voici le journal de Mosquitto broken :
2023-11-01 17:37:36: Saving in-memory database to /data//mosquitto.db.
2023-11-01 17:38:17: New connection from 172.30.32.2:55602 on port 1883.
2023-11-01 17:38:17: Client <unknown> closed its connection.
2023-11-01 17:40:17: New connection from 172.30.32.2:48184 on port 1883.
2023-11-01 17:40:17: Client <unknown> closed its connection.
2023-11-01 17:42:17: New connection from 172.30.32.2:35240 on port 1883.
2023-11-01 17:42:17: Client <unknown> closed its connection.
2023-11-01 17:44:17: New connection from 172.30.32.2:46250 on port 1883.
2023-11-01 17:44:17: Client <unknown> closed its connection.
2023-11-01 17:46:17: New connection from 172.30.32.2:41174 on port 1883.
2023-11-01 17:46:17: Client <unknown> closed its connection.
2023-11-01 17:48:17: New connection from 172.30.32.2:52322 on port 1883.
2023-11-01 17:48:17: Client <unknown> closed its connection.
2023-11-01 17:50:17: New connection from 172.30.32.2:43240 on port 1883.
2023-11-01 17:50:17: Client <unknown> closed its connection.
2023-11-01 17:52:17: New connection from 172.30.32.2:53568 on port 1883.
2023-11-01 17:52:17: Client <unknown> closed its connection.
2023-11-01 17:54:17: New connection from 172.30.32.2:34056 on port 1883.
2023-11-01 17:54:17: Client <unknown> closed its connection.
2023-11-01 17:56:17: New connection from 172.30.32.2:43600 on port 1883.
2023-11-01 17:56:17: Client <unknown> closed its connection.
2023-11-01 17:58:17: New connection from 172.30.32.2:52988 on port 1883.
2023-11-01 17:58:17: Client <unknown> closed its connection.
2023-11-01 18:00:17: New connection from 172.30.32.2:40172 on port 1883.
2023-11-01 18:00:17: Client <unknown> closed its connection.
2023-11-01 18:02:17: New connection from 172.30.32.2:48568 on port 1883.
2023-11-01 18:02:17: Client <unknown> closed its connection.
2023-11-01 18:04:17: New connection from 172.30.32.2:42602 on port 1883.
2023-11-01 18:04:17: Client <unknown> closed its connection.
2023-11-01 18:06:17: New connection from 172.30.32.2:52792 on port 1883.
2023-11-01 18:06:17: Client <unknown> closed its connection.
2023-11-01 18:07:37: Saving in-memory database to /data//mosquitto.db.
2023-11-01 18:08:17: New connection from 172.30.32.2:46036 on port 1883.
2023-11-01 18:08:17: Client <unknown> closed its connection.
2023-11-01 18:10:17: New connection from 172.30.32.2:47134 on port 1883.
2023-11-01 18:10:17: Client <unknown> closed its connection.
2023-11-01 18:12:17: New connection from 172.30.32.2:36918 on port 1883.
2023-11-01 18:12:17: Client <unknown> closed its connection.
2023-11-01 18:13:47: Client 26mN7bAEpT7GElcZFTMQCt closed its connection.
2023-11-01 18:14:15: New connection from 172.30.32.1:47941 on port 1883.
2023-11-01 18:14:15: New client connected from 172.30.32.1:47941 as 2TvP0gYmDnAhkBaHl2jdgP (p2, c1, k60, u'homeassistant').
2023-11-01 18:14:17: New connection from 172.30.32.2:40410 on port 1883.
2023-11-01 18:14:17: Client <unknown> closed its connection.
2023-11-01 18:16:17: New connection from 172.30.32.2:47892 on port 1883.
2023-11-01 18:16:17: Client <unknown> closed its connection.
2023-11-01 18:18:17: New connection from 172.30.32.2:54384 on port 1883.
2023-11-01 18:18:17: Client <unknown> closed its connection.
2023-11-01 18:20:17: New connection from 172.30.32.2:51332 on port 1883.
2023-11-01 18:20:17: Client <unknown> closed its connection.
2023-11-01 18:22:17: New connection from 172.30.32.2:53732 on port 1883.
2023-11-01 18:22:17: Client <unknown> closed its connection.
2023-11-01 18:22:33: Client 2TvP0gYmDnAhkBaHl2jdgP closed its connection.
2023-11-01 18:22:48: Client mqttjs_1f4e08b7 closed its connection.
2023-11-01 18:23:00: New connection from 172.30.33.1:37224 on port 1883.
2023-11-01 18:23:00: New client connected from 172.30.33.1:37224 as mqttjs_231f74de (p2, c1, k60, u'mqtt').
2023-11-01 18:23:01: New connection from 172.30.32.1:54285 on port 1883.
2023-11-01 18:23:01: New client connected from 172.30.32.1:54285 as 3cMf8J9OKyL5FL9gIm6YXG (p2, c1, k60, u'homeassistant').
2023-11-01 18:24:17: New connection from 172.30.32.2:49448 on port 1883.
2023-11-01 18:24:17: Client <unknown> closed its connection.
2023-11-01 18:26:17: New connection from 172.30.32.2:36076 on port 1883.
2023-11-01 18:26:17: Client <unknown> closed its connection.
2023-11-01 18:28:17: New connection from 172.30.32.2:57290 on port 1883.
2023-11-01 18:28:17: Client <unknown> closed its connection.
2023-11-01 18:30:17: New connection from 172.30.32.2:41070 on port 1883.
2023-11-01 18:30:17: Client <unknown> closed its connection.
2023-11-01 18:31:04: Client 3cMf8J9OKyL5FL9gIm6YXG closed its connection.
2023-11-01 18:31:23: New connection from 172.30.32.1:55563 on port 1883.
2023-11-01 18:31:23: New client connected from 172.30.32.1:55563 as 5K5p4t7uyUaESNqDKOcROd (p2, c1, k60, u'homeassistant').
2023-11-01 18:32:17: New connection from 172.30.32.2:55696 on port 1883.
2023-11-01 18:32:17: Client <unknown> closed its connection.
2023-11-01 18:34:17: New connection from 172.30.32.2:37964 on port 1883.
2023-11-01 18:34:17: Client <unknown> closed its connection.
2023-11-01 18:35:18: Client 5K5p4t7uyUaESNqDKOcROd closed its connection.
2023-11-01 18:35:46: New connection from 172.30.32.1:52139 on port 1883.
2023-11-01 18:35:46: New client connected from 172.30.32.1:52139 as 36uMWSn7PBl6MfoIu2eWoh (p2, c1, k60, u'homeassistant').
2023-11-01 18:36:17: New connection from 172.30.32.2:38076 on port 1883.
2023-11-01 18:36:17: Client <unknown> closed its connection.
2023-11-01 18:37:38: Saving in-memory database to /data//mosquitto.db.
2023-11-01 18:38:17: New connection from 172.30.32.2:57840 on port 1883.
2023-11-01 18:38:17: Client <unknown> closed its connection.
2023-11-01 18:40:17: New connection from 172.30.32.2:60612 on port 1883.
2023-11-01 18:40:17: Client <unknown> closed its connection.
2023-11-01 18:42:17: New connection from 172.30.32.2:44258 on port 1883.
2023-11-01 18:42:17: Client <unknown> closed its connection.
2023-11-01 18:44:17: New connection from 172.30.32.2:52402 on port 1883.
2023-11-01 18:44:17: Client <unknown> closed its connection.
2023-11-01 18:46:17: New connection from 172.30.32.2:46734 on port 1883.
2023-11-01 18:46:17: Client <unknown> closed its connection.
2023-11-01 18:46:33: Client 36uMWSn7PBl6MfoIu2eWoh closed its connection.
2023-11-01 18:47:00: New connection from 172.30.32.1:41327 on port 1883.
2023-11-01 18:47:00: New client connected from 172.30.32.1:41327 as 4HbbJExOBpwGmVjFS5xeRO (p2, c1, k60, u'homeassistant').
2023-11-01 18:48:17: New connection from 172.30.32.2:40490 on port 1883.
2023-11-01 18:48:17: Client <unknown> closed its connection.
2023-11-01 18:50:17: New connection from 172.30.32.2:52592 on port 1883.
2023-11-01 18:50:17: Client <unknown> closed its connection.
2023-11-01 18:50:24: Client 4HbbJExOBpwGmVjFS5xeRO closed its connection.
2023-11-01 18:50:47: New connection from 172.30.32.1:37865 on port 1883.
2023-11-01 18:50:47: New client connected from 172.30.32.1:37865 as 5QFtCGNh4G81Win4Jb06f0 (p2, c1, k60, u'homeassistant').
2023-11-01 18:52:17: New connection from 172.30.32.2:52430 on port 1883.
2023-11-01 18:52:17: Client <unknown> closed its connection.
et voilà celui de Zigbee2MQTT :
[18:22:49] INFO: Preparing to start...
[18:22:50] INFO: Socat not enabled
[18:22:52] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-11-01 18:22:59: Logging to console and directory: '/config/zigbee2mqtt/log/2023-11-01.18-22-59' filename: log.txt
Zigbee2MQTT:info 2023-11-01 18:22:59: Starting Zigbee2MQTT version 1.33.1 (commit #unknown)
Zigbee2MQTT:info 2023-11-01 18:22:59: Starting zigbee-herdsman (0.19.0)
Zigbee2MQTT:info 2023-11-01 18:23:00: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2023-11-01 18:23:00: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:info 2023-11-01 18:23:00: Currently 0 devices are joined:
Zigbee2MQTT:info 2023-11-01 18:23:00: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2023-11-01 18:23:00: Connecting to MQTT server at mqtt://core-mosquitto
Zigbee2MQTT:info 2023-11-01 18:23:01: Connected to MQTT server
Zigbee2MQTT:info 2023-11-01 18:23:01: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload 'online'
Zigbee2MQTT:info 2023-11-01 18:23:01: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2023-11-01 18:23:01: MQTT publish: topic 'zigbee2mqtt/bridge/config', payload '{"commit":"unknown","coordinator":{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"},"log_level":"info","network":{"channel":11,"extendedPanID":"0x3b109baad7456ee3","panID":61828},"permit_join":false,"version":"1.33.1"}'
Zigbee2MQTT:info 2023-11-01 18:23:01: Zigbee2MQTT started!
Zigbee2MQTT:info 2023-11-01 18:33:12: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-11-01 18:33:33: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-11-01 18:33:45: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-11-01 18:34:14: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-11-01 18:34:18: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:34:18: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"b7u0l-1"}'
Zigbee2MQTT:info 2023-11-01 18:34:22: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-11-01 18:34:31: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-11-01 18:34:38: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:34:38: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"b7u0l-2"}'
Zigbee2MQTT:error 2023-11-01 18:34:50: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:34:50: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"b7u0l-3"}'
Zigbee2MQTT:error 2023-11-01 18:35:19: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:35:19: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"jvtqz-1"}'
Zigbee2MQTT:error 2023-11-01 18:35:27: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:35:27: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"jvtqz-2"}'
Zigbee2MQTT:error 2023-11-01 18:35:36: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:35:36: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"jvtqz-3"}'
Zigbee2MQTT:info 2023-11-01 18:36:24: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-11-01 18:37:29: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:37:29: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"5v579-1"}'
Zigbee2MQTT:info 2023-11-01 18:45:46: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-11-01 18:46:51: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:46:51: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"gpbuv-1"}'
Zigbee2MQTT:info 2023-11-01 18:50:09: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-11-01 18:51:14: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:51:14: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"5i1pq-1"}'
Zigbee2MQTT:info 2023-11-01 18:51:19: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-11-01 18:51:35: Zigbee: allowing new devices to join.
Zigbee2MQTT:info 2023-11-01 18:51:48: Zigbee: allowing new devices to join.
Zigbee2MQTT:error 2023-11-01 18:52:24: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:52:24: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"xfp4n-1"}'
Zigbee2MQTT:error 2023-11-01 18:52:41: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:52:41: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"xfp4n-2"}'
Zigbee2MQTT:error 2023-11-01 18:52:53: Request 'zigbee2mqtt/bridge/request/permit_join' failed with error: 'APS TIMEOUT'
Zigbee2MQTT:info 2023-11-01 18:52:53: MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{},"error":"APS TIMEOUT","status":"error","transaction":"e41j7-1"}'
@Barbotx : J’ai bien ZHA comme suggéré
@Nothing : J’ai déjà suivi ce tuto. Je viens de le suivre à nouveau en supprimant le étapes 1 et 3 comme indiqué par WarC0zes et du coup le module Z2M ne démarre pas du tout, c’est pour ça que j’avais les paramètres que j’avais dans mon premier post et ça fonctionnait avant le SSD
Voici le journal de Z2M avec le tuto que tu m’as donné :
[19:03:47] INFO: Preparing to start...
[19:03:47] INFO: Socat not enabled
[19:03:49] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-11-01 19:03:55: Logging to console and directory: '/config/zigbee2mqtt/log/2023-11-01.19-03-55' filename: log.txt
Zigbee2MQTT:info 2023-11-01 19:03:55: Starting Zigbee2MQTT version 1.33.1 (commit #unknown)
Zigbee2MQTT:info 2023-11-01 19:03:55: Starting zigbee-herdsman (0.19.0)
Zigbee2MQTT:error 2023-11-01 19:03:56: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-11-01 19:03:56: Failed to start zigbee
Zigbee2MQTT:error 2023-11-01 19:03:56: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-11-01 19:03:56: Exiting...
Zigbee2MQTT:error 2023-11-01 19:03:56: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2234130-if00'
at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/deconz/driver/driver.ts:200:28)
at SerialPort._error (/app/node_modules/@serialport/stream/dist/index.js:82:22)
at /app/node_modules/@serialport/stream/dist/index.js:118:18
