18:02.510 - INFO : EXPORTATION INFLUXDB
2023-07-06 22:18:02.510 - INFO : [041XXXXXXXXXXX2] EXPORTATION DES DONNÉES "CONSUMPTION" DANS INFLUXDB
2023-07-06 22:18:02.526 - INFO : - 2023-07
2023-07-06 22:18:02.537 - INFO : - 2023-06
2023-07-06 22:18:02.546 - INFO : - 2023-05
2023-07-06 22:18:02.553 - INFO : - 2023-04
2023-07-06 22:18:02.560 - INFO : - 2023-03
2023-07-06 22:18:02.585 - INFO : - 2023-02
2023-07-06 22:18:02.591 - INFO : - 2023-01
2023-07-06 22:18:02.607 - INFO : - 2022-12
2023-07-06 22:18:02.623 - INFO : - 2022-11
2023-07-06 22:18:02.636 - INFO : - 2022-10
2023-07-06 22:18:02.648 - INFO : - 2022-09
2023-07-06 22:18:02.654 - INFO : - 2022-08
2023-07-06 22:18:02.665 - INFO : - 2022-07
2023-07-06 22:18:02.673 - INFO : - 2022-06
2023-07-06 22:18:02.677 - INFO : - 2022-05
2023-07-06 22:18:02.685 - INFO : - 2022-04
2023-07-06 22:18:02.693 - INFO : - 2022-03
2023-07-06 22:18:02.700 - INFO : - 2022-02
2023-07-06 22:18:02.706 - INFO : - 2022-01
2023-07-06 22:18:02.712 - INFO : - 2021-12
2023-07-06 22:18:02.718 - INFO : - 2021-11
2023-07-06 22:18:02.724 - INFO : - 2021-10
2023-07-06 22:18:02.730 - INFO : - 2021-09
2023-07-06 22:18:02.736 - INFO : - 2021-08
2023-07-06 22:18:02.742 - INFO : - 2021-07
2023-07-06 22:18:02.748 - INFO : - 2021-06
2023-07-06 22:18:02.754 - INFO : - 2021-05
2023-07-06 22:18:02.760 - INFO : - 2021-04
2023-07-06 22:18:02.766 - INFO : - 2021-03
2023-07-06 22:18:02.773 - INFO : - 2021-02
2023-07-06 22:18:02.780 - INFO : - 2021-01
2023-07-06 22:18:02.787 - INFO : - 2020-12
2023-07-06 22:18:02.794 - INFO : - 2020-11
2023-07-06 22:18:02.801 - INFO : - 2020-10
2023-07-06 22:18:02.807 - INFO : - 2020-09
2023-07-06 22:18:02.813 - INFO : - 2020-08
2023-07-06 22:18:02.824 - INFO : - 2020-07
2023-07-06 22:18:02.830 - INFO : - 2020-06
2023-07-06 22:18:02.837 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 22:18:02.838 - INFO : [041XXXXXXXXX62] EXPORTATION DES DONNÉES "CONSUMPTION_DETAIL" DANS INFLUXDB
2023-07-06 22:18:02.838 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 22:18:03.901 - INFO : - 2021-06
2023-07-06 22:18:03.907 - INFO : - 2021-07
2023-07-06 22:18:04.215 - INFO : - 2021-08
2023-07-06 22:18:04.423 - INFO : - 2021-09
2023-07-06 22:18:04.619 - INFO : - 2021-10
2023-07-06 22:18:04.943 - INFO : - 2021-11
2023-07-06 22:18:05.418 - INFO : - 2021-12
2023-07-06 22:18:05.855 - INFO : - 2022-01
2023-07-06 22:18:06.405 - INFO : - 2022-02
2023-07-06 22:18:06.819 - INFO : - 2022-03
2023-07-06 22:18:07.249 - INFO : - 2022-04
2023-07-06 22:18:07.651 - INFO : - 2022-05
2023-07-06 22:18:08.111 - INFO : - 2022-06
2023-07-06 22:18:08.548 - INFO : - 2022-07
2023-07-06 22:18:09.223 - INFO : - 2022-08
2023-07-06 22:18:09.698 - INFO : - 2022-09
2023-07-06 22:18:10.213 - INFO : - 2022-10
2023-07-06 22:18:10.642 - INFO : - 2022-11
2023-07-06 22:18:11.039 - INFO : - 2022-12
2023-07-06 22:18:11.486 - INFO : - 2023-01
2023-07-06 22:18:12.062 - INFO : - 2023-02
2023-07-06 22:18:12.485 - INFO : - 2023-03
2023-07-06 22:18:12.916 - INFO : - 2023-04
2023-07-06 22:18:13.333 - INFO : - 2023-05
2023-07-06 22:18:13.779 - INFO : - 2023-06
2023-07-06 22:18:14.217 - INFO : - 2023-07
2023-07-06 22:18:14.404 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
2023-07-06 22:18:14.404 - INFO : EXPORT TERMINÉ
2023-07-06 22:18:14.405 - INFO : ▌│█║▌║▌║ ___ _ _____ _ _ _ _ _ _ ║▌║▌║█│▌
2023-07-06 22:18:14.405 - INFO : ▌│█║▌║▌║ |_ _| _ __ ___ _ __ ___ _ __ | |_ | ___|(_) _ __ (_) ___ | |__ | || || | ║▌║▌║█│▌
2023-07-06 22:18:14.405 - INFO : ▌│█║▌║▌║ | | | '_ ` _ \ | '_ \ / _ \ | '__|| __| | |_ | || '_ \ | |/ __|| '_ \ | || || | ║▌║▌║█│▌
2023-07-06 22:18:14.405 - INFO : ▌│█║▌║▌║ | | | | | | | || |_) || (_) || | | |_ | _| | || | | || |\__ \| | | ||_||_||_| ║▌║▌║█│▌
2023-07-06 22:18:14.405 - INFO : ▌│█║▌║▌║ |___||_| |_| |_|| .__/ \___/ |_| \__| |_| |_||_| |_||_||___/|_| |_|(_)(_)(_) ║▌║▌║█│▌
2023-07-06 22:18:14.405 - INFO : ▌│█║▌║▌║ |_| ║▌║▌║█│▌
2023-07-06 22:18:14.405 - INFO : ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━ ◦ ❖ ◦ ━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━━
C'EST COOL !!!... :
mais ma base de données influxdb myelectricaldata.autogen reste désespéramment vide ..je sais pas où il les a mises ses données !!!
