Bonjour, ayant une installation delta avec une tydom, j’essaye d’utiliser mqtt2tydom.
mais je bataille un peu … installation de mqtt d’un coté et de mqtt2tydom de l’autre.
sous mqtt2tydom j’ai le message suivant
STARTING TYDOM2MQTT
Dectecting environnement......
/data/options.json detected ! Hassio Addons Environnement : parsing options.json....
{'TYDOM_MAC': '001A2XXXXXXXX', 'TYDOM_IP': '192.168.0.10', 'TYDOM_PASSWORD': 'XXXXX', 'TYDOM_ALARM_PIN': 123456, 'TYDOM_ALARM_HOME_ZONE': 1, 'TYDOM_ALARM_NIGHT_ZONE': 2, 'MQTT_HOST': 'localhost', 'MQTT_USER': 'jppmqtt', 'MQTT_PASSWORD': 'jppmqtt', 'MQTT_PORT': 1883, 'MQTT_SSL': False, 'log_level': 'info'}
Initialising TydomClient Class
Setting local mode context.
Starting main loop_task
Attempting MQTT connection...
MQTT host : localhost
MQTT user : jppmqtt
Subscribing to : +/tydom/#
TYDOM WEBSOCKET CONNECTION INITIALISING....
Building headers, getting 1st handshake and authentication....
Upgrading http connection to websocket....
Attempting websocket connection with tydom hub.......................
Host Target :
192.168.0.10
Task exception was never retrieved
future: <Task finished name='Task-5' coro=<listen_tydom_forever() done, defined at /opt/tydom2mqtt/main.py:104> exception=InvalidMessage('did not receive a valid HTTP response')>
File "/usr/lib/python3.8/site-packages/websockets/client.py", line 101, in read_http_response
status_code, reason, headers = await read_response(self.reader)
File "/usr/lib/python3.8/site-packages/websockets/http.py", line 160, in read_response
headers = await read_headers(stream)
File "/usr/lib/python3.8/site-packages/websockets/http.py", line 188, in read_headers
raise ValueError(f"invalid HTTP header line: {d(line)}") from None
ValueError: invalid HTTP header line: realm="Protected Area",
The above exception was the direct cause of the following exception:
File "/opt/tydom2mqtt/main.py", line 113, in listen_tydom_forever
await tydom_client.connect()
File "/opt/tydom2mqtt/tydomConnector.py", line 120, in connect
self.connection = await websockets.client.connect('wss://{}:443/mediation/client?mac={}&appli=1'.format(self.host, self.mac),
File "/usr/lib/python3.8/site-packages/websockets/client.py", line 542, in __await_impl__
await protocol.handshake(
File "/usr/lib/python3.8/site-packages/websockets/client.py", line 290, in handshake
status_code, response_headers = await self.read_http_response()
File "/usr/lib/python3.8/site-packages/websockets/client.py", line 103, in read_http_response
raise InvalidMessage("did not receive a valid HTTP response") from exc
websockets.exceptions.InvalidMessage: did not receive a valid HTTP response
Starting /opt/tydom2mqtt/main.py
Quelqu’un a une idée de l’erreur ? pas clair pour moi ![]()
Merci à tous.
