Wanfr
Avril 1, 2021, 8:56
1
Bonsoir,
System Health
version
core-2021.3.4
installation_type
Home Assistant OS
dev
false
hassio
true
docker
true
virtualenv
false
python_version
3.8.7
os_name
Linux
os_version
5.4.83-v8
arch
aarch64
timezone
Europe/Paris
GitHub API
ok
Github API Calls Remaining
4870
Installed Version
1.11.3
Stage
running
Available Repositories
778
Installed Repositories
21
logged_in
false
can_reach_cert_server
ok
can_reach_cloud_auth
ok
can_reach_cloud
ok
Hass.io
host_os
Home Assistant OS 5.12
update_channel
stable
supervisor_version
supervisor-2021.03.6
docker_version
19.03.13
disk_total
116.7 GB
disk_used
16.0 GB
healthy
true
supported
true
board
rpi4-64
supervisor_api
ok
version_api
ok
installed_addons
Samba share (9.3.1), Terminal & SSH (9.1.0), Mosquitto broker (5.1.1), ADB - Android Debug Bridge (0.7.0), deCONZ (6.8.0), InfluxDB (4.0.3), Grafana (6.2.0), Node-RED (8.2.1), Let’s Encrypt (4.11.0), ESPHome (1.16.2), Samba Backup (4.5.0), File editor (5.2.0), SSH & Web Terminal (8.1.0), Visual Studio Code (3.3.0), Z-Wave JS to MQTT (0.9.1)
Lovelace
dashboards
7
resources
14
views
21
mode
storage
Apparemment mon Z-Wave JS to MQTT ne démarre pas, il reste bloqué à cette étape :
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] configuration.sh: executing...
[cont-init.d] configuration.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:44:04] INFO: Starting the Z-Wave JS to MQTT...
______ _ ___ _ _
|___ / (_) |__ \ | | | |
/ /_ ____ ___ _____ _ ___ ) |_ __ ___ __ _| |_| |_
/ /\ \ /\ / / _` \ \ / / _ \ / __| / /| '_ ` _ \ / _` | __| __|
/ /__\ V V / (_| |\ V / __/ \__ \/ /_| | | | | | (_| | |_| |_
/_____|\_/\_/ \__,_| \_/ \___| |___/____|_| |_| |_|\__, |\__|\__|
_/ | | |
|__/ |_|
2021-04-01 22:44:04.651 WARN STORE: scenes.json not found
/bin/sh: git: not found
2021-04-01 22:44:07.383 INFO APP: Version: 3.0.3
2021-04-01 22:44:07.385 INFO APP: Application path:/opt
[22:44:08] INFO: Starting NGinx...
Donc impossible de démarrer mon intégration avec URL :
ws://a0d7b954_zwavejs2mqtt:3000
j’ai chaque fois « erreur connexion »
Une idée ?
C’est dommage d’avoir supprimé l’aide à la rédaction d’une demande d’aide car il manque toute la partie concernant ton installation…
Merci de la mettre
Wanfr
Avril 1, 2021, 9:40
3
Bonsoir
C’est corrigé
Je viens de voir une erreur dans l’interface gui
Driver: Failed to initialize the driver: Timeout while waiting for an ACK from the controller
Moi j’ai le même problème que j’ai écrit dans une autre post sans réponse …
https://forum.hacf.fr/t/z-wave-vs-openzwave-vs-z-wave-js/2731/31
Je viens de te répondre. Le pb de @Wanfr ne semble pas tout à fait le même.
Wanfr
Avril 2, 2021, 8:37
6
Alors on est deux à attendre une solution…
Tu n’as rien dans le log après ça?
Wanfr
Avril 2, 2021, 10:48
8
Salut @MoPepettes
j’ai trouvé un sujet sur reedit similaire et on solutionné avec un reboot du pi.
J’ai rebooter le pi mais rien de mieux…
A priori, oui le log s’arrête là.
Mais je n’en suis pas sur car je travaille toujours sur mon installation et donc j’ai redémarré plusieurs fois ces dernier jours, là dernier démarrage et rien de puis 12h40 il est 13h16
[12:40:37] INFO: Starting NGinx...
Wanfr
Avril 2, 2021, 11:46
9
re
Voila la suite, car au dernier reboot j’ai mis le log sur « error » :
Terminated
[13:21:30] DEBUG: Requested API resource: http://supervisor/discovery
[13:21:30] DEBUG: Request method: POST
[13:21:30] DEBUG: Request data: {"service":"zwave_js","config":{"host":"a0d7b954-zwavejs2mqtt","port":3000}}
[13:21:30] DEBUG: API HTTP Response code: 200
[13:21:30] DEBUG: API Response: {"result": "ok", "data": {"uuid": "e83da70ef4024b0d8a5d8b898a2bc7e5"}}
[13:21:30] DEBUG: Filtering response using: .uuid
[13:21:31] INFO: Successfully send discovery information to Home Assistant.
Toujours erreur driver:
et WS inaccessible
Coupe (ou désinstalle) zwjs2mqtt et zwjs puis essaye openzwave. Regarde si ton stick répond mieux. Si c’est le cas, c’est ton installation de zwjs + zwjs2mqtt qui pose soucis. Si ton stick ne répond toujours pas à openzwave, alors c’et ton stick ou ton pi (ou éventuellement le core HA).
Wanfr
Avril 2, 2021, 1:15
11
Re
Je veux bien essayer Openzwave, mais pour l’avoir essayer depuis que l’intégration zwave est déconseillée, je n’ai jamais réussi à le faire fonctionner…
A suivre…
Wanfr
Avril 2, 2021, 7:17
12
Re
Je ne saurai dire après quoi parce que je redémarre j'essaye....
Openzwave je ne suis arrivé à rien, comme chaque fois que j'ai essayé....
Mais le message dans le log de Zwavejs2MQTT a changer :
______ _ ___ _ _
_/ | | |
|__/ |_|
2021-04-02 19:10:53.832 WARN STORE: scenes.json not found
2021-04-02 19:10:56.472 INFO APP: Version: 3.0.3
2021-04-02 19:10:56.474 INFO APP: Application path:/opt
Logging to file:
/data/store/zwavejs_359.log
Terminated
[session-file-store] Deleting expired sessions
au cas où, voila ma config:
J'avoue que je suis un peu perdu, le couple Z-waveJS intégration et add-ons fonctionne mais mal et même très mal, et le couple Z-wave JS et Z-waveJSMQTT ne fonctionne pas !
En tant qu’utilisateur z-wave j'avoue que c'est pénible....
Pozzi
Avril 3, 2021, 4:39
13
Ton Serial port est bon ?
Tu dois le voir dans Supervisor > System > Host > (les 3 petits points) > Matériels
Le driver fait référence à la clé USB.
Wanfr
Avril 3, 2021, 4:44
14
Bonjour @Pozzi
Voila mon serial :
- name: ttyUSB0
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.2/1-1.3.2:1.0/ttyUSB0/tty/ttyUSB0
dev_path: /dev/ttyUSB0
subsystem: tty
by_id: >-
/dev/serial/by-id/usb-Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001-if00-port0
attributes:
DEVLINKS: >-
/dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.2:1.0-port0
DEVNAME: /dev/ttyUSB0
DEVPATH: >-
ID_BUS: usb
ID_MODEL: CP2102_USB_to_UART_Bridge_Controller
ID_MODEL_ENC: CP2102\x20USB\x20to\x20UART\x20Bridge\x20Controller
ID_MODEL_ID: ea60
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.2:1.0'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_2_1_0
ID_REVISION: '0100'
ID_SERIAL: Silicon_Labs_CP2102_USB_to_UART_Bridge_Controller_0001
ID_SERIAL_SHORT: '0001'
ID_TYPE: generic
ID_USB_DRIVER: cp210x
ID_USB_INTERFACES: ':ff0000:'
ID_USB_INTERFACE_NUM: '00'
ID_VENDOR: Silicon_Labs
ID_VENDOR_ENC: Silicon\x20Labs
ID_VENDOR_ID: 10c4
MAJOR: '188'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '543027328'
J’ai essayé la version longue
et la version courte
/dev/ttyUSB0
Aucune ne fonctionne, mais je dirai que la version longue me semble mieux…
Pozzi
Avril 3, 2021, 4:59
15
Quelle clé ZWave utilises tu ? La marque et model ?
Wanfr
Avril 3, 2021, 6:51
16
re
Aeotec Z-Stick Gen5 sur une rallonge USB de 50cm sur un hub USB 3 auto-alimenté sur le port USB 2 du pi puisque ce dernier aime pas trop USB 3
Sur le même hub j’ai une clé Combee II aussi sur une rallonge de 50cm dans le sens opposé
Le réseau zigbee fonctionne bien et avant mes essai le z-wave aussi.
Car ce que j’ai fait je ne l’ai pas encore dit :
Je fonctionnais ni mal ni bien avec Z-waveJS add-on et intégration, mais beaucoup de post sur le net disent que on a plus d’options et de réglages avec le couple Z-waveJS2MQTT et Z-waveJS.
Alors, même si j’ai écrit le contraire, j’ai tous désinstallé et redémarre HA puis j’ai installé Z-waveJS2MQTT et depuis plus rien…
J’ai même essaye un retour, openz-wave, et rien ne fonctionne…
Je ne sus pas chez moi et je fait donc tout à distance et je pense qu’après tout ces test et l’avis de @MoPepettes il doit falloir une intervention physique, mais je suis pas chez moi avant mercredi…
Merci à vous
Pozzi
Avril 3, 2021, 8:03
17
Si tu es sur RPi, tu devrais plutôt avoir /dev/ttyACM0 ou /dev/ttyACM1 pour tes clés USB.
L’un doit être pris avec la Conbee (par ex /dev/ttyACM0) donc l’autre sera ta clé ZWave (donc /dev/ttyACM1).
Les 2 doivent exister dans la liste des matériels, et pour bien faire il faut utiliser le by_id.
Wanfr
Avril 3, 2021, 8:09
18
re @Pozzi
Voila le log entier, confirme ton idée car c’est peut être là mon erreur…
devices:
- name: usb1
sysfs: >-
dev_path: /dev/bus/usb/001/001
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/001
DEVNUM: '001'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0
ID_MODEL: xHCI_Host_Controller
ID_MODEL_ENC: xHCI\x20Host\x20Controller
ID_MODEL_ID: '0002'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0'
ID_REVISION: '0504'
ID_SERIAL: 'Linux_5.4.83-v8_xhci-hcd_xHCI_Host_Controller_0000:01:00.0'
ID_SERIAL_SHORT: '0000:01:00.0'
ID_USB_INTERFACES: ':090000:'
ID_VENDOR: Linux_5.4.83-v8_xhci-hcd
ID_VENDOR_ENC: Linux\x205.4.83-v8\x20xhci-hcd
ID_VENDOR_ID: 1d6b
MAJOR: '189'
MINOR: '0'
OF_COMPATIBLE_N: '0'
OF_FULLNAME: '/scb/pcie@7d500000/pci@1,0/usb@1,0'
OF_NAME: usb
PRODUCT: 1d6b/2/504
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/1
USEC_INITIALIZED: '3008957'
- name: 1-1
sysfs: >-
dev_path: /dev/bus/usb/001/002
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/002
DEVNUM: '002'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1
ID_MODEL: USB2.0_Hub
ID_MODEL_ENC: USB2.0\x20Hub
ID_MODEL_ID: '3431'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1'
ID_REVISION: '0421'
ID_SERIAL: 2109_USB2.0_Hub
ID_VENDOR: '2109'
ID_VENDOR_ENC: '2109'
ID_VENDOR_ID: '2109'
MAJOR: '189'
MINOR: '1'
PRODUCT: 2109/3431/421
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/1
USEC_INITIALIZED: '3017718'
- name: 1-1.4
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4
dev_path: /dev/bus/usb/001/003
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/003
DEVNUM: '003'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_4
ID_MODEL: SSK_Storage
ID_MODEL_ENC: SSK\x20Storage
ID_MODEL_ID: '0562'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_4
ID_REVISION: 0209
ID_SERIAL: SSK_SSK_Storage_DD564198838B8
ID_SERIAL_SHORT: DD564198838B8
ID_USB_INTERFACES: ':080650:080662:'
ID_VENDOR: SSK
ID_VENDOR_ENC: SSK
ID_VENDOR_ID: 152d
MAJOR: '189'
MINOR: '2'
PRODUCT: 152d/562/209
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 0/0/0
USEC_INITIALIZED: '3035811'
- name: sda
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda
dev_path: /dev/sda
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0'
attributes:
DEVLINKS: >-
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0
DEVNAME: /dev/sda
DEVPATH: >-
DEVTYPE: disk
ID_BUS: usb
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_TABLE_TYPE: gpt
ID_PART_TABLE_UUID: 2052bde1-125d-4d7d-9c0a-e7a9a5f06345
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_4_1_0-scsi-0_0_0_0
ID_REVISION: 0209
ID_SERIAL: 'SSK_SSK_Storage_DD564198838B8-0:0'
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ENC: SSK\x20\x20\x20\x20\x20
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '0'
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3161799'
- name: sda1
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda1
dev_path: /dev/sda1
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part1'
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-boot /dev/disk/by-partlabel/hassos-boot
/dev/disk/by-partuuid/b3dd0952-733c-4c88-8cba-cab9b8b4377f
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part1
/dev/disk/by-uuid/1225-9DDE
DEVNAME: /dev/sda1
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_FS_LABEL: hassos-boot
ID_FS_LABEL_ENC: hassos-boot
ID_FS_TYPE: vfat
ID_FS_USAGE: filesystem
ID_FS_UUID: 1225-9DDE
ID_FS_UUID_ENC: 1225-9DDE
ID_FS_VERSION: FAT16
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_DISK: '8:0'
ID_PART_ENTRY_NAME: hassos-boot
ID_PART_ENTRY_NUMBER: '1'
ID_PART_ENTRY_OFFSET: '2048'
ID_PART_ENTRY_SCHEME: gpt
ID_PART_ENTRY_SIZE: '65536'
ID_PART_ENTRY_TYPE: e3c9e316-0b5c-4db8-817d-f92df00215ae
ID_PART_ENTRY_UUID: b3dd0952-733c-4c88-8cba-cab9b8b4377f
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '1'
PARTN: '1'
PARTNAME: hassos-boot
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3369437'
- name: sda2
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda2
dev_path: /dev/sda2
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part2'
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-kernel /dev/disk/by-partlabel/hassos-kernel0
/dev/disk/by-partuuid/26700fc6-b0bc-4ccf-9837-ea1a4cba3e65
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part2
/dev/disk/by-uuid/47fc80e2-8a22-4a2e-88e7-7b6c3ff30c44
DEVNAME: /dev/sda2
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_FS_LABEL: hassos-kernel
ID_FS_LABEL_ENC: hassos-kernel
ID_FS_TYPE: ext4
ID_FS_UUID: 47fc80e2-8a22-4a2e-88e7-7b6c3ff30c44
ID_FS_UUID_ENC: 47fc80e2-8a22-4a2e-88e7-7b6c3ff30c44
ID_FS_VERSION: '1.0'
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-kernel0
ID_PART_ENTRY_NUMBER: '2'
ID_PART_ENTRY_OFFSET: '67584'
ID_PART_ENTRY_SIZE: '49152'
ID_PART_ENTRY_TYPE: 0fc63daf-8483-4772-8e79-3d69d8477de4
ID_PART_ENTRY_UUID: 26700fc6-b0bc-4ccf-9837-ea1a4cba3e65
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '2'
PARTN: '2'
PARTNAME: hassos-kernel0
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3356333'
- name: sda3
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda3
dev_path: /dev/sda3
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part3'
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-system0
/dev/disk/by-partuuid/8d3d53e3-6d49-4c38-8349-aff6859e82fd
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part3
DEVNAME: /dev/sda3
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_FS_TYPE: squashfs
ID_FS_VERSION: '4.0'
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-system0
ID_PART_ENTRY_NUMBER: '3'
ID_PART_ENTRY_OFFSET: '116736'
ID_PART_ENTRY_SIZE: '524288'
ID_PART_ENTRY_UUID: 8d3d53e3-6d49-4c38-8349-aff6859e82fd
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '3'
PARTN: '3'
PARTNAME: hassos-system0
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3363105'
- name: sda4
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda4
dev_path: /dev/sda4
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part4'
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-kernel /dev/disk/by-partlabel/hassos-kernel1
/dev/disk/by-partuuid/fc02a4f0-5350-406f-93a2-56cbed636b5f
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part4
/dev/disk/by-uuid/213a2785-28a8-4e3d-92e9-51f1804d990f
DEVNAME: /dev/sda4
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_FS_TYPE: ext4
ID_FS_UUID: 213a2785-28a8-4e3d-92e9-51f1804d990f
ID_FS_UUID_ENC: 213a2785-28a8-4e3d-92e9-51f1804d990f
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-kernel1
ID_PART_ENTRY_NUMBER: '4'
ID_PART_ENTRY_OFFSET: '641024'
ID_PART_ENTRY_UUID: fc02a4f0-5350-406f-93a2-56cbed636b5f
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '4'
PARTN: '4'
PARTNAME: hassos-kernel1
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3318249'
- name: sda5
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda5
dev_path: /dev/sda5
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part5'
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-system1
/dev/disk/by-partuuid/a3ec664e-32ce-4665-95ea-7ae90ce9aa20
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part5
DEVNAME: /dev/sda5
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-system1
ID_PART_ENTRY_NUMBER: '5'
ID_PART_ENTRY_OFFSET: '690176'
ID_PART_ENTRY_UUID: a3ec664e-32ce-4665-95ea-7ae90ce9aa20
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '5'
PARTN: '5'
PARTNAME: hassos-system1
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3346195'
- name: sda6
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda6
dev_path: /dev/sda6
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part6'
attributes:
DEVLINKS: >-
/dev/disk/by-partlabel/hassos-bootstate
/dev/disk/by-partuuid/33236519-7f32-4dff-8002-3390b62c309d
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part6
DEVNAME: /dev/sda6
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-bootstate
ID_PART_ENTRY_NUMBER: '6'
ID_PART_ENTRY_OFFSET: '1214464'
ID_PART_ENTRY_SIZE: '16384'
ID_PART_ENTRY_UUID: 33236519-7f32-4dff-8002-3390b62c309d
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '6'
PARTN: '6'
PARTNAME: hassos-bootstate
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3228857'
- name: sda7
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda7
dev_path: /dev/sda7
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part7'
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-overlay /dev/disk/by-partlabel/hassos-overlay
/dev/disk/by-partuuid/f1326040-5236-40eb-b683-aaa100a9afcf
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part7
/dev/disk/by-uuid/3b4e0307-c8c9-4bd3-8507-0621d90e3e45
DEVNAME: /dev/sda7
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_FS_LABEL: hassos-overlay
ID_FS_LABEL_ENC: hassos-overlay
ID_FS_TYPE: ext4
ID_FS_UUID: 3b4e0307-c8c9-4bd3-8507-0621d90e3e45
ID_FS_UUID_ENC: 3b4e0307-c8c9-4bd3-8507-0621d90e3e45
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-overlay
ID_PART_ENTRY_NUMBER: '7'
ID_PART_ENTRY_OFFSET: '1230848'
ID_PART_ENTRY_SIZE: '196608'
ID_PART_ENTRY_UUID: f1326040-5236-40eb-b683-aaa100a9afcf
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '7'
PARTN: '7'
PARTNAME: hassos-overlay
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3302020'
- name: sda8
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/block/sda/sda8
dev_path: /dev/sda8
subsystem: block
by_id: '/dev/disk/by-id/usb-SSK_SSK_Storage_DD564198838B8-0:0-part8'
attributes:
DEVLINKS: >-
/dev/disk/by-label/hassos-data /dev/disk/by-partlabel/hassos-data
/dev/disk/by-partuuid/a52a4597-fa3a-4851-aefd-2fbe9f849079
/dev/disk/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-scsi-0:0:0:0-part8
/dev/disk/by-uuid/7b3a4805-2fb6-4e32-9d77-a066347d3e72
DEVNAME: /dev/sda8
DEVPATH: >-
DEVTYPE: partition
ID_BUS: usb
ID_FS_LABEL: hassos-data
ID_FS_LABEL_ENC: hassos-data
ID_FS_TYPE: ext4
ID_FS_UUID: 7b3a4805-2fb6-4e32-9d77-a066347d3e72
ID_FS_UUID_ENC: 7b3a4805-2fb6-4e32-9d77-a066347d3e72
ID_INSTANCE: '0:0'
ID_MODEL_ID: '0562'
ID_PART_ENTRY_NAME: hassos-data
ID_PART_ENTRY_NUMBER: '8'
ID_PART_ENTRY_OFFSET: '1427456'
ID_PART_ENTRY_SIZE: '248642191'
ID_PART_ENTRY_UUID: a52a4597-fa3a-4851-aefd-2fbe9f849079
ID_REVISION: 0209
ID_TYPE: disk
ID_USB_DRIVER: uas
ID_VENDOR: SSK
ID_VENDOR_ID: 152d
MAJOR: '8'
MINOR: '8'
PARTN: '8'
PARTNAME: hassos-data
SUBSYSTEM: block
TAGS: ':systemd:'
USEC_INITIALIZED: '3419077'
- name: '0:0:0:0'
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.4/1-1.4:1.0/host0/target0:0:0/0:0:0:0/bsg/0:0:0:0
dev_path: '/dev/bsg/0:0:0:0'
subsystem: bsg
by_id: null
attributes:
DEVNAME: '/dev/bsg/0:0:0:0'
DEVPATH: >-
MAJOR: '248'
MINOR: '0'
SUBSYSTEM: bsg
- name: usb2
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb2
dev_path: /dev/bus/usb/002/001
subsystem: usb
by_id: null
attributes:
BUSNUM: '002'
DEVNAME: /dev/bus/usb/002/001
DEVNUM: '001'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_MODEL_ID: '0003'
ID_REVISION: '0504'
ID_VENDOR_ID: 1d6b
MAJOR: '189'
MINOR: '128'
OF_NAME: usb
PRODUCT: 1d6b/3/504
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/3
USEC_INITIALIZED: '2999751'
- name: media1
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/bcm2835-codec/media1
dev_path: /dev/media1
subsystem: media
by_id: null
attributes:
DEVNAME: /dev/media1
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-codec/media1
MAJOR: '251'
MINOR: '1'
SUBSYSTEM: media
- name: video10
sysfs: >-
/sys/devices/platform/soc/fe00b840.mailbox/bcm2835-codec/video4linux/video10
dev_path: /dev/video10
subsystem: video4linux
by_id: null
attributes:
DEVLINKS: /dev/v4l/by-path/platform-bcm2835-codec-video-index0
DEVNAME: /dev/video10
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-codec/video4linux/video10
ID_PATH: platform-bcm2835-codec
ID_PATH_TAG: platform-bcm2835-codec
ID_V4L_CAPABILITIES: ':'
ID_V4L_PRODUCT: bcm2835-codec-decode
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '4'
SUBSYSTEM: video4linux
USEC_INITIALIZED: '3187142'
- name: video11
sysfs: >-
/sys/devices/platform/soc/fe00b840.mailbox/bcm2835-codec/video4linux/video11
dev_path: /dev/video11
by_id: null
attributes:
DEVNAME: /dev/video11
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-codec/video4linux/video11
ID_V4L_PRODUCT: bcm2835-codec-encode
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '5'
USEC_INITIALIZED: '3188163'
- name: video12
sysfs: >-
/sys/devices/platform/soc/fe00b840.mailbox/bcm2835-codec/video4linux/video12
dev_path: /dev/video12
by_id: null
attributes:
DEVNAME: /dev/video12
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-codec/video4linux/video12
ID_V4L_PRODUCT: bcm2835-codec-isp
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '6'
USEC_INITIALIZED: '3193150'
- name: media0
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/bcm2835-isp/media0
dev_path: /dev/media0
subsystem: media
by_id: null
attributes:
DEVNAME: /dev/media0
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-isp/media0
MAJOR: '251'
MINOR: '0'
SUBSYSTEM: media
- name: video13
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video13
dev_path: /dev/video13
by_id: null
attributes:
DEVLINKS: /dev/v4l/by-path/platform-bcm2835-isp-video-index0
DEVNAME: /dev/video13
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video13
ID_PATH: platform-bcm2835-isp
ID_PATH_TAG: platform-bcm2835-isp
ID_V4L_CAPABILITIES: ':video_output:'
ID_V4L_PRODUCT: bcm2835-isp
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '0'
USEC_INITIALIZED: '3166105'
- name: video14
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video14
dev_path: /dev/video14
by_id: null
attributes:
DEVLINKS: /dev/v4l/by-path/platform-bcm2835-isp-video-index1
DEVNAME: /dev/video14
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video14
ID_V4L_CAPABILITIES: ':capture:'
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '1'
USEC_INITIALIZED: '3161465'
- name: video15
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video15
dev_path: /dev/video15
by_id: null
attributes:
DEVLINKS: /dev/v4l/by-path/platform-bcm2835-isp-video-index2
DEVNAME: /dev/video15
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video15
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '2'
USEC_INITIALIZED: '3180764'
- name: video16
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video16
dev_path: /dev/video16
by_id: null
attributes:
DEVLINKS: /dev/v4l/by-path/platform-bcm2835-isp-video-index3
DEVNAME: /dev/video16
DEVPATH: /devices/platform/soc/fe00b840.mailbox/bcm2835-isp/video4linux/video16
ID_V4L_VERSION: '2'
MAJOR: '81'
MINOR: '3'
USEC_INITIALIZED: '3192658'
- name: pcmC0D0p
sysfs: >-
/sys/devices/platform/soc/fe00b840.mailbox/bcm2835_audio/sound/card0/pcmC0D0p
dev_path: /dev/snd/pcmC0D0p
subsystem: sound
by_id: null
attributes:
DEVNAME: /dev/snd/pcmC0D0p
DEVPATH: >-
DEVTYPE: pcm
MAJOR: '116'
MINOR: '2'
SUBSYSTEM: sound
- name: controlC0
sysfs: >-
/sys/devices/platform/soc/fe00b840.mailbox/bcm2835_audio/sound/card0/controlC0
dev_path: /dev/snd/controlC0
subsystem: sound
by_id: null
attributes:
DEVLINKS: /dev/snd/by-path/platform-bcm2835_audio
DEVNAME: /dev/snd/controlC0
DEVPATH: >-
ID_PATH: platform-bcm2835_audio
ID_PATH_TAG: platform-bcm2835_audio
MAJOR: '116'
MINOR: '3'
SUBSYSTEM: sound
SYSTEMD_USER_WANTS: sound.target
SYSTEMD_WANTS: sound.target
TAGS: ':systemd:'
USEC_INITIALIZED: '3146550'
- name: vchiq
sysfs: /sys/devices/platform/soc/fe00b840.mailbox/vchiq/vchiq
dev_path: /dev/vchiq
subsystem: vchiq
by_id: null
attributes:
DEVNAME: /dev/vchiq
DEVPATH: /devices/platform/soc/fe00b840.mailbox/vchiq/vchiq
MAJOR: '242'
MINOR: '0'
SUBSYSTEM: vchiq
- name: watchdog
sysfs: /sys/devices/platform/soc/fe100000.watchdog/bcm2835-wdt/misc/watchdog
dev_path: /dev/watchdog
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/watchdog
DEVPATH: /devices/platform/soc/fe100000.watchdog/bcm2835-wdt/misc/watchdog
MAJOR: '10'
MINOR: '130'
SUBSYSTEM: misc
- name: watchdog0
sysfs: /sys/devices/platform/soc/fe100000.watchdog/bcm2835-wdt/watchdog/watchdog0
dev_path: /dev/watchdog0
subsystem: watchdog
by_id: null
attributes:
DEVNAME: /dev/watchdog0
DEVPATH: /devices/platform/soc/fe100000.watchdog/bcm2835-wdt/watchdog/watchdog0
MAJOR: '249'
MINOR: '0'
SUBSYSTEM: watchdog
- name: gpiochip0
sysfs: /sys/devices/platform/soc/fe200000.gpio/gpiochip0
dev_path: /dev/gpiochip0
subsystem: gpio
by_id: null
attributes:
DEVNAME: /dev/gpiochip0
DEVPATH: /devices/platform/soc/fe200000.gpio/gpiochip0
MAJOR: '254'
MINOR: '0'
OF_COMPATIBLE_0: 'brcm,bcm2711-gpio'
OF_COMPATIBLE_N: '1'
OF_FULLNAME: /soc/gpio@7e200000
OF_NAME: gpio
SUBSYSTEM: gpio
- name: ttyAMA0
sysfs: /sys/devices/platform/soc/fe201000.serial/tty/ttyAMA0
dev_path: /dev/ttyAMA0
subsystem: tty
by_id: null
attributes:
DEVLINKS: /dev/serial1
DEVNAME: /dev/ttyAMA0
DEVPATH: /devices/platform/soc/fe201000.serial/tty/ttyAMA0
MAJOR: '204'
MINOR: '64'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '3073693'
- name: gpiochip1
sysfs: '/sys/devices/platform/soc/soc:firmware/soc:firmware:gpio/gpiochip1'
dev_path: /dev/gpiochip1
subsystem: gpio
by_id: null
attributes:
DEVNAME: /dev/gpiochip1
DEVPATH: '/devices/platform/soc/soc:firmware/soc:firmware:gpio/gpiochip1'
MAJOR: '254'
MINOR: '1'
OF_COMPATIBLE_0: 'raspberrypi,firmware-gpio'
OF_FULLNAME: /soc/firmware/gpio
OF_NAME: gpio
SUBSYSTEM: gpio
- name: vcio
sysfs: /sys/devices/virtual/bcm2708_vcio/vcio
dev_path: /dev/vcio
subsystem: bcm2708_vcio
by_id: null
attributes:
DEVNAME: /dev/vcio
DEVPATH: /devices/virtual/bcm2708_vcio/vcio
MAJOR: '246'
MINOR: '0'
SUBSYSTEM: bcm2708_vcio
- name: gpiomem
sysfs: /sys/devices/virtual/bcm2835-gpiomem/gpiomem
dev_path: /dev/gpiomem
subsystem: bcm2835-gpiomem
by_id: null
attributes:
DEVNAME: /dev/gpiomem
DEVPATH: /devices/virtual/bcm2835-gpiomem/gpiomem
MAJOR: '245'
MINOR: '0'
SUBSYSTEM: bcm2835-gpiomem
- name: 'linux,cma'
sysfs: '/sys/devices/virtual/dma_heap/linux,cma'
dev_path: '/dev/dma_heap/linux,cma'
subsystem: dma_heap
by_id: null
attributes:
DEVNAME: '/dev/dma_heap/linux,cma'
DEVPATH: '/devices/virtual/dma_heap/linux,cma'
MAJOR: '253'
MINOR: '1'
SUBSYSTEM: dma_heap
- name: system
sysfs: /sys/devices/virtual/dma_heap/system
dev_path: /dev/dma_heap/system
subsystem: dma_heap
by_id: null
attributes:
DEVNAME: /dev/dma_heap/system
DEVPATH: /devices/virtual/dma_heap/system
MAJOR: '253'
MINOR: '0'
SUBSYSTEM: dma_heap
- name: mice
sysfs: /sys/devices/virtual/input/mice
dev_path: /dev/input/mice
subsystem: input
by_id: null
attributes:
DEVNAME: /dev/input/mice
DEVPATH: /devices/virtual/input/mice
MAJOR: '13'
MINOR: '63'
SUBSYSTEM: input
- name: full
sysfs: /sys/devices/virtual/mem/full
dev_path: /dev/full
subsystem: mem
by_id: null
attributes:
DEVMODE: '0666'
DEVNAME: /dev/full
DEVPATH: /devices/virtual/mem/full
MAJOR: '1'
MINOR: '7'
SUBSYSTEM: mem
- name: kmsg
sysfs: /sys/devices/virtual/mem/kmsg
dev_path: /dev/kmsg
subsystem: mem
by_id: null
attributes:
DEVMODE: '0644'
DEVNAME: /dev/kmsg
DEVPATH: /devices/virtual/mem/kmsg
MAJOR: '1'
MINOR: '11'
SUBSYSTEM: mem
- name: mem
sysfs: /sys/devices/virtual/mem/mem
dev_path: /dev/mem
subsystem: mem
by_id: null
attributes:
DEVNAME: /dev/mem
DEVPATH: /devices/virtual/mem/mem
MAJOR: '1'
MINOR: '1'
SUBSYSTEM: mem
- name: 'null'
sysfs: /sys/devices/virtual/mem/null
dev_path: /dev/null
subsystem: mem
by_id: null
attributes:
DEVMODE: '0666'
DEVNAME: /dev/null
DEVPATH: /devices/virtual/mem/null
MAJOR: '1'
MINOR: '3'
SUBSYSTEM: mem
- name: port
sysfs: /sys/devices/virtual/mem/port
dev_path: /dev/port
subsystem: mem
by_id: null
attributes:
DEVNAME: /dev/port
DEVPATH: /devices/virtual/mem/port
MAJOR: '1'
MINOR: '4'
SUBSYSTEM: mem
- name: random
sysfs: /sys/devices/virtual/mem/random
dev_path: /dev/random
subsystem: mem
by_id: null
attributes:
DEVMODE: '0666'
DEVNAME: /dev/random
DEVPATH: /devices/virtual/mem/random
MAJOR: '1'
MINOR: '8'
SUBSYSTEM: mem
- name: urandom
sysfs: /sys/devices/virtual/mem/urandom
dev_path: /dev/urandom
subsystem: mem
by_id: null
attributes:
DEVMODE: '0666'
DEVNAME: /dev/urandom
DEVPATH: /devices/virtual/mem/urandom
MAJOR: '1'
MINOR: '9'
SUBSYSTEM: mem
- name: zero
sysfs: /sys/devices/virtual/mem/zero
dev_path: /dev/zero
subsystem: mem
by_id: null
attributes:
DEVMODE: '0666'
DEVNAME: /dev/zero
DEVPATH: /devices/virtual/mem/zero
MAJOR: '1'
MINOR: '5'
SUBSYSTEM: mem
- name: autofs
sysfs: /sys/devices/virtual/misc/autofs
dev_path: /dev/autofs
subsystem: misc
by_id: null
attributes:
DEVMODE: '0644'
DEVNAME: /dev/autofs
DEVPATH: /devices/virtual/misc/autofs
MAJOR: '10'
MINOR: '235'
SUBSYSTEM: misc
- name: cachefiles
sysfs: /sys/devices/virtual/misc/cachefiles
dev_path: /dev/cachefiles
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/cachefiles
DEVPATH: /devices/virtual/misc/cachefiles
MAJOR: '10'
MINOR: '62'
SUBSYSTEM: misc
- name: cpu_dma_latency
sysfs: /sys/devices/virtual/misc/cpu_dma_latency
dev_path: /dev/cpu_dma_latency
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/cpu_dma_latency
DEVPATH: /devices/virtual/misc/cpu_dma_latency
MAJOR: '10'
MINOR: '61'
SUBSYSTEM: misc
- name: fuse
sysfs: /sys/devices/virtual/misc/fuse
dev_path: /dev/fuse
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/fuse
DEVPATH: /devices/virtual/misc/fuse
MAJOR: '10'
MINOR: '229'
SUBSYSTEM: misc
- name: hw_random
sysfs: /sys/devices/virtual/misc/hw_random
dev_path: /dev/hwrng
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/hwrng
DEVPATH: /devices/virtual/misc/hw_random
MAJOR: '10'
MINOR: '183'
SUBSYSTEM: misc
- name: kvm
sysfs: /sys/devices/virtual/misc/kvm
dev_path: /dev/kvm
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/kvm
DEVPATH: /devices/virtual/misc/kvm
MAJOR: '10'
MINOR: '232'
SUBSYSTEM: misc
- name: loop-control
sysfs: /sys/devices/virtual/misc/loop-control
dev_path: /dev/loop-control
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/loop-control
DEVPATH: /devices/virtual/misc/loop-control
MAJOR: '10'
MINOR: '237'
SUBSYSTEM: misc
- name: rfkill
sysfs: /sys/devices/virtual/misc/rfkill
dev_path: /dev/rfkill
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/rfkill
DEVPATH: /devices/virtual/misc/rfkill
MAJOR: '10'
MINOR: '242'
SUBSYSTEM: misc
SYSTEMD_WANTS: systemd-rfkill.socket
TAGS: ':systemd:'
USEC_INITIALIZED: '3150664'
- name: tun
sysfs: /sys/devices/virtual/misc/tun
dev_path: /dev/net/tun
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/net/tun
DEVPATH: /devices/virtual/misc/tun
MAJOR: '10'
MINOR: '200'
SUBSYSTEM: misc
- name: vcsm-cma
sysfs: /sys/devices/virtual/misc/vcsm-cma
dev_path: /dev/vcsm-cma
subsystem: misc
by_id: null
attributes:
DEVMODE: '0666'
DEVNAME: /dev/vcsm-cma
DEVPATH: /devices/virtual/misc/vcsm-cma
MAJOR: '10'
MINOR: '60'
SUBSYSTEM: misc
- name: vga_arbiter
sysfs: /sys/devices/virtual/misc/vga_arbiter
dev_path: /dev/vga_arbiter
subsystem: misc
by_id: null
attributes:
DEVNAME: /dev/vga_arbiter
DEVPATH: /devices/virtual/misc/vga_arbiter
MAJOR: '10'
MINOR: '63'
SUBSYSTEM: misc
- name: rawctl
sysfs: /sys/devices/virtual/raw/rawctl
dev_path: /dev/raw/rawctl
subsystem: raw
by_id: null
attributes:
DEVNAME: /dev/raw/rawctl
DEVPATH: /devices/virtual/raw/rawctl
MAJOR: '162'
MINOR: '0'
SUBSYSTEM: raw
- name: rpivid-h264mem
sysfs: /sys/devices/virtual/rpivid-h264mem/rpivid-h264mem
dev_path: /dev/rpivid-h264mem
subsystem: rpivid-h264mem
by_id: null
attributes:
DEVNAME: /dev/rpivid-h264mem
DEVPATH: /devices/virtual/rpivid-h264mem/rpivid-h264mem
MAJOR: '238'
MINOR: '0'
SUBSYSTEM: rpivid-h264mem
- name: rpivid-hevcmem
sysfs: /sys/devices/virtual/rpivid-hevcmem/rpivid-hevcmem
dev_path: /dev/rpivid-hevcmem
subsystem: rpivid-hevcmem
by_id: null
attributes:
DEVNAME: /dev/rpivid-hevcmem
DEVPATH: /devices/virtual/rpivid-hevcmem/rpivid-hevcmem
MAJOR: '240'
MINOR: '0'
SUBSYSTEM: rpivid-hevcmem
- name: rpivid-intcmem
sysfs: /sys/devices/virtual/rpivid-intcmem/rpivid-intcmem
dev_path: /dev/rpivid-intcmem
subsystem: rpivid-intcmem
by_id: null
attributes:
DEVNAME: /dev/rpivid-intcmem
DEVPATH: /devices/virtual/rpivid-intcmem/rpivid-intcmem
MAJOR: '239'
MINOR: '0'
SUBSYSTEM: rpivid-intcmem
- name: rpivid-vp9mem
sysfs: /sys/devices/virtual/rpivid-vp9mem/rpivid-vp9mem
dev_path: /dev/rpivid-vp9mem
subsystem: rpivid-vp9mem
by_id: null
attributes:
DEVNAME: /dev/rpivid-vp9mem
DEVPATH: /devices/virtual/rpivid-vp9mem/rpivid-vp9mem
MAJOR: '237'
MINOR: '0'
SUBSYSTEM: rpivid-vp9mem
- name: timer
sysfs: /sys/devices/virtual/sound/timer
dev_path: /dev/snd/timer
subsystem: sound
by_id: null
attributes:
DEVNAME: /dev/snd/timer
DEVPATH: /devices/virtual/sound/timer
MAJOR: '116'
MINOR: '33'
SUBSYSTEM: sound
- name: vc-mem
sysfs: /sys/devices/virtual/vc-mem/vc-mem
dev_path: /dev/vc-mem
subsystem: vc-mem
by_id: null
attributes:
DEVNAME: /dev/vc-mem
DEVPATH: /devices/virtual/vc-mem/vc-mem
MAJOR: '247'
MINOR: '0'
SUBSYSTEM: vc-mem
- name: 1-1.3
sysfs: >-
dev_path: /dev/bus/usb/001/004
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/004
DEVNUM: '004'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3
ID_MODEL: USB2.1_Hub
ID_MODEL_ENC: USB2.1\x20Hub
ID_MODEL_ID: '0610'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3'
ID_REVISION: '0655'
ID_SERIAL: GenesysLogic_USB2.1_Hub
ID_VENDOR: GenesysLogic
ID_VENDOR_ENC: GenesysLogic
ID_VENDOR_ID: 05e3
MAJOR: '189'
MINOR: '3'
PRODUCT: 5e3/610/655
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 9/0/1
USEC_INITIALIZED: '542496393'
- name: 1-1.3.2
sysfs: >-
dev_path: /dev/bus/usb/001/005
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/005
DEVNUM: '005'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_2
ID_MODEL_ID: ea60
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.2'
ID_REVISION: '0100'
ID_VENDOR_ID: 10c4
MAJOR: '189'
MINOR: '4'
PRODUCT: 10c4/ea60/100
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 0/0/0
USEC_INITIALIZED: '542977898'
- name: ttyUSB0
sysfs: >-
subsystem: tty
by_id: >-
attributes:
DEVLINKS: >-
DEVPATH: >-
ID_BUS: usb
ID_MODEL_ID: ea60
ID_REVISION: '0100'
ID_TYPE: generic
ID_VENDOR_ID: 10c4
MAJOR: '188'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
- name: 1-1.3.3
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3
dev_path: /dev/bus/usb/001/006
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/006
DEVNUM: '006'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_MODEL: '0200'
ID_MODEL_ENC: '0200'
ID_MODEL_ID: '0200'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.3'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_3
ID_REVISION: '0000'
ID_SERIAL: 0658_0200
ID_USB_INTERFACES: ':020201:0a0000:'
ID_VENDOR: 0658
ID_VENDOR_ENC: 0658
ID_VENDOR_ID: 0658
MAJOR: '189'
MINOR: '5'
PRODUCT: 658/200/0
SUBSYSTEM: usb
TYPE: 2/0/0
USEC_INITIALIZED: '543217506'
- name: ttyACM0
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.3/1-1.3.3:1.0/tty/ttyACM0
dev_path: /dev/ttyACM0
subsystem: tty
by_id: /dev/serial/by-id/usb-0658_0200-if00
attributes:
DEVLINKS: >-
/dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.3:1.0
DEVNAME: /dev/ttyACM0
DEVPATH: >-
ID_BUS: usb
ID_MODEL: '0200'
ID_MODEL_ID: '0200'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.3:1.0'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_3_1_0
ID_REVISION: '0000'
ID_TYPE: generic
ID_USB_DRIVER: cdc_acm
ID_VENDOR: 0658
ID_VENDOR_ENC: 0658
ID_VENDOR_ID: 0658
MAJOR: '166'
MINOR: '0'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '543238830'
- name: 1-1.2
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2
dev_path: /dev/bus/usb/001/008
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/008
DEVNUM: 008
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_FOR_SEAT: usb-platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_2
ID_MODEL: RFXtrx433
ID_MODEL_ENC: RFXtrx433
ID_MODEL_ID: '6001'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_2
ID_REVISION: '0600'
ID_SERIAL: RFXCOM_RFXtrx433_A11ZLBEO
ID_SERIAL_SHORT: A11ZLBEO
ID_USB_INTERFACES: ':ffffff:'
ID_VENDOR: RFXCOM
ID_VENDOR_ENC: RFXCOM
ID_VENDOR_ID: '0403'
MAJOR: '189'
MINOR: '7'
PRODUCT: 403/6001/600
SUBSYSTEM: usb
TAGS: ':seat:'
TYPE: 0/0/0
USEC_INITIALIZED: '550853637'
- name: gpiochip2
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/gpiochip2
dev_path: /dev/gpiochip2
subsystem: gpio
by_id: null
attributes:
DEVNAME: /dev/gpiochip2
DEVPATH: >-
MAJOR: '254'
MINOR: '2'
SUBSYSTEM: gpio
- name: ttyUSB1
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.2/1-1.2:1.0/ttyUSB1/tty/ttyUSB1
dev_path: /dev/ttyUSB1
subsystem: tty
by_id: /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A11ZLBEO-if00-port0
attributes:
DEVLINKS: >-
/dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0-port0
DEVNAME: /dev/ttyUSB1
DEVPATH: >-
ID_BUS: usb
ID_MODEL: RFXtrx433
ID_MODEL_ID: '6001'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.2:1.0'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_2_1_0
ID_REVISION: '0600'
ID_TYPE: generic
ID_USB_DRIVER: ftdi_sio
ID_VENDOR: RFXCOM
MAJOR: '188'
MINOR: '1'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '550927519'
- name: 1-1.3.4
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.4
dev_path: /dev/bus/usb/001/012
subsystem: usb
by_id: null
attributes:
BUSNUM: '001'
DEVNAME: /dev/bus/usb/001/012
DEVNUM: '012'
DEVPATH: >-
DEVTYPE: usb_device
DRIVER: usb
ID_BUS: usb
ID_MODEL: ConBee_II
ID_MODEL_ENC: ConBee\x20II
ID_MODEL_ID: '0030'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.4'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_4
ID_REVISION: '0100'
ID_SERIAL: dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2400601
ID_SERIAL_SHORT: DE2400601
ID_VENDOR: dresden_elektronik_ingenieurtechnik_GmbH
ID_VENDOR_ENC: dresden\x20elektronik\x20ingenieurtechnik\x20GmbH
ID_VENDOR_ID: 1cf1
MAJOR: '189'
MINOR: '11'
PRODUCT: 1cf1/30/100
SUBSYSTEM: usb
TYPE: 2/0/0
USEC_INITIALIZED: '633296454'
- name: ttyACM1
sysfs: >-
/sys/devices/platform/scb/fd500000.pcie/pci0000:00/0000:00:00.0/0000:01:00.0/usb1/1-1/1-1.3/1-1.3.4/1-1.3.4:1.0/tty/ttyACM1
dev_path: /dev/ttyACM1
subsystem: tty
by_id: >-
/dev/serial/by-id/usb-dresden_elektronik_ingenieurtechnik_GmbH_ConBee_II_DE2400601-if00
attributes:
DEVLINKS: >-
/dev/serial/by-path/platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.4:1.0
DEVNAME: /dev/ttyACM1
DEVPATH: >-
ID_BUS: usb
ID_MODEL: ConBee_II
ID_MODEL_ID: '0030'
ID_PATH: 'platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.3.4:1.0'
ID_PATH_TAG: platform-fd500000_pcie-pci-0000_01_00_0-usb-0_1_3_4_1_0
ID_REVISION: '0100'
ID_TYPE: generic
ID_VENDOR_ID: 1cf1
MAJOR: '166'
MINOR: '1'
SUBSYSTEM: tty
TAGS: ':systemd:'
USEC_INITIALIZED: '633304708'
Merci pour ta patience !
Pozzi
Avril 3, 2021, 8:14
19
C’est ton device ZWave : /dev/serial/by-id/usb-0658_0200-if00
Les /dev/ttyUSB sont les contrôleurs USB sur le RPi
Wanfr
Avril 3, 2021, 8:30
20
Re
Je regarde même pas pourquoi je me suis trompé, j'en ai mare d'être comme je l'ai déjà dit une truffe !
Vous me dirait une truffe, si elle st en chocolat, c'est ça place puisque c'est pâques....
Solution à moitié car maintenant avec le bon chemin USB j'ai des remonté dans Z-wave JS2MQTT
Il manque les noms des 27 appareils, mais il voit et reconnait ma clé mais toujours impossible de lancer l’intégration..
Quand je met ws://a0d7b954_zwavejs2mqtt:3000 je ne me trompe pas encore une fois ?!
Car j'ai erreur connexion chaque fois, même après avoir redémarrer.
