Suivi du coût HC/HP dans le dashboard energy
J’ai mis en place des pinces ampermétrique Shelly pour suivre ma conso electrique.
Je suis en mode heure pleine / heure creuse et j’aurais souhaité pouvoir « donner » au dashboard energie le coût au kwh en fonction de l’heure et du jour (pour ma part je suis en HC de 1h30 à 7h30 et de 13h a 15 ainsi que les mercredi et weekend.
Et je ne sais pas du tout comment faire ça.
Un script ? un helper ?
[center]## System Information
version core-2022.8.4
hassio false
python_version 3.10.5
os_version 5.10.0-16-amd64
arch x86_64
GitHub API Calls Remaining 4982
Installed Version 1.26.2
Available Repositories 1198
Downloaded Repositories 17
logged_in true
subscription_expiration March 9, 2023 at 1:00 AM
relayer_connected true
remote_enabled true
remote_connected true
alexa_enabled false
google_enabled true
remote_server eu-central-1-4.ui.nabu.casa
dashboards 6
resources 8
views 9
oldest_recorder_run January 26, 2023 at 10:11 PM
current_recorder_run January 26, 2023 at 11:11 PM
estimated_db_size 530.57 MiB
database_version 3.38.5
Spotify
api_endpoint_reachable ok
[/center]
il vous faut mettre en place un utility meter
Home Assistant
Utility Meter
Instructions on how to integrate the Utility Meter into Home Assistant.
et plus particulierement la configuration avancée
Advanced Configuration
The following configuration shows an example where 2 utility_meters (daily_energy and monthly_energy) track daily and monthly energy consumptions.
Both track the same sensor (sensor.energy) which continuously monitors the energy consumed.
4 different sensors will be created, 2 per utility meter and corresponding to each tariff. Sensor sensor.daily_energy_peak, sensor.daily_energy_offpeak, sensor.monthly_energy_peak and sensor.monthly_energy_offpeak will automatically be created to track the consumption in each tariff for the given cycle.
The select.daily_energy and select.monthly_energy select entities will track the current tariff and allow changing the tariff.
utility_meter:
  daily_energy:
    source: sensor.energy
    cycle: daily
    tariffs:
      - peak
      - offpeak
  monthly_energy:
    cycle: monthly
    tariffs:
      - peak
      - offpeak
YAML
Copy
Assuming your energy provider tariffs are time based according to:
  • peak: from 06:08 to 12:38 and 15:38 to 01:08
  • offpeak: from 01:08 to 06:08 and 12:38 to 15:38
a time based automation can be used:
automation:
    - platform: time
      at: "01:08:00"
      variables:
        tariff: offpeak
    - platform: time
      at: "06:08:00"
      variables:
        tariff: peak
    - platform: time
      at: "12:38:00"
      variables:
        tariff: offpeak
    - platform: time
      at: "15:38:00"
      variables:
        tariff: peak
    - service: select.select_option
        entity_id: select.daily_energy
        option: "{{ tariff }}"
        entity_id: select.monthly_energy
vous aurez automatiquement une ségrégation des valeurs de consommation HP HC qui sera intégrable directement dans le module energy de HA
Merci pour ta réponse cela m’a bien aidé.
Voici ma conf qui semble super bien fonctionner :
Sachant que j’ai défini un Calendar de type helper avec les bon créneaux.
Pour que tout fonctionne j’ai fait un package :
configuration.yaml :
homeassistant:
  packages: !include_dir_named packages
packages/edf.yaml :
utility_meter:
  daily_energy:
    source: sensor.shellyem_production_consommation_channel_1_energy
    name: Consommation EDF - J
    cycle: daily
    tariffs:
      - HP
      - HC
  monthly_energy:
    name: Consommation EDF - M
    cycle: monthly
    tariffs:
      - HP
      - HC
automation:
  alias: "Heures Creuses - Heures Pleines"
    - platform: calendar
      event: start
      offset: 0:0:0
      entity_id: schedule.hc_schedule
      variables:
        tariff: "HC"
      event: stop
      offset: 0:0:0
      variables:
        tariff: "HP"
Cool je connaissais pas les packages ça va me plaire pour les split configuration
Bonjour @Joachim / @jrvrcd,
Je suis exactement dans le même cas, j’ai également un Shelly EM pour monitorer ma conso.
Depuis un certain temps, j’étais en tarif base mais je viens de passer en HP/HC. J’aimerai également pouvoir donner au dashboard énergie le coût du kwh. Après plusieurs recherches, de nombreuses personnes semblent utiliser 2 compteurs pour les coûts mais cela semble poser certains problèmes & je suis tombé sur votre discussion :).
J’essaye donc de mettre en place la solution proposée mais je ne comprends réellement comment intégrer les infos dans le dashboard énergie. Pouvez-vous m’éclairer SVP ?
Aujourd’hui, j’ai une config standard :
  • Conso. ENEDIS > sensor shelly em
  • Electricity Unit Price > sensor avec un prix renseigné dans le yaml
Que dois-je modifier ? Je ne vois pas comment utiliser le utility meter daily dans tout cela. J’ai certainement manqué quelque chose :(.
Merci pour votre aide !
si je comprends bien tu as un shelly qui monitore ta consommation
donc j’imagine qu’il te renvoie une puissance instantanée ( soit des Watts soit des Volts Amperes)
et avec un peu de bol un cumul d’ energie ( des Watts heure )
premier cas de figure
ton shelly ne te donne pas le cumul de l’energie. ( des wh ou des kwh)
il va falloir le calculer
tu vas faire cela avec un sensor de type integration
  - platform: integration
    source: sensor.shelly_power
    method: left
    unit_prefix: k
    unit_time: h
    round: 2
cette nouvelle entité va te « convertir » des watts ( qui est une valeur instantanée de puissance ) en energie ( qui est un cumul de cette puissance instantanée sur une durée donnée )
a partir de là que ton shelly te fournisse une consommation ou pas,
c’est la partie « commune » de ce principe
cette consommation ( que ce soit celle calculée ou celle fournie par ton shelly)
maintenant tu va devoir la « découper » en fonction de ton contrat en heure creuse et en heure pleine
pour ma part j’ai deux tranches horaires heure creuse et heure pleine
de 01:08 a 06:08
et de
12:38 a 15:38
c’est la qu’entre en jeu les « utility meter »
utility_meter:
  consommation_maison:
    source: sensor.consommation
    cycle: daily
    tariffs:
      - peak
      - offpeaks
automation:
- id: '1669997472702'
  alias: peak-offpeak
  description: ''
  - platform: time
    at: 01:08:00
    variables:
      tariff: offpeak
  - platform: time
    at: 06:08:00
    variables:
      tariff: peak
  - platform: time
    at: '12:38:00'
    variables:
      tariff: offpeak
  - platform: time
    at: '15:38:00'
    variables:
      tariff: peak
      entity_id: select.consommation_maison
      option: '{{ tariff }}'
tu auras deus nouvelles entitées
sensor.consommation_maison_offpeak
et
sensor.consommation_maison_peak
que tu mettras dans ta definition de dashboard energie
comme je suis branché directement a mon linky j’ai ça
tu n’as qu’a remplacer consommation_heure_pleine par consommation_maison_peek
et consommation_heure_creuse par consommation_maison_offpeek
elle est pas belle la vie ???
Un grand merci pour ces explications précises @jrvrcd !
C’était juste une incompréhension de ma part, c’est parfait !
J’ai simplement perdu l’historique de l’ancien mais ce n’est pas grave.
Merci @jrvrcd ça fonctionne parfaitement chez moi avec le Shelly EM Pro 50 qui a été ajouté dans l’intégration Shelly hier
c’est le but du forum
etre aidé et ensuite finir par aider
Je coince sur une chose. Dans l’es automatisation quel déclencheur prend tu ?
Peut tu nous montrer les déclencheur condition et action que tu a mise car je coince à ce niveau et étant pas encore pro de ha je bloque merci
le déclencheur est un ou un ensemble de condition horaire.
lorsque la condition est atteinte, la variable tariff se voit affecter respectivement la valeur peak ou offpeak
attention
dans l’automation c’est tarrif
et dans l’utility meter c’est tarrifs
tu as un deuxième exemple d’utilisation dans ce sujet là si cela peux t’aider
sinon la doc
Bonsoir,
Je m’exprime peut mal.
En faute je ne sait pas comment mettre ce code dans l’es automatisation tout simplement
automation:
  alias: peak-offpeak
  description: ''
  - platform: time
    at: 01:08:00
    variables:
      tariff: offpeak
  - platform: time
    at: 06:08:00
    variables:
      tariff: peak
  - platform: time
    at: '12:38:00'
    variables:
      tariff: offpeak
  - platform: time
    at: '15:38:00'
    variables:
      tariff: peak
SAlut
tu vas dans
parametres
automatisations et scenes
creer une automatisation
creer une nouvelle automatisation
et tu cliques sur les 3 petits points
et tu choisis l’option
modifier en YAML
et tu fait un copier coller du code.
ne pas oublier de valider et checker ton automation
dans
outils de développement
verifier la configuration
et recharger toute la configuration sui tu n’as pas de messages d’erreur
Si tu es un grand debutant
je t’invite a regarder des tutos en video sur youtube pour assimiler les bases principales
Bonjour à tous
J’ai une config qui fonctionne parfaitement pour les énergies. Par device, groupe,…
Le pannel energie fonctionne aussi parfaitement avec les utility meter (jour, semaine, mois…)
En revanche maintenant, je souhaiterais pouvoir avoir le cout par équipement et groupe pour en faire un dashboard et qui prenne en compte la période tarifaire en compte. (HP/HC)
A ce jour j’ai un template qui calcul le cout pour chaque période en temps réel mais il n’est pas sauvegardé en Long term statistiques. Pourquoi ? pour pouvoir faire des graphiques par rapport à la période précédente ! exemple comparer année et année n-1
Quelle est la meilleure manière de procéder ?
Je me demandais si il fallait refaire des utility meter pour les couts € ou garder le même template cout pat équipement et par période tarifaire mais avec un state_class total ?
L 'idée est aussi pouvoir modifier le tarif quand EDF change au 1er féfvrier par exemple. manuellement.
Bonjour Joachim
J’ai copié ton code dans le config.yaml je n’arrive pas à créer le « packages.yaml »
Merci jrvrcd,
Ça m’a débloqué, explications simples et limpides ! :slight_smile: :+1:
Bonjour jrvrcd,
J’ai quelques jours de recul après avoir implémenté mon code et j’ai « 0 KWh » dans heures creuses alors que c’est bon pour les heures pleines.
Je joins mon code pour qu’éventuellement tu vois ou est l’erreur ! :blush:
default_config:
frontend:
# automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
# Ajout
    source: sensor.home_power
    method: left
    unit_prefix: k
    unit_time: h
    round: 2
    source: sensor.generator_power
    method: left
    unit_prefix: k
    unit_time: h
    round: 2
utility_meter:
    cycle: daily
    tariffs:
      - HeuresPleines
      - HeuresCreuses
  consommation_maison_semaine:
    cycle: weekly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
  consommation_maison_mois:
    cycle: monthly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
  consommation_maison_trimestrielle:
    cycle: quarterly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
  consommation_maison_annee:
    cycle: yearly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
  production_solaire:
    source: sensor.production
    cycle: daily
    tariffs:
      - HeuresPleines2
      - HeuresCreuses2
  production_solaire_annuelle:
    cycle: yearly
    tariffs:
      - HeuresPleines2
      - HeuresCreuses2
automation:
  - id: "1669997472702"
    alias: peak-offpeak
    description: ""
      - platform: time
        at: 02:00:00
        variables:
          tariff: HeuresCreuses
      - platform: time
        at: 07:00:00
        variables:
          tariff: HeuresPleines
      - platform: time
        at: "14:00:00"
        variables:
      - platform: time
        at: "17:00:00"
        variables:
  - id: "188974720002"
    alias: peak-offpeak2
    description: ""
      - platform: time
        at: 02:00:00
        variables:
          tariff2: HeuresCreuses2
      - platform: time
        at: 07:00:00
        variables:
          tariff2: HeuresPleines2
      - platform: time
        at: "14:00:00"
        variables:
      - platform: time
        at: "17:00:00"
        variables:
          entity_id: select.production_solaire
          option: "{{ tariff2 }}"
Voici le resulat :
On voit que : consommation_maison_annee HeuresCreuses se tank à « 0.02 KWh » . J’avais remis ce compteur a Zero hier et il se bloque a 0.02 KWh… Comprend pas …
Bonjour @Sun,
utilise la balise texte préformaté ( icône image) quand tu colles du code dans un message.
Ça permet une meilleure visibilité, respecte les espaces et caractères.
J’ai modifier ton message.
default_config:
frontend:
# Ajout
    method: left
    unit_prefix: k
    unit_time: h
    round: 2
    method: left
    unit_prefix: k
    unit_time: h
    round: 2
utility_meter:
    cycle: daily
    tariffs:
      - HeuresPleines
      - HeuresCreuses
    cycle: weekly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
    cycle: monthly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
    cycle: quarterly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
    cycle: yearly
    tariffs:
      - HeuresPleines
      - HeuresCreuses
  production_solaire:
    cycle: daily
    tariffs:
      - HeuresPleines2
      - HeuresCreuses2
    cycle: yearly
    tariffs:
      - HeuresPleines2
      - HeuresCreuses2
automation:
    alias: peak-offpeak
    description: ""
      - platform: time
        at: 02:00:00
        variables:
      - platform: time
        at: 07:00:00
        variables:
      - platform: time
        at: "14:00:00"
        variables:
      - platform: time
        at: "17:00:00"
        variables:
    description: ""
      - platform: time
        at: 02:00:00
        variables:
      - platform: time
        at: 07:00:00
        variables:
      - platform: time
        at: "14:00:00"
        variables:
      - platform: time
        at: "17:00:00"
        variables:
Donc le code « formaté » :slight_smile:
