Je viens d’intégrer ma prise NOUS (A4Z) sur Z2M. Quand je change l’état à ON d’une prise, celle-ci se remet en OFF automatiquement alors que je n’ai rien paramétré. Comment analyser d’ou vient le problème et/ou modifier le paramètre qui force ce comportement ?
Merci d’avance.
[center]## System Information
| version |
core-2024.11.3 |
| installation_type |
Home Assistant OS |
| dev |
false |
| hassio |
true |
| docker |
true |
| user |
root |
| virtualenv |
false |
| python_version |
3.12.4 |
| os_name |
Linux |
| os_version |
6.6.54-haos |
| arch |
x86_64 |
| timezone |
Europe/Paris |
| config_dir |
/config |
| GitHub API |
ok |
| GitHub Content |
ok |
| GitHub Web |
ok |
| HACS Data |
ok |
5000 |
| Installed Version |
2.0.1 |
| Stage |
running |
| Available Repositories |
1472 |
| Downloaded Repositories |
19 |
| logged_in |
false |
| can_reach_cert_server |
ok |
| can_reach_cloud_auth |
ok |
| can_reach_cloud |
ok |
| host_os |
Home Assistant OS 13.2 |
| update_channel |
stable |
| supervisor_version |
supervisor-2024.11.4 |
| agent_version |
1.6.0 |
| docker_version |
27.2.0 |
| disk_total |
30.8 GB |
| disk_used |
8.6 GB |
| healthy |
true |
| supported |
true |
| host_connectivity |
true |
| supervisor_connectivity |
true |
| ntp_synchronized |
true |
| virtualization |
kvm |
| board |
ova |
| supervisor_api |
ok |
| version_api |
ok |
| installed_addons |
Nginx Proxy Manager (0.12.3), MariaDB (2.7.1), File editor (5.8.0), Mosquitto broker (6.4.1), Zigbee2MQTT (1.42.0-2) |
| dashboards |
5 |
| resources |
28 |
| views |
16 |
| mode |
storage |
| oldest_recorder_run |
27 novembre 2024 à 12:39 |
| current_recorder_run |
3 décembre 2024 à 16:06 |
| estimated_db_size |
96.80 MiB |
| database_engine |
sqlite |
| database_version |
3.45.3 |
Xiaomi Miot Auto
| component_version |
1.0.1 |
| can_reach_server |
ok |
| can_reach_spec |
ok |
| logged_accounts |
1 |
| total_devices |
3 |
[/center]
Il y a quelques chose de brancher dessus ?
Hello @Sebastien_G,
J'ai la même et pas ce genre de soucis. C'est curieux.
Si tu vas sur l'équipement tu peux voir qui le commande (Automatisations, Scenes, Scripts) :
Exemple chez moi :
Ca doit aider à trouver le coupable.
Comme tu peux le voir, il s'éteinds au bout de 6 seconds
Dans le wiki mqtt, il y a des paramètres ontime et ontimeoff mais je ne sais pas comment les manipuler :
Dans la page Zigbee tu ne vois pas ces attributs ?
j’ai pareil. Pas d’idées du coup.
Par contre, dans la console dev, quand je mets l1 ou l2 qui me permettrait de lire les valeurs des paramètres associés aux prises, cela me fait une page de bug :
Tu devrais forcer sa suppression et le réappairer. On a l’impression qu’il est mal reconnu.
Déjà testé pour un même résultat
J’ai exactement la même chose avec ces prises Nous maus socket A1Z toutes neuves.
Ça fonctionne 1 soirée puis ça redéconne peu de temps après, elle repassent à off.
Si j’allume la prise avec son bouton physique elle fonctionne et je peux l’éteindre 1 fois depuis HA.
Dans les tuiles HA elles ne changent pas d’état non plus et ne renvoient visiblement pas d’info puisque l’icône ne change pas de couleur.
Quelqu’un a trouvé une solution à ce problème ?
Il doit y avoir un problème d’appairage si tu ne vois pas l’état dans HA. As-tu essayé de faire un reset d’usine et une ré-apparirage assez proche de ton coordinateur?
J’utilise ces prises depuis 18 mois sans avoir rencontré un seul soucis pour le moment. J’en ai une dizaine actives (sous ZHA). La prise remonte-t’elle les infos de courant, tension, summation delivered?
Autre question, quelle charge as-tu branché sur la prise? Si elle détecte un appel de courant trop iomportant, elle s’éteint par sécurité. Ceci dit, ceci n’expliquerait pas pourquoi tu le vois pas les remontées dans HA.
Même comportement, reset factory effectué à l’instant, en supprimant la prise de l’application NOUS comme indiqué dans l’user guide (https://nous.technology/product/manual?slug=a4z&alias=EN)
Une fois resynchronisé avec le coordinateur (1 mètre les sépare), l’activation des prises n’est effectif que 5 seconds et se désactive à nouveau…
peut être un problème zigbee général qui est perturbé par le wifi 2.4Ghz, les produits NOUS sont peut être plus sensibles que les autres.
Tu as regardé quel canal zigbee et wifi tu utilises, ou même le wifi des voisins ?
Une fois le reset fait (appui long sur le bouton d’après le manuel) et ré-ajout à HA, est-ce que les informations de consommation et le statut remontent bien dans HA?
Est-ce qu’il pourrait y avoir un conflit entre l’pplication NOUS et HA?
Je n’ai jamais installé l’application NOUS ni lié mes prises A1Z avec cette application de mon côté.
Salut à tous et merci pour vos réponses !
Je n’ai jamais fait l’installation via l’application Nous non plus.
À priori non mes consommations et puissance ne remontent pas. Ce sont simplement des lampes.
Effectivement ce midi j’ai changé le canal wifi en le passant sur 3 et le zigbee sur 25.
Après reboot a priori ça n’a pas non plus fonctionné. L’état ne remonte pas.
J’allume la prise sur son bouton je peux l’éteindre via HA mais une fois. Ensuite c’est très aléatoire et/ou avec un délai conséquent mais toujours pas de remontée de l’état.
Je vais tester un factory reset et les réimporter.
Mon LQI est à 105 et 60.
Je précise que je n’ai que ces 2 prises pour le moment. J’avais tout en zwave (aucun pb de réactivité
) et je commence à installer du zigbee.
J’ai un SLZB-06 en POE comme concentrateur pour info…
Bonsoir
J’ai un SLZB-06P10 également et 12 nous A1Z (3 lot de 4 acheter a différente période). Jamais eu aucun soucis avec ces prises. Même quand j’avais des interférences.Toujours sur Z2M. Avant j’avais une sonoff P et pas de soucis non plus.
Est ce que tu connais quelqu’un qui pourrait les tester avec son zigbee ? Je sais que Z2M m’a proposé une mise a jour pour chacune
J’ai fait un reset des prises.
Les A1Z sont en fait des Tuya et il est conseillé de faire une MAJ OTA si elles s’éteignent seules.
J’ai fait cette MAJ et réinstallé la prise hier soir elle fonctionnait parfaitement hier jusqu’à ce que je m’aperçoive que 2h plus tard dans la nuit elle est devenue indisponible sans raison.
Impossible de la faire réagir.
Z2M parfaitement actif et y le SLZB-06 aussi
J’ai pas d’idée à part de me dire que c’est une prise défectueuse ?
