Problème zigbee2MQTT plantage
Bonjour!
J’ai installé un nouveau server HA au travail, j’en ai déjà un chez moi.
Je viens d’installer zigbee2MQTT avec une cléf Sonoff Lite MG21 sur un raspberry pi3.
Le module se lance bien, mais au bout d’un certain temps, il plante. Je ne sais pas pourquoi. J’ai regardé les log mais je n’y comprends rien…
J’ai réussi à installer 4 modules mais il plante, il redémarre pas tout seul… Est ce qu’on peut me filer un coup de main?
Merci!
[14:38:30] INFO: Preparing to start...
[14:38:31] INFO: Socat not enabled
[14:38:33] INFO: Starting Zigbee2MQTT...
[2026-02-06 14:38:51] info: 	z2m: Logging to console, file (filename: log.log)
[2026-02-06 14:38:54] info: 	z2m: Starting Zigbee2MQTT version 2.8.0 (commit #unknown)
[2026-02-06 14:38:54] info: 	z2m: Starting zigbee-herdsman (9.0.2)
[2026-02-06 14:38:55] info: 	zh:ember: Using default stack config.
[2026-02-06 14:38:55] info: 	zh:ember: ======== Ember Adapter Starting ========
[2026-02-06 14:38:55] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2026-02-06 14:38:55] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 14:38:55] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-02-06 14:38:55] info: 	zh:ember:uart:ash: Serial port opened
[2026-02-06 14:38:55] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 14:38:57] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2026-02-06 14:38:57] info: 	zh:ember:uart:ash: ======== ASH started ========
[2026-02-06 14:38:57] info: 	zh:ember:ezsp: ======== EZSP started ========
[2026-02-06 14:38:57] info: 	zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2026-02-06 14:38:57] info: 	zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.5 [GA]","build":0,"major":7,"minor":4,"patch":5,"special":0,"type":170}
[2026-02-06 14:38:57] info: 	zh:ember: [STACK STATUS] Network up.
[2026-02-06 14:38:57] info: 	zh:ember: [INIT TC] Adapter network matches config.
[2026-02-06 14:38:57] info: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1247ms until next broadcast.
[2026-02-06 14:38:57] info: 	z2m: zigbee-herdsman started (resumed)
[2026-02-06 14:38:57] info: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":5,"revision":"7.4.5 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2026-02-06 14:38:57] info: 	z2m: Capteur fuite d'eau (0x8c73dafffe014b0d): SNZB-05P - SONOFF Zigbee water sensor (EndDevice)
[2026-02-06 14:38:57] info: 	z2m: Linky (0x00158d000638e9a7): ZLinky_TIC - LiXee Lixee ZLinky (Router)
[2026-02-06 14:38:57] info: 	z2m: Interrupteur salle d'attente (0xe456acfffe5dc273): ZBMINIL2 - SONOFF Zigbee smart switch (no neutral) (EndDevice)
[2026-02-06 14:38:57] info: 	z2m: 0xf044d3fffe9c706c (0xf044d3fffe9c706c): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2026-02-06 14:38:57] info: 	z2m: Currently 4 devices are joined.
[2026-02-06 14:38:57] info: 	z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2026-02-06 14:38:59] info: 	z2m: Connected to MQTT server
[2026-02-06 14:38:59] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2026-02-06 14:39:00] info: 	z2m: Started frontend on port 8099
[2026-02-06 14:39:01] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur fuite d'eau', payload '{"battery":100,"battery_low":false,"linkquality":144,"update":{"installed_version":4098,"latest_release_notes":null,"latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/Sonoff/snzb-05p_v1.0.2.ota","latest_version":4098,"state":"idle"},"water_leak":false}'
[2026-02-06 14:39:01] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1180,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:39:01] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Interrupteur salle d'attente', payload '{"linkquality":140,"power_on_behavior":"off","state":"OFF","update":{"installed_version":4110,"latest_release_notes":null,"latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/Sonoff/zigbeeminil2_100E_stand_ota_file.ota","latest_version":4110,"state":"idle"}}'
[2026-02-06 14:39:01] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf044d3fffe9c706c', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":84,"tamper":false,"update":{"installed_version":8704,"latest_release_notes":null,"latest_source":null,"latest_version":8704,"state":"idle"},"voltage":3200}'
[2026-02-06 14:39:01] info: 	z2m: Zigbee2MQTT started!
[2026-02-06 14:39:05] warning: 	zhc:lixee: Failed to read Zigbee attributes during startup: Error: ZCL command 0x00158d000638e9a7/1 liXeePrivate.read(["linkyMode","currentTarif"], {"timeout":10000,"disableResponse":false,"disableRecovery":false,"disableDefaultResponse":true,"direction":0,"reservedBits":0,"manufacturerCode":null,"writeUndiv":false}) failed (Delivery failed for '33823'.)
[2026-02-06 14:39:06] info: 	z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x04e3e5fffea80a6d/connection_state/config', payload '{"default_entity_id":"binary_sensor.zigbee2mqtt_bridge_connection_state","device":{"hw_version":"EmberZNet 7.4.5 [GA]","identifiers":["zigbee2mqtt_bridge_0x04e3e5fffea80a6d"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.8.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"2.8.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x04e3e5fffea80a6d_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2026-02-06 14:39:15] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1180,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:39:51] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":490,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:40:51] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":470,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:41:57] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":520,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[14:42:28] INFO: Preparing to start...
[14:42:29] INFO: Socat not enabled
[14:42:30] INFO: Starting Zigbee2MQTT...
[2026-02-06 14:42:56] info: 	z2m: Logging to console, file (filename: log.log)
[2026-02-06 14:42:58] info: 	z2m: Starting Zigbee2MQTT version 2.8.0 (commit #unknown)
[2026-02-06 14:42:58] info: 	z2m: Starting zigbee-herdsman (9.0.2)
[2026-02-06 14:42:59] info: 	zh:ember: Using default stack config.
[2026-02-06 14:42:59] info: 	zh:ember: ======== Ember Adapter Starting ========
[2026-02-06 14:42:59] info: 	zh:ember:ezsp: ======== EZSP starting ========
[2026-02-06 14:42:59] info: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-06 14:42:59] info: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-02-06 14:42:59] info: 	zh:ember:uart:ash: Serial port opened
[2026-02-06 14:42:59] info: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-06 14:43:00] info: 	zh:ember:uart:ash: ======== ASH connected ========
[2026-02-06 14:43:00] info: 	zh:ember:uart:ash: ======== ASH started ========
[2026-02-06 14:43:00] info: 	zh:ember:ezsp: ======== EZSP started ========
[2026-02-06 14:43:00] info: 	zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2026-02-06 14:43:00] info: 	zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.5 [GA]","build":0,"major":7,"minor":4,"patch":5,"special":0,"type":170}
[2026-02-06 14:43:01] info: 	zh:ember: [STACK STATUS] Network up.
[2026-02-06 14:43:01] info: 	zh:ember: [INIT TC] Adapter network matches config.
[2026-02-06 14:43:01] info: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1247ms until next broadcast.
[2026-02-06 14:43:01] info: 	z2m: zigbee-herdsman started (resumed)
[2026-02-06 14:43:01] info: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":5,"revision":"7.4.5 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2026-02-06 14:43:01] info: 	z2m: Capteur fuite d'eau (0x8c73dafffe014b0d): SNZB-05P - SONOFF Zigbee water sensor (EndDevice)
[2026-02-06 14:43:01] info: 	z2m: Linky (0x00158d000638e9a7): ZLinky_TIC - LiXee Lixee ZLinky (Router)
[2026-02-06 14:43:01] info: 	z2m: Interrupteur salle d'attente (0xe456acfffe5dc273): ZBMINIL2 - SONOFF Zigbee smart switch (no neutral) (EndDevice)
[2026-02-06 14:43:01] info: 	z2m: 0xf044d3fffe9c706c (0xf044d3fffe9c706c): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2026-02-06 14:43:01] info: 	z2m: Currently 4 devices are joined.
[2026-02-06 14:43:01] info: 	z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2026-02-06 14:43:03] info: 	z2m: Connected to MQTT server
[2026-02-06 14:43:03] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2026-02-06 14:43:05] info: 	z2m: Started frontend on port 8099
[2026-02-06 14:43:05] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1180,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:43:06] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur fuite d'eau', payload '{"battery":100,"battery_low":false,"linkquality":144,"update":{"installed_version":4098,"latest_release_notes":null,"latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/Sonoff/snzb-05p_v1.0.2.ota","latest_version":4098,"state":"idle"},"water_leak":false}'
[2026-02-06 14:43:06] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1180,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:43:06] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Interrupteur salle d'attente', payload '{"linkquality":140,"power_on_behavior":"off","state":"OFF","update":{"installed_version":4110,"latest_release_notes":null,"latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/Sonoff/zigbeeminil2_100E_stand_ota_file.ota","latest_version":4110,"state":"idle"}}'
[2026-02-06 14:43:06] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/0xf044d3fffe9c706c', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":84,"tamper":false,"update":{"installed_version":8704,"latest_release_notes":null,"latest_source":null,"latest_version":8704,"state":"idle"},"voltage":3200}'
[2026-02-06 14:43:06] info: 	z2m: Zigbee2MQTT started!
[2026-02-06 14:43:11] info: 	z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x04e3e5fffea80a6d/connection_state/config', payload '{"default_entity_id":"binary_sensor.zigbee2mqtt_bridge_connection_state","device":{"hw_version":"EmberZNet 7.4.5 [GA]","identifiers":["zigbee2mqtt_bridge_0x04e3e5fffea80a6d"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.8.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"2.8.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x04e3e5fffea80a6d_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
[2026-02-06 14:43:27] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1180,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:43:58] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1340,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:44:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1340,"available_power":30,"current_summ_delivered":18515.65,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:44:55] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1340,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:44:57] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":2150,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:45:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":2150,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":9,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:45:57] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":2200,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":9,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:46:18] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":2200,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":9,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:46:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":2200,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":8,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:46:57] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1170,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":8,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:47:39] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1170,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:47:58] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1230,"available_power":30,"current_summ_delivered":18515.86,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:48:31] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1230,"available_power":30,"current_summ_delivered":18515.96,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-06 14:48:58] info: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1190,"available_power":30,"current_summ_delivered":18515.96,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
Voici le log…
et la configuration :
data_path: /config/zigbee2mqtt
socat:
enabled: false
master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
options: « -d -d »
log: false
mqtt:
user: mqtt
password: xxx
base_topic: zigbee2mqtt
serial:
port: >-
/dev/serial/by-id/usb-SONOFF_SONOFF_Dongle_Lite_MG21_9afdf234ea9bef119600b89061ce3355-if00-port0
adapter: ember
Mmmh un rpi3 c’est trop leger pas assez de RAM
surveille ta RAM avec le system monitor dans les intégrations mais tu dois etre trop limite
Je pense à la même chose que @Barbotx
On en parle ici :
Dans ta configuration, ajoute :
rtscts: true
Le Zlinky (qu’on voit dans ton log) est très « bavard » avec cette charge ça serait plausible que ça plante.
Merci pour la réponse.
Effectivement je suis à 700/750Mo de ram utilisée sur 1go. Je ne sais pas si c’est critique ou pas.
J’ai rajouté rtscts: true et ai redémarré. Pour l’instant ca fonctionne.
Je verrais bien dans la nuit si ça saute ou pas…
Je vous tiens au courant.
Bonne soirée!
1 go ram c’est mort c’est pas assez clairement
C’est chaud oui 1GO de RAM.
Si tu souhaites changer de Raspberry pour la suite, tape le Pi V, idéalement en 4Go, tu seras tranquille un bout de temps avant de saturer la RAM. Et le Pi V à l’avantage de gérer les SSD PCIe avec un HAT et le POE aussi au besoin.
Bon, je viens donner quelques nouvelles : j’ai l’impression que rtscts: true a amélioré la situation (même si je ne comprends pas ce que c’est :grin: )
Mais bon ce n’est pas parfait : ça plante toujours de manière aléatoire :
[2026-02-10 20:04:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":430,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:05:18] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:06:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":400,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:07:00] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":400,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:07:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":950,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:08:00] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":950,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:08:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1400,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:09:18] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1400,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:09:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1420,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:10:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1510,"available_power":30,"current_summ_delivered":18637.3,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:10:29] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1510,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:11:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1520,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:12:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1510,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:12:52] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1510,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:13:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1280,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:13:36] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1280,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:14:09] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1280,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:14:16] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1770750856599,"os":{"load_average":[0.73,0.72,0.73],"memory_used_mb":714.12,"memory_percent":78.986},"process":{"uptime_sec":5419,"memory_used_mb":74.73,"memory_percent":8.2652},"mqtt":{"connected":true,"queued":0,"published":233,"received":41},"devices":{"0x00158d000638e9a7":{"messages":107,"messages_per_sec":0.02,"leave_count":0,"network_address_changes":0},"0xf044d3fffe9c706c":{"messages":5,"messages_per_sec":0.0011,"leave_count":0,"network_address_changes":0},"0x8c73dafffe014b0d":{"messages":2,"messages_per_sec":0.0007,"leave_count":0,"network_address_changes":0}}}'
[2026-02-10 20:14:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1280,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:14:19] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1280,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:14:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":940,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:15:10] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":940,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:15:21] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:16:21] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":390,"available_power":30,"current_summ_delivered":18637.4,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:17:06] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":390,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:17:21] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:17:41] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:18:21] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1270,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":104,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:18:41] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1270,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:19:22] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1350,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:19:22] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Porte garage', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":68,"tamper":false,"update":{"installed_version":8704,"latest_release_notes":null,"latest_source":null,"latest_version":8704,"state":"idle"},"voltage":3200}'
[2026-02-10 20:19:42] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1350,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:20:22] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:21:22] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":390,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:22:22] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":420,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:22:38] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":420,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:23:23] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1290,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:23:39] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1290,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:24:16] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1770751456608,"os":{"load_average":[0.87,0.75,0.74],"memory_used_mb":714.49,"memory_percent":79.0275},"process":{"uptime_sec":6019,"memory_used_mb":67.88,"memory_percent":7.5083},"mqtt":{"connected":true,"queued":0,"published":277,"received":41},"devices":{"0x00158d000638e9a7":{"messages":128,"messages_per_sec":0.0215,"leave_count":0,"network_address_changes":0},"0xf044d3fffe9c706c":{"messages":6,"messages_per_sec":0.0012,"leave_count":0,"network_address_changes":0},"0x8c73dafffe014b0d":{"messages":2,"messages_per_sec":0.0006,"leave_count":0,"network_address_changes":0}}}'
[2026-02-10 20:24:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1290,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:24:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1290,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:24:23] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1480,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:24:39] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1480,"available_power":30,"current_summ_delivered":18637.5,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:24:58] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1480,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:25:23] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1460,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":6,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:25:46] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1460,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:26:23] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1380,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:27:24] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1360,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:28:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1370,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:28:40] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1370,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:29:24] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1320,"available_power":30,"current_summ_delivered":18637.6,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:29:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1320,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:30:24] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1330,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:31:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1300,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:32:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1270,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:32:36] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1270,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:33:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1110,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:34:12] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1110,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:34:16] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1770752056603,"os":{"load_average":[1.1,0.89,0.79],"memory_used_mb":715.82,"memory_percent":79.174},"process":{"uptime_sec":6619,"memory_used_mb":68.71,"memory_percent":7.5999},"mqtt":{"connected":true,"queued":0,"published":318,"received":41},"devices":{"0x00158d000638e9a7":{"messages":149,"messages_per_sec":0.0228,"leave_count":0,"network_address_changes":0},"0xf044d3fffe9c706c":{"messages":6,"messages_per_sec":0.0011,"leave_count":0,"network_address_changes":0},"0x8c73dafffe014b0d":{"messages":4,"messages_per_sec":0.001,"leave_count":0,"network_address_changes":0}}}'
[2026-02-10 20:34:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1110,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:34:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":390,"available_power":30,"current_summ_delivered":18637.7,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:34:40] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":390,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:35:26] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":360,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:36:26] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":370,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:37:23] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":370,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:37:26] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":690,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:38:23] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":690,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:38:26] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1380,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:39:26] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1360,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:40:27] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1330,"available_power":30,"current_summ_delivered":18637.8,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:41:25] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1330,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:41:27] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1280,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:42:28] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1270,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:43:29] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1240,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:43:44] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1240,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:44:14] e[32minfoe[39m: 	zh:ember: [NCP COUNTERS] 282,470,5064,32,3,0,0,0,111,30,0,0,61,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
[2026-02-10 20:44:14] e[32minfoe[39m: 	zh:ember: [ASH COUNTERS] 810,262,31,231,0,0,0,0,5918,231,227,0,0,4,0,0,0,0,0,0,0,0,0,0,4,0,0
[2026-02-10 20:44:16] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/health', payload '{"response_time":1770752656599,"os":{"load_average":[0.39,0.59,0.7],"memory_used_mb":721.36,"memory_percent":79.7867},"process":{"uptime_sec":7219,"memory_used_mb":67.34,"memory_percent":7.4478},"mqtt":{"connected":true,"queued":0,"published":356,"received":41},"devices":{"0x00158d000638e9a7":{"messages":168,"messages_per_sec":0.0235,"leave_count":0,"network_address_changes":0},"0xf044d3fffe9c706c":{"messages":6,"messages_per_sec":0.001,"leave_count":0,"network_address_changes":0},"0x8c73dafffe014b0d":{"messages":4,"messages_per_sec":0.0009,"leave_count":0,"network_address_changes":0}}}'
[2026-02-10 20:44:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1240,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:44:20] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1240,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":104,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:44:29] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1190,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:44:58] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1190,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:45:29] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":4,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:45:58] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":410,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:46:29] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":390,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:48:03] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":430,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":1,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:48:17] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":430,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:49:03] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1250,"available_power":30,"current_summ_delivered":18637.9,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:49:05] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1250,"available_power":30,"current_summ_delivered":18638,"current_tarif":"BASE","linkquality":96,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":2,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:49:17] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1250,"available_power":30,"current_summ_delivered":18638,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[2026-02-10 20:50:03] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload '{"MOTDETAT":null,"active_register_tier_delivered":"TH..","apparent_power":1350,"available_power":30,"current_summ_delivered":18638,"current_tarif":"BASE","linkquality":100,"meter_serial_number":"022161079324","mot_d_etat":"000000","rms_current":5,"rms_current_max":90,"update":{"installed_version":17,"latest_release_notes":"https://github.com/fairecasoimeme/Zlinky_TIC/releases/tag/v17.0","latest_source":"https://raw.githubusercontent.com/Koenkk/zigbee-OTA/master/images/LiXee/ZLinky_router_v17.ota","latest_version":17,"state":"idle"},"warn_d_p_s":0}'
[20:50:34] INFO: e[32mPreparing to start...e[0m
[20:50:34] INFO: e[32mSocat not enablede[0m
[20:50:36] INFO: e[32mStarting Zigbee2MQTT...e[0m
[2026-02-10 20:50:49] e[32minfoe[39m: 	z2m: Logging to console, file (filename: log.log)
[2026-02-10 20:50:50] e[32minfoe[39m: 	z2m: Starting Zigbee2MQTT version 2.8.0 (commit #unknown)
[2026-02-10 20:50:50] e[32minfoe[39m: 	z2m: Starting zigbee-herdsman (9.0.2)
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember: Using default stack config.
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember: ======== Ember Adapter Starting ========
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember:ezsp: ======== EZSP starting ========
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember:uart:ash: ======== ASH Adapter reset ========
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember:uart:ash: Serial port opened
[2026-02-10 20:50:51] e[32minfoe[39m: 	zh:ember:uart:ash: ======== ASH starting ========
[2026-02-10 20:50:52] e[32minfoe[39m: 	zh:ember:uart:ash: ======== ASH connected ========
[2026-02-10 20:50:52] e[32minfoe[39m: 	zh:ember:uart:ash: ======== ASH started ========
[2026-02-10 20:50:52] e[32minfoe[39m: 	zh:ember:ezsp: ======== EZSP started ========
[2026-02-10 20:50:52] e[32minfoe[39m: 	zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2026-02-10 20:50:52] e[32minfoe[39m: 	zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.5 [GA]","build":0,"major":7,"minor":4,"patch":5,"special":0,"type":170}
[2026-02-10 20:50:53] e[32minfoe[39m: 	zh:ember: [STACK STATUS] Network up.
[2026-02-10 20:50:53] e[32minfoe[39m: 	zh:ember: [INIT TC] Adapter network matches config.
[2026-02-10 20:50:53] e[32minfoe[39m: 	zh:ember: [CONCENTRATOR] Started source route discovery. 1247ms until next broadcast.
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: zigbee-herdsman started (resumed)
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":5,"revision":"7.4.5 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Capteur fuite d'eau (0x8c73dafffe014b0d): SNZB-05P - SONOFF Zigbee water sensor (EndDevice)
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Linky (0x00158d000638e9a7): ZLinky_TIC - LiXee Lixee ZLinky (Router)
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Interrupteur salle d'attente (0xe456acfffe5dc273): ZBMINIL2 - SONOFF Zigbee smart switch (no neutral) (EndDevice)
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Porte garage (0xf044d3fffe9c706c): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Currently 4 devices are joined.
[2026-02-10 20:50:53] e[32minfoe[39m: 	z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2026-02-10 20:50:55] e[32minfoe[39m: 	z2m: Connected to MQTT server
[2026-02-10 20:50:55] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2026-02-10 20:50:56] e[32minfoe[39m: 	z2m: Started frontend on port 8099
[2026-02-10 20:50:56] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'homeassistant/sensor/0x00158d000638e9a7/active_register_tier_delivered/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"default_entity_id":"sensor.linky_active_register_tier_delivered","device":{"hw_version":1,"identifiers":["zigbee2mqtt_0x00158d000638e9a7"],"manufacturer":"LiXee","model":"Lixee ZLinky","model_id":"ZLinky_TIC","name":"Linky","sw_version":"4000-0017","via_device":"zigbee2mqtt_bridge_0x04e3e5fffea80a6d"},"name":"PTEC","object_id":"linky_active_register_tier_delivered","origin":{"name":"Zigbee2MQTT","sw":"2.8.0","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/Linky","unique_id":"0x00158d000638e9a7_active_register_tier_delivered_zigbee2mqtt","value_template":"{{ value_json.active_register_tier_delivered | default('',True) | string | truncate(254, True, '', 0) }}"}'
[2026-02-10 20:50:56] e[32minfoe[39m: 	z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Linky', payload
Du coup vous pensez à coup sûr que c’est le manque de RAM?
Chez moi au lieu d’acheter un nouveau RPI qui sont devenu cher, je suis passé sur un nuc d’intel d’occas’, moins cher et « bidouillable » (je pense que c’est pas une mauvaise idée)
La cas échéant je me mettrais en quête d’un nouveau nuc… C’est dommage je pensais que mon RPI allait suffire, vu le peu de choses qu’il doit gérer…
For sure …
Tu as monitoré ta RAM?
Yep :
Voilà donc je crois que c’est plutôt clair
Mais c’est moins que 1 Go :grimacing:
C’est trop quand même?
Je vais de ce pas sur LBC?
Tu es au taquet non ça suffit pas
Tu n’es pas le 1er a avoir le même soucis avec 1 Go
Mais je pensais que ça serait différent avec moi :smiling_face_with_tear:
Bon pas d’autres solution que d’acheter un nouveau setup alors…
Merci en tout cas pour l’aide! :+1:
