Ce thermomètre est proche de ton coordinateur ? L’appairage s’est fait sans problème ?
Tout proche, à 1 ou 2 mètre(s).
Tu n’as pas répondu pour l’appairage Tu peux remettre une copie d’écran du journal de z2m maintenant ?
Oops my bad, j’ai refais l’apparaige et voici les logs (j’ai eu bien du mal, il a fallu plusieurs reboot, il ne voulait plus réappairer !!) :
Debug 2024-02-02 18:16:33Received MQTT message on 'zigbee2mqtt/bridge/request/device/remove' with data '{"block":false,"force":false,"id":"0x00158d00045c2b2f","transaction":"0t5in-4"}'
Info 2024-02-02 18:16:33Removing device '0x00158d00045c2b2f' (block: false, force: false)
Error 2024-02-02 18:16:43Request 'zigbee2mqtt/bridge/request/device/remove' failed with error: 'Failed to remove device '0x00158d00045c2b2f' (block: false, force: false) (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms)'
Debug 2024-02-02 18:16:43Error: Failed to remove device '0x00158d00045c2b2f' (block: false, force: false) (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms) at Bridge.removeEntity (/app/lib/extension/bridge.ts:580:19) at Bridge.onMQTTMessage (/app/lib/extension/bridge.ts:128:34) at EventEmitter.wrappedCallback (/app/lib/eventBus.ts:174:17)
Info 2024-02-02 18:16:43MQTT publish: topic 'zigbee2mqtt/bridge/response/device/remove', payload '{"data":{},"error":"Failed to remove device '0x00158d00045c2b2f' (block: false, force: false) (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms)","status":"error","transaction":"0t5in-4"}'
Debug 2024-02-02 18:16:49Received MQTT message on 'zigbee2mqtt/bridge/request/device/remove' with data '{"block":false,"force":true,"id":"0x00158d00045c2b2f","transaction":"0t5in-5"}'
Info 2024-02-02 18:16:49Removing device '0x00158d00045c2b2f' (block: false, force: true)
Debug 2024-02-02 18:16:49Clearing Home Assistant discovery topic for '0x00158d00045c2b2f'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/battery/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/temperature/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/humidity/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/pressure/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/voltage/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/linkquality/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/last_seen/config', payload 'null'
Info 2024-02-02 18:16:49MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload ''
Info 2024-02-02 18:16:50Successfully removed device '0x00158d00045c2b2f' (block: false, force: true)
Info 2024-02-02 18:16:50MQTT publish: topic 'zigbee2mqtt/bridge/response/device/remove', payload '{"data":{"block":false,"force":true,"id":"0x00158d00045c2b2f"},"status":"ok","transaction":"0t5in-5"}'
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/battery/config' with data ''
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/temperature/config' with data ''
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/humidity/config' with data ''
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/pressure/config' with data ''
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/voltage/config' with data ''
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/linkquality/config' with data ''
Debug 2024-02-02 18:16:50Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/last_seen/config' with data ''
Warning 2024-02-02 18:17:04Device '0x00158d00045c2b2f' left the network
Info 2024-02-02 18:17:05MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00158d00045c2b2f","ieee_address":"0x00158d00045c2b2f"},"type":"device_leave"}'
Info 2024-02-02 18:17:05MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"left_network","meta":{"friendly_name":"0x00158d00045c2b2f"},"type":"device_removed"}'
Info 2024-02-02 18:32:26MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:26.546Z"}'
Info 2024-02-02 18:32:26Device '0x00158d00045c2b2f' joined
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00158d00045c2b2f","ieee_address":"0x00158d00045c2b2f"},"type":"device_joined"}'
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":{"friendly_name":"0x00158d00045c2b2f"},"type":"device_connected"}'
Info 2024-02-02 18:32:27Starting interview of '0x00158d00045c2b2f'
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00158d00045c2b2f","ieee_address":"0x00158d00045c2b2f","status":"started"},"type":"device_interview"}'
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_started","meta":{"friendly_name":"0x00158d00045c2b2f"},"type":"pairing"}'
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:27.541Z"}'
Debug 2024-02-02 18:32:27Device '0x00158d00045c2b2f' announced itself
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"0x00158d00045c2b2f","ieee_address":"0x00158d00045c2b2f"},"type":"device_announce"}'
Info 2024-02-02 18:32:27MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"announce","meta":{"friendly_name":"0x00158d00045c2b2f"},"type":"device_announced"}'
Debug 2024-02-02 18:32:28Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'genBasic', data '{"appVersion":3,"modelId":"lumi.weather"}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:28MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:28.066Z","linkquality":171}'
Debug 2024-02-02 18:32:28Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'genBasic', data '{"65281":{"1":2965,"10":0,"100":2161,"101":8007,"102":102665,"4":424,"5":46198,"6":[0,1]}}' from endpoint 1 with groupID 0
Debug 2024-02-02 18:32:31Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2175}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:31MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:31.646Z","linkquality":160}'
Debug 2024-02-02 18:32:31Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":8101}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:31MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:31.682Z","linkquality":156}'
Debug 2024-02-02 18:32:31Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":1026,"scale":-1,"scaledValue":10266}' from endpoint 1 with groupID 0
Debug 2024-02-02 18:32:35Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2175}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:35MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:35.129Z","linkquality":156}'
Debug 2024-02-02 18:32:35Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":7482}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:35MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:35.166Z","linkquality":156}'
Debug 2024-02-02 18:32:35Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":1026,"scale":-1,"scaledValue":10266}' from endpoint 1 with groupID 0
Debug 2024-02-02 18:32:38Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"manufacturerName":"LUMI"}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:38MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:38.169Z","linkquality":153}'
Debug 2024-02-02 18:32:38Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2192}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:38MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:38.607Z","linkquality":156}'
Debug 2024-02-02 18:32:38Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":6905}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:38MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:38.643Z","linkquality":156}'
Debug 2024-02-02 18:32:38Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":1026,"scale":-1,"scaledValue":10266}' from endpoint 1 with groupID 0
Debug 2024-02-02 18:32:41Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"powerSource":3}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:41MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:41.655Z","linkquality":156}'
Debug 2024-02-02 18:32:44Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"zclVersion":1}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:44MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:44.920Z","linkquality":153}'
Debug 2024-02-02 18:32:48Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"stackVersion":2}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:48MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:48.186Z","linkquality":156}'
Debug 2024-02-02 18:32:48Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msTemperatureMeasurement', data '{"measuredValue":2173}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:48MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:48.642Z","linkquality":160}'
Debug 2024-02-02 18:32:48Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msRelativeHumidity', data '{"measuredValue":6170}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:48MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:48.685Z","linkquality":156}'
Debug 2024-02-02 18:32:48Received Zigbee message from '0x00158d00045c2b2f', type 'attributeReport', cluster 'msPressureMeasurement', data '{"measuredValue":1026,"scale":-1,"scaledValue":10266}' from endpoint 1 with groupID 0
Debug 2024-02-02 18:32:51Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"hwVersion":30}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:51MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:51.684Z","linkquality":160}'
Debug 2024-02-02 18:32:54Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"dateCode":"20161129"}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:54MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:54.950Z","linkquality":160}'
Debug 2024-02-02 18:32:58Received Zigbee message from '0x00158d00045c2b2f', type 'readResponse', cluster 'genBasic', data '{"swBuildId":"3000-0001"}' from endpoint 1 with groupID 0
Info 2024-02-02 18:32:58MQTT publish: topic 'zigbee2mqtt/0x00158d00045c2b2f', payload '{"last_seen":"2024-02-02T17:32:58.219Z","linkquality":156}'
Info 2024-02-02 18:32:58Successfully interviewed '0x00158d00045c2b2f', device has successfully been paired
Info 2024-02-02 18:32:58Device '0x00158d00045c2b2f' is supported, identified as: Aqara Temperature and humidity sensor (WSDCGQ11LM)
Info 2024-02-02 18:32:58MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Temperature and humidity sensor","exposes":[{"access":1,"category":"diagnostic","description":"Remaining battery in %, can take up to 24 hours before reported","label":"Battery","name":"battery","property":"battery","type":"numeric","unit":"%","value_max":100,"value_min":0},{"access":1,"description":"Measured temperature value","label":"Temperature","name":"temperature","property":"temperature","type":"numeric","unit":"°C"},{"access":1,"description":"Measured relative humidity","label":"Humidity","name":"humidity","property":"humidity","type":"numeric","unit":"%"},{"access":1,"description":"The measured atmospheric pressure","label":"Pressure","name":"pressure","property":"pressure","type":"numeric","unit":"hPa"},{"access":1,"category":"diagnostic","description":"Voltage of the battery in millivolts","label":"Voltage","name":"voltage","property":"voltage","type":"numeric","unit":"mV"},{"access":1,"category":"diagnostic","description":"Link quality (signal strength)","label":"Linkquality","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"WSDCGQ11LM","options":[{"access":2,"description":"Calibrates the temperature value (absolute offset), takes into effect on next report of device.","label":"Temperature calibration","name":"temperature_calibration","property":"temperature_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for temperature, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Temperature precision","name":"temperature_precision","property":"temperature_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the humidity value (absolute offset), takes into effect on next report of device.","label":"Humidity calibration","name":"humidity_calibration","property":"humidity_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for humidity, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Humidity precision","name":"humidity_precision","property":"humidity_precision","type":"numeric","value_max":3,"value_min":0},{"access":2,"description":"Calibrates the pressure value (absolute offset), takes into effect on next report of device.","label":"Pressure calibration","name":"pressure_calibration","property":"pressure_calibration","type":"numeric"},{"access":2,"description":"Number of digits after decimal point for pressure, takes into effect on next report of device. This option can only decrease the precision, not increase it.","label":"Pressure precision","name":"pressure_precision","property":"pressure_precision","type":"numeric","value_max":3,"value_min":0}],"supports_ota":false,"vendor":"Aqara"},"friendly_name":"0x00158d00045c2b2f","ieee_address":"0x00158d00045c2b2f","status":"successful","supported":true},"type":"device_interview"}'
Info 2024-02-02 18:32:58Configuring '0x00158d00045c2b2f'
Info 2024-02-02 18:32:58MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"message":"interview_successful","meta":{"description":"Temperature and humidity sensor","friendly_name":"0x00158d00045c2b2f","model":"WSDCGQ11LM","supported":true,"vendor":"Aqara"},"type":"pairing"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/battery/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_battery","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/temperature/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"temperature","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_temperature","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/humidity/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"humidity","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_humidity","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_humidity_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity }}"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/pressure/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"atmospheric_pressure","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_pressure","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_pressure_zigbee2mqtt","unit_of_measurement":"hPa","value_template":"{{ value_json.pressure }}"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/voltage/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/linkquality/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","name":"Linkquality","object_id":"0x00158d00045c2b2f_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Info 2024-02-02 18:32:58MQTT publish: topic 'homeassistant/sensor/0x00158d00045c2b2f/last_seen/config', payload '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"timestamp","enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:clock","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","name":"Last seen","object_id":"0x00158d00045c2b2f_last_seen","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_last_seen_zigbee2mqtt","value_template":"{{ value_json.last_seen }}"}'
Info 2024-02-02 18:32:58Successfully configured '0x00158d00045c2b2f'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/battery/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"battery","enabled_by_default":true,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_battery","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_battery_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.battery }}"}'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/temperature/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"temperature","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_temperature","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_temperature_zigbee2mqtt","unit_of_measurement":"°C","value_template":"{{ value_json.temperature }}"}'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/humidity/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"humidity","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_humidity","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_humidity_zigbee2mqtt","unit_of_measurement":"%","value_template":"{{ value_json.humidity }}"}'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/pressure/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"atmospheric_pressure","enabled_by_default":true,"json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_pressure","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_pressure_zigbee2mqtt","unit_of_measurement":"hPa","value_template":"{{ value_json.pressure }}"}'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/voltage/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"voltage","enabled_by_default":false,"entity_category":"diagnostic","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","object_id":"0x00158d00045c2b2f_voltage","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_voltage_zigbee2mqtt","unit_of_measurement":"mV","value_template":"{{ value_json.voltage }}"}'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/linkquality/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:signal","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","name":"Linkquality","object_id":"0x00158d00045c2b2f_linkquality","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_class":"measurement","state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_linkquality_zigbee2mqtt","unit_of_measurement":"lqi","value_template":"{{ value_json.linkquality }}"}'
Debug 2024-02-02 18:32:59Received MQTT message on 'homeassistant/sensor/0x00158d00045c2b2f/last_seen/config' with data '{"availability":[{"topic":"zigbee2mqtt/bridge/state"},{"topic":"zigbee2mqtt/0x00158d00045c2b2f/availability"}],"availability_mode":"all","device":{"identifiers":["zigbee2mqtt_0x00158d00045c2b2f"],"manufacturer":"Aqara","model":"Temperature and humidity sensor (WSDCGQ11LM)","name":"0x00158d00045c2b2f","sw_version":"3000-0001","via_device":"zigbee2mqtt_bridge_0x00124b0021b77fed"},"device_class":"timestamp","enabled_by_default":false,"entity_category":"diagnostic","icon":"mdi:clock","json_attributes_topic":"zigbee2mqtt/0x00158d00045c2b2f","name":"Last seen","object_id":"0x00158d00045c2b2f_last_seen","origin":{"name":"Zigbee2MQTT","sw":"1.35.2","url":"https://www.zigbee2mqtt.io"},"state_topic":"zigbee2mqtt/0x00158d00045c2b2f","unique_id":"0x00158d00045c2b2f_last_seen_zigbee2mqtt","value_template":"{{ value_json.last_seen }}"}'
EDIT : et la, la température et tous les autres attributs sont remontés. J’espère que ça va tenir dans le temps
Ton zigbee est sur quel canal ?
25, j’avais fait une analyze des wifis pour choisir ce canal, mais ça remonte déjà à pas mal de temps … ça pourrait jouer tu penses ?
Si ton wifi est sur le canal 11 ça devrait être bon. Je me demandais juste si des interférences n’étaient pas la cause de la lenteur de mise à jour de ton thermomètre. Après je ne connais pas ta clé et notamment la puissance de son signal. A ta place, j’investirais dans une clé Sonoff Type P et je mettrais celle que tu as actuellement en routeur si jamais les avancées d’aujourd’hui ne devaient pas tenir dans le temps.
Puis passer éventuellement sur un rpi 4 ou une configuration plus musclée
Oui je pensais au changement de raspberry. Je vais peut-être m’y pencher plus rapidement que prévu !
Merci pour ton aide en tout cas !
De rien, en espérant que ça tienne (je sentais bien un problème de mot de passe depuis le début en tous cas
Des nouvelles de mon réseau Zigbee … qui va beaucoup mieux maintenant que j’ai trouvé la source du problème
@anon41081891 merci de m’avoir mise sur la bonne piste, en regardant du côté du channel zigbee, j’ai atterri sur cette page, prévenant que les appareils Awox perturbent le réseau zigbee.
Il s’avère que j’ai remplacé une ampoule le jour-même où les problèmes sont apparus, avec la première ampoule qui m’est tombée sous la main : une Awox. L’ampoule n’étant pas appairée, j’aurai pu chercher très longtemps sans trouver la source des problèmes.
A tous, évitez à tout prix Awox !!
Et merci à ceux qui se sont arrêtés sur mon problème
Dommage pas de bon point
bientot une image.
