Je vois que certain voudraient utiliser un TH05Z (@Sigalou par exemple
) qui n’est pas encore compatible Zibee2MQTT sans utiliser / passer par une passerelle Tuya.
voici comment faire si cela intéresse quelques uns d’entre vous pour le faire reconnaitre dans zigbee2mqtt :
créer un fichier ext_TH05Z.js dans le folder Zigbee2mqtt et copier le code ci dessous dedans
const fz = require('zigbee-herdsman-converters/converters/fromZigbee');
const tz = require('zigbee-herdsman-converters/converters/toZigbee');
const exposes = require('zigbee-herdsman-converters/lib/exposes');
const reporting = require('zigbee-herdsman-converters/lib/reporting');
const extend = require('zigbee-herdsman-converters/lib/extend');
const ota = require('zigbee-herdsman-converters/lib/ota');
const tuya = require('zigbee-herdsman-converters/lib/tuya');
const utils = require('zigbee-herdsman-converters/lib/utils');
const globalStore = require('zigbee-herdsman-converters/lib/store');
const e = exposes.presets;
const ea = exposes.access;
const legacy = require('zigbee-herdsman-converters/lib/legacy');
const definition = {
fingerprint: [{
modelID: 'TS0601',
manufacturerName: '_TZE200_vvmbj46n'
model: 'JM-TRH-ZGB-V1',
vendor: 'TuYa',
description: 'Temperature & humidity sensor with clock',
fromZigbee: [legacy.fromZigbee.nous_lcd_temperature_humidity_sensor, fz.ignore_tuya_set_time],
toZigbee: [legacy.toZigbee.nous_lcd_temperature_humidity_sensor],
onEvent: tuya.onEventSetLocalTime,
configure: async (device, coordinatorEndpoint, logger) => {
const endpoint = device.getEndpoint(1);
await reporting.bind(endpoint, coordinatorEndpoint, ['genBasic']);
exposes: [
e.temperature(), e.humidity(), e.battery(),
e.numeric('temperature_report_interval', ea.STATE_SET).withUnit('min').withValueMin(1).withValueMax(60)
.withValueStep(1)
.withDescription('Temperature Report interval'),
e.numeric('humidity_report_interval', ea.STATE_SET).withUnit('min').withValueMin(1).withValueMax(60)
.withValueStep(1)
.withDescription('Humidity Report interval'),
e.enum('temperature_unit_convert', ea.STATE_SET, ['celsius', 'fahrenheit']).withDescription(
'Current display unit'),
e.enum('temperature_alarm', ea.STATE, ['canceled', 'lower_alarm', 'upper_alarm'])
.withDescription('Temperature alarm status'),
e.numeric('max_temperature', ea.STATE_SET).withUnit('°C').withValueMin(-20).withValueMax(60)
.withDescription('Alarm temperature max'),
e.numeric('min_temperature', ea.STATE_SET).withUnit('°C').withValueMin(-20).withValueMax(60)
.withDescription('Alarm temperature min'),
e.enum('humidity_alarm', ea.STATE, ['canceled', 'lower_alarm', 'upper_alarm'])
.withDescription('Humidity alarm status'),
e.numeric('max_humidity', ea.STATE_SET).withUnit('%').withValueMin(0).withValueMax(100)
.withDescription('Alarm humidity max'),
e.numeric('min_humidity', ea.STATE_SET).withUnit('%').withValueMin(0).withValueMax(100)
.withDescription('Alarm humidity min'),
module.exports = definition;
dans le fichier configuration.yaml de Zibgee2mqtt, ajouter en fin les lignes :
external_converters:
- ext_TH05Z.js
redémarrer zigbee2mqtt, et c’est fini. l’icone n’est pas tout a fait le même, mais le capteur remonte toutes les valeurs. ![]()
