Oups alors
c est corrigé en 0.3.5 ![]()
J’ai mis a jour et setter ma env variable mais j’ai cette erreur maintenant :
Error while setting up vigieau platform for sensor
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 353, in _async_setup_platform
await asyncio.shield(task)
File "/config/custom_components/vigieau/sensor.py", line 42, in async_setup_entry
await vigieau_coordinator.async_config_entry_first_refresh()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 251, in async_config_entry_first_refresh
await self._async_refresh(
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 374, in _async_refresh
self.async_update_listeners()
File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 164, in async_update_listeners
update_callback()
File "/config/custom_components/vigieau/__init__.py", line 220, in _handle_coordinator_update
self._attr_icon = {
KeyError: 'alerte renforcée'
j’ai fais une maj sur la carte pour quelle soit compacter si pas d’alerte, au lieu d’avoir tout les restrictions afficher.
Pas d’alerte :
Avec alerte, affichera que les restrictions avec interdictions :
Code carte complet :
type: custom:stack-in-card
mode: vertical
keep:
box_shadow: false
margin: false
border_radius: false
background: false
outer_padding: false
cards:
- type: custom:mod-card
card_mod:
style:
:host {
--text-divider-color: rgb(68, 115, 158);
--text-divider-line-size: 1px;
card:
type: custom:text-divider-row
text: SÉCHERESSE
align: left
card_mod:
style: |
ha-card {
margin: -15px -5px 0px -5px;
card:
type: horizontal-stack
cards:
- type: custom:button-card
entity: sensor.alert_level
name: 'Vigieau xxxxxxx:'
layout: icon_name_state2nd
color_type: icon
show_name: true
show_state: true
state:
- value: Vigilance
operator: '=='
color: green
icon: mdi:water-check
styles:
state:
- color: green
- value: Alerte
operator: '=='
color: yellow
icon: mdi:water-alert
styles:
state:
- color: yellow
- value: Alerte renforcée
operator: '=='
color: orange
icon: mdi:water-remove
styles:
state:
- color: orange
- value: Crise
operator: '=='
color: red
icon: mdi:water-off
styles:
state:
- color: red
styles:
card:
- '--mdc-ripple-color': rgb(68, 115, 158)
- '--mdc-ripple-press-opacity': 0.5
name:
- font-size: 15px
state:
- font-weight: bold
- font-size: 15px
card_mod:
style: |
ha-card {
border: none;
- type: custom:bar-card
- entity: sensor.alert_level
icon: mdi:alert-circle
height: 47px
color: red
positions:
indicator: 'off'
icon: 'off'
severity:
- text: Vigilance
color: green
- text: Alerte
color: yellow
- text: Alerte renforcée
color: orange
- text: Crise
color: red
card_mod:
style: >
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 25px;
#states > bar-card-row > bar-card-card > bar-card-background >
bar-card-contentbar > bar-card-name {
font-size: 16px;
} ha-card {
margin-top: -2px;
background: none;
border: none;
- type: conditional
conditions:
state_not: Vigilance
card:
card_mod:
style: |
ha-card {
margin: 5px 5px 5px 5px;
card:
type: custom:auto-entities
card:
type: grid
columns: 5
square: true
card_param: cards
filter:
include:
- entity_id: sensor.*_restrictions
options:
color_type: icon
aspect_ratio: 1/1
show_name: true
show_state: true
return entity.attributes.friendly_name
styles:
card:
- border-radius: 8px
name:
- font-size: 11px
- white-space: normal
state:
- font-weight: bold
- font-size: 10px
state:
- value: Aucune restriction
operator: '=='
color: green
styles:
card:
- box-shadow: 0px 0px 0px 2px green
state:
- color: green
- value: Interdiction sauf exception
operator: '=='
color: orange
styles:
card:
- box-shadow: 0px 0px 0px 2px orange
state:
- color: orange
operator: '=='
color: red
styles:
card:
- box-shadow: 0px 0px 0px 2px red
state:
- color: red
- value: Interdiction sur plage horaire
operator: '=='
color: orange
styles:
card:
state:
- color: orange
exclude:
state: Aucune restriction
sort:
method: name
reverse: false
Edit 22/07/23:
- ajout d’icone pour le niveau d’alerte.
mdi:water-check,mdi:water-alert,mdi:water-removeetmdi:water-off.
Merci pour le code
Si tu masques la ville sur la photo, il faut aussi penser à l enlever du code ![]()
Salut merci pour le code , voilà le changement, parcontre il y a un décalage
Sur les dux premiers case.
C’est un soucis de taille de police sur ton mobile, sur pc aucun problème.
Faut adapter pour ton mobile, recherche ces lignes dans le button-card:
name:
- font-size: 11px
state:
- font-weight: bold
- font-size: 10px
diminue - font-size: 10,9,8…px. tu peu le faire sur name et state.
peut etre comment tu enleve le carde de vigieau XXXXXX
Tiens cela m’amène une question sur les couleurs.
J’ai des couleurs en hexa '#04B404' par exemple bon c’est vert pas orange mais pas grave ![]()
Elle passe nickel sur les color: mais pas sur le box-shadow: 0px 0px 0px 2px orange pour remplacer le orange par exemple
J’ai modifier le code ( de mon post précédent), faut ajouter ces lignes:
card_mod:
style: |
ha-card {
border: none;
Faut convertir ta couleur hex (#04B404) en dec (rgb(4,180,4)).
et tu met ta couleur telle quelle:
- box-shadow: 0px 0px 0px 2px rgb(4,180,4)
Liste de couleur en nom
https://www.w3.org/TR/css-color-3/#svg-color
super merci, je pense ouvrir un autre poste sur les carte vigieau car sur mon mobile , il y a pas vraiment le meme aperçue.
En copiant ton code, la couleur n’est pas la bonne :
Elle devrait être verte.
je viens de tester un copier/coller du code et c’est bon.
le code de ce lien Nouvelle intégration Vigieau - #66 par WarC0zes
J’ai pas pensé au RGB pour ce cas
je vais tester ça
Comment récupérer les heures de restrictions afin d’animer la carte en fonction de celles-ci ?
Je vois bien le mot clef pour récupérer « friendly_name » entity.attributes.friendly_name
Mais la syntax pour heureDebut et heureFin ?
Fred
C’est dans les attributs
Merci @titof2375, un exemple ?
Fred
