dans la doc hass-browser_mod/popups.md at master · thomasloven/hass-browser_mod · GitHub
exemple:
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.popup
browser_id: THIS
style: |-
--popup-border-width: 0px;
content:
Galadan
Février 27, 2023, 12:40
103
J’ai essayé mais cela ne fonctionne pas, tu peux me dire ou tu met cette partie stp?
### Card Graph Custom ###
custom_card_temperature:
triggers_update: "all"
styles:
grid:
- grid-template-areas: "'item1' 'item2' 'item3'"
- grid-template-columns: "1fr"
- grid-template-rows: "min-content min-content"
card:
- border-radius: "var(--border-radius)"
- box-shadow: "var(--box-shadow)"
- padding: "0px"
custom_fields:
item1:
card:
type: "custom:button-card"
template:
- "card_title"
name: "[[[ return variables.ulm_card_graph_title ]]]"
item2:
card:
name: "[[[ return variables.ulm_card_graph_name ]]]"
template:
- "icon_info_bg"
styles:
icon:
- color: "[[[ return variables.ulm_card_graph_color ]]]"
img_cell:
- background-color: "[[[ return variables.ulm_card_graph_background_color ]]]"
card:
- box-shadow: "none"
- border-radius: "var(--border-radius) var(--border-radius) 0px 0px"
- padding: "10px"
label:
- align-self: "center"
- font-size: "14px"
entity: "[[[ return variables.ulm_card_graph_entity ]]]"
label: |
return states[variables.ulm_card_graph_entity].state + "°";
tap_action:
browser_mod:
content:
type: "custom:mini-graph-card"
template:
- "icon_info_bg"
- entity: "[[[ return variables.ulm_card_graph_entity ]]]"
line_color: >
var col = [];
col.push(variables.ulm_card_graph_color);
return col;
show:
icon: true
legend: true
state: true
extrema: true
graph: "[[[ return variables.ulm_card_graph_type=='fill'?'line':variables.ulm_card_graph_type; ]]]"
fill: "[[[ return variables.ulm_card_graph_type=='fill'?true:false; ]]]"
hours_to_show: "[[[ return variables.ulm_card_graph_hours; ]]]"
hour24: true
style: |
ha-card .header.flex .icon {
color: rgba(255,0,0,1);
background: rgba(255,0,0,0.20);
border-radius: 50px;
padding: 10px;
item3:
card:
name: "[[[ return variables.ulm_card_graph_name_2 ]]]"
template:
- "icon_info_bg"
styles:
icon:
- color: "rgba(66,133,244, 1)"
img_cell:
- background-color: "rgba(66,133,244, 0.20)"
card:
- padding: "10px"
label:
- font-size: "14px"
entity: "[[[ return variables.ulm_card_graph_entity_2 ]]]"
label: |
return states[variables.ulm_card_graph_entity_2].state + "%";
tap_action:
browser_mod:
content:
template:
- "icon_info_bg"
- entity: "[[[ return variables.ulm_card_graph_entity_2 ]]]"
line_color: >
var col = [];
col.push(variables.ulm_card_graph_color_2);
return col;
show:
icon: true
legend: true
state: true
extrema: true
hour24: true
style: |
color: rgba(66,133,244, 1);
background: rgba(66,133,244, 0.20);
padding: 10px;
Ok, c’est bien ce que j’avais fait, mais pas de changement …
J’ai tester et ca fonctionne pas, il y a un bug avec la carte mini graph si je me souviens bien.
Faut contourner avec la carte popup-card.
Lit a partir de mon post Utilisation de Browser_mod - #51 par WarC0zes
et @Herbs explique comment mettre ca en place avec de jolie gif.
avec popup-card c’est sur que ca fonctionne car j’utilise bien popup-border-width:
- type: custom:popup-card
entity: sensor.processor_temperature
style: |-
--popup-border-radius: 10px;
--popup-background-color: transparent;
--popup-min-width: 500px;
--popup-max-width: 600px;
card:
type: custom:mini-graph-card
name: CPU Température
height: 101
hours_to_show: 24
points_per_hour: 2
hour24: true
line_width: 6
show:
fill: true
graph: line
icon: true
state: true
labels: false
extrema: true
average: true
icon_adaptive_color: true
- entity: sensor.processor_temperature
align_icon: right
align_state: center
font_size: 100
animate: true
card_mod:
style: |
color: rgb(31, 111, 235);
--mdc-icon-size: 37px;
.fill {
fill: white;
opacity: 1 !important;
Galadan
Février 28, 2023, 12:42
107
Merci ton aide, j’ai essayé mais je suis pas sur de faire ce qu’il faut.
Comment le lien est effectué entre l’appuie sur une des données et l’ouverture de la popup qui doit lui être associé?
Le lien s’effectue par rapport a l’entité que tu utilise. J’avoue pas facile a comprendre au début.
Dans mon exemple, j’utilise bar-card pour l’entité sensor.processor_use. Quand tu clique sur la bar, sa ouvre le popup du mini-graph.
entity: sensor.processor_use #c'est l'entité qui fait le lien.
exemple:
- type: vertical-stack
cards:
- type: horizontal-stack
cards:
- type: custom:bar-card
- entity: sensor.processor_use #entité utilisé
icon: phu:intel-cpu
color: rgb(68, 115, 158)
height: 27px
min: '0'
max: '100'
target: '90'
positions:
indicator: 'off'
style: |
ha-card {
top: -31px;
margin-top: -20px;
margin-left: -15px;
margin-right: -5px;
bar-card-currentbar, bar-card-backgroundbar {
border-radius: 4px;
ha-icon {
--mdc-icon-size: 30px;
bar-card-name {
margin: 2px;
entity: sensor.processor_use # entité qui fait le lien
style: |-
card:
icon: phu:intel-cpu
height: 101
hours_to_show: 24
points_per_hour: 2
hour24: true
line_width: 3
show:
fill: true
graph: line
icon: true
state: true
labels: false
extrema: true
average: true
align_icon: right
align_state: center
line_color: rgb(68, 115, 158)
font_size: 100
animate: true
card_mod:
style: |
--mdc-icon-size: 40px;
.fill {
fill: white;
BBE
Février 28, 2023, 4:56
109
Comme te l’indique @WarC0zes c’est dans la definition de la popup card que tu indiques à quelle entité elle va se substituer au pop-up « plus d’info ».
la carte popup-card va ensuite être affichée à la place de la fenêtre « plus d’info » de l’entité associée.
Tu peux donc définir plusieurs popup-card, tant que tu changes d’entité à chaque fois (une pour la température, une pour l’humidité par exemple)
BBE
Février 28, 2023, 6:38
111
Oui mais toi tu as mis un exemple complet !
Merci @WarC0zes et @BBE pour les infos et explications!!
Hello, pas de solution pour centré les popup ??
si tu rajoute ça à ton thème ça devrait faire le taf:
card-mod-more-info-yaml: |
ha-dialog {
--vertical-align-dialog: center !important;
Sinon depuis la dernière update de HA mes tap_action sont à l’ouest.
Avant ceci fonctionnait parfaitement :
tap_action:
action: call-service
service: switch.turn_off
data: {}
entity_id: switch.adguard_home_filtering
J’ai loupé quelque chose ?
Je confirme j’ai ce genre de comportement. J’ai plein de boutons qui ne marchent plus bien
Cubeez
Juillet 14, 2023, 3:11
118
J’ai un souci sur mes mushroom-card. Je précise que j’avais réussi à le faire, mais que je n’ai plus le code yaml correspondant…
J’ai donc des panneaux avec mes différentes ampoules :
Je possède 2 ampoules dites « Suspensions » et idem pour les « Appliques ». Lorsque je clique sur « Suspensions » par exemple, j’ai une fenêtre pop-up générée avec browser_mod qui apparait dans laquelle j’ai accès à mes 2 ampoules.
Et là arrive le problème. Lorsque j’appuie sur « Suspension G » ou « D », il est censé apparaître le panneau de contrôle des lumières comme cela :
J’ai testé dans une card à part et tout fonctionne bien, mais c’est lorsque je la combine dans mon panneau avec la commande browser_mod que cela ne fonctionne pas. Impossible d’allumer les ampoules…
Je vous joint le code complet du panneau qui comprend celui des pop-up en espérant que quelqu’un puisse m’aider.
cards:
- type: custom:mushroom-light-card
entity: light.mijia_group4_5120_light
layout: vertical
primary_info: name
secondary_info: none
icon: mdi:lightbulb-group
double_tap_action:
action: none
hold_action:
service: light.turn_off
entity_id:
- light.yeelink_color5_ec44_light
- light.yeelink_color5_a6e3_light
data: {}
tap_action:
browser_mod:
content:
cards:
entity: light.yeelink_color5_ec44_light
layout: vertical
primary_info: name
icon: mdi:lightbulb-variant
double_tap_action:
action: none
hold_action:
action: more-info
collapsible_controls: true
show_color_temp_control: true
show_color_control: true
show_brightness_control: true
tap_action:
service: light.toggle
entity_id: light.yeelink_color5_ec44_light
kelvin: 3500
brightness_pct: 80
use_light_color: true
entity: light.yeelink_color5_a6e3_light
layout: vertical
primary_info: name
double_tap_action:
action: none
hold_action:
action: more-info
tap_action:
entity_id: light.yeelink_color5_a6e3_light
kelvin: 3500
brightness_pct: 80
entity: light.mijia_group4_1232_light
layout: vertical
primary_info: name
double_tap_action:
action: none
hold_action:
entity_id:
- light.yeelink_color5_f52d_light
- light.yeelink_color5_fe26_light
tap_action:
browser_mod:
content:
cards:
entity: light.yeelink_color5_f52d_light
layout: vertical
primary_info: name
double_tap_action:
action: none
hold_action:
action: more-info
tap_action:
entity_id: light.yeelink_color5_f52d_light
kelvin: 3500
brightness_pct: 80
use_light_color: false
entity: light.yeelink_color5_fe26_light
layout: vertical
primary_info: name
double_tap_action:
action: none
hold_action:
action: more-info
tap_action:
entity_id: light.yeelink_color5_fe26_light
kelvin: 3500
brightness_pct: 80
entity: light.yeelink_color5_af10_light
layout: vertical
primary_info: name
double_tap_action:
action: none
hold_action:
action: more-info
tap_action:
entity_id: light.yeelink_color5_af10_light
kelvin: 4000
brightness_pct: 65
entity: light.yeelink_color5_64f1_light
layout: vertical
primary_info: name
double_tap_action:
action: none
hold_action:
action: more-info
tap_action:
entity_id: light.yeelink_color5_64f1_light
kelvin: 6000
brightness_pct: 80
- type: custom:mushroom-chips-card
chips:
- type: entity
entity: person.jonathan
double_tap_action:
action: none
icon: mdi:location-exit
content_info: name
hold_action:
action: none
tap_action:
action: navigate
navigation_path: /dashboard-home/0
- type: entity
double_tap_action:
action: none
content_info: name
icon: mdi:lightbulb-auto-outline
hold_action:
action: none
- type: action
double_tap_action:
action: none
icon: mdi:lightbulb-group-off-outline
tap_action:
entity_id:
- light.yeelink_color5_af10_light
- light.yeelink_color5_64f1_light
data: {}
hold_action:
action: none
Guizmos
Juillet 19, 2023, 12:08
119
C’est revenu à la normal avec la dernière update.
J’ai cependant encore des bug sous iOS ou mon popup est présent sur tout l’écran alors qu’auparavant celle-ci était de la taille d’une card classique:
Idem sur Android, pop-up qui prend tout l’écran depuis la MAJ browser_mod.
Kyar
Août 15, 2023, 3:17
121
J’aimerais afficher une carte avec un tap_action mais je n’arrive pas à faire ce que je veux.
J’aimerais :
type: custom:mushroom-vacuum-card
entity: vacuum.roborock_s5_max
icon_animation: true
fill_container: false
commands:
- start_pause
- stop
- clean_spot
- return_home
tap_action: null
à partir d’ici, afficher ceci :
type: custom:xiaomi-vacuum-map-card
map_source:
camera: camera.roborock_s5
calibration_source:
camera: true
language: fr
debug: true
vacuum_platform: default
map_locked: true
two_finger_pan: false
map_modes:
- template: vacuum_clean_zone
- template: vacuum_goto
- template: vacuum_clean_segment
predefined_selections:
- id: '16'
icon:
x: 27675
'y': 23450
label:
text: Chambre
x: 27675
'y': 23450
offset_y: 35
outline:
- - 25950
- 21800
- - 29400
- 21800
- - 29400
- 25100
- - 25950
- 25100
- id: '17'
icon:
x: 23350
'y': 22350
label:
text: Salle de bain
x: 23350
'y': 22350
offset_y: 35
outline:
- - 22600
- 21550
- - 24100
- 21550
- - 24100
- 23150
- - 22600
- 23150
- id: '18'
icon:
x: 26300
'y': 22325
label:
text: Couloir
x: 26300
'y': 22325
offset_y: 35
outline:
- - 24150
- 20400
- - 28450
- 20400
- - 28450
- 24250
- - 24150
- 24250
- id: '20'
icon:
x: 30375
'y': 22850
label:
text: Bureau
x: 30375
'y': 22850
offset_y: 35
outline:
- - 28500
- 20650
- - 32250
- 20650
- - 32250
- 25050
- - 28500
- 25050
- id: '21'
icon:
x: 25175
'y': 27100
label:
text: Salon
x: 25175
'y': 27100
offset_y: 35
outline:
- - 22250
- 24300
- - 28100
- 24300
- - 28100
- 29900
- - 22250
- 29900
Je coince à force de supprimer refaire
