votre support a tous agit comme de la magie :
maintenant (alors que rien n’a été modifié) j’ai quelque chose dans les log NodeRed :
28 Jun 08:18:20 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:18:26 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:18:35 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:18:42 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:18:48 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:18:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:18:54 - [error] [ha-binary-sensor:presence_papa] NoConnectionError: No connection to Home Assistant
28 Jun 08:18:54 - [error] [ha-binary-sensor:presence_maman] NoConnectionError: No connection to Home Assistant
28 Jun 08:18:54 - [error] [ha-binary-sensor:presence_alienor] NoConnectionError: No connection to Home Assistant
28 Jun 08:18:54 - [error] [ha-binary-sensor:etat_portail] NoConnectionError: No connection to Home Assistant
28 Jun 08:18:59 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:19:06 - [info] [server:Home Assistant] Connected to http://supervisor/core
28 Jun 08:23:39 - [info] [server:Home Assistant] Connection closed to http://supervisor/core
28 Jun 08:23:40 - [error] [ha-binary-sensor:presence_papa] NoConnectionError: No connection to Home Assistant
28 Jun 08:23:40 - [error] [ha-binary-sensor:presence_maman] NoConnectionError: No connection to Home Assistant
28 Jun 08:23:40 - [error] [ha-binary-sensor:presence_alienor] NoConnectionError: No connection to Home Assistant
28 Jun 08:23:40 - [error] [ha-binary-sensor:etat_portail] NoConnectionError: No connection to Home Assistant
28 Jun 08:23:45 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:23:46 - [info] [server:Home Assistant] Connected to http://supervisor/core
[08:33:00] INFO: Service Node-RED exited with code 256 (by signal 9)
[08:33:02] INFO: Starting Node-RED...
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
28 Jun 08:33:14 - [info]
Welcome to Node-RED
28 Jun 08:33:14 - [info] Node-RED version: v3.0.2
28 Jun 08:33:14 - [info] Node.js version: v18.16.0
28 Jun 08:33:14 - [info] Linux 6.1.34 x64 LE
28 Jun 08:33:17 - [info] Loading palette nodes
28 Jun 08:33:38 - [info] Dashboard version 3.5.0 started at /endpoint/ui
28 Jun 08:33:52 - [info] Settings file : /etc/node-red/config.js
28 Jun 08:33:53 - [info] Context store : 'default' [module=memory]
28 Jun 08:33:53 - [info] User directory : /config/node-red/
28 Jun 08:33:53 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Jun 08:33:53 - [info] Flows file : /config/node-red/flows.json
28 Jun 08:33:54 - [info] Server now running at http://127.0.0.1:46836/
28 Jun 08:33:56 - [info] Starting flows
28 Jun 08:34:01 - [info] Started flows
28 Jun 08:34:03 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 08:34:07 - [info] [server:Home Assistant] Connected to http://supervisor/core
[09:12:47] INFO: Service Node-RED exited with code 256 (by signal 9)
2023/06/28 09:12:48 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
[09:12:49] INFO: Starting Node-RED...
2023/06/28 09:12:49 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:12:52 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:12:53 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
> start
2023/06/28 09:12:55 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:12:57 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:12:59 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
28 Jun 09:13:01 - [info]
Welcome to Node-RED
28 Jun 09:13:01 - [info] Node-RED version: v3.0.2
28 Jun 09:13:01 - [info] Node.js version: v18.16.0
28 Jun 09:13:01 - [info] Linux 6.1.34 x64 LE
2023/06/28 09:13:02 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:03 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
28 Jun 09:13:04 - [info] Loading palette nodes
2023/06/28 09:13:05 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:08 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:09 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:11 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:15 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:17 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:19 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:22 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:24 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:26 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:29 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:31 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:33 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:35 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
28 Jun 09:13:36 - [info] Dashboard version 3.5.0 started at /endpoint/ui
2023/06/28 09:13:37 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:39 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:42 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:45 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
2023/06/28 09:13:46 [error] 630#630: *220 connect() failed (111: Connection refused) while connecting to upstream, client: 172.30.32.2, server: a0d7b954-nodered, request: "GET /comms HTTP/1.1", upstream: "http://127.0.0.1:46836/comms", host: "roland.yt"
28 Jun 09:13:47 - [info] Settings file : /etc/node-red/config.js
28 Jun 09:13:47 - [info] Context store : 'default' [module=memory]
28 Jun 09:13:47 - [info] User directory : /config/node-red/
28 Jun 09:13:47 - [warn] Projects disabled : editorTheme.projects.enabled=false
28 Jun 09:13:47 - [info] Flows file : /config/node-red/flows.json
28 Jun 09:13:47 - [info] Server now running at http://127.0.0.1:46836/
28 Jun 09:13:47 - [info] Starting flows
28 Jun 09:13:49 - [info] Started flows
28 Jun 09:13:53 - [info] [server:Home Assistant] Connecting to http://supervisor/core
28 Jun 09:13:53 - [info] [server:Home Assistant] Connected to http://supervisor/core
