J’essaye de configurer Zigbee2 MQTT, celui-ci ne fonctionne pas ouverture de la page web (502 bad gateway), je souhaiterais flacher ma clef Zigbee Sonoff peut-être pour résoudre le problème mais je n’arrive pas à télécharger le logiciel « flash Programmer2 » impossibles de m’enregistrer sur le site texas instruments. Si une personne pourrais m’aidé s’il vous plaît.
Voici le résumer de mon journal de Zigbee2 MQTT et MQTT
> Zigbee2MQTT
> s6-rc: info: service s6rc-oneshot-runner: starting
> s6-rc: info: service s6rc-oneshot-runner successfully started
> s6-rc: info: service fix-attrs: starting
> s6-rc: info: service fix-attrs successfully started
> s6-rc: info: service legacy-cont-init: starting
> cont-init: info: running /etc/cont-init.d/socat.sh
> [22:21:05] INFO: Socat not enabled, marking service as down
> cont-init: info: /etc/cont-init.d/socat.sh exited 0
> cont-init: info: running /etc/cont-init.d/zigbee2mqtt.sh
> cont-init: info: /etc/cont-init.d/zigbee2mqtt.sh exited 0
> s6-rc: info: service legacy-cont-init successfully started
> s6-rc: info: service legacy-services: starting
> services-up: info: copying legacy longrun socat (no readiness notification)
> services-up: info: copying legacy longrun zigbee2mqtt (no readiness notification)
> [22:21:06] INFO: Handing over control to Zigbee2MQTT Core ...
> > zigbee2mqtt@1.26.0 start
> > node index.js
> Zigbee2MQTT:info 2022-07-03 22:21:10: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-03.22-21-10' filename: log.txt
> Zigbee2MQTT:info 2022-07-03 22:21:10: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
> Zigbee2MQTT:info 2022-07-03 22:21:10: Starting zigbee-herdsman (0.14.40)
> Zigbee2MQTT:info 2022-07-03 22:21:11: zigbee-herdsman started (resumed)
> Zigbee2MQTT:info 2022-07-03 22:21:11: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
> Zigbee2MQTT:info 2022-07-03 22:21:11: Currently 0 devices are joined:
> Zigbee2MQTT:info 2022-07-03 22:21:11: Zigbee: disabling joining new devices.
> Zigbee2MQTT:info 2022-07-03 22:21:11: Connecting to MQTT server at mqtt://core-mosquitto
> Zigbee2MQTT:error 2022-07-03 22:21:11: MQTT failed to connect: Connection refused: Not authorized
> Zigbee2MQTT:error 2022-07-03 22:21:11: Exiting...
> Zigbee2MQTT:info 2022-07-03 22:21:11: Stopping zigbee-herdsman...
> # Mosquitto broker
> error: received null username or password for unpwd check 1656879654: Client <unknown> disconnected, not authorised. 1656879655: New connection from 172.30.33.1:58032 on port 1883. error: received null username or password for unpwd check 1656879655: Client <unknown> disconnected, not authorised. 1656879656: New connection from 172.30.33.1:58038 on port 1883. error: received null username or password for unpwd check 1656879656: Client <unknown> disconnected, not authorised. 1656879657: New connection from 172.30.33.1:56774 on port 1883. error: received null username or password for unpwd check 1656879657: Client <unknown> disconnected, not authorised. 1656879658: New connection from 172.30.33.1:56786 on port 1883. error: received null username or password for unpwd check 1656879658: Client <unknown> disconnected, not authorised. 1656879659: New connection from 172.30.33.1:56788 on port 1883. error: received null username or password for unpwd check 1656879659: Client <unknown> disconnected, not authorised. 1656879660: New connection from 172.30.33.1:56790 on port 1883. error: received null username or password for unpwd check 1656879660: Client <unknown>
