Aucun add-on démarre
Depuis que j’ai du réinstaller ha sur une autre carte sd, plus aucun add-on ne démarre. J’ai deja essayé de desinstallé puis installé, j’ai vérifier les logs ha c’est correct et j’ai verifié les dépots.
Voici les logs d’un add-on (esphome)
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Add-on: ESPHome
 ESPHome add-on for intelligently managing all your ESP8266/ESP32 devices
 Add-on version: 2022.10.2
 You are running the latest version of this add-on.
 System: Home Assistant OS 9.3  (aarch64 / raspberrypi4-64)
 Home Assistant Core: 2022.11.1
 Home Assistant Supervisor: 2022.10.2
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 10-requirements.sh: executing...
[cont-init.d] 10-requirements.sh: exited 0.
[cont-init.d] 20-nginx.sh: executing...
[cont-init.d] 20-nginx.sh: exited 0.
[cont-init.d] 30-dirs.sh: executing...
[cont-init.d] 30-dirs.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[23:19:19] INFO: Waiting for dashboard to come up...
[23:19:19] INFO: Starting ESPHome dashboard...
2022-11-05 23:19:21,240 INFO Starting dashboard web server on unix socket /var/run/esphome.sock and configuration dir /config/esphome...
[23:19:21] INFO: Starting NGINX...
RPI4 2gb de ram
Nouvelle version de ha
Là c’est difficile de te dire quoi que ce soit.
Le log de EspHome est normal… j’ai exactement ça quand il démarre…il n’y a rien d’autre après la ligne « Starting NGINX »
Non, je n’ai rien d’autre
Désolé, je me suis peut être mal exprimé :slight_smile:
Ce n’était pas une question, mais une affirmation : Il n’y a rien d’autre qui d’affiche après la ligne « Starting NGINX » et c’est totalement normal.
bonjour,
tu peux tester c’est solution Modules complémentaires / Addon arrêtés et impossibles à relancer - #3 par WarC0zes
Citation
La solution, est d’arrêter le RPi et débrancher l’alimentation du secteur. Rebrancher l’alimentation et relancer HA.
Ta reinstaller un backup je suppose, d’ou ce problème. Ont est nombreux a l’avoir eux.
Super merci beaucoup
