Projet voice control
J’ai reçu tout le matériel donc c’est parti mais voila…
J’ai suivi le branchement indiqué sur:
Même micro / ampli sur un ESP32WroomM32.
Mon yaml pour l’instant :
esphome:
  friendly_name: Esp32 Voice Control 1
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "q9W1KdaUqIRk4xxxxxxDhfIwh2r12VW7d7bSkke3f1U="
ota:
  password: "546340f29b91xxxxxxac0038e07534d9"
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.1.13
    gateway: 192.168.1.254
    subnet: 255.255.255.0
  ap:
    ssid: "Esp32-Voice-Control-1"
    password: "bDXXXxxx9KB6"
captive_portal:
switch:
  - platform: gpio
    pin: 2
# voice assistant
i2s_audio:
  - id: i2s_in
    i2s_lrclk_pin: GPIO26   #WS / LRC
    i2s_bclk_pin: GPIO25    #SCK /BCLK
microphone:
  - platform: i2s_audio
    adc_type: external
    pdm: false
    channel: left
    bits_per_sample: 32bit
    i2s_audio_id: i2s_in
    i2s_din_pin: GPIO33    #SD
speaker:
    dac_type: external
    i2s_dout_pin: GPIO27   #DIN
    mode: mono
# Example configuration entry
web_server:
  port: 80
Au flashage :
Uploading: [============================================================] 100% Done...
INFO Upload took 9.35 seconds, waiting for result...
INFO OTA successful
INFO Successfully uploaded program.
INFO Starting log output from 192.168.1.13 using esphome API
INFO Successfully connected to esp32-voice-control-1 @ 192.168.1.13 in 7.141s
INFO Successful handshake with esp32-voice-control-1 @ 192.168.1.13 in 0.119s
[17:37:09][I][app:102]: ESPHome version 2023.12.5 compiled on Dec 29 2023, 17:36:08
[17:37:09][C][wifi:573]: WiFi:
[17:37:09][C][wifi:405]:   Local MAC: B0:A7:32:22:77:A8
[17:37:09][C][wifi:410]:   SSID: [redacted]
[17:37:09][C][wifi:411]:   IP Address: 192.168.1.13
[17:37:09][C][wifi:413]:   BSSID: [redacted]
[17:37:09][C][wifi:414]:   Hostname: 'esp32-voice-control-1'
[17:37:09][C][wifi:416]:   Signal strength: -51 dB ▂▄▆█
[17:37:09][C][wifi:420]:   Channel: 11
[17:37:09][C][wifi:421]:   Subnet: 255.255.255.0
[17:37:09][C][wifi:422]:   Gateway: 192.168.1.254
[17:37:09][C][wifi:423]:   DNS1: 0.0.0.0
[17:37:09][C][wifi:424]:   DNS2: 0.0.0.0
[17:37:09][C][logger:443]: Logger:
[17:37:09][C][logger:444]:   Level: DEBUG
[17:37:09][C][logger:445]:   Log Baud Rate: 115200
[17:37:09][C][logger:447]:   Hardware UART: UART0
[17:37:09][C][switch.gpio:068]: GPIO Switch 'LedBleu2'
[17:37:09][C][switch.gpio:091]:   Restore Mode: always OFF
[17:37:09][C][switch.gpio:031]:   Pin: GPIO2
[17:37:09][C][captive_portal:088]: Captive Portal:
[17:37:09][C][web_server:168]: Web Server:
[17:37:09][C][web_server:169]:   Address: 192.168.1.13:80
[17:37:09][C][mdns:115]: mDNS:
[17:37:09][C][mdns:116]:   Hostname: esp32-voice-control-1
[17:37:09][C][ota:097]: Over-The-Air Updates:
[17:37:09][C][ota:098]:   Address: 192.168.1.13:3232
[17:37:09][C][ota:101]:   Using Password.
[17:37:09][C][api:139]: API Server:
[17:37:09][C][api:140]:   Address: 192.168.1.13:6053
[17:37:09][C][api:142]:   Using noise encryption: YES
[17:37:41][D][api:102]: Accepted 192.168.1.32
[17:37:42][W][api.connection:092]: : Socket operation failed: HANDSHAKESTATE_READ_FAILED errno=11
Je vois bien l’ESP et je peux piloter la LED bleu.
Une idée ?
PS : 192.168.1.32 c’est mon PI.
Bob
il te manque c’est parti du code.
voice_assistant:
  microphone: mic
  use_wake_word: false
  noise_suppression_level: 2
  auto_gain: 31dBFS
  volume_multiplier: 2.0
  speaker: big_speaker
switch:
    name: Use wake word
    optimistic: true
    restore_mode: RESTORE_DEFAULT_ON
    entity_category: config
    on_turn_on:
      - lambda: id(assist).set_use_wake_word(true);
      - if:
          condition:
            not:
              - voice_assistant.is_running
          then:
            - voice_assistant.start_continuous
    on_turn_off:
      - voice_assistant.stop
      - lambda: id(assist).set_use_wake_word(false);
Bonsoir @WarC0zes
Merci beaucoup, je pensais avancer pas à pas et déjà trouver micro et ampli :wink:
C’est OK merci, reste à paramétrer le « word detected » avec snowboy ou autre :wink:
[18:35:21][E][voice_assistant:656]: Error: no_wake_word - No wake word detected
ça avance :slight_smile:
captive_portal:
# voice assistant
i2s_audio:
  - id: i2s_in
microphone:
    adc_type: external
    pdm: false
    channel: left
speaker:
    dac_type: external
    mode: mono
voice_assistant:
  microphone: mic_i2s
  auto_gain: 31dBFS
  use_wake_word: true
  speaker: my_speaker
binary_sensor:
  - platform: status
    name: API Connection
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
            switch.is_on: use_wake_word
          then:
            - voice_assistant.start_continuous:
    on_release:
      - if:
          condition:
          then:
            - voice_assistant.stop:
switch:
    name: Use wake word
    optimistic: true
    on_turn_on:
      - if:
          condition:
            not:
          then:
    on_turn_off:
  - platform: gpio
    pin: 2
Bob
Hello, désolé pour la réponse tardive, je n'ai pu m'en occuper avant. En effet, c'est beaucoup plus rapide mais toujours le même soucis, il ne comprend rien, même quand je lui demande d'allumer le four...
je suis passer sur porcupine ( GitHub - chatziko/wyoming-porcupine · GitHub ) au lieu de snowboy et j'utilise un wake word perso, "Terminator" en FR :sweat_smile:.
Utilise Vosk ( hassio-addons/vosk at master · rhasspy/hassio-addons · GitHub ) a la place de faster-whisper, si c'est pas déja fait.
Utilise l'option alias qui ce paramètre dans chaque entité, pour utiliser un nom simple de l'appareil si c'est un peu trop compliquer a comprendre.
exemple: quel est la température du séjour ?
Pour savoir les commandes pris en charge regarde les sentences en FR
Merci pour ton retour. Je regarde les alias, et si jamais je reconfigure ca.
Comme convenu, petit retour flash sur le korvo V1.1, reçu cet après-midi.
Pour mon premier test j’ai utilisé le yaml dispo ici :
korvo-esphome/esp32korvo_esphome.yaml at dev · haade-administrator/korvo-esphome (github.com)
Il est à modifier en partie pour prendre en compte la restriction d’utilisation multiple des gpio apparue dans la version 2023.12 d’EspHome.
Partie à modifier :
i2s_audio:
  - id: codec
    i2s_lrclk_pin: GPIO22
    i2s_mclk_pin:
      number: GPIO0
      allow_other_uses: true
  - id: mic_adc
    i2s_bclk_pin: GPIO27
    i2s_mclk_pin:
      number: GPIO0
Très très bonne sensibilité et portée du mic-array, même dans un environnement bruyant (sans autre voix , mais avec musique OK).
La partie Speaker ne fonctionne pas pour l’instant, mais il y a du monde sur le coup.
Bonsoir,
comme indiqué j'ai suivi le câblage de:
Mon assistant (favoris):
Je teste avec perroquet pour l'instant mais je retrouve bien dans la liste le mot créé sur porcupine et déposé dans /shared/porcupine
Wyoming Protocol:
Mon ESP32 (autorisé à passer des appels de service HA):
Assist en cours est toujours désactivé et je ne vois jamais dans les logs une ligne de ce type:
[23:02:18][D][voice_assistant:538]: Wake word detected
Mon YAML d'ESPHome :
esphome:
  on_boot:
    - priority: -100
      then:
        - wait_until: api.connected
        - delay: 5s
        - speaker.play:
            data: [0x00]
        #- delay: 1s
        #- if:
        #    condition:
        #      switch.is_on: use_wake_word
        #    then:
        #      - voice_assistant.start_continuous:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
api:
  encryption:
    key: "q9W1KdaUqIRkxxxxxxxxxfIwh2r12VW7d7bSkke3f1U="
ota:
  password: "54634xxxxxxxxx94b2ac0038e07534d9"
wifi:
  manual_ip:
  ap:
    password: "bxxxxxxxxKB6"
captive_portal:
# voice assistant
i2s_audio:
  - id: i2s_in
microphone:
    adc_type: external
    pdm: false
    channel: left
speaker:
    dac_type: external
    mode: mono
voice_assistant:
  microphone: mic_i2s
  auto_gain: 31dBFS
  use_wake_word: true
  speaker: my_speaker
  #on_error:
  # - if:
  #      condition:
  #      then:
  #        - switch.turn_off: use_wake_word
  #        - switch.turn_on: use_wake_word
  on_client_connected:
    - if:
        condition:
        then:
  on_client_disconnected:
    - if:
        condition:
        then:
binary_sensor:
  - platform: status
    filters:
      - delayed_on: 1s
    on_press:
      - if:
          condition:
          then:
    on_release:
      - if:
          condition:
          then:
switch:
    name: Use wake word
    optimistic: true
    on_turn_on:
      - lambda: id(brunoassist).set_use_wake_word(true);
      - if:
          condition:
            not:
          then:
    on_turn_off:
      - lambda: id(brunoassist).set_use_wake_word(false);
  - platform: gpio
    pin: 2
web_server:
  port: 80
Un extrait des logs de l'ESP32 en prononçant le mot de réveil :
[19:50:40][D][voice_assistant:529]: Event Type: 0
[19:50:40][D][voice_assistant:529]: Event Type: 2
[19:50:40][D][voice_assistant:619]: Assist Pipeline ended
[19:50:40][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to IDLE
[19:50:40][D][voice_assistant:428]: Desired state set to IDLE
[19:50:40][D][voice_assistant:422]: State changed from IDLE to START_PIPELINE
[19:50:40][D][voice_assistant:428]: Desired state set to START_MICROPHONE
[19:50:40][D][voice_assistant:206]: Requesting start...
[19:50:40][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[19:50:40][D][voice_assistant:443]: Client started, streaming microphone
[19:50:40][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[19:50:40][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[19:50:40][D][voice_assistant:529]: Event Type: 1
[19:50:40][D][voice_assistant:532]: Assist Pipeline running
[19:50:40][D][voice_assistant:529]: Event Type: 9
[19:50:45][D][voice_assistant:529]: Event Type: 0
[19:50:45][D][voice_assistant:529]: Event Type: 2
[19:50:45][D][voice_assistant:619]: Assist Pipeline ended
[19:50:45][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to IDLE
[19:50:45][D][voice_assistant:428]: Desired state set to IDLE
[19:50:45][D][voice_assistant:422]: State changed from IDLE to START_PIPELINE
[19:50:45][D][voice_assistant:428]: Desired state set to START_MICROPHONE
[19:50:45][D][voice_assistant:206]: Requesting start...
[19:50:45][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[19:50:45][D][voice_assistant:443]: Client started, streaming microphone
[19:50:45][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[19:50:45][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[19:50:45][D][voice_assistant:529]: Event Type: 1
[19:50:45][D][voice_assistant:532]: Assist Pipeline running
[19:50:45][D][voice_assistant:529]: Event Type: 9
[19:50:50][D][voice_assistant:529]: Event Type: 0
[19:50:50][D][voice_assistant:529]: Event Type: 2
[19:50:50][D][voice_assistant:619]: Assist Pipeline ended
[19:50:50][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to IDLE
[19:50:50][D][voice_assistant:428]: Desired state set to IDLE
[19:50:50][D][voice_assistant:422]: State changed from IDLE to START_PIPELINE
[19:50:50][D][voice_assistant:428]: Desired state set to START_MICROPHONE
[19:50:50][D][voice_assistant:206]: Requesting start...
[19:50:50][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[19:50:50][D][voice_assistant:443]: Client started, streaming microphone
[19:50:50][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[19:50:50][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[19:50:50][D][voice_assistant:529]: Event Type: 1
[19:50:50][D][voice_assistant:532]: Assist Pipeline running
[19:50:50][D][voice_assistant:529]: Event Type: 9
[19:50:51][D][api:102]: Accepted 192.168.1.32
[19:50:51][W][api.connection:092]: : Socket operation failed: HANDSHAKESTATE_READ_FAILED errno=11
[19:50:55][D][voice_assistant:529]: Event Type: 0
[19:50:55][D][voice_assistant:529]: Event Type: 2
[19:50:55][D][voice_assistant:619]: Assist Pipeline ended
[19:50:55][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to IDLE
[19:50:55][D][voice_assistant:428]: Desired state set to IDLE
[19:50:55][D][voice_assistant:422]: State changed from IDLE to START_PIPELINE
[19:50:55][D][voice_assistant:428]: Desired state set to START_MICROPHONE
[19:50:55][D][voice_assistant:206]: Requesting start...
[19:50:55][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[19:50:55][D][voice_assistant:443]: Client started, streaming microphone
[19:50:55][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[19:50:55][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[19:50:55][D][voice_assistant:529]: Event Type: 1
[19:50:55][D][voice_assistant:532]: Assist Pipeline running
[19:50:55][D][voice_assistant:529]: Event Type: 9
[19:51:00][D][voice_assistant:529]: Event Type: 0
[19:51:00][D][voice_assistant:529]: Event Type: 2
[19:51:00][D][voice_assistant:619]: Assist Pipeline ended
[19:51:00][D][voice_assistant:422]: State changed from STREAMING_MICROPHONE to IDLE
[19:51:00][D][voice_assistant:428]: Desired state set to IDLE
[19:51:00][D][voice_assistant:422]: State changed from IDLE to START_PIPELINE
[19:51:00][D][voice_assistant:428]: Desired state set to START_MICROPHONE
[19:51:00][D][voice_assistant:206]: Requesting start...
[19:51:00][D][voice_assistant:422]: State changed from START_PIPELINE to STARTING_PIPELINE
[19:51:00][D][voice_assistant:443]: Client started, streaming microphone
[19:51:00][D][voice_assistant:422]: State changed from STARTING_PIPELINE to STREAMING_MICROPHONE
[19:51:00][D][voice_assistant:428]: Desired state set to STREAMING_MICROPHONE
[19:51:00][D][voice_assistant:529]: Event Type: 1
[19:51:00][D][voice_assistant:532]: Assist Pipeline running
[19:51:00][D][voice_assistant:529]: Event Type: 9
Avec de temps en temps cette ligne :
[19:59:53][W][api.connection:092]: : Socket operation failed: HANDSHAKESTATE_READ_FAILED errno=11
Voilà pour l'instant, pas de reconnaissance du mot de réveil alors si vous avez une petite ou grande idée :wink:
Je précise que via assist depuis le micro du PC j'arrive à allumer des lampes.
Merci d'avance pour votre aide.
Bob
Hello @Bob
Mes meilleurs voeux pour cette nouvelle année.
Peut-être as-tu un pb de micro sur ton montage.
En ajoutant ces lignes à ton yaml, tu peux forcer l’écoute sans wakeword, et tu vas voir le résultat dans le pipeline
    optimistic: true
    restore_mode: ALWAYS_OFF
    on_turn_on:
      - delay: 0.5s
    on_turn_off:
Bonjour @anon21985933,
Meilleur vœux à toi aussi :wink:
J’attendais avec impatience une (ta) réponse :slight_smile:, nous sommes nombreux je crois sur le sujet.
Merci, je teste ce midi, j’ai deux micros et 3 amplis d’avance au cas où.
Dans le pipeline je verrai le texte énoncé ?
Bob
Oui, dans la partie débogage du pipeline
@anon21985933
Je le colle où le code :hugs:
En remplacement d’un autre code ?
J’ai testé quelques possibilités mais ça ne passe pas au flashage :wink:
Bob
Effectivement, je viens de tester une recompile et aussi une erreur.
C’est passé en changeant listen par listen_force :wink:
On dirait que le mot listen est maintenant réservé par Esphome :crazy_face:
Ce code est à ajouter au niveau des switchs
OK, merci @anon21985933, je ferai un test ce soir, j’ai testé un deuxième micro sans meilleurs résultat.
Bob
J'ai bien le Listen maintenant mais je ne vois pas de résultat dans le pipeline.
Heureusement que le micro ne m'entend pas :rofl:
Bob
Quand tu active listen, tu devrais avoir assist en cours qui passe en activé.
Je pense pas que VOSK accepte les jurons :grinning:
En effet, mais pas de résultat dans le pipeline si je parle :wink:
Puis assist en cours repasse a désactivé.
Bob
Quand tu es dans le débogage du pipeline, tu peux acceder à l'historique en haut.
Tu n'as rien en revenant en arrière ?
Mais la majorité du temps j'ai :
Ou
Bob
T’es sur une breadboard ?
Dans la positive, supprime le MAX et modifie ton yaml en conséquence (éventuellement branche l’INMP sur d’autres GPIO)
