J’essaie de mettre mon nom de domaine fait avec freebox , mais lorsque que lance let’s encrypt j’ai un message d’erreur.
Pour infos , avant je me servait de ce nom de domaine pour me connecter a mon jeedom!
j’ai bien entendu retiré les redirection de port vers jeedom !
Voici les logs d’erreur qu’il me retourne :
[10:16:24] INFO: Selected http verification
[10:16:24] INFO: Detecting existing certificate type for https://********.freeboxos.fr
Saving debug log to /var/log/letsencrypt/letsencrypt.log
[10:16:25] INFO: No certificate found - using 'ecdsa' key type.
Requested name https://*********.freeboxos.fr appears to be a URL, not a FQDN. Try again without the leading "https://".
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/certbot-log-a1yx133g/log or re-run Certbot with -v for more details.
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
[10:20:47] INFO: Selected http verification
[10:20:47] INFO: Detecting existing certificate type for https://*********.freeboxos.fr
[10:20:48] INFO: No certificate found - using 'ecdsa' key type.
Requested name https://**********.freeboxos.fr appears to be a URL, not a FQDN. Try again without the leading "https://".
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /tmp/certbot-log-b4hjazr8/log or re-run Certbot with -v for more details.
version
core-2024.6.3
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.12.2
os_name
Linux
os_version
6.6.29-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 12.3
update_channel
stable
supervisor_version
supervisor-2024.06.0
agent_version
1.6.0
docker_version
25.0.5
disk_total
30.8 GB
disk_used
6.5 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
kvm
board
ova
supervisor_api
ok
version_api
ok
installed_addons
Matter Server (6.1.2), Advanced SSH & Web Terminal (18.0.0), File editor (5.8.0), Let’s Encrypt (5.0.18)
tu as lu le log au moins car le message d’erreur et la solution est présentée sur la 3eme ligne
il faut renseigner un nom de domaine dans l’addon alors qu’il faut un nom de domaine donc « juste » *********.freeboxos.fr et relancer l’addon pour générer ton certificat
edit: les certificats let’encrypt son valables 90 jours donc il ne faut pas oublier de créer une automations régulière (tous les jours par exemple) qui relance l’addon pour renouveler le certificat qui se renouvellera automatiquement dès que possible, l’addon ne tourne pas en tache de fond (c’est pour ça qu’il est arrêté dans son état normal)
Tous les mois ou 2 semaines est préférable et largement suffisant sinon tu risques le banissement temporaire de Let’s Encrypt pour trop de requêtes abusives
tous les scripts certbot sont tous les 24h voir même 12h, dans le procédé de renouvellement tu as une vérification si le certificat doit être renouvelé ou pas donc aucun risque de bannissement
Et encore un module à installer tout ça juste pour un certificat LE pourquoi il gèrent pas le renouvellement dans l’addon let’s encrypt aah le meilleur côté usine a gaz de HA
Ici c’est un forum domotique. On n’est pas tous loin de la, admin linux et familier avec tout ça. Essaye d’être un peu moins sarcastique, moqueur envers les participants et on y gagnera tous en convivialité je pense. Simple conseil, sans animosité aucune.
Alors la aucune animosité envers qui que ce soit a part envers ce module qui fais les choses de façon justement trop compliqué pour un débutant a mon avis et qu’il faille installer et installer des add-ons pour juste un certificat LE, le seul que je fustige c’est celui qui a eu la bonne idée de faire cet add-on
