Carte personalisé lune
Bonjour tout le monde
Voila mon problème j'ai eu beau suivre le tuto de WarC0zes sur la Carte des phase de la lune j'ai bien réussi a affichée la lune en icône mais pas en image comme il a pu faire...
voila mon configuration.yaml
 Loads default set of integrations. Do not remove.
default_config:
    sensor.moon_phase
    sensor.moon_phases
    notify.telegram_groupe
#phase de lune
  - platform: moon
    sensors:
      moon_phases:
        friendly_name: 'Lune'
        value_template: >-
          {% set phases = {'first_quarter': 'Premier quartier', 'full_moon': 'Pleine lune',
                           'last_quarter': 'Dernier quartier', 'new_moon': 'Nouvelle lune',
                           'waning_crescent': 'Dernier croissant', 'waning_gibbous': 'Gibbeuse décroissante',
                           'waxing_crescent': 'Premier croissant', 'waxing_gibbous': 'Gibbeuse croissante'} %}
          {% set phase = states('sensor.moon') %}
          {{ phases[phase] if phase in phases.keys() else 'Error' }}
        entity_picture_template: /local/moon_phases/{{ states('sensor.moon') }}.png
# config SSL
#Theme
frontend:
  themes:
    Google Dark Theme:
      app-header-background-color: "#171717"
      app-header-text-color: "#BDC1C6"
      # .. rest of theme here
    Google Light Theme:
      app-header-background-color: "#F8F8F8"
      app-header-text-color: "#424242"
automation:
  # Set the correct theme during day and night
  - alias: Automatic Theme Change
      - platform: homeassistant
        event: start
      - platform: state
        entity_id: sun.sun
      - service_template: frontend.set_theme
        data_template:
            {% if is_state('sun.sun', 'above_horizon') %}
              Google Light Theme
              Google Dark Theme
# Text to speech
tts:
  - platform: google_translate
#host
device_tracker:
  - platform: ping
    hosts:
      hostone: 192.168.1.1
      hosttow: 192.168.1.15
      hostthree: 192.168.1.17
      hostfor: 192.168.1.60
      hostb: 192.168.1.23
      hostphu: 192.168.1.10
      hostrevl: 192.168.12
      hostrevt: 192.168.1.11
      hostpritv: 192.168.1.16
      hostprimeu: 192.168.1.13
      hostgooh: 192.168.1.15
      hostgsast: 192.168.1.14
      hosttv: 192.168.1.22
      hosttabsal: 192.168.1.39
      hosttabcui: 192.168.1.18
      hostpc: 192.168.1.49
#telegram
telegram_bot:
  - platform: polling
    api_key: !secret telegram_token
    allowed_chat_ids:
      - !secret id_telegram_tom ## McFly
      - !secret id_telegram_test ##groupe
notify:
  - name: Telegram Groupe
    platform: telegram
    chat_id: !secret id_telegram_test ## Groupe
  - name: Telegram McFly
    platform: telegram
    chat_id: !secret id_telegram_tom ## McFly
#Box TV Orange
media_player:
  - platform: liveboxtvuhd
    host: 192.168.1.23
    port: 8080
    scan_interval: 10
    country: france
#include
binary_sensor: !include binary_sensor.yaml
scene: !include scenes.yaml
script: !include scripts.yaml
et la ou sont les photos j'ai suivi ce qu'il disait en les mettant dans le dossier configuration/www/moon_phases ( sur la machine distante )
si vous voyer ou est mon/mes erreur(s) je suis preneurs
car j'aimerai passé d'un icône "moche" a une belle lune
Je vous en remercie par avance.
Passez une bonne journée/soirée/nuit
version core-2022.8.6
python_version 3.10.5
os_version 5.15.55
arch x86_64
Home Assistant Community Store Home Assistant Cloud Home Assistant Supervisor Dashboards Recorder
Bonsoir @Tomaz
Mes images sont au même endroit que les tiennes.
Pour le yaml voici le code que j'ai :
  - platform: moon
    sensors:
      moon_phases:
        value_template: >-
J'ai aussi l'intégration :
Ca fait un moment que j'ai mis ça en place, j'oublie peut être quelque chose.
Le yaml de la carte :
type: glance
  - entity: sensor.moon_phases
  - entity: sun.sun
  - entity: sensor.temperature_ext
Le résultat:
Bob
Question bête … La config yaml est correcte ? Parce qu’on voit un gros pâté rouge (telegram tout ça)
Si pas valable, pas de restart, si pas de start : pas de sensor et donc pas de carte affichée correctement
Bonsoir Bob ça na pas fonctionné
Bonsoir Pulpy malgré le rouge ça fonctionne mais j'ai cette erreur
Vu que tu as l’intégration « Moon » via l’ui, tu devrais supprimer le sensor :
- platform: moon
Juste pour voir au cas où.
Evidemment il faut redémarre HA.
Bonsoir,
je viens d’essayer mais ça ne fonctionne pas non plus, et évidement j’ai redémarré et vider le cache
Je vois que tu as un fichier « sensors.yaml » dans ton arborescence.
Est-ce que dans configuration.yaml t’as une ligne du genre :
sensor: !include sensors.yaml
J’ai essayer avec et ça ma mis une erreur bloquante pour le redémarrage et j’ai ce message
Error loading /config/configuration.yaml: in "/config/configuration.yaml", line 123, column 9: Unable to read file /config/sensors.yaml.
Ok, donc de base tu n’utilises pas le fichier sensors.yaml.
Si il est bien vide, tu peux virer le « include » précédent et il faut continuer investiguer pour le bug d’origine.
Nope de base je ne l’utilise pas je préfère avoir tout dans le même fichier, et j’ai viré le fichier mais rien y fait
Tu devrais partager ton configuration.yaml complet avec la balise qui va bien :
Les capture d'écran partielles c'est bien mais du coup on voit pas tout :upside_down_face:
le voila :slight_smile: je pensais le premier coup quand je l’avais mis entre les balise [code] ça allais
#Loads default set of integrations. Do not remove.
default_config:
#phase de lune
moon:
  - platform: moon
    sensors:
      moon_phase:
        value_template: >-
# config SSL
#Theme
frontend:
  themes:
    Google Dark Theme:
    Google Light Theme:
automation:
        event: start
      - platform: state
        entity_id: sun.sun
        data_template:
              Google Light Theme
              Google Dark Theme
# Text to speech
tts:
#host
device_tracker:
  - platform: ping
    hosts:
      hostb: 192.168.1.23
#telegram
telegram_bot:
  - platform: polling
    allowed_chat_ids:
notify:
    platform: telegram
    platform: telegram
#Box TV Orange
media_player:
    host: 192.168.1.23
    port: 8080
    scan_interval: 10
    country: france
#include
Sur cette partie et par rapport à ton premier post tu as remplacé :
Par
moon:
Donc perso je remplacerai tout ça par :
    sensors:
      moon_phase:
        value_template: >-
Et par curiosité dans les outils de dev je collerai ça pour voir ce qu’il dit :
{{ states('sensor.moon_phase') }}
pardon j’ai essayer différent truc pour savoir ou ça n’allais pas car a vrais dire ça fait 3 semaines que je suis sur HA et une semaine que j’essaie des truc
et les outils de dev sont ou pour mettre ça ?
desoler je suis vraiment novice
Dans la sidebar le p'tit marteau, puis l'onglet Modèle.
Exemple chez moi avec les sensors équivalent
Du coup je le laisse comme ça ? Je cherchais un onglet développeur
Pourtant j'ai bien l'intégration pour la lune
Et si tu clics sur "entité" ici :
Ca donne quoi ?
Tu peux aussi tester les 3 p'tits points en bas à droite puis recharger.
Ça donne sa
On dirait bien que tes 2 sensors ont le même nom :upside_down_face:
Celui de l'intégration moon donne [color=]sensor.moon_phase[/color] selon ton dernier screen.
Et celui dans configuration.yaml la même :
    sensors:
      moon_phase:
Tu vas dans l'intégration, tu cliques à nouveau sur "entité", tu cliques sur son nom et tu modifies l'id de l'entité comme suit :
Et ça devrait aller mieux.
