Bonjour à tous, je vous contacter aujourd’hui car j’ai un petit soucis avec mes télérupteurs Legrand connecté 412170
Lorsque je réinitialise mon télérupteur, il passe en mode appairage avec la led installation en rouge fixe.
Je lance la détection dans mon Z2M et il s’affiche correctement, il est reconnu et se configure.
Seulement, quelques secondes plus tard, il quitte le réseau et le télérupteur se réinitialise.
Et ça recommence… Détecté, reconfiguré, et il se réinitialise.
Voici les logs de ce qu’il se passe :
Debug 2024-01-07 19:16:28Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"m0dv6-1","value":true}'
Info 2024-01-07 19:16:28Zigbee: allowing new devices to join.
Info 2024-01-07 19:16:29MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"m0dv6-1"}'
Info 2024-01-07 19:16:31Device '0x0004740001241a63' joined
Info 2024-01-07 19:16:31MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740001241a63","ieee_address":"0x0004740001241a63"},"type":"device_joined"}'
Info 2024-01-07 19:16:31Starting interview of '0x0004740001241a63'
Info 2024-01-07 19:16:31MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740001241a63","ieee_address":"0x0004740001241a63","status":"started"},"type":"device_interview"}'
Debug 2024-01-07 19:16:31Device '0x0004740001241a63' announced itself
Info 2024-01-07 19:16:31MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740001241a63","ieee_address":"0x0004740001241a63"},"type":"device_announce"}'
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"modelId":" Teleruptor\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Skipping message, still interviewing
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":" Legrand\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000\u0000"}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"powerSource":1}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"zclVersion":2}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"appVersion":0}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"stackVersion":66}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"hwVersion":2}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"dateCode":" \u000020230911\u0000\u0000\u0000\u0000\u0000"}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:32Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"swBuildId":"0025"}' from endpoint 1 with groupID 0
Info 2024-01-07 19:16:32Successfully interviewed '0x0004740001241a63', device has successfully been paired
Info 2024-01-07 19:16:32Device '0x0004740001241a63' is supported, identified as: Legrand DIN smart relay for light control (412170)
Info 2024-01-07 19:16:32MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"DIN smart relay for light control","exposes":[{"features":[{"access":7,"description":"On/off state of the switch","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"On/off (works only if device is in \"switch\" mode)","label":"State","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"}],"type":"switch"},{"access":5,"description":"Instantaneous measured power","label":"Power","name":"power","property":"power","type":"numeric","unit":"W"},{"access":7,"description":"switch: allow on/off, auto will use wired action via C1/C2 on teleruptor with buttons","label":"Device mode","name":"device_mode","property":"device_mode","type":"enum","values":["switch","auto"]},{"access":1,"description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"412170","options":[{"access":2,"description":"Calibrates the power value (percentual offset), takes into effect on next report of device.","label":"Power calibration","name":"power_calibration","property":"power_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for power, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Power precision","name":"power_precision","property":"power_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"State actions will also be published as 'action' when true (default false).","label":"State action","name":"state_action","property":"state_action","type":"binary","value_off":false,"value_on":true}],"supports_ota":true,"vendor":"Legrand"},"friendly_name":"0x0004740001241a63","ieee_address":"0x0004740001241a63","status":"successful","supported":true},"type":"device_interview"}'
Info 2024-01-07 19:16:32Configuring '0x0004740001241a63'
Info 2024-01-07 19:16:32MQTT publish: topic 'homeassistant/switch/0x0004740001241a63/switch/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0x0004740001241a63/set","device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"name":null,"object_id":"0x0004740001241a63","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_switch_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
Info 2024-01-07 19:16:32MQTT publish: topic 'homeassistant/sensor/0x0004740001241a63/power/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"0x0004740001241a63_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Info 2024-01-07 19:16:33MQTT publish: topic 'homeassistant/sensor/0x0004740001241a63/device_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:tune","name":"Device mode","object_id":"0x0004740001241a63_device_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_device_mode_zigbee2mqtt","value_template":"{{ value_json.device_mode }}"}'
Info 2024-01-07 19:16:33MQTT publish: topic 'homeassistant/select/0x0004740001241a63/device_mode/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0x0004740001241a63/set/device_mode","device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"entity_category":"config","icon":"mdi:tune","name":"Device mode","object_id":"0x0004740001241a63_device_mode","options":["switch","auto"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_device_mode_zigbee2mqtt","value_template":"{{ value_json.device_mode }}"}'
Info 2024-01-07 19:16:33MQTT publish: topic 'homeassistant/sensor/0x0004740001241a63/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0x0004740001241a63_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Info 2024-01-07 19:16:33MQTT publish: topic 'homeassistant/sensor/0x0004740001241a63/update_state/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"0x0004740001241a63_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Info 2024-01-07 19:16:33MQTT publish: topic 'homeassistant/binary_sensor/0x0004740001241a63/update_available/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"0x0004740001241a63_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Info 2024-01-07 19:16:33MQTT publish: topic 'homeassistant/update/0x0004740001241a63/update/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/0x0004740001241a63","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/0x0004740001241a63","name":null,"object_id":"0x0004740001241a63","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x0004740001241a63\"}","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/switch/0x0004740001241a63/switch/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0x0004740001241a63/set","device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"name":null,"object_id":"0x0004740001241a63","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"payload_off":"OFF","payload_on":"ON","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_switch_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/sensor/0x0004740001241a63/power/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"device_class":"power","enabled_by_default":true,"entity_category":"diagnostic","object_id":"0x0004740001241a63_power","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_power_zigbee2mqtt","unit_of_measurement":"W","value_template":"{{ value_json.power }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/sensor/0x0004740001241a63/device_mode/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:tune","name":"Device mode","object_id":"0x0004740001241a63_device_mode","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_device_mode_zigbee2mqtt","value_template":"{{ value_json.device_mode }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/select/0x0004740001241a63/device_mode/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/0x0004740001241a63/set/device_mode","device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"entity_category":"config","icon":"mdi:tune","name":"Device mode","object_id":"0x0004740001241a63_device_mode","options":["switch","auto"],"origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_device_mode_zigbee2mqtt","value_template":"{{ value_json.device_mode }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/sensor/0x0004740001241a63/linkquality/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","name":"Linkquality","object_id":"0x0004740001241a63_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/sensor/0x0004740001241a63/update_state/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:update","name":"Update state","object_id":"0x0004740001241a63_update_state","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_update_state_zigbee2mqtt","value_template":"{{ value_json['update']['state'] }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/binary_sensor/0x0004740001241a63/update_available/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"device_class":"update","enabled_by_default":false,"entity_category":"diagnostic","name":null,"object_id":"0x0004740001241a63_update_available","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"payload_off":false,"payload_on":true,"state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_update_available_zigbee2mqtt","value_template":"{{ value_json['update']['state'] == \"available\" }}"}'
Debug 2024-01-07 19:16:33Received MQTT message on 'homeassistant/update/0x0004740001241a63/update/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state","value_template":"{{ value_json.state }}"}],"command_topic":"zigbee2mqtt/bridge/request/device/ota_update/update","device":{"identifiers":["zigbee2mqtt_0x0004740001241a63"],"manufacturer":"Legrand","model":"DIN smart relay for light control (412170)","name":"0x0004740001241a63","sw_version":"0025","via_device":"zigbee2mqtt_bridge_0x00124b002c3ac33e"},"device_class":"firmware","entity_category":"config","entity_picture":"https://github.com/Koenkk/zigbee2mqtt/raw/master/images/logo.png","json_attributes_template":"{\"in_progress\": {{ iif(value_json['update']['state'] == 'updating', 'true', 'false') }} }","json_attributes_topic":"zigbee2mqtt/0x0004740001241a63","latest_version_template":"{{ value_json['update']['latest_version'] }}","latest_version_topic":"zigbee2mqtt/0x0004740001241a63","name":null,"object_id":"0x0004740001241a63","origin":{"name":"Zigbee2MQTT","sw":"1.35.1","url":"https://www.zigbee2mqtt.io"},"payload_install":"{\"id\": \"0x0004740001241a63\"}","state_topic":"zigbee2mqtt/0x0004740001241a63","unique_id":"0x0004740001241a63_update_zigbee2mqtt","value_template":"{{ value_json['update']['installed_version'] }}"}'
Debug 2024-01-07 19:16:33Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'haElectricalMeasurement', data '{"acCurrentMultiplier":0,"acVoltageDivisor":0,"acVoltageMultiplier":0}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:33Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'haElectricalMeasurement', data '{"acCurrentDivisor":0,"acPowerDivisor":1,"acPowerMultiplier":1}' from endpoint 1 with groupID 0
Info 2024-01-07 19:16:33Successfully configured '0x0004740001241a63'
Debug 2024-01-07 19:16:33Received Zigbee message from '0x0004740001241a63', type 'readResponse', cluster 'genBasic', data '{"dateCode":" \u000020230911\u0000\u0000\u0000\u0000\u0000"}' from endpoint 1 with groupID 0
Debug 2024-01-07 19:16:43Received Zigbee message from '0x0004740001241a63', type 'read', cluster 'genBasic', data '[61440]' from endpoint 1 with groupID 0
Warning 2024-01-07 19:16:43Device '0x0004740001241a63' left the network
Info 2024-01-07 19:16:43MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x0004740001241a63","ieee_address":"0x0004740001241a63"},"type":"device_leave"}'
Debug 2024-01-07 19:16:44Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"m0dv6-2","value":false}'
Dans la documentation officielle (ici) le voyant d’installation est censé passer au vert lorsque l’appareillage est terminé mais au lieu de ça il se réinitialise.
J’ai fait quelques recherche sur le sujet, et j’ai fait quelques tests :
J’utilise un dongle SONOFF ZigBee 3.0 USB Dongle Plus, EFR32MG21 Coordinator. Il semblerait que se soit une version encore expérimentale et que ça puisse venir de là le soucis (Commentaire ici).
J’ai donc acheté une clé SONOFF ZigBee 3.0 USB Dongle Plus, TI CC2652P Coordinator et j’ai réinitialisé mon Z2M => Même problème. -
Je me suis dit c’est peut-être Z2M qui pose soucis, j’ai donc désactivé Z2M et j’ai ajouté l’intégration ZHA, et là il me fait la meme chose : Configuration, leave configuration… au bout d’un moment, ZHA à réussi à valider l’appairage (pour une raison que j’ignore) et par contre, la LED d’installation sur mon télérupteur est passé au violet. A ce stade, j’avais mes entitées connectée, le controle avec HA et mes boutons poussoir. Donc résultat voulu sauf : La led devrait être verte, pourquoi est-elle violette ^^ impossible de trouver l’information.
J’ai supprimé mes entité et l’intégration de ZHA et j’ai remis Z2M pour essayer à nouveau, après 1h de tests d’appairage, rien y fait Z2M n’arrive pas a garder l’appairage (ou le télérupteur refuse l’appairage). -
Je vais devoir acheter un kit starter pour espérer mettre à jour mes télérupteurs pour espérer que le soucis se règle
mais j’aimerais éviter de dépenser autant d’argent dans un module que je n’utiliserais pas au risque que ça ne fonctionne toujours pas derrière. -
J’ai mis un commentaire sur GitHub car il semblerait qu’il y a un soucis avec l’appairage :
Regression on pairing some Legrand devices with v1.35.0 (was somewhat working on 1.34.0) · Issue #20617 · Koenkk/zigbee2mqtt · GitHub
Est-ce que l’un d’entre vous pourrait essayer de m’aider à debug tout ça ? J’aimerais vraiement que ça fonctionne sachant que je viens d’installer 25 télérupteurs legrand chez moi, se serait dommage que je ne puisse pas les connecter à HA
et je comprend pas comment ZHA arrive à finaliser l’appairage (parfois) et pas Z2M ![]()
Je vous remercie infiniment. Si besoin de plus d’information, je suis dispo.
En attendant, je remet ma clé V2 EFR32MG21 ![]()
- Infos supplémentaire :
Canal de ma conf Zigbee : 11
| version | core-2024.1.2 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.11.6 |
| os_name | Linux |
| os_version | 6.1.63-haos-raspi |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| Installed Version | 1.33.0 |
| Stage | running |
| Available Repositories | 1370 |
| Downloaded Repositories | 1 |
| HACS Data | ok |
| logged_in | true |
| subscription_expiration | 1 janvier 2018 à 01:00 |
| relayer_connected | false |
| relayer_region | null |
| remote_enabled | true |
| remote_connected | false |
| alexa_enabled | false |
| google_enabled | true |
| remote_server | null |
| certificate_status | null |
| instance_id | 1ecf62b54d904d7c8fc1bdd4b640426e |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 11.3 |
| update_channel | stable |
| supervisor_version | supervisor-2023.12.0 |
| agent_version | 1.6.0 |
| docker_version | 24.0.7 |
| disk_total | 13.5 GB |
| disk_used | 6.5 GB |
| healthy | true |
| supported | true |
| board | rpi4-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Let’s Encrypt (5.0.9), File editor (5.7.0), Zigbee2MQTT (1.35.1-1), Mosquitto broker (6.4.0), Terminal & SSH (9.8.1), NGINX Home Assistant SSL proxy (3.6.0), Studio Code Server (5.15.0), ESPHome (dev) (dev) |
| dashboards | 1 |
| resources | 0 |
| views | 1 |
| mode | storage |
| oldest_recorder_run | 28 décembre 2023 à 23:22 |
| current_recorder_run | 7 janvier 2024 à 17:10 |
| estimated_db_size | 4.51 MiB |
| database_engine | sqlite |
| database_version | 3.41.2 |
