Ok donc ce que tu veux c’est que le 19.5 soit une valeur de HA …
Le premier noeud s’active quand la sonde envoie la température (info dans msg.payload)
Le deuxième lit la consigne (info dans msg.consigne)
Le troisième fait le test de comparaison de msg.payload <=> msg.consigne
Et le debug montre la construction du msg
[{"id":"214218271dc9e0cd","type":"server-state-changed","z":"767e42e9550f1957","name":"","server":"94a12356.a4a14","version":4,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"sensor.sonde_jardin_temperature","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"","halt_if_type":"str","halt_if_compare":"is","outputs":1,"output_only_on_state_change":true,"for":"0","forType":"num","forUnits":"minutes","ignorePrevStateNull":false,"ignorePrevStateUnknown":false,"ignorePrevStateUnavailable":false,"ignoreCurrentStateUnknown":false,"ignoreCurrentStateUnavailable":false,"outputProperties":[{"property":"payload","propertyType":"msg","value":"","valueType":"entityState"}],"x":240,"y":120,"wires":[["3f0057d920b7aac9","0346d2ad8e9c4724"]]},{"id":"3f0057d920b7aac9","type":"api-current-state","z":"767e42e9550f1957","name":"","server":"94a12356.a4a14","version":3,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","entity_id":"sensor.consigne_confort","state_type":"str","blockInputOverrides":false,"outputProperties":[{"property":"consigne","propertyType":"msg","value":"","valueType":"entityState"}],"for":"0","forType":"num","forUnits":"minutes","override_topic":false,"state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","x":450,"y":200,"wires":[["0346d2ad8e9c4724","fd637538d20376ce"]]},{"id":"0346d2ad8e9c4724","type":"debug","z":"767e42e9550f1957","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":770,"y":100,"wires":[]},{"id":"fd637538d20376ce","type":"switch","z":"767e42e9550f1957","name":"sup ou inf","property":"payload","propertyType":"msg","rules":[{"t":"lt","v":"consigne","vt":"msg"},{"t":"gt","v":"consigne","vt":"msg"}],"checkall":"true","repair":false,"outputs":2,"x":620,"y":280,"wires":[[],[]]},{"id":"94a12356.a4a14","type":"server","name":"Home Assistant","version":2,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open|1","connectionDelay":true,"cacheJson":true,"heartbeat":false,"heartbeatInterval":30}]
