Mon journal z2m :
"Info 2024-07-31 10:43:25z2m: Zigbee: disabling joining new devices.
Info 2024-07-31 10:43:25z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":false},"status":"ok","transaction":"n8rq2-1"}'
Info 2024-07-31 10:43:27z2m: Zigbee: allowing new devices to join.
Info 2024-07-31 10:43:27z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"n8rq2-2"}'
Info 2024-07-31 10:43:57z2m: Starting network scan (includeRoutes 'false')
Info 2024-07-31 10:44:00z2m: Network scan finished
Info 2024-07-31 10:44:00z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/networkmap', payload '{"data":{"routes":false,"type":"raw","value":{"links":[{"depth":15,"linkquality":230,"lqi":230,"relationship":2,"routes":[],"source":{"ieeeAddr":"0xa4c1385925b9f868","networkAddress":39015},"sourceIeeeAddr":"0xa4c1385925b9f868","sourceNwkAddr":39015,"target":{"ieeeAddr":"0x8c65a3fffe548456","networkAddress":0},"targetIeeeAddr":"0x8c65a3fffe548456"},{"depth":1,"linkquality":142,"lqi":142,"relationship":1,"routes":[],"source":{"ieeeAddr":"0xa4c138c59a32ffc9","networkAddress":47590},"sourceIeeeAddr":"0xa4c138c59a32ffc9","sourceNwkAddr":47590,"target":{"ieeeAddr":"0x8c65a3fffe548456","networkAddress":0},"targetIeeeAddr":"0x8c65a3fffe548456"},{"depth":1,"linkquality":200,"lqi":200,"relationship":1,"routes":[],"source":{"ieeeAddr":"0xa4c138f82a779a91","networkAddress":32676},"sourceIeeeAddr":"0xa4c138f82a779a91","sourceNwkAddr":32676,"target":{"ieeeAddr":"0x8c65a3fffe548456","networkAddress":0},"targetIeeeAddr":"0x8c65a3fffe548456"},{"depth":0,"linkquality":121,"lqi":121,"relationship":0,"routes":[],"source":{"ieeeAddr":"0x8c65a3fffe548456","networkAddress":0},"sourceIeeeAddr":"0x8c65a3fffe548456","sourceNwkAddr":0,"target":{"ieeeAddr":"0xa4c1385925b9f868","networkAddress":39015},"targetIeeeAddr":"0xa4c1385925b9f868"}],"nodes":[{"definition":null,"failed":[],"friendlyName":"Coordinator","ieeeAddr":"0x8c65a3fffe548456","lastSeen":1722415407168,"networkAddress":0,"type":"Coordinator"},{"definition":{"description":"1 gang switch module - (without neutral)","model":"TS0011_switch_module","supports":"switch (state), power_on_behavior, switch_type, linkquality","vendor":"Tuya"},"friendlyName":"Lumière terrasse","ieeeAddr":"0xa4c138c59a32ffc9","lastSeen":1722415335789,"manufacturerName":"_TZ3000_ji4araar","modelID":"TS0011","networkAddress":47590,"type":"EndDevice"},{"definition":{"description":"Door sensor","model":"MC500A","supports":"contact, battery, voltage, battery_low, linkquality","vendor":"Tuya"},"friendlyName":"Capteur de porte","ieeeAddr":"0xa4c138f82a779a91","lastSeen":1722412744469,"manufacturerName":"_TZ3000_2mbfxlzr","modelID":"TS0203","networkAddress":32676,"type":"EndDevice"},{"definition":{"description":"Wall switch module","model":"WHD02","supports":"switch (state), countdown, power_on_behavior, switch_type, linkquality","vendor":"Tuya"},"failed":[],"friendlyName":"Prise Salle de jeu","ieeeAddr":"0xa4c1385925b9f868","lastSeen":1722415364741,"manufacturerName":"_TZ3000_npzfdcof","modelID":"TS0001","networkAddress":39015,"type":"Router"}]}},"status":"ok","transaction":"n8rq2-3"}'
Info 2024-07-31 10:44:11z2m: Start Touchlink scan
Info 2024-07-31 10:44:11zh:controller:touchlink: Set InterPAN channel to '11'
Warning 2024-07-31 10:44:11zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:11zh:controller:touchlink: Set InterPAN channel to '15'
Warning 2024-07-31 10:44:12zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:12zh:controller:touchlink: Set InterPAN channel to '20'
Info 2024-07-31 10:44:12zh:controller:touchlink: Set InterPAN channel to '25'
Warning 2024-07-31 10:44:13zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:13zh:controller:touchlink: Set InterPAN channel to '12'
Info 2024-07-31 10:44:13zh:controller:touchlink: Set InterPAN channel to '13'
Warning 2024-07-31 10:44:14zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:14zh:controller:touchlink: Set InterPAN channel to '14'
Info 2024-07-31 10:44:14zh:controller:touchlink: Set InterPAN channel to '16'
Warning 2024-07-31 10:44:15zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:15zh:controller:touchlink: Set InterPAN channel to '17'
Info 2024-07-31 10:44:15zh:controller:touchlink: Set InterPAN channel to '18'
Warning 2024-07-31 10:44:16zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:16zh:controller:touchlink: Set InterPAN channel to '19'
Info 2024-07-31 10:44:16zh:controller:touchlink: Set InterPAN channel to '21'
Warning 2024-07-31 10:44:17zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:17zh:controller:touchlink: Set InterPAN channel to '22'
Info 2024-07-31 10:44:17zh:controller:touchlink: Set InterPAN channel to '23'
Warning 2024-07-31 10:44:18zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:18zh:controller:touchlink: Set InterPAN channel to '24'
Info 2024-07-31 10:44:18zh:controller:touchlink: Set InterPAN channel to '26'
Warning 2024-07-31 10:44:19zh:controller:touchlink: Scan request failed or was not answered: 'Error: Timeout - null - 254 - null - 4096 - 1 after 500ms'
Info 2024-07-31 10:44:19zh:controller:touchlink: Restore InterPAN channel
Info 2024-07-31 10:44:22z2m: Finished Touchlink scan
Info 2024-07-31 10:44:22z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/response/touchlink/scan', payload '{"data":{"found":[]},"status":"ok","transaction":"n8rq2-4"}'
Info 2024-07-31 10:44:27z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lumière terrasse', payload '{"linkquality":156,"power_on_behavior":"on","state":"OFF","switch_type":null}'
Info 2024-07-31 10:44:27z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Lumière terrasse', payload '{"linkquality":156,"power_on_behavior":"on","state":"OFF","switch_type":"toggle"}'
