Alors comme l’on m’a suggéré dans un autre post en cas de soucis, j’ai,été voir dans les logs et voici,ce que j’ai
Sonoff/Ewelink
Détails du journal (ATTENTION)
Cette erreur provient d’une intégration personnalisée
Logger: custom_components.sonoff.core.ewelink.cloud
Source: custom_components/sonoff/core/ewelink/cloud.py:321
Integration: Sonoff (documentation, issues)
First occurred: 5 juin 2022 à 19:00:12 (4 occurrences)
Last logged: 03:30:50
Cloud WS Connection error: Cannot connect to host as-pconnect5.coolkit.cc:8080 ssl:True [SSLCertVerificationError: (1, « [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: Hostname mismatch, certificate is not valid for ‹ as-pconnect5.coolkit.cc ›. (_ssl.c:1129) »)]
Et Tuya
Logger: custom_components.localtuya.common
Source: custom_components/localtuya/pytuya/init.py:247
Integration: LocalTuya integration (documentation, issues)
First occurred: 08:08:43 (1 occurrences)
Last logged: 08:08:43
[eb6…tqz] Connect to 192.168.0.170 failed
File « /usr/local/lib/python3.9/asyncio/locks.py », line 417, in acquire
await fut
asyncio.exceptions.CancelledError
File « /usr/local/lib/python3.9/asyncio/tasks.py », line 490, in wait_for
return fut.result()
The above exception was the direct cause of the following exception:
File « /config/custom_components/localtuya/common.py », line 155, in _make_connection
status = await self._interface.status()
File « /config/custom_components/localtuya/pytuya/init.py », line 481, in status
status = await self.exchange(STATUS)
File « /config/custom_components/localtuya/pytuya/init.py », line 460, in exchange
msg = await self.dispatcher.wait_for(seqno)
File « /config/custom_components/localtuya/pytuya/init.py », line 247, in wait_for
await asyncio.wait_for(self.listeners[seqno].acquire(), timeout=timeout)
File « /usr/local/lib/python3.9/asyncio/tasks.py », line 492, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
