Alors ma config :
cycle: 14400
debug: false
home_assistant:
card_myenedis: true
enable: true
influxdb:
batching_options:
batch_size: 100
exponential_base: 2
flush_interval: 1000
jitter_interval: 0
max_retries: 5
max_retry_delay: 125000
max_retry_time: 180000
retry_interval: 5000
bucket: myelectricaldata
enable: false
hostname: a0d7b954-influxdb
method: synchronous
org: MyElectrical
port: 8086
token: TOKEN
mqtt:
client_id: myelectricaldata
enable: true
hostname: core-mosquitto
password: PWD
port: 1883
prefix: myelectricaldata
qos: 0
retain: true
username: mqttuser
myelectricaldata:
'PLD':
cache: 'true'
consumption: 'true'
consumption_detail: 'true'
consumption_detail_max_date: '2023-10-07'
consumption_max_date: '2023-10-07'
consumption_max_power: 'true'
consumption_price_base: '0.175'
consumption_price_hc: '0.175'
consumption_price_hp: '0.175'
enable: 'true'
offpeak_hours_0: ''
offpeak_hours_1: ''
offpeak_hours_2: ''
offpeak_hours_3: ''
offpeak_hours_4: ''
offpeak_hours_5: ''
offpeak_hours_6: ''
plan: BASE
production: 'false'
production_detail: 'false'
production_detail_max_date: ''
production_max_date: ''
production_price: '0'
refresh_addresse: 'true'
refresh_contract: 'true'
token: TOKEN
Merci pour l’aide
si tu utilise pas influxdb, juste enable: false suffira. J’ai nettoyer des options que tu n’utilise pas.
essaye avec c’est config:
cycle: 14400
debug: false
home_assistant:
enable: true
discovery: true
influxdb:
enable: false
mqtt:
enable: true
port: 1883
username: mqttuser
password: PWD
qos: 0
retain: true
myelectricaldata:
'PLD':
token: TOKEN
addresses: 'true'
cache: 'true'
consumption: 'true'
consumption_price_base: '0.2276'
consumption_price_hc: '0.1828'
consumption_price_hp: '0.2460'
enable: 'true'
plan: BASE
Salut WarC0zes,
J’avais beaucoup de problème pour pouvoir récupérer MED, je viens de le faire avec ta config et j’ai pus récupérer MED merci pour l’aide que du as apporté à Sylvain_Lo.
Moi je souhaiterai utiliser INFLUX pourrais tu me dire qu’elles lignes je dois rajouter afin de le configurer.
en te remerciant d’avance
désoler mais j’utilise pas influxdb, je pourrais pas t’aider.
J'ai réussi à installé MED mais je n'est aucune entité
quand je regarde MQTT je n'ai que cela
Comment dois-je faire pour récupérer mes entités afin de pouvoir faire ma carte
merci
Salut ...
Qu'elle version utilisez vous ? @WarC0zes
Tu veux la carte comme celle là ?
voilà la version utilisée
oui ta carte me parais bien
Je voulais dire celle de MyElectricalData ! voir ici
oui je souhaite une carte opérationnelle moi de mon coté je ne comprends pas j’ai rien
Il faut la carte type: custom:content-card-linky qui normalement est expliquée si tu prends la bonne version de MyElectricalData !
Ce qui m’étonne ainsi que @WarC0zes , c’est que le fichier config.yaml fait encore référence au Cycle ?
que dois-je modifier dans ce cas là
Pas forcement modifier, suivant comment tu as installé ta version de MyElectricalData.
Pour avoir la carte comme celle plus haut il suffit de l’installer !
j’ai installé MED via l’addons
pourquoi je n’ai pas de sensor.myelectricaldata?
as tu la solution
Comme dit par ailleurs, il y avait une version de @alexbelgium qui doit être abandonné pour passé sur celle de @m4dm4rtig4n
Pour la carte tu vas sur HACS et tu cherche la carte, ou charge dépôt
Tu as regardé le nom des sensors sous ce que tu montres (MQTT) ?
de quoi tu parle ?
edit:
ok , j’ai la 0.9.2
Tu utilises l’ancienne version ?
