Humm…
tu es sur de ça ?
Class measurement, j’y crois pas, c’est pas une valeur numérique
ah oui effectivement ça doit être ça l’erreur
je viens d’effacer et je redémarre HA
re
ça a de nouveau planté hier soir j’ai dautre erreur
ci joint le rapport log 1
2024-04-06 21:20:52.870 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration seatconnect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.889 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration mydolphin_plus which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.895 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.899 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.904 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration aqua_temp which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.910 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.916 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration gazpar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.921 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.926 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration aquatemp which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.931 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration smartlife which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.936 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration pronote which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:20:52.945 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-06 21:21:04.072 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2024-04-06 21:21:04.188 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=390 from 2024-04-06 11:20:56.580136)
2024-04-06 21:21:19.969 WARNING (MainThread) [homeassistant.const] TEMP_CELSIUS was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.CELSIUS instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:19.984 WARNING (MainThread) [homeassistant.const] TEMP_FAHRENHEIT was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use UnitOfTemperature.FAHRENHEIT instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:20.000 WARNING (MainThread) [homeassistant.components.climate.const] HVAC_MODE_OFF was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.OFF instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:20.015 WARNING (MainThread) [homeassistant.components.climate.const] HVAC_MODE_HEAT was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.HEAT instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:20.030 WARNING (MainThread) [homeassistant.components.climate.const] HVAC_MODE_COOL was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.COOL instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:20.044 WARNING (MainThread) [homeassistant.components.climate.const] HVAC_MODE_AUTO was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use HVACMode.AUTO instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:20.059 WARNING (MainThread) [homeassistant.components.climate.const] SUPPORT_TARGET_TEMPERATURE was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.TARGET_TEMPERATURE instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:20.074 WARNING (MainThread) [homeassistant.components.climate.const] SUPPORT_FAN_MODE was used from aquatemp, this is a deprecated constant which will be removed in HA Core 2025.1. Use ClimateEntityFeature.FAN_MODE instead, please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:33.021 DEBUG (SyncWorker_5) [homeassistant.components.rfxtrx] Using modes: ac,x10,arc,homeeasy,oregon,lighting4
2024-04-06 21:21:33.056 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2024-04-06 21:21:33.360 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2024-04-06 21:21:33.381 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x00 0x01 0x02 0x53 0x2b 0x08 0x00 0x2f 0x00 0x03 0x01 0x2b 0x10 0x75 0x46 0x58 0x43 0x4f 0x4d
2024-04-06 21:21:33.382 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x00 0x03 0x53 0x2b 0x08 0x00 0x2f 0x00 0x00 0x00 0x00
2024-04-06 21:21:33.508 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x00 0x00 0x03 0x53 0x2b 0x08 0x00 0x2f 0x00 0x03 0x01 0x2b 0x10 0x74 0x46 0x58 0x43 0x4f 0x4d
2024-04-06 21:21:33.509 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2024-04-06 21:21:33.548 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x00 0x01 0x02 0x53 0x2b 0x08 0x00 0x2f 0x00 0x03 0x01 0x2b 0x10 0x74 0x46 0x58 0x43 0x4f 0x4d
2024-04-06 21:21:33.549 DEBUG (Thread-2 (_connect)) [RFXtrx] Status: Status [subtype=433.92MHz, firmware=43, output_power=43, devices=['ac', 'arc', 'homeeasy', 'lighting4', 'oregon', 'x10']]
2024-04-06 21:21:33.565 DEBUG (Thread-2 (_connect)) [RFXtrx] Send: 0x0d 0x00 0x00 0x03 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
2024-04-06 21:21:33.698 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x07 0x03 0x07 0x43 0x6f 0x70 0x79 0x72 0x69 0x67 0x68 0x74 0x20 0x52 0x46 0x58 0x43 0x4f 0x4d
2024-04-06 21:21:36.575 WARNING (MainThread) [homeassistant.setup] Setup of ffmpeg is taking over 10 seconds.
2024-04-06 21:21:36.576 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2024-04-06 21:21:36.577 WARNING (MainThread) [homeassistant.setup] Setup of application_credentials is taking over 10 seconds.
2024-04-06 21:21:36.577 WARNING (MainThread) [homeassistant.setup] Setup of tag is taking over 10 seconds.
2024-04-06 21:21:36.577 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2024-04-06 21:21:36.578 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2024-04-06 21:21:36.578 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2024-04-06 21:21:36.579 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2024-04-06 21:21:36.580 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2024-04-06 21:21:36.580 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2024-04-06 21:21:36.582 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2024-04-06 21:21:36.582 WARNING (MainThread) [homeassistant.setup] Setup of schedule is taking over 10 seconds.
2024-04-06 21:21:37.354 WARNING (MainThread) [homeassistant.helpers.entity] Entity None (<class 'custom_components.aquatemp.climate.Aquatemp'>) is using deprecated supported features values which will be removed in HA Core 2025.1. Instead it should use <ClimateEntityFeature.TARGET_TEMPERATURE|FAN_MODE: 9>, please report it to the author of the 'aquatemp' custom integration and reference https://developers.home-assistant.io/blog/2023/12/28/support-feature-magic-numbers-deprecation
2024-04-06 21:21:37.355 WARNING (MainThread) [homeassistant.components.climate] Entity None (<class 'custom_components.aquatemp.climate.Aquatemp'>) implements HVACMode(s): off, cool, heat, auto and therefore implicitly supports the turn_on/turn_off methods without setting the proper ClimateEntityFeature. Please report it to the author of the 'aquatemp' custom integration
2024-04-06 21:21:38.826 WARNING (MainThread) [homeassistant.components.meteo_france] 1 hour rain forecast not available. Hésingue - Alsace (68) - FR is not in covered zone
2024-04-06 21:21:49.592 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2024-04-06 21:21:49.926 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform rpi_power is taking over 10 seconds.
2024-04-06 21:21:49.957 WARNING (MainThread) [homeassistant.components.climate] Setup of climate platform aquatemp is taking over 10 seconds.
2024-04-06 21:21:53.515 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for weather.hesingue (<class 'homeassistant.components.meteo_france.weather.MeteoFranceWeather'>) took 0.679 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+meteo_france%22
2024-04-06 21:21:57.559 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2024-04-06 21:21:57.560 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform energy is taking over 10 seconds.
2024-04-06 21:21:57.755 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry 4awkpclo.fbxos.fr for freebox
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 504, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/freebox/__init__.py", line 29, in async_setup_entry
freebox_config = await api.system.get_config()
File "/usr/local/lib/python3.12/site-packages/freebox_api/api/system.py", line 9, in get_config
return await self._access.get("system/")
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 122, in get
return await self._perform_request(self.session.get, end_url)
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 86, in _perform_request
await self._refresh_session_token()
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 69, in _refresh_session_token
session_token, session_permissions = await self._get_session_token(
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 45, in _get_session_token
challenge = await self._get_challenge(base_url, timeout)
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 28, in _get_challenge
r = await self.session.get(url, timeout=timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 504, in _request
with timer:
File "/usr/local/lib/python3.12/site-packages/aiohttp/helpers.py", line 735, in __exit__
raise asyncio.TimeoutError from None
TimeoutError
2024-04-06 21:21:57.833 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2024-04-06 21:21:58.397 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': {'role_name': 'User', 'user_type': 'Customer', 'user_id': '1426947412878057472', 'user_name': 'st.simon68@free.fr', 'nick_name': 'Audi68', 'roleName': 'User', 'x-token': 'B5378F0249949D563E542DCCCE38CB0C', 'real_name': None}, 'is_reuslt_suc': True}
2024-04-06 21:21:58.793 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'device_status': 'OFFLINE', 'device_name': '34EAE71D5148', 'is_fault': False, 'device_id': '1426949450676424706', 'device_code': '34EAE71D5148', 'product_id': '1132174963097280512', 'device_type': None, 'device_nick_name': '34EAE71D5148'}], 'is_reuslt_suc': True}
2024-04-06 21:22:03.703 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:22:03.936 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-04-06 21:22:04.313 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:22:10.118 WARNING (MainThread) [homeassistant.components.device_tracker] SOURCE_TYPE_GPS was used from seatconnect, this is a deprecated constant which will be removed in HA Core 2025.1. Use SourceType.GPS instead, please create a bug report at https://github.com/farfar/homeassistant-seatconnect/issues
2024-04-06 21:22:10.142 WARNING (MainThread) [homeassistant.components.device_tracker] SOURCE_TYPE_GPS was used from seatconnect, this is a deprecated constant which will be removed in HA Core 2025.1. Use SourceType.GPS instead, please create a bug report at https://github.com/farfar/homeassistant-seatconnect/issues
2024-04-06 21:22:22.491 WARNING (MainThread) [homeassistant.components.sensor] Entity sensor.batterie (<class 'homeassistant.components.template.sensor.SensorTemplate'>) is using native unit of measurement 'None' which is not a valid unit for the device class ('battery') it is using; expected one of ['%']; Please update your configuration if your entity is manually configured, otherwise create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+template%22
2024-04-06 21:22:25.912 ERROR (MainThread) [homeassistant.components.homekit.util] media_player.freebox_player does not support any media_player features
2024-04-06 21:22:30.425 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.mydolphin_plus.light.MyDolphinPlusLightEntity'>) does not set supported color modes, this will stop working in Home Assistant Core 2025.3, please create a bug report at https://github.com/sh00t2kill/dolphin-robot/issues
2024-04-06 21:23:04.691 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:23:04.886 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:24:04.832 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:24:05.015 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:25:04.869 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:25:05.076 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:26:04.566 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:26:04.747 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:27:04.576 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:27:04.767 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:28:04.610 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:28:04.794 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:29:04.836 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:29:05.025 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:30:06.267 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:30:06.669 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:31:05.161 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:31:05.357 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:32:05.192 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:32:05.572 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:33:04.580 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:33:04.768 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:34:04.580 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:34:04.816 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:35:04.912 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:35:05.115 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:36:04.699 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:36:04.884 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:37:04.584 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:37:04.773 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:38:04.583 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:38:04.766 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:39:04.595 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:39:04.822 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:40:04.581 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:40:04.765 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:41:04.580 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:41:04.783 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:42:05.547 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:42:05.778 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:43:05.129 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:43:05.635 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:44:04.990 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:44:05.188 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:45:04.974 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:45:05.188 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:46:01.343 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x08 0x20 0x00 0x00 0xfd 0xdf 0xf0 0x82 0x79
2024-04-06 21:46:01.357 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 32, 'sub_type': 0, 'type_string': 'X10 Security', 'id_string': 'fddff0:32', 'data': '08200000fddff08279', 'values': {'Sensor Status': 'Alarm Tamper', 'Battery numeric': 9, 'Rssi numeric': 7}}
2024-04-06 21:46:05.705 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:46:06.059 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:47:04.939 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:47:05.144 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:48:04.594 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:48:04.789 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:49:04.882 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:49:05.085 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:50:04.785 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:50:04.973 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:51:04.625 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:51:04.823 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:52:04.600 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:52:04.782 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:53:04.592 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:53:04.778 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:54:04.619 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:54:04.804 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:55:04.609 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:55:04.793 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
suite
2024-04-06 21:56:04.598 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:56:04.780 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:57:04.597 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:57:04.780 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:58:04.651 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:58:04.880 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 21:59:04.605 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 21:59:04.790 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:00:04.600 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:00:04.834 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:01:04.795 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:01:04.979 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:02:04.608 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:02:04.790 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:03:04.605 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:03:04.788 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:04:04.981 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:04:05.163 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:05:04.610 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:05:04.795 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:06:04.614 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:06:04.841 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:07:05.549 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:07:05.912 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:08:04.686 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:08:04.885 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:09:05.031 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:09:05.279 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:10:04.633 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:10:04.834 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:11:04.634 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:11:04.850 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:12:04.660 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:12:04.853 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:13:04.635 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:13:04.835 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:14:04.627 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:14:04.809 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:15:05.006 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:15:05.192 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:15:26.525 WARNING (Thread-5 (_thread_main)) [roombapy.roomba] Unexpectedly disconnected from Roomba 192.168.1.188, code The connection was lost
2024-04-06 22:16:04.623 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:16:04.806 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:17:04.966 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:17:05.217 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:18:04.628 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:18:04.814 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:19:04.646 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:19:04.851 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:20:04.625 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:20:04.812 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:21:04.653 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:21:04.856 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:22:04.639 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:22:04.849 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:22:15.011 WARNING (MainThread) [seatconnect.connection] Could not fetch realCarData, error: Failed to set token for "seat"
2024-04-06 22:23:04.630 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:23:04.832 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:24:04.633 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:24:04.817 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:25:04.858 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:25:05.538 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:26:05.635 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:26:05.889 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:27:05.281 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:27:05.485 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:28:04.882 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:28:05.074 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:28:29.470 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x08 0x20 0x0a 0x01 0x8f 0x4f 0xdd 0x06 0x79
2024-04-06 22:28:29.489 DEBUG (MainThread) [homeassistant.components.rfxtrx] Receive RFXCOM event: {'packet_type': 32, 'sub_type': 10, 'type_string': 'RM174RF Smoke Detector', 'id_string': '8f4fdd:32', 'data': '08200a018f4fdd0679', 'values': {'Sensor Status': 'Panic', 'Battery numeric': None, 'Rssi numeric': 7}}
2024-04-06 22:29:04.891 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:29:05.077 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:30:05.202 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:30:05.415 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:31:05.302 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:31:05.501 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:32:05.342 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:32:05.528 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:33:04.943 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:33:05.216 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:34:05.249 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:34:05.442 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:35:05.281 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:35:05.481 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:36:05.453 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:36:05.673 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:37:05.142 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:37:05.333 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:37:33.536 ERROR (MainThread) [custom_components.mydolphin_plus.managers.rest_api] Failed to post JSON to https://mbapp18.maytronics.com/api/serialnumbers/getrobotdetailsbymusn/, Error: Cannot connect to host mbapp18.maytronics.com:443 ssl:False [Try again], Line: 167
2024-04-06 22:37:33.631 ERROR (MainThread) [custom_components.mydolphin_plus.managers.rest_api] Status changed from 'Connected to the API' to 'Failed to access API'
2024-04-06 22:38:04.934 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:38:05.175 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:39:04.907 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:39:05.100 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:40:05.733 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:40:05.927 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:41:04.953 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:41:05.145 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:42:05.156 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:42:05.358 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:42:30.193 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 91, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 25, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 68, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 52, in get
return await WebSocketHandler(request.app["hass"], request).async_handle()
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 285, in async_handle
await wsock.prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 152, in prepare
payload_writer = await super().prepare(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 415, in prepare
return await self._start(request)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 423, in _start
await self._write_headers()
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_response.py", line 503, in _write_headers
await writer.write_headers(status_line, self._headers)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 130, in write_headers
self._write(buf)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_writer.py", line 75, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
suite
2024-04-06 22:43:06.272 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:43:06.548 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:43:59.401 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-06 22:43:59.406 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-06 22:44:05.147 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:44:05.351 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:44:50.004 WARNING (Thread-5 (_thread_main)) [roombapy.remote_client] Unknown disconnection error: ID=16.Kindly use https://github.com/pschmitt/roombapy/issues/new
2024-04-06 22:44:50.060 WARNING (Thread-5 (_thread_main)) [roombapy.roomba] Unexpectedly disconnected from Roomba 192.168.1.188, code UNKNOWN_ERROR
2024-04-06 22:44:50.080 WARNING (Thread-5 (_thread_main)) [roombapy.remote_client] Unknown disconnection error: ID=16.Kindly use https://github.com/pschmitt/roombapy/issues/new
2024-04-06 22:44:50.104 WARNING (Thread-5 (_thread_main)) [roombapy.roomba] Unexpectedly disconnected from Roomba 192.168.1.188, code UNKNOWN_ERROR
2024-04-06 22:45:06.269 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:45:06.678 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:46:04.905 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:46:05.089 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:47:05.847 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:47:06.215 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:48:04.972 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:48:05.177 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:49:05.002 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:49:05.196 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:50:06.464 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:50:06.864 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:51:04.923 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:51:05.116 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:52:04.975 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:52:05.179 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:53:04.924 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:53:05.117 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:54:04.933 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:54:05.140 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:55:05.213 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:55:05.489 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:56:06.831 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:56:07.066 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:57:05.410 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:57:05.615 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:58:04.943 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:58:05.136 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 22:59:05.320 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 22:59:05.513 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:00:05.727 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:00:05.980 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:01:05.750 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:01:06.378 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:02:05.317 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:02:05.511 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:03:04.951 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:03:05.139 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:03:28.595 ERROR (MainThread) [custom_components.mydolphin_plus.managers.rest_api] Failed to post JSON to https://mbapp18.maytronics.com/api/serialnumbers/getrobotdetailsbymusn/, Error: Cannot connect to host mbapp18.maytronics.com:443 ssl:False [Try again], Line: 167
2024-04-06 23:03:28.661 ERROR (MainThread) [custom_components.mydolphin_plus.managers.rest_api] Status changed from 'Connected to the API' to 'Failed to access API'
2024-04-06 23:04:07.956 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:04:08.333 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:05:07.268 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:05:07.517 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:06:07.699 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:06:08.006 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:07:12.512 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:07:15.252 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:07:15.370 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:08:05.585 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:08:06.294 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:09:08.667 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:09:09.361 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:09:28.849 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.prise_seche_linge_rms_current_2 (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.426 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:10:11.773 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:10:12.339 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:11:14.152 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.mesure_lave_linge_left (<class 'homeassistant.components.integration.sensor.IntegrationSensor'>) took 0.747 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+integration%22
2024-04-06 23:11:27.509 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:11:46.932 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-06 23:11:46.968 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-06 23:11:46.985 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-06 23:11:46.986 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-06 23:11:46.988 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-06 23:11:46.991 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-04-06 23:11:46.994 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-04-06 23:11:46.995 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-06 23:11:46.998 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-06 23:11:47.001 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-06 23:11:47.390 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data:
2024-04-06 23:11:47.395 ERROR (MainThread) [homeassistant.components.hassio] Error fetching hassio data: Error on Supervisor API:
2024-04-06 23:11:49.021 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:11:54.158 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_current_3 (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.737 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:12:02.081 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:12:14.037 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:12:15.180 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:13:14.371 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:13:14.855 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:13:23.827 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1059, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1098, in request_callback_rsp
await self.request(request, timeout=timeout, **response_params)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1055, in request
async with async_timeout.timeout(
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 141, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 228, in _do_exit
raise asyncio.TimeoutError
TimeoutError
2024-04-06 23:13:24.433 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1033, in request
async with ctx:
File "/usr/local/lib/python3.12/site-packages/zigpy/datastructures.py", line 22, in __aenter__
await self.on_enter()
File "/usr/local/lib/python3.12/site-packages/zigpy/datastructures.py", line 111, in acquire
await fut
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1097, in request_callback_rsp
async with async_timeout.timeout(timeout):
TimeoutError
2024-04-06 23:14:13.732 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:14:14.230 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:15:13.812 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:15:14.184 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:16:14.221 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:16:15.522 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:17:13.844 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:17:14.069 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:18:12.631 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:18:12.965 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:19:13.065 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:19:13.269 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:20:16.636 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:20:20.482 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:21:13.250 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:21:13.435 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:22:13.297 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:22:13.631 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:22:44.032 WARNING (MainThread) [seatconnect.connection] Could not fetch realCarData, error: Failed to set token for "seat"
2024-04-06 23:23:19.525 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:23:21.397 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:24:22.326 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:24:24.905 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:24:26.197 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:25:15.930 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:25:17.862 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:26:15.114 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:26:15.478 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:26:54.648 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_summation_delivered_3 (<class 'homeassistant.components.zha.sensor.PolledSmartEnergySummation'>) took 0.852 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:27:16.052 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:27:16.262 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:27:57.659 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.mesure_seche_linge_left (<class 'homeassistant.components.integration.sensor.IntegrationSensor'>) took 0.673 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+integration%22
2024-04-06 23:28:35.207 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:28:38.154 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:28:48.152 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:29:21.985 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:29:22.341 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:29:47.516 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-06 23:29:48.451 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-06 23:29:58.437 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.cupra_request_results (<class 'custom_components.seatconnect.sensor.SeatSensor'>) took 1.883 seconds. Please create a bug report at https://github.com/farfar/homeassistant-seatconnect/issues
2024-04-06 23:30:32.283 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:31:09.109 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_current (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 1.285 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:31:18.062 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_voltage (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSVoltage'>) took 1.414 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:31:19.295 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_summation_delivered (<class 'homeassistant.components.zha.sensor.PolledSmartEnergySummation'>) took 0.731 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:31:30.826 WARNING (MainThread) [homeassistant.components.climate] Updating aquatemp climate took longer than the scheduled update interval 0:01:00
2024-04-06 23:31:31.740 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:33.404 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:31:33.520 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:33.535 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:33.550 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:33.566 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:33.580 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:33.595 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-06 23:31:52.534 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:32:31.364 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:32:31.553 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:33:33.724 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:33:33.905 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:34:32.693 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:34:33.140 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:35:35.155 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-06 23:35:35.157 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-06 23:35:45.425 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:35:47.242 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:35:50.824 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:36:39.566 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:36:47.254 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:36:58.662 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:37:06.824 WARNING (MainThread) [zigpy.application] Watchdog failure
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 673, in _watchdog_loop
await self.watchdog_feed()
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 655, in watchdog_feed
await self._watchdog_feed()
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 628, in _watchdog_feed
await self._znp.request(c.SYS.Ping.Req())
TimeoutError
2024-04-06 23:37:07.134 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1052, in request
self._uart.send(frame)
AttributeError: 'NoneType' object has no attribute 'send'
2024-04-06 23:37:07.155 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-06 23:37:13.636 WARNING (MainThread) [homeassistant.helpers.dispatcher] Unable to remove unknown dispatcher <bound method GroupProbe._reprobe_group of <homeassistant.components.zha.core.discovery.GroupProbe object at 0x7f597805f0>>
2024-04-06 23:37:47.933 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:37:48.723 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:37:55.433 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:37:56.671 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for climate.aquatemp (<class 'custom_components.aquatemp.climate.Aquatemp'>) took 0.601 seconds. Please report it to the author of the 'aquatemp' custom integration
2024-04-06 23:38:39.828 WARNING (MainThread) [zigpy.backups] Failed to create a network backup
File "/usr/local/lib/python3.12/site-packages/zigpy/backups.py", line 220, in _backup_loop
await self.create_backup()
File "/usr/local/lib/python3.12/site-packages/zigpy/backups.py", line 143, in create_backup
await self.app.load_network_info(load_devices=load_devices)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 144, in load_network_info
await self._znp.load_network_info(load_devices=load_devices)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 238, in load_network_info
await self._load_network_info(load_devices=load_devices)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 183, in _load_network_info
tclk_seed = await self.nvram.osal_read(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/nvram.py", line 168, in osal_read
length = (await self.znp.request(c.SYS.OSALNVLength.Req(Id=nv_id))).ItemLen
TimeoutError
2024-04-06 23:38:41.071 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:38:47.004 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:38:48.439 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:39:36.313 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:39:36.513 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:40:36.383 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:40:36.572 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:41:36.072 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:41:36.265 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:42:37.202 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:42:37.390 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:43:36.188 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:43:36.387 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:44:36.993 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:44:37.175 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:45:36.276 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:45:36.584 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:46:39.289 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:46:39.593 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:47:36.165 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:47:36.356 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:48:39.075 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:48:39.720 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:49:38.360 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:49:38.989 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:50:36.169 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:50:36.362 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:51:36.477 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:51:36.672 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:52:46.476 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:52:46.799 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:52:48.707 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:53:50.406 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:53:55.112 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:54:00.826 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:54:40.934 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:54:41.140 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:55:40.882 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:55:41.638 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:56:41.253 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:56:41.443 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:57:14.164 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.thermometre_garage_battery_2 (<class 'homeassistant.components.zha.sensor.Battery'>) took 0.406 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-06 23:57:42.626 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:57:43.612 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:58:41.569 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:58:41.930 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-06 23:59:44.777 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-06 23:59:51.078 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-06 23:59:51.175 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:00:47.446 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:00:51.425 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 00:00:53.137 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:01:42.041 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:01:42.300 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:02:42.245 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:02:43.059 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:03:42.302 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:03:42.684 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:04:41.796 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:04:41.985 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:05:31.313 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.prise_seche_linge_rms_current_2 (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.944 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:05:44.680 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:05:52.462 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 00:06:11.058 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:06:49.651 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:06:51.813 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 00:06:56.401 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:07:23.935 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 00:07:24.557 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 00:07:25.233 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-07 00:07:25.236 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-04-07 00:07:29.055 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data:
2024-04-07 00:07:30.687 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-04-07 00:07:30.692 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-07 00:07:30.696 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-07 00:07:30.700 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-07 00:07:59.335 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_current (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.659 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:08:06.204 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 00:08:09.400 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:08:16.687 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:08:20.709 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.prise_tv_rms_current (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.420 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:08:45.778 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:08:47.468 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:09:46.058 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:09:49.198 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:10:42.185 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:10:42.369 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:11:42.970 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:11:44.658 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:12:21.941 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1098, in request_callback_rsp
await self.request(request, timeout=timeout, **response_params)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1059, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1097, in request_callback_rsp
async with async_timeout.timeout(timeout):
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 141, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 228, in _do_exit
raise asyncio.TimeoutError
TimeoutError
2024-04-07 00:12:42.422 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:12:43.352 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:13:42.542 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:13:42.823 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:14:44.582 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:14:45.946 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:15:02.173 DEBUG (SyncWorker_5) [RFXtrx] Send: 0x0a 0x14 0x11 0x00 0x00 0x3b 0x5c 0x00 0x00 0x00 0x00
2024-04-07 00:15:03.653 DEBUG (Thread-2 (_connect)) [RFXtrx] Recv: 0x04 0x02 0x01 0x00 0x00
2024-04-07 00:15:42.276 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:15:42.484 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:16:43.618 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:16:43.878 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:17:46.116 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:17:48.206 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:18:41.968 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:18:42.166 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:19:43.556 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:19:43.872 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:20:45.223 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:20:50.409 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:21:49.375 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:21:52.509 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:22:45.553 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:22:48.580 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:23:43.491 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:23:43.674 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:24:37.662 WARNING (MainThread) [seatconnect.connection] Could not fetch realCarData, error: Failed to set token for "seat"
2024-04-07 00:24:44.794 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:24:50.153 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:25:40.025 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_current_3 (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.507 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:25:59.080 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 00:26:16.356 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:27:01.892 WARNING (MainThread) [homeassistant.components.climate] Updating aquatemp climate took longer than the scheduled update interval 0:01:00
2024-04-07 00:27:17.907 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1033, in request
async with ctx:
File "/usr/local/lib/python3.12/site-packages/zigpy/datastructures.py", line 22, in __aenter__
await self.on_enter()
File "/usr/local/lib/python3.12/site-packages/zigpy/datastructures.py", line 111, in acquire
await fut
TimeoutError
2024-04-07 00:27:18.605 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:28:31.605 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 00:28:31.778 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.rpi_power_status is taking over 10 seconds
2024-04-07 00:28:31.779 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_rssi is taking over 10 seconds
2024-04-07 00:28:31.780 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_lqi is taking over 10 seconds
2024-04-07 00:28:31.781 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_rssi is taking over 10 seconds
2024-04-07 00:28:31.782 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_lqi is taking over 10 seconds
2024-04-07 00:28:55.505 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.prise_seche_linge_summation_delivered_2 (<class 'homeassistant.components.zha.sensor.PolledSmartEnergySummation'>) took 1.238 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:29:07.705 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 00:29:19.754 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.prise_seche_linge_active_power_2 (<class 'homeassistant.components.zha.sensor.PolledElectricalMeasurement'>) took 0.620 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:29:21.578 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_summation_delivered_3 (<class 'homeassistant.components.zha.sensor.PolledSmartEnergySummation'>) took 1.431 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 00:29:35.289 WARNING (MainThread) [seatconnect.connection] Could not fetch trip statistics, error: 'NoneType' object has no attribute 'get'
2024-04-07 00:29:35.426 WARNING (MainThread) [seatconnect.connection] Could not fetch position, error: 'NoneType' object has no attribute 'get'
2024-04-07 00:29:37.790 WARNING (MainThread) [seatconnect.connection] Could not fetch charger, error: 'NoneType' object has no attribute 'get'
2024-04-07 00:29:38.164 WARNING (MainThread) [seatconnect.connection] Could not fetch timers, error: 'NoneType' object has no attribute 'get'
2024-04-07 00:29:38.171 WARNING (MainThread) [seatconnect.connection] Could not fetch StoredVehicleDataResponse, error: 'NoneType' object has no attribute 'get'
2024-04-07 00:29:41.609 WARNING (MainThread) [homeassistant.components.climate] Updating aquatemp climate took longer than the scheduled update interval 0:01:00
2024-04-07 00:29:45.691 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:51.587 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:53.047 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:53.341 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:53.355 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:53.431 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:53.946 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:53.963 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:54.049 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:29:54.231 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 00:30:00.565 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 00:30:00.796 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 00:30:08.491 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.rpi_power_status is taking over 10 seconds
2024-04-07 00:30:08.492 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_rssi is taking over 10 seconds
2024-04-07 00:30:08.494 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_lqi is taking over 10 seconds
2024-04-07 00:30:08.494 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_rssi is taking over 10 seconds
2024-04-07 00:30:08.495 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_lqi is taking over 10 seconds
2024-04-07 00:30:09.380 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 00:30:09.522 ERROR (Thread-2 (_connect)) [root] Uncaught thread exception
File "/usr/local/lib/python3.12/threading.py", line 1073, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.12/threading.py", line 1010, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 1045, in _connect
self._connect_internal()
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 1073, in _connect_internal
event = self.transport.receive_blocking()
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 807, in __errors
return func(instance, *args, **kargs)
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 845, in receive_blocking
return self._receive_packet()
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 849, in _receive_packet
data = self.serial.read()
File "/usr/local/lib/python3.12/site-packages/serial/serialposix.py", line 575, in read
buf = os.read(self.fd, size - len(read))
TypeError: 'NoneType' object cannot be interpreted as an integer
2024-04-07 00:30:16.995 ERROR (MainThread) [zigpy.zcl] [0xB680:1:0x0000] Traceback (most recent call last):
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 415, in reply
return await self._endpoint.reply(
File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 278, in reply
return await self.device.reply(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 508, in reply
return await self.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 334, in request
await send_request()
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request
await self.send_packet(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 959, in send_packet
await self._send_request_raw(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 850, in _send_request_raw
response = await asyncio.shield(
2024-04-07 00:30:19.132 ERROR (MainThread) [homeassistant.components.shelly] Error fetching shellyplus1-083af2024b14 data: Device disconnected: DeviceConnectionError(DeviceConnectionError(TimeoutError()))
Salut.
Il faut que tu regarde autour de aquatemp (un radiateur ?)
Il y a beaucoup d’erreurs et le device est régulièrement inaccessible
merci pour ta réponse.
Oui c’est la pompe a chaleur de la piscine je suis entrain de faire le câblage électrique c’est pour ça qu’elle est offline.
Je dois désactiver le module aquatemp?
et le zigbee j’ai aussi des erreur?
Oui désactive pour le moment (en plus c’est bavard en mode de bug) ça permettra d’y voir un peu plus clair avec le reste.
Et désactive le debug de rfxtrx.
Pour le zigbee c’est pas clair… Problème d’alimentation ?
comment ça problème d’alimentation?
Je suis brancher en USB
2024-04-07 14:52:00.506 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
TimeoutError
2024-04-07 14:52:00.614 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 14:52:07.202 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:52:07.411 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:53:16.851 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 14:53:17.164 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:53:19.006 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:54:07.070 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:54:07.395 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:55:06.746 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:55:06.932 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:56:07.153 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:56:07.505 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:57:06.880 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:57:07.078 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:58:07.538 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:58:07.732 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 14:59:06.770 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 14:59:06.967 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:00:06.756 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:00:06.960 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:01:06.751 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:01:06.943 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:02:07.201 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:02:07.391 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:03:07.710 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:03:08.238 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:03:54.368 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
TimeoutError
2024-04-07 15:04:08.478 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:04:17.755 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 15:04:18.565 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:05:07.234 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:05:07.497 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:06:07.674 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:06:07.878 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:07:08.527 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:07:09.175 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:08:08.860 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:08:09.168 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:09:07.840 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:09:08.042 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:10:07.916 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:10:08.107 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:11:07.587 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:11:07.801 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:12:08.202 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:12:08.403 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:13:27.633 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 15:13:33.933 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.lave_linge_mensuel (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) took 4.347 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-04-07 15:13:55.112 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.lave_lingue_quotidien (<class 'homeassistant.components.utility_meter.sensor.UtilityMeterSensor'>) took 3.861 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+utility_meter%22
2024-04-07 15:14:07.935 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/aioshelly/rpc_device/wsrpc.py", line 253, in _ping_if_not_closed
await self._client.ping()
File "/usr/local/lib/python3.12/site-packages/aiohttp/client_ws.py", line 157, in ping
await self._writer.ping(message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 715, in ping
await self._send_frame(message, WSMsgType.PING)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 675, in _send_frame
self._write(header + mask + message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 702, in _write
raise ConnectionResetError("Cannot write to closing transport")
ConnectionResetError: Cannot write to closing transport
2024-04-07 15:14:08.609 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [547093522752] Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2024.03.1 aiohttp/3.9.3 Python/3.12): Unexpected error inside websocket API
File "/usr/src/homeassistant/homeassistant/components/websocket_api/http.py", line 386, in async_handle
msg = await wsock.receive()
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 486, in receive
await self.pong(msg.data)
File "/usr/local/lib/python3.12/site-packages/aiohttp/web_ws.py", line 328, in pong
await self._writer.pong(message)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 709, in pong
await self._send_frame(message, WSMsgType.PONG)
File "/usr/local/lib/python3.12/site-packages/aiohttp/http_websocket.py", line 682, in _send_frame
self._write(header + message)
2024-04-07 15:14:08.755 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [546994693184] Supervisor from 172.30.32.2 (HomeAssistantSupervisor/2024.03.1 aiohttp/3.9.3 Python/3.12): Unexpected error inside websocket API
2024-04-07 15:14:08.878 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:14:08.913 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:14:10.394 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:14:10.451 WARNING (MainThread) [homeassistant.components.climate] Updating aquatemp climate took longer than the scheduled update interval 0:01:00
2024-04-07 15:14:11.235 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:14:48.802 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.mesure_lave_linge_left (<class 'homeassistant.components.integration.sensor.IntegrationSensor'>) took 0.536 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+integration%22
2024-04-07 15:15:10.731 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:15:10.925 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:16:18.086 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:16:20.917 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:17:13.741 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:17:14.007 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:18:12.714 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:18:12.905 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:19:13.493 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:19:13.729 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:20:13.081 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:20:13.293 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:20:49.616 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 15:20:49.730 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 15:21:13.578 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:21:13.779 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:21:43.514 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.steve_cycle_time_left (<class 'custom_components.mydolphin_plus.sensor.MyDolphinPlusSensorEntity'>) took 0.495 seconds. Please create a bug report at https://github.com/sh00t2kill/dolphin-robot/issues
2024-04-07 15:22:13.189 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:22:13.383 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:23:15.325 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:23:18.340 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:23:50.204 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_summation_delivered_3 (<class 'homeassistant.components.zha.sensor.PolledSmartEnergySummation'>) took 0.421 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-07 15:24:14.566 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:24:15.472 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:25:09.138 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 15:25:11.024 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 15:25:12.679 WARNING (MainThread) [seatconnect.connection] Could not fetch trip statistics, error: 'NoneType' object has no attribute 'get'
2024-04-07 15:25:12.780 WARNING (MainThread) [seatconnect.connection] Could not fetch position, error: 'NoneType' object has no attribute 'get'
2024-04-07 15:25:12.781 WARNING (MainThread) [seatconnect.connection] Could not fetch StoredVehicleDataResponse, error: 'NoneType' object has no attribute 'get'
2024-04-07 15:25:12.783 WARNING (MainThread) [seatconnect.connection] Could not fetch charger, error: 'NoneType' object has no attribute 'get'
2024-04-07 15:25:12.794 WARNING (MainThread) [seatconnect.connection] Could not fetch timers, error: 'NoneType' object has no attribute 'get'
2024-04-07 15:25:14.840 WARNING (MainThread) [seatconnect.connection] Could not fetch climatisation, error: 'NoneType' object has no attribute 'get'
2024-04-07 15:25:29.262 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.freebox_wifi is taking over 10 seconds
2024-04-07 15:25:29.304 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-07 15:25:29.306 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-07 15:25:29.307 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-07 15:25:29.309 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-07 15:25:29.315 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-07 15:25:29.316 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-04-07 15:25:29.317 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-04-07 15:25:29.320 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-07 15:25:29.322 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-07 15:25:29.323 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
2024-04-07 15:25:29.397 ERROR (MainThread) [homeassistant.helpers.entity] Update for switch.freebox_wifi fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 945, in async_update_ha_state
await self.async_device_update()
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1262, in async_device_update
await self.async_update()
File "/usr/src/homeassistant/homeassistant/components/freebox/switch.py", line 74, in async_update
datas = await self._router.wifi.get_global_config()
File "/usr/local/lib/python3.12/site-packages/freebox_api/api/wifi.py", line 132, in get_global_config
return await self._access.get("wifi/config/")
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 122, in get
return await self._perform_request(self.session.get, end_url)
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 94, in _perform_request
r = await verb(url, **request_params)
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 504, in _request
with timer:
File "/usr/local/lib/python3.12/site-packages/aiohttp/helpers.py", line 735, in __exit__
raise asyncio.TimeoutError from None
TimeoutError
2024-04-07 15:25:29.969 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 129, in update_all
await self.update_device_trackers()
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 141, in update_device_trackers
self.supports_hosts, fbx_devices = await get_hosts_list_if_supported(
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 74, in get_hosts_list_if_supported
fbx_devices = await fbx_api.lan.get_hosts_list() or []
File "/usr/local/lib/python3.12/site-packages/freebox_api/api/lan.py", line 64, in get_hosts_list
return await self._access.get(f"lan/browser/{interface}")
with timer:
TimeoutError
2024-04-07 15:25:30.023 ERROR (MainThread) [homeassistant.components.hassio] Error fetching hassio data: Error on Supervisor API:
2024-04-07 15:25:30.028 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data:
2024-04-07 15:25:31.135 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:25:35.187 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:26:23.283 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 15:26:23.828 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 15:26:28.043 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 130, in update_all
await self.update_sensors()
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 182, in update_sensors
connection_datas: dict[str, Any] = await self._api.connection.get_status()
File "/usr/local/lib/python3.12/site-packages/freebox_api/api/connection.py", line 35, in get_status
return await self._access.get("connection/")
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 605, in _request
await resp.start(conn)
File "/usr/local/lib/python3.12/site-packages/aiohttp/client_reqrep.py", line 961, in start
with self._timer:
TimeoutError
2024-04-07 15:26:32.538 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1098, in request_callback_rsp
await self.request(request, timeout=timeout, **response_params)
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1059, in request
response = await response_future
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1097, in request_callback_rsp
async with async_timeout.timeout(timeout):
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 141, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.12/site-packages/async_timeout/__init__.py", line 228, in _do_exit
TimeoutError
2024-04-07 15:26:56.082 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.rpi_power_status is taking over 10 seconds
2024-04-07 15:26:57.238 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_rssi is taking over 10 seconds
2024-04-07 15:26:57.239 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_lqi is taking over 10 seconds
2024-04-07 15:26:57.240 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_rssi is taking over 10 seconds
2024-04-07 15:26:57.240 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_lqi is taking over 10 seconds
2024-04-07 15:26:57.249 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.freebox_wifi is taking over 10 seconds
2024-04-07 15:27:02.554 ERROR (MainThread) [homeassistant.helpers.entity] Update for switch.freebox_wifi fails
with timer:
TimeoutError
2024-04-07 15:27:08.737 WARNING (MainThread) [homeassistant.helpers.entity] Update of climate.aquatemp is taking over 10 seconds
2024-04-07 15:27:32.501 WARNING (MainThread) [homeassistant.components.sensor] Updating zha sensor took longer than the scheduled update interval 0:00:30
2024-04-07 15:27:42.403 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1033, in request
async with ctx:
File "/usr/local/lib/python3.12/site-packages/zigpy/datastructures.py", line 22, in __aenter__
await self.on_enter()
File "/usr/local/lib/python3.12/site-packages/zigpy/datastructures.py", line 111, in acquire
await fut
TimeoutError
2024-04-07 15:27:43.597 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:48.070 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 15:27:48.470 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 15:27:48.827 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.season_2 is taking over 10 seconds
2024-04-07 15:27:50.478 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
with timer:
TimeoutError
2024-04-07 15:27:52.965 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:54.736 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.221 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.238 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.253 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.270 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.290 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.307 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.323 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.336 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:55.350 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:27:58.784 WARNING (MainThread) [homeassistant.components.climate] Updating aquatemp climate took longer than the scheduled update interval 0:01:00
2024-04-07 15:28:05.466 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:34.352 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.freebox_wifi is taking over 10 seconds
2024-04-07 15:28:47.084 ERROR (MainThread) [homeassistant.helpers.entity] Update for switch.freebox_wifi fails
with timer:
TimeoutError
2024-04-07 15:28:53.064 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
with timer:
TimeoutError
2024-04-07 15:28:53.333 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:28:53.513 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:28:53.533 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:28:53.550 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:28:53.567 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-07 15:28:53.659 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-07 15:28:53.660 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-07 15:28:53.696 WARNING (MainThread) [homeassistant.helpers.entity] Update of binary_sensor.rpi_power_status is taking over 10 seconds
2024-04-07 15:28:54.492 ERROR (Thread-2 (_connect)) [root] Uncaught thread exception
File "/usr/local/lib/python3.12/threading.py", line 1073, in _bootstrap_inner
self.run()
File "/usr/local/lib/python3.12/threading.py", line 1010, in run
self._target(*self._args, **self._kwargs)
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 1045, in _connect
self._connect_internal()
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 1073, in _connect_internal
event = self.transport.receive_blocking()
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 807, in __errors
return func(instance, *args, **kargs)
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 845, in receive_blocking
return self._receive_packet()
File "/usr/local/lib/python3.12/site-packages/RFXtrx/__init__.py", line 849, in _receive_packet
data = self.serial.read()
File "/usr/local/lib/python3.12/site-packages/serial/serialposix.py", line 575, in read
buf = os.read(self.fd, size - len(read))
TypeError: 'NoneType' object cannot be interpreted as an integer
2024-04-07 15:28:55.255 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1052, in request
self._uart.send(frame)
AttributeError: 'NoneType' object has no attribute 'send'
2024-04-07 15:28:55.440 ERROR (MainThread) [zigpy.zcl] [0x9EAD:1:0x0702] Traceback (most recent call last):
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 415, in reply
return await self._endpoint.reply(
File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 278, in reply
return await self.device.reply(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 508, in reply
return await self.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 334, in request
await send_request()
File "/usr/local/lib/python3.12/site-packages/zigpy/application.py", line 841, in request
await self.send_packet(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 959, in send_packet
await self._send_request_raw(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/zigbee/application.py", line 850, in _send_request_raw
response = await asyncio.shield(
File "/usr/local/lib/python3.12/site-packages/zigpy_znp/api.py", line 1023, in request
raise RuntimeError("Coordinator is disconnected, cannot send request")
RuntimeError: Coordinator is disconnected, cannot send request
2024-04-07 15:28:55.472 ERROR (MainThread) [zigpy.zcl] [0x9EAD:1:0x0702] Traceback (most recent call last):
2024-04-07 15:28:55.475 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:55.514 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:55.553 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:55.588 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/zha/sensor.py", line 263, in _refresh
File "/usr/src/homeassistant/homeassistant/components/zha/entity.py", line 256, in async_update
await asyncio.gather(*tasks)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/homeautomation.py", line 127, in async_update
result = await self.get_attributes(attrs, from_cache=False, only_cache=False)
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/__init__.py", line 513, in _get_attributes
read, _ = await self.cluster.read_attributes(
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 528, in read_attributes
result = await self.read_attributes_raw(to_read, manufacturer=manufacturer)
File "/usr/local/lib/python3.12/site-packages/zigpy/quirks/__init__.py", line 289, in read_attributes_raw
results = await super().read_attributes_raw(
File "/usr/local/lib/python3.12/site-packages/zigpy/quirks/__init__.py", line 334, in _read_attributes
return await super()._read_attributes(
File "/usr/local/lib/python3.12/site-packages/zigpy/zcl/__init__.py", line 377, in request
return await self._endpoint.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/endpoint.py", line 253, in request
return await self.device.request(
File "/usr/local/lib/python3.12/site-packages/zigpy/device.py", line 339, in request
2024-04-07 15:28:56.197 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.244 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'Success', 'error_msg_code': '', 'object_result': [{'code': 'Power', 'value': '0'}, {'code': 'Mode', 'value': '2'}, {'code': 'Manual-mute', 'value': '0'}, {'code': 'T01', 'value': '14.0'}, {'code': 'T02', 'value': '14.5'}, {'code': '2074', 'value': '0000000000000000'}, {'code': '2075', 'value': '0000000000000000'}, {'code': '2076', 'value': '0000000000000000'}, {'code': '2077', 'value': '0000000000000000'}, {'code': 'H03', 'value': '0'}, {'code': 'Set_Temp', 'value': '34.5'}, {'code': 'R08', 'value': '8.0'}, {'code': 'R09', 'value': '35.0'}, {'code': 'R10', 'value': '15.0'}, {'code': 'R11', 'value': '35.0'}, {'code': 'R01', 'value': '35.0'}, {'code': 'R02', 'value': '29.0'}, {'code': 'R03', 'value': '34.5'}, {'code': 'T03', 'value': '15.5'}, {'code': '1158', 'value': '0'}, {'code': '1159', 'value': '0'}, {'code': 'F17', 'value': '0'}, {'code': 'H02', 'value': '1'}, {'code': 'T04', 'value': '11.5'}, {'code': 'T05', 'value': '11.5'}, {'code': 'T06', 'value': '14.5'}, {'code': 'T07', 'value': '0.1'}, {'code': 'T12', 'value': '0'}, {'code': 'T14', 'value': '228'}], 'is_reuslt_suc': True}
2024-04-07 15:28:56.509 ERROR (MainThread) [zigpy.zcl] [0xE26E:1:0x0000] Traceback (most recent call last):
2024-04-07 15:28:56.649 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.693 ERROR (MainThread) [zigpy.zcl] [0x9EAD:1:0x0702] Traceback (most recent call last):
2024-04-07 15:28:56.771 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.811 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.853 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.888 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.915 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:56.971 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 104, in _perform_request
await self._refresh_session_token()
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 69, in _refresh_session_token
session_token, session_permissions = await self._get_session_token(
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 45, in _get_session_token
challenge = await self._get_challenge(base_url, timeout)
File "/usr/local/lib/python3.12/site-packages/freebox_api/access.py", line 28, in _get_challenge
r = await self.session.get(url, timeout=timeout)
File "/usr/local/lib/python3.12/site-packages/aiohttp/client.py", line 425, in _request
raise RuntimeError("Session is closed")
RuntimeError: Session is closed
2024-04-07 15:28:57.028 ERROR (MainThread) [homeassistant.helpers.entity] Update for switch.freebox_wifi fails
File "/usr/local/lib/python3.12/site-packages/aiohttp/client_reqrep.py", line 966, in start
message, payload = await protocol.read() # type: ignore[union-attr]
File "/usr/local/lib/python3.12/site-packages/aiohttp/streams.py", line 622, in read
await self._waiter
aiohttp.client_exceptions.ClientOSError: [Errno 1] [SSL: APPLICATION_DATA_AFTER_CLOSE_NOTIFY] application data after close notify (_ssl.c:2685)
2024-04-07 15:28:57.292 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/zha/core/cluster_handlers/smartenergy.py", line 324, in async_update
2024-04-07 15:28:57.372 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:57.498 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:57.585 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:57.653 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:57.744 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-07 15:28:57.796 DEBUG (MainThread) [custom_components.aquatemp.climate] {'error_code': '0', 'error_msg': 'The device offline', 'error_msg_code': '', 'object_result': {'is_fault': False, 'status': 'OFFLINE'}, 'is_reuslt_suc': True}
2024-04-07 15:29:04.026 WARNING (Thread-16 (_do_shutdown)) [homeassistant.util.executor] Thread[SyncWorker_1] is still running at shutdown: File "/usr/local/lib/python3.12/threading.py", line 1030, in _bootstrap
self._bootstrap_inner()
self.run()
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 89, in _worker
work_item = work_queue.get(block=True)
Allez, un petit effort :
- sur la mise en forme, là les 100aines de ligne c’est pas simple à lire. Il n’y a même pas de contexte…
- en suivant les recommandations : désactiver aquatemp, virer les logs rfxtrx… Les messages qui pourraient être intéressants sont noyés dans la masse. ça la fout mal pour une piscine
Oui le pi n’a qu’une source d’alim qui fait fonctionne l’ensemble du système : SSD, clés usb etc… Quand il n’y a pas assez d’energie (ou des micro coupures), les appareils se réinitialisent. Je ne sais pas si c’est le cas, là, mais c’est une piste envisageable
J’ai bien désactiver le module aquatemp depuis hier matin.
J’ai supprimé la ligne
RFXtrx: debug
Dois supprimer homeassistant.components.rfxtrx?
Dois redémarrer HA?
J’ai juste recharger les fichier .yaml
Il faut que mette en commentaire tous les trucs en rouge :
- les debug qui ne servent à rien pour l’instant
- les déclarations d’entités basées sur les intégrations qu’il faut désactiver
Et oui, il tout redémarrer pour la prise en compte
ok merci je viens de supprimer tous les logs et pompe a chaleur
on verra demain je pense?
Re ma liste est toujours super longue dans home-assistant.log.1
Je n’ai rien en rouge.
C’est bien ce journal que je dois mettre?
Le fichier log.1 contient ce qu’il y a avant le dernier reboot(arrêt/plantage), donc oui c’est bien le bon…
Par contre, il ne faut pas oublier de redémarrer pour la prise en compte des changements
2024-04-09 16:59:29.682 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration seatconnect which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.689 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration mydolphin_plus which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.695 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.701 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.716 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration aqua_temp which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.722 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration watchman which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.727 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration gazpar which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.737 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.743 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration aquatemp which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.751 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration smartlife which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.765 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration pronote which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:29.770 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-09 16:59:55.852 WARNING (MainThread) [homeassistant.components.meteo_france] 1 hour rain forecast not available. Hésingue - Alsace (68) - FR is not in covered zone
2024-04-09 17:00:01.611 ERROR (SyncWorker_4) [tuya_sharing] net work error = network error:(1010) token is expired
2024-04-09 17:00:01.719 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry xxxxxxxxxxxxx@free.fr for smartlife
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 551, in async_setup
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/smartlife/__init__.py", line 69, in async_setup_entry
await hass.async_add_executor_job(smart_life_manager.report_version, __version__, smart_life_version, sharing_sdk)
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
result = self.fn(*self.args, **self.kwargs)
File "/usr/local/lib/python3.12/site-packages/tuya_sharing/manager.py", line 69, in report_version
self.user_repository.user_version_report(ha_version, integration_version, sdk_version)
File "/usr/local/lib/python3.12/site-packages/tuya_sharing/user.py", line 46, in user_version_report
self.api.post("/v1.0/m/life/home-assistant/qrcode/versions", None, {
File "/usr/local/lib/python3.12/site-packages/tuya_sharing/customerapi.py", line 192, in post
return self.__request("POST", path, params, body)
File "/usr/local/lib/python3.12/site-packages/tuya_sharing/customerapi.py", line 121, in __request
raise Exception(f"network error:({ret['code']}) {ret['msg']}")
Exception: network error:(-9999999) sign invalid
2024-04-09 17:00:08.206 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'hacs' accesses hass.components.frontend. This is deprecated and will stop working in Home Assistant 2024.9, it should be updated to import functions used from frontend directly at custom_components/hacs/frontend.py, line 68: hass.components.frontend.async_register_built_in_panel(, please create a bug report at https://github.com/hacs/integration/issues
2024-04-09 17:00:12.474 WARNING (MainThread) [homeassistant.components.freebox.router] Home access is not granted
2024-04-09 17:00:20.518 WARNING (ImportExecutor_0) [homeassistant.components.device_tracker] SOURCE_TYPE_GPS was used from seatconnect, this is a deprecated constant which will be removed in HA Core 2025.1. Use SourceType.GPS instead, please report it to the author of the 'seatconnect' custom integration
2024-04-09 17:00:20.539 WARNING (ImportExecutor_0) [homeassistant.components.device_tracker] SOURCE_TYPE_GPS was used from seatconnect, this is a deprecated constant which will be removed in HA Core 2025.1. Use SourceType.GPS instead, please report it to the author of the 'seatconnect' custom integration
2024-04-09 17:00:36.635 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: {('zha', '5126928725bb98a42f8ee868c0d49ab3'): 504424.290460843}
2024-04-09 17:00:40.872 ERROR (MainThread) [homeassistant.components.homekit.util] media_player.tv_samsung_9_series_65 does not support any media_player features
2024-04-09 17:00:40.874 ERROR (MainThread) [homeassistant.components.homekit.util] media_player.freebox_player does not support any media_player features
2024-04-09 17:00:43.936 WARNING (MainThread) [homeassistant.components.light] None (<class 'custom_components.mydolphin_plus.light.MyDolphinPlusLightEntity'>) does not set supported color modes, this will stop working in Home Assistant Core 2025.3, please create a bug report at https://github.com/sh00t2kill/dolphin-robot/issues
2024-04-09 17:01:04.363 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 142, in update_device_trackers
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 75, in get_hosts_list_if_supported
with self._timer:
TimeoutError
2024-04-09 17:11:31.477 ERROR (MainThread) [custom_components.mydolphin_plus.managers.rest_api] Failed to post JSON to https://mbapp18.maytronics.com/api/serialnumbers/getrobotdetailsbymusn/, Error: Cannot connect to host mbapp18.maytronics.com:443 ssl:False [Try again], Line: 167
2024-04-09 17:11:31.525 ERROR (MainThread) [custom_components.mydolphin_plus.managers.rest_api] Status changed from 'Connected to the API' to 'Failed to access API'
2024-04-09 17:15:45.661 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
TimeoutError
2024-04-09 17:21:26.205 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.freebox_wifi is taking over 10 seconds
2024-04-09 17:21:43.998 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 131, in update_all
File "/usr/src/homeassistant/homeassistant/components/freebox/router.py", line 175, in update_sensors
syst_datas: dict[str, Any] = await self._api.system.get_config()
File "/usr/local/lib/python3.12/site-packages/freebox_api/api/system.py", line 9, in get_config
return await self._access.get("system/")
with timer:
TimeoutError
2024-04-09 17:23:01.354 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
with self._timer:
TimeoutError
2024-04-09 17:24:13.235 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.freebox_wifi is taking over 10 seconds
2024-04-09 17:24:13.406 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-09 17:24:13.407 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-09 17:24:14.127 ERROR (MainThread) [homeassistant.helpers.entity] Update for switch.freebox_wifi fails
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 951, in async_update_ha_state
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1268, in async_device_update
File "/usr/src/homeassistant/homeassistant/components/freebox/switch.py", line 75, in async_update
with timer:
TimeoutError
2024-04-09 17:24:18.569 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
with timer:
TimeoutError
2024-04-09 17:24:26.475 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.thermostat_2_rdc_temperature (<class 'homeassistant.components.zha.sensor.Temperature'>) took 0.633 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-09 17:25:09.050 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:25:16.517 WARNING (MainThread) [seatconnect.connection] Could not fetch trip statistics, error: 'NoneType' object has no attribute 'get'
2024-04-09 17:25:22.076 WARNING (MainThread) [seatconnect.connection] Could not fetch StoredVehicleDataResponse, error: 'NoneType' object has no attribute 'get'
2024-04-09 17:25:22.107 WARNING (MainThread) [seatconnect.connection] Could not fetch position, error: 'NoneType' object has no attribute 'get'
2024-04-09 17:25:22.111 WARNING (MainThread) [seatconnect.connection] Could not fetch timers, error: 'NoneType' object has no attribute 'get'
2024-04-09 17:25:22.115 WARNING (MainThread) [seatconnect.connection] Could not fetch charger, error: 'NoneType' object has no attribute 'get'
2024-04-09 17:25:22.315 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:25:23.101 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:25:43.198 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2024-04-09 17:25:43.676 WARNING (MainThread) [homeassistant.helpers.entity] Update of media_player.samsung_9_series_65 is taking over 10 seconds
2024-04-09 17:25:43.679 WARNING (MainThread) [homeassistant.helpers.entity] Update of switch.freebox_wifi is taking over 10 seconds
2024-04-09 17:25:43.680 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_rssi is taking over 10 seconds
2024-04-09 17:25:43.681 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.prise_tv_lqi is taking over 10 seconds
2024-04-09 17:25:43.683 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_rssi is taking over 10 seconds
2024-04-09 17:25:43.684 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.ewelink_th01_lqi is taking over 10 seconds
2024-04-09 17:25:44.819 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:25:48.349 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:25:57.179 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:26:11.541 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.prise_tv_active_power (<class 'homeassistant.components.zha.sensor.PolledElectricalMeasurement'>) took 3.180 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-09 17:26:22.396 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_current_3 (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSCurrent'>) took 0.465 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-09 17:26:25.118 WARNING (MainThread) [homeassistant.helpers.entity] Updating state for sensor.tz3000_2putqrmw_ts011f_rms_voltage_3 (<class 'homeassistant.components.zha.sensor.ElectricalMeasurementRMSVoltage'>) took 1.604 seconds. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+zha%22
2024-04-09 17:27:07.358 ERROR (MainThread) [homeassistant.helpers.entity] Update for switch.freebox_wifi fails
with timer:
TimeoutError
2024-04-09 17:27:08.538 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-09 17:27:31.749 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:28:08.489 WARNING (MainThread) [homeassistant.components.sensor] Updating zha sensor took longer than the scheduled update interval 0:00:30
2024-04-09 17:28:20.370 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:28:24.142 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
async with ctx:
await fut
TimeoutError
2024-04-09 17:28:32.517 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /info request
2024-04-09 17:28:34.136 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /host/info request
2024-04-09 17:28:34.161 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /store request
2024-04-09 17:28:34.162 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /core/info request
2024-04-09 17:28:34.164 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /supervisor/info request
2024-04-09 17:28:34.325 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /os/info request
Ta config est vraiment en mauvaise état… il y a beaucoup de trucs qui ne fonctionnent pas bien ou pas ou plus
Tuya
Dolphin
Mediaplayer
Des machins sur f
Freebox, l’intégration j’imagine
ZHA
Seat connect (encore)
Eweelink
olala
Tuya fonctione j’ai quelques 3 prises connectée elle s’alume avec HA
Dolphin c’est peut etre du que le robot ne soit pas brancher?
Media player ca doit etre la TV je peux aussi l’aluumer et eteindre avec HA
Freebox c’est l’integration mais je ne l’utilise pas…
ZHA C’est HA ?
Seat j’ai toutes les valeurs comme sur l’application.
Je dois faire quoi?
Repartir de zéro ?
