Cherche Tutoriel RFXCOM
j’ai reinstaller home assistant ,ca ne change rien!!! pour rfxtrx :frowning:
Le journal complet, il y a tout
ça ne m’étonne pas vraiment… si tu refais la même chose, ça produit les même effets et si tu as une anomalie qui n’est pas corrigée, alors elle sera là aussi
2022-07-11 18:57:09 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration husqvarna_automower which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-11 18:57:09 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-07-11 18:57:09 INFO (MainThread) [homeassistant.setup] Setup of domain logger took 0.0 seconds
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setting up recorder
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.1 seconds
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 1: {'ssdp', 'auth', 'diagnostics', 'lovelace', 'http', 'websocket_api', 'person', 'image', 'hassio', 'system_log', 'zeroconf', 'device_automation', 'dhcp', 'config', 'analytics', 'webhook', 'onboarding', 'cloud', 'api', 'search', 'network', 'frontend', 'usb'}
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setting up device_automation
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setup of domain device_automation took 0.0 seconds
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setting up http
2022-07-11 18:57:10 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up dhcp
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain dhcp took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.2 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up auth
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up diagnostics
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up hassio
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up config
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up webhook
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up api
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain diagnostics took 0.6 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.4 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up search
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain search took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up analytics
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up image
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain analytics took 0.1 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain image took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up network
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain network took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up usb
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setup of domain usb took 0.0 seconds
2022-07-11 18:57:11 INFO (MainThread) [homeassistant.setup] Setting up person
2022-07-11 18:57:11 INFO (SyncWorker_1) [homeassistant.loader] Loaded google_assistant from homeassistant.components.google_assistant
2022-07-11 18:57:11 INFO (SyncWorker_2) [homeassistant.loader] Loaded alexa from homeassistant.components.alexa
2022-07-11 18:57:11 INFO (SyncWorker_0) [homeassistant.loader] Loaded camera from homeassistant.components.camera
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2022-07-11 18:57:12 INFO (MainThread) [zeroconf] Address in use when adding (('fe80::c297:dd87:e403:95e0', 0, 3), 3) to multicast group, it is expected to happen on some systems
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 0.1 seconds
2022-07-11 18:57:12 INFO (SyncWorker_4) [homeassistant.loader] Loaded media_player from homeassistant.components.media_player
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain person took 0.2 seconds
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setting up cloud
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 0.5 seconds
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 0.1 seconds
2022-07-11 18:57:12 INFO (SyncWorker_2) [homeassistant.loader] Loaded panel_custom from homeassistant.components.panel_custom
2022-07-11 18:57:12 INFO (SyncWorker_3) [homeassistant.loader] Loaded device_tracker from homeassistant.components.device_tracker
2022-07-11 18:57:12 INFO (SyncWorker_4) [homeassistant.loader] Loaded group from homeassistant.components.group
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setting up frontend
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.components.http] Now listening on port 8123
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain hassio took 1.5 seconds
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setting up hardware
2022-07-11 18:57:12 INFO (MainThread) [homeassistant.setup] Setup of domain hardware took 0.0 seconds
2022-07-11 18:57:13 WARNING (MainThread) [hass_nabucasa.cloud_api] Fetched https://alexa-api.nabucasa.com/access_token (400)
2022-07-11 18:57:13 INFO (MainThread) [hass_nabucasa.iot] Connected
2022-07-11 18:57:13 INFO (SyncWorker_3) [homeassistant.loader] Loaded binary_sensor from homeassistant.components.binary_sensor
2022-07-11 18:57:13 INFO (MainThread) [homeassistant.setup] Setting up binary_sensor
2022-07-11 18:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain binary_sensor took 0.0 seconds
2022-07-11 18:57:13 INFO (SyncWorker_4) [homeassistant.loader] Loaded stt from homeassistant.components.stt
2022-07-11 18:57:13 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.cloud
2022-07-11 18:57:13 INFO (MainThread) [homeassistant.setup] Setting up stt
2022-07-11 18:57:13 INFO (MainThread) [homeassistant.setup] Setup of domain stt took 0.0 seconds
2022-07-11 18:57:13 INFO (SyncWorker_3) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2022-07-11 18:57:14 INFO (MainThread) [homeassistant.setup] Setting up tts
2022-07-11 18:57:14 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds
2022-07-11 18:57:14 INFO (MainThread) [snitun.utils.aiohttp_client] AioHTTP snitun client started on 127.0.0.1:52801
2022-07-11 18:57:15 INFO (MainThread) [snitun.utils.aiohttp_client] AioHTTP snitun client connected to: eu-central-1-0.ui.nabu.casa:443
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.hassio
2022-07-11 18:57:17 INFO (SyncWorker_3) [homeassistant.loader] Loaded sensor from homeassistant.components.sensor
2022-07-11 18:57:17 INFO (SyncWorker_4) [homeassistant.loader] Loaded update from homeassistant.components.update
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.bootstrap] Setting up stage 2: {'tag', 'input_button', 'timer', 'input_boolean', 'sun', 'input_select', 'application_credentials', 'rfxtrx', 'met', 'map', 'media_source', 'blueprint', 'energy', 'radio_browser', 'input_datetime', 'raspberry_pi', 'trace', 'logbook', 'default_config', 'input_number', 'counter', 'input_text', 'hacs', 'persistent_notification', 'mobile_app', 'system_health', 'scene', 'history', 'script', 'cast', 'hardware', 'rpi_power', 'automation', 'zone', 'my', 'tts'}
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up sensor
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up update
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain update took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up tag
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up input_button
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up timer
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up input_boolean
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up sun
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up input_select
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up application_credentials
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up map
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up media_source
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up blueprint
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain blueprint took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up input_datetime
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up raspberry_pi
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain raspberry_pi took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up trace
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain trace took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up logbook
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up input_number
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up counter
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up input_text
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up system_health
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up scene
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.components.scene] Setting up scene.homeassistant
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up history
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up zone
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up my
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain my took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hassio
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.components.update] Setting up update.hassio
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up rfxtrx
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain rfxtrx took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain media_source took 0.2 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.1 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.1 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.1 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up script
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up automation
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain tag took 0.2 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain application_credentials took 0.2 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up energy
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain energy took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up met
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain timer took 0.3 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain counter took 0.2 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.energy
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setting up radio_browser
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain radio_browser took 0.0 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.2 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.2 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_boolean took 0.4 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_button took 0.5 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_select took 0.4 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain zone took 0.4 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_number took 0.4 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_datetime took 0.4 seconds
2022-07-11 18:57:17 INFO (MainThread) [homeassistant.setup] Setup of domain input_text took 0.4 seconds
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up hacs
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain hacs took 0.0 seconds
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up rpi_power
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain rpi_power took 0.0 seconds
2022-07-11 18:57:18 INFO (MainThread) [custom_components.hacs]
HACS (Home Assistant Community Store)
Version: 1.26.0
This is a custom integration
If you have any issues with this you need to open an issue here:
https://github.com/hacs/integration/issues
2022-07-11 18:57:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.rpi_power
2022-07-11 18:57:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded plex from homeassistant.components.plex
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 0.0 seconds
2022-07-11 18:57:18 INFO (SyncWorker_1) [homeassistant.components.rpi_power.binary_sensor] Voltage normalized. Everything is working as intended.
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.rfxtrx
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.binary_sensor] Setting up binary_sensor.rfxtrx
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up notify
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds
2022-07-11 18:57:18 INFO (SyncWorker_3) [homeassistant.loader] Loaded cover from homeassistant.components.cover
2022-07-11 18:57:18 INFO (SyncWorker_2) [homeassistant.loader] Loaded switch from homeassistant.components.switch
2022-07-11 18:57:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded light from homeassistant.components.light
2022-07-11 18:57:18 INFO (SyncWorker_1) [homeassistant.loader] Loaded siren from homeassistant.components.siren
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up cast
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain cast took 0.0 seconds
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up default_config
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up cover
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain cover took 0.0 seconds
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up switch
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain switch took 0.0 seconds
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up light
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up siren
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain siren took 0.0 seconds
2022-07-11 18:57:18 INFO (SyncWorker_4) [homeassistant.loader] Loaded stream from homeassistant.components.stream
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.cover] Setting up cover.rfxtrx
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.switch] Setting up switch.rfxtrx
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain light took 0.3 seconds
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.components.siren] Setting up siren.rfxtrx
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setting up media_player
2022-07-11 18:57:18 INFO (MainThread) [homeassistant.setup] Setup of domain media_player took 0.0 seconds
2022-07-11 18:57:18 INFO (SyncWorker_0) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.components.light] Setting up light.rfxtrx
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setting up weather
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] <HacsData restore> Restore started
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.components.media_player] Setting up media_player.cast
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setting up stream
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setup of domain stream took 0.0 seconds
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] <HacsData restore> Restore done
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 1.0 seconds
2022-07-11 18:57:19 INFO (zeroconf-ServiceBrowser-_googlecast._tcp-89) [homeassistant.components.cast.helpers] Fetched cast details for unknown model 'Freebox Player POP' manufacturer: 'Freebox', type: 'cast'. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+cast%22
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Enable category: integration
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Enable category: plugin
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Enable category: theme
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] <HacsFrontend> LovelaceMode.STORAGE mode, cache for /hacsfiles/: True
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.SETUP
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.WAITING
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Setup complete, waiting for Home Assistant before startup tasks starts
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.hacs
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 10.10s
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.STARTUP
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setting up alexa
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setup of domain alexa took 0.0 seconds
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setting up google_assistant
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.setup] Setup of domain google_assistant took 0.0 seconds
2022-07-11 18:57:19 INFO (MainThread) [custom_components.hacs] Loading removed repositories
2022-07-11 18:57:19 INFO (MainThread) [homeassistant.components.zeroconf] Starting Zeroconf broadcast
2022-07-11 18:57:20 INFO (SyncWorker_0) [homeassistant.loader] Loaded freebox from homeassistant.components.freebox
2022-07-11 18:57:20 INFO (SyncWorker_1) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2022-07-11 18:57:22 INFO (MainThread) [custom_components.hacs] Loading known repositories
2022-07-11 18:57:22 INFO (SyncWorker_1) [homeassistant.loader] Loaded dlna_dms from homeassistant.components.dlna_dms
2022-07-11 18:57:24 INFO (MainThread) [custom_components.hacs] Starting recurring background task for downloaded repositories
2022-07-11 18:57:24 INFO (MainThread) [custom_components.hacs] Stage changed: HacsStage.RUNNING
Bon, ça semble correct. Pas d’anomalie et le volet à l’air chargé
Supprime la partie yaml et redémarre ha pour voir
Je viens de percuté…
Dans le yaml
Dans la config actuelle du rfxtrx
Dans tes entités
Comme l’ID de ce dernier n’est pas le même, pour moi il est tout simplement pas configuré et c’est le reste d’une de tes tentatives
supprimé la partie yaml, redemarré et memes conséquences! :persevere:
Ton rfxcom en permet pour l’instant de piloter que le volet 003020801
Combien de volets vois-tu dans les états
Attention à bien mettre le filtre cover.
1 seul pour l’instant : cover.rfy_030208_1
Donc ça sert à rien de voloir piloter
car il n’est pas là pour le moment
Confirme que cover.rfy_030208_1 est pilotable et si c’est bien le cas, comme je le pense, tu pourras inclure les autres volets ensuite
oui il est bien pilotable, pas de soucis,j’avais bien reussi a rajouter les autres volets via l’integration rfx ,
mais c’est quand je redemarre HA que le covers.rfy devient « unavailable » donc non pilotable
Non, il est non pilotable car pas dans la config RFXtrx par conséquent, quand tu dis
Soit ça a marché et tu as fait un reset à un moment donné de l’intégration, soit l’intégration n’est pas réussie.
Le plus simple c’est d’ajouter un autre volet, de vérifier qu’il est bien dans le RFXtrx et de rebooter
2 volets bien integrés
et apres redemarrage HA
tous les statuts passent en rouge
Si tu retourne dans l’intégration rfxtrx, que tu cliques sur « telecharger les journaux », combien tu vois de volets listés dans la config ?
Salut maitre :grin:
Quel sont les protocoles activés ?
@+Dom
saisissez ou collez du code ici
  "home_assistant": {
    "installation_type": "Home Assistant OS",
    "version": "2022.7.3",
    "dev": false,
    "hassio": true,
    "virtualenv": false,
    "python_version": "3.10.5",
    "docker": true,
    "arch": "armv7l",
    "timezone": "UTC",
    "os_name": "Linux",
    "os_version": "5.15.32-v7l",
    "supervisor": "2022.07.0",
    "host_os": "Home Assistant OS 8.2",
    "docker_version": "20.10.14",
    "chassis": "embedded",
    "run_as_root": true
  "custom_components": {
    "husqvarna_automower": {
      "version": "0.0.0",
      "requirements": [
        "aioautomower==2022.7.0",
        "geopy>=2.1.0",
        "numpy>=1.21.6",
        "Pillow>=9.1.1"
    "hacs": {
      "version": "1.26.0",
      "requirements": [
        "aiogithubapi>=22.2.4"
  "integration_manifest": {
    "domain": "rfxtrx",
    "name": "RFXCOM RFXtrx",
    "documentation": "https://www.home-assistant.io/integrations/rfxtrx",
    "requirements": [
      "pyRFXtrx==0.30.0"
    "codeowners": [
      "@danielhiversen",
      "@elupus",
      "@RobBie1221"
    "config_flow": true,
    "iot_class": "local_push",
    "loggers": [
      "RFXtrx"
    "is_built_in": true
  "data": {
    "entry": {
      "entry_id": "db1c4129ac49c66e731c6202d13d189d",
      "version": 1,
      "domain": "rfxtrx",
      "title": "RFXTRX",
      "data": {
        "host": null,
        "port": null,
        "device": "/dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO76UO40-if00-port0",
        "automatic_add": false,
        "devices": {}
      "options": {},
      "pref_disable_new_entities": false,
      "pref_disable_polling": false,
      "source": "user",
      "unique_id": "rfxtrx",
      "disabled_by": null
}`Texte préformaté`
Hummm ta config est vide…
Dans un de tes messages précédents tu avais
        "devices": {
          "071a000003020801": {
            "device_id": [
              "1a",
              "0",
              "030208:1"
            "venetian_blind_mode": "Unknown"
Là il n’y a même pas une ligne device
On boucle mais comment fais-tu l’ajout d’un volet ?
coucou @Doubledom merci d’avance pour le renfort :wink:
Est ce tout se passe bien en branchant le rfxtrx au PC ?
Rfxlanager, le soft rfx sur pc, reconnaît bien le matériel ?
Salut…
Tu crois pas qu’il faudrait faire une commande List remotes pour vérifier ce qui est effectivement enregistré ?
Puis vérifier log si les télécommandes sont là !
Le 6émé octet N° puis ID et Unit et RFu les 3
2022-07-12 20:27:28 INFO (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Running websocket_api script
2022-07-12 20:27:28 INFO (MainThread) [homeassistant.helpers.script.websocket_api_script] websocket_api script: Executing step call service
2022-07-12 20:27:28 DEBUG (SyncWorker_2) [RFXtrx] Send: 0x0c 0x1a 0x00 0x0d 0x03 0x08 0x02 0x01 0x06 0x00 0x01 0x02 0x00
2022-07-12 20:27:28 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x00 0x03 0xca 0x5e 0x01 0xa4 0x00 0x04 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:29 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x01 0x03 0xca 0x5f 0x06 0xa1 0x00 0x01 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:29 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x02 0x03 0xca 0x4f 0x06 0xa2 0x00 0x02 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:29 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x03 0x00 0x00 0x02 0x01 0xa6 0x03 0x0a 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:29 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x04 0x00 0xeb 0xf0 0x01 0xa6 0x03 0x0a 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:30 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x05 0x00 0x01 0x02 0x00 0xa2 0x04 0x07 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:30 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x06 0x0c 0x1c 0x1c 0x03 0xa6 0x00 0xfb 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:30 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x07 0x0c 0x1c 0x1d 0x01 0xac 0x00 0x11 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:30 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x08 0x00 0x00 0x01 0x01 0xa7 0x00 0x97 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:31 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x09 0x00 0x00 0x01 0x02 0xa5 0x00 0x90 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:31 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x0a 0x00 0x00 0x01 0x03 0xa1 0xb0 0xc1 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:31 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x0b 0x00 0x00 0x01 0x04 0xac 0xb0 0xfc 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:31 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x0c 0x00 0x00 0x01 0x00 0xa3 0x00 0x53 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:31 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x0d 0x03 0x08 0x08 0x01 0xa1 0x01 0x03 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
2022-07-12 20:27:32 DEBUG (Thread-3 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x03 0x0d 0x03 0x0e 0x03 0x08 0x02 0x01 0xa1 0x01 0x03 0xa4 0xc6 0xcf 0x4c 0x59 0x00 0x69 0x4d
Oui pourquoi pas, par contre ça liste les commandes connues dans le rfxcom ça, non ? On peut avoir des volets dedans sans pour autant les avoir importés dans HA, correct ?
oui tout est ok avec le soft sur pc
dans event ,je rentre le numero que tu as indiqué?>>>>échec d’appel erreur inconnu
