ah !!!
merci
ah !!!
merci
c’est bon la non ??
par ce que lorsque je lance Zigbee2mqtt sur le coté …
il me met 502: bad gateway
ttyACM0
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2446739-if00
Sous-système:
tty
Chemin d’accès au périphérique:
/dev/ttyACM0
ID:
Attributs:
DEVLINKS: >-
/dev/serial/by-path/pci-0000:01:1b.0-usb-0:1:1.0
DEVNAME: /dev/ttyACM0
DEVPATH: /devices/pci0000:00/0000:00:1e.0/0000:01:1b.0/usb2/2-1/2-1:1.0/tty/ttyACM0
ID_BUS: usb
ID_MODEL: ConBee_II
ID_MODEL_ENC: ConBee\x20II
ID_MODEL_ID: '0030'
ID_PATH: pci-0000:01:1b.0-usb-0:1:1.0
ID_PATH_TAG: pci-0000_01_1b_0-usb-0_1_1_0
ID_REVISION: '0100'
ID_SERIAL: dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2446739
ID_SERIAL_SHORT: DE2446739
ID_TYPE: generic
ID_USB_DRIVER: cdc_acm
ID_USB_INTERFACES: ':020201:0a0000:'
ID_USB_INTERFACE_NUM: '00'
ID_USB_MODEL: ConBee_II
ID_USB_MODEL_ENC: ConBee\x20II
ID_USB_MODEL_ID: '0030'
ID_USB_REVISION: '0100'
ID_USB_SERIAL: dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2446739
ID_USB_SERIAL_SHORT: DE2446739
ID_USB_TYPE: generic
ID_USB_VENDOR: dresden_elektronik_ingenieurtechnik_GmbH
ID_USB_VENDOR_ENC: dresden\x20elektronik\x20ingenieurtechnik\x20GmbH
ID_USB_VENDOR_ID: 1cf1
ID_VENDOR: dresden_elektronik_ingenieurtechnik_GmbH
ID_VENDOR_ENC: dresden\x20elektronik\x20ingenieurtechnik\x20GmbH
ID_VENDOR_ID: 1cf1
MAJOR: '166'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '2848175'
[20:49:27] INFO: Preparing to start...
[20:49:27] INFO: Socat not enabled
[20:49:28] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2024-01-23 20:49:29: Logging to console and directory: '/config/zigbee2mqtt/log/2024-01-23.20-49-29' filename: log.txt
Zigbee2MQTT:info 2024-01-23 20:49:29: Starting Zigbee2MQTT version 1.35.1 (commit #unknown)
Zigbee2MQTT:info 2024-01-23 20:49:29: Starting zigbee-herdsman (0.30.0)
Zigbee2MQTT:info 2024-01-23 20:49:32: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2024-01-23 20:49:32: Coordinator firmware version: 'undefined'
Zigbee2MQTT:error 2024-01-23 20:49:42: Failed to start zigbee
Zigbee2MQTT:error 2024-01-23 20:49:42: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2024-01-23 20:49:42: Exiting...
Zigbee2MQTT:error 2024-01-23 20:49:42: Error: get network parameters Error:TIMEOUT
at DeconzAdapter.getNetworkParameters (/app/node_modules/zigbee-herdsman/src/adapter/deconz/adapter/deconzAdapter.ts:1017:35)
at runNextTicks (node:internal/process/task_queues:60:5)
at listOnTimeout (node:internal/timers:538:9)
at processTimers (node:internal/timers:512:7)
at Controller.getNetworkParameters (/app/node_modules/zigbee-herdsman/src/controller/controller.ts:360:44)
at Zigbee.start (/app/lib/zigbee.ts:120:62)
at Controller.start (/app/lib/controller.ts:98:27)
at start (/app/index.js:107:5)
Tu copies/colles le chemin pour par te poser de question et ne te tromper
C’est les logs le plus important… c’est là que tu as tous les détails…
Pas de ZHA (genre message de détection… et tu as cliqué sur OUI) ?
c est bien ca que je dois coller ??
oui et tu remplace la ligne équivalente
bah je l’ai fais ca ne marche pas …
peut etre en desinstallant et reinstannt zigbee2mqtt ??
Commence par redémarrer HA maintenant que la config est mieux
le voyant de Zigbee2mqtt passe de vert en rouge
C’est pas la même chose : /tmp/ttyZ2M c’est un fichier
Normal ça s’arrête
Tu as viré l’option usb3 dans le passtrough proxmox ?
j’ai mis les 4 ports usb …
option usb3 non cochée
OK, donc je sais pas.
Essaye de refaire la config après désinstallation Mais pas contre il va falloir refaire les appairages à mon avis
ca ne marche pas mieux en reinstallant …
c’est pereil
Vire l’addon.
Efface le contenu de /config/zigbee2mqtt (ou /config/zigbee je ne sais plus exactement son nom)
Et recommence proprement
Pourquoi tu lui passe ta souris et ton audio? Pour le bluetooth c’est une clé ou le bluetooth interne de ta machine proxmox?
oui j’ai retiré la souris et l’audio …
je ne comprend pas trop ce que vient faire de l’audio sur un port USB ou rien n’est branché dessus …
j’ai conservé BT et combee2
je suppose qu’il faut vider le contenu de zigbee2mqtt ca peut peut etre resoudre mon probleme.
je verai demain
