J’utilise actuellement un domaine duckdns avec l’option let’s encrypt pour le chiffrement SSL.
Afin de pouvoir utiliser l’adresse locale depuis l’application mobile HA, je souhaiterai migrer vers la solution reverse proxy de NGINX.
J’ai suivi ce tuto:
Mais j’obtiens une erreur lors de la création du certificat: (internal error sur l’IHM)
Voici la log:
[6/8/2022] [2:03:13 PM] [Nginx ] › ℹ info Reloading Nginx
[6/8/2022] [2:03:14 PM] [SSL ] › ℹ info Requesting Let'sEncrypt certificates for Cert #7: toto.duckdns.org
[6/8/2022] [2:03:31 PM] [Nginx ] › ℹ info Reloading Nginx
[6/8/2022] [2:03:31 PM] [Express ] › ⚠ warning Command failed: /usr/bin/certbot certonly --non-interactive --config "/etc/letsencrypt.ini" --cert-name "npm-7" --agree-tos --email "toto@gmail.com" --preferred-challenges "dns,http" --domains "toto.duckdns.org"
Saving debug log to /data/logs/letsencrypt/letsencrypt.log
Plugins selected: Authenticator webroot, Installer None
Performing the following challenges:
http-01 challenge for toto.duckdns.org
Using the webroot path /data/letsencrypt-acme-challenge for all unmatched domains.
Waiting for verification...
Challenge failed for domain toto.duckdns.org
Cleaning up challenges
Some challenges have failed.
J’ai essayé en arretant le module « Duckdns » et en supprimant les certificats mais l’erreur est toujours présente.
System Health
version
core-2022.6.3
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.9.12
os_name
Linux
os_version
5.15.32-v8
arch
aarch64
timezone
Europe/Paris
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
GitHub API Calls Remaining
4732
Installed Version
1.25.5
Stage
running
Available Repositories
1060
Downloaded Repositories
41
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 8.1
update_channel
stable
supervisor_version
supervisor-2022.05.3
agent_version
1.2.1
docker_version
20.10.14
disk_total
58.9 GB
disk_used
27.8 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Samba share (9.6.1), File editor (5.3.3), Duck DNS (1.15.0), deCONZ (6.14.1), Terminal & SSH (9.4.0), Node-RED (12.0.0), Mosquitto broker (6.1.2), Check Home Assistant configuration (3.10.0), InfluxDB (4.4.1), Grafana (7.5.2), Glances (0.15.0), SSH & Web Terminal (11.0.0), Log Viewer (0.13.0), ESPHome (2022.3.1), NGINX Home Assistant SSL proxy (3.1.1), Zigbee2mqtt (1.25.2-1), Home Assistant Google Drive Backup (0.108.2), Enedisgateway2mqtt (0.7.7-3), Studio Code Server (5.0.6), Zigbee2mqtt Edge (edge), Nginx Proxy Manager (0.11.0), MariaDB (2.4.0)
