J’ai réussi a faire une pop up avec browser mod mais le soucie est que sur application mobile elle est en plein écran alors que sur pc elle se retrouve bien a la taille définie
je vous poste des photos sur pc et téléphone
type: horizontal-stack
cards:
- entity: switch.circulateur_plancher_chauffage_switch
type: custom:button-card
icon: mdi:radioactive-circle
show_last_changed: true
color: green
show_state: false
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
browser_id: THIS
style: |-
--popup-min-width: 400px;
--popup-max-width: 400px;
--popup-border-radius: 10px;
--popup-padding-y: -15px;
--popup-padding-x: 5px;
content:
type: custom:mini-graph-card
height: 40
show_state: false
hours_to_show: 24
points_per_hour: 60
update_interval: 30
aggregate_func: max
line_width: 1
smoothing: false
state_map:
- value: "off"
label: Arret
- value: "on"
label: Marche
state:
- value: "on"
color: rgb(41, 246, 31)
spin: true
- value: "off"
color: grey
- entity: switch.circulateur_chauffage_chauffage_switch
name: Circulateur Chauffage
color: green
show_state: false
tap_action:
action: more-info
state:
- value: "on"
spin: true
- value: "off"
color: grey
version
core-2024.10.1
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
user
root
virtualenv
false
python_version
3.12.4
os_name
Linux
os_version
6.6.46-haos
arch
x86_64
timezone
Europe/Paris
config_dir
/config
GitHub API
ok
GitHub Content
ok
GitHub Web
ok
HACS Data
ok
GitHub API Calls Remaining
5000
Installed Version
2.0.1
Stage
running
Available Repositories
1430
Downloaded Repositories
14
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
host_os
Home Assistant OS 13.1
update_channel
stable
supervisor_version
supervisor-2024.09.1
agent_version
1.6.0
docker_version
26.1.4
disk_total
30.8 GB
disk_used
11.3 GB
healthy
true
supported
true
host_connectivity
true
supervisor_connectivity
true
ntp_synchronized
true
virtualization
kvm
board
ova
supervisor_api
ok
version_api
ok
installed_addons
Node-RED (18.1.1), Get HACS (1.3.1), Linky (1.5.0), Studio Code Server (5.17.0)
dashboards
10
resources
12
views
36
mode
storage
oldest_recorder_run
28 septembre 2024 à 12:10
current_recorder_run
7 octobre 2024 à 11:26
estimated_db_size
1602.93 MiB
database_engine
sqlite
database_version
3.45.3
sujet déja évoquer, avec solution.
Hey! j’ai un problème depuis plusieurs mois, j’ai cherché un peu partout mais je ne vois pas du tout de solutions…
Sur desktop (chrome), j’ai mes popups qui s’affichent très bien:
[image]
Mais sur mobile (android companion), c’est limite en plein écran!
[image]
C’est un tout petit peu en train de me faire péter un plomb ^^
Evidemment, le code est identique, car le dashboard est commun à tous mes appareils. Et le « problème » ne dépend pas du thème que j’utilise. C’est idem ave…
j’ai essayer cette solution également mais cela ne fonctionne pas chez moi
en plus je ne peut pas a inspecter la page web sur l’application donc je ne trouve pas le chemin a modifier pour card mod
j’ai essayer de copier coller l’exemple mais sa ne fonctionne pas
cards:
color: green
show_state: false
tap_action:
browser_mod:
browser_id: THIS
style: |-
content:
height: 40
show_state: false
hours_to_show: 24
points_per_hour: 60
update_interval: 30
aggregate_func: max
line_width: 1
smoothing: false
state_map:
- value: "off"
label: Arret
- value: "on"
label: Marche
card_mod:
style: |
ha-dialog {
--mdc-dialog-min-height: fit-content !important;
--mdc-dialog-max-height: 180vw !important;
--mdc-dialog-min-width: 340px !important;
--mdc-dialog-max-width: 90vw !important;;
--ha-dialog-border-radius: var(--ha-card-border-radius) !important;
--vertical-align-dialog: center !important;
.content {
max-height: 90vh !important
pointer-events: unset !important;
.container {
padding: 4px 8px !important;
div.buttons {
padding: 8px !important;
state:
- value: "on"
spin: true
- value: "off"
color: grey
color: green
show_state: false
tap_action:
action: more-info
state:
- value: "on"
spin: true
- value: "off"
color: grey
un exemple :
tap_action:
browser_mod:
right_button: Fermer
right_button_action:
service: browser_mod.close_popup
browser_id: THIS
browser_id: THIS
card_mod:
style: |
ha-dialog {
--mdc-dialog-min-width: 90vw !important;
--mdc-dialog-max-width: var(--mdc-dialog-min-width) !important;
--mdc-dialog-max-height: var(--mdc-dialog-min-height) !important;
--header-height: 5vh !important;
--footer-height: var(--header-height) !important;
--padding-y: 8px !important;
-webkit-tap-highlight-color: rgba(0, 0, 0, 0) !important;
.content {
max-height: 95vh !important;
padding: 0 !important;
.container {
title: Liste course
style: "--popup-border-radius: 15px; "
content:
type: shopping-list
prends mon exemple et teste le telle qelle , en changant que la carte que tu veux afficher.
n’utilise pas le style de browser-mod
size sur fullscreen
Avec ton code cela fonctionne
je souhaiterait juste que soit un peut plus haute en dimension c’est tu quel paramètre faut modifier
j’ai essayer le
max-height: 95vh !important; a 150 mes cela ne change rien
Ca dépend ce que tu veux plus haut. Je viens de voir une erreur dans mon code, c’est vw et pas vh
teste ces lignes :
--mdc-dialog-min-height: 30vw !important;
--mdc-dialog-max-height: 65vw !important;
je vois pas trop sinon, j’ai un peu batailler pour faire le popup sur mobile.
