Je débute sur node-red, j’ai lu plusieurs de vos posts, ce qui m’a permis de démarrer un premier flow, merci à vous.
Avant de me lancer dans la lecture de posts plus aboutis, voici mon souci. Le statut de mon volet ne change pas entre chaque exécution.???
Voici ce que j’ai fait, si vous pouviez me dire où j’ai une erreur.
la configuration du switch:
Le state ne change pas donc je passe toujours dans open. Le volet s’ouvre ou se ferme à chaque exécution mais sans changer d’état. Je ne sais pas pourquoi.
Mon flow en JSON si plus simple
"id": "0690c21701f8a1a7",
"type": "inject",
"z": "41f6b287083c2ada",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 120,
"y": 160,
"wires": [
"533e4727957ae2e9"
"id": "533e4727957ae2e9",
"type": "api-current-state",
"name": "",
"server": "8ba7aec4.1022e",
"version": 3,
"outputs": 1,
"halt_if": "",
"halt_if_type": "str",
"halt_if_compare": "is",
"entity_id": "cover.commutateur_de_rideau_5_curtain",
"state_type": "str",
"blockInputOverrides": false,
"outputProperties": [
"property": "data",
"propertyType": "msg",
"value": "",
"valueType": "entity"
"for": "0",
"forType": "num",
"forUnits": "minutes",
"override_topic": false,
"state_location": "payload",
"override_payload": "msg",
"entity_location": "data",
"override_data": "msg",
"x": 430,
"y": 60,
"wires": [
"67f5e5d499af69e8",
"b9cc2f0448265ebd"
"id": "860d4ff9e62c4993",
"type": "debug",
"name": "JSON",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 870,
"y": 140,
"wires": []
"id": "becaa97ac4c4a19e",
"type": "api-call-service",
"name": "",
"version": 5,
"debugenabled": true,
"domain": "cover",
"service": "open_cover",
"areaId": [],
"deviceId": [
"c39d8e65a25cc96e65bd524011ba935a"
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"mustacheAltTags": false,
"outputProperties": [],
"queue": "none",
"x": 1090,
"y": 240,
"wires": [
"id": "67f5e5d499af69e8",
"type": "json",
"name": "",
"property": "data.entity_id",
"action": "str",
"pretty": false,
"x": 470,
"y": 140,
"wires": [
"90885d949b1bb328",
"860d4ff9e62c4993",
"36dde56eeb6e146b"
"id": "88c3911f830af95c",
"type": "debug",
"name": "close",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "data.state",
"targetType": "msg",
"statusVal": "",
"x": 1070,
"y": 200,
"wires": []
"id": "90885d949b1bb328",
"type": "switch",
"name": "",
"property": "data.state",
"rules": [
"t": "eq",
"v": "close",
"vt": "str"
"t": "eq",
"v": "open",
"vt": "str"
"checkall": "false",
"repair": false,
"outputs": 2,
"x": 730,
"y": 200,
"wires": [
"88c3911f830af95c",
"becaa97ac4c4a19e"
"8e3a709b6e7523c8",
"299e6ad8c4d39aeb"
"id": "8e3a709b6e7523c8",
"type": "debug",
"name": "Open",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 1070,
"y": 320,
"wires": []
"id": "299e6ad8c4d39aeb",
"name": "",
"version": 5,
"domain": "cover",
"service": "close_cover",
"areaId": [],
"deviceId": [
"entityId": [
"data": "",
"dataType": "json",
"mergeContext": "",
"queue": "none",
"x": 1090,
"y": 360,
"wires": [
"id": "36dde56eeb6e146b",
"type": "debug",
"name": "cover.state",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 630,
"y": 320,
"wires": []
"id": "b9cc2f0448265ebd",
"type": "debug",
"name": "debug 7",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"statusVal": "",
"x": 820,
"y": 60,
"wires": []
"id": "8ba7aec4.1022e",
"type": "server",
"name": "Home Assistant",
"version": 5,
"addon": true,
"rejectUnauthorizedCerts": true,
"ha_boolean": "y|yes|true|on|home|open",
"connectionDelay": true,
"cacheJson": true,
"heartbeat": false,
"heartbeatInterval": 30,
"areaSelector": "friendlyName",
"deviceSelector": "friendlyName",
"entitySelector": "friendlyName",
"statusSeparator": "at: ",
"statusYear": "hidden",
"statusMonth": "short",
"statusDay": "numeric",
"statusHourCycle": "h23",
"statusTimeFormat": "h:m",
"enableGlobalContextStore": true
Merci pour votre aide
