Comment configurer un NDD OVH avec let's encrypt et NGNIX Home assistant SSL Proxy?
dans DNS tu met rien ?
non puisque c’est du challenge http pas besoin de DNS
edit : n’oublies pas la regle de port dans ta box port 80 externe vers port 80 de l’ip de HA
Décidément !
cont-init: info: running /etc/cont-init.d/file-structure.sh
cont-init: info: /etc/cont-init.d/file-structure.sh exited 0
services-up: info: copying legacy longrun lets-encrypt (no readiness notification)
[09:19:31] INFO: Selected DNS Provider: dns-ovh
[09:19:31] INFO: Use propagation seconds: 60
[09:19:31] INFO: Detecting existing certificate type for homeassistant.xxxxx.com
Saving debug log to /var/log/letsencrypt/letsencrypt.log
[09:19:32] INFO: No certificate found - using 'ecdsa' key type.
Requesting a certificate for homeassistant.xxxxx.com
Error determining zone identifier for homeassistant.xxxx.com: 403 Client Error: Forbidden for url: https://eu.api.ovh.com/1.0/domain/zone/. (Are your Application Key and Consumer Key values correct?)
Ask for help or search for solutions at https://community.letsencrypt.org. See the logfile /var/log/letsencrypt/letsencrypt.log or re-run Certbot with -v for more details.
[10:19:01] INFO: Selected http verification
[10:19:01] INFO: Detecting existing certificate type for homeassistant.handicarauto.com
[10:19:03] INFO: No certificate found - using 'ecdsa' key type.
Certbot failed to authenticate some domains (authenticator: standalone). The Certificate Authority reported these problems:
  Domain: homeassistant.xxxxx.com
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "08Rvo3EttDXu-1UxO86Hu_lYX7ICmi4Sq_vxO7x7Vzg.DtYtklcMRwSgadmYzYkhJQbL2ahs1F2nYUHD3rBmpUM" (got "08Rvo3EttDXu-1UxO86Hu_lYX7ICmi4Sq_vxO7x7Vzg.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8")
Hint: The Certificate Authority failed to download the challenge files from the temporary standalone webserver started by Certbot on port 80. Ensure that the listed domains point to this machine and that it can accept inbound connections from the internet.
Some challenges have failed.
[10:26:46] INFO: Selected http verification
[10:26:46] INFO: Detecting existing certificate type for homeassistant.xxxxxx.com
[10:26:47] INFO: No certificate found - using 'ecdsa' key type.
Requesting a certificate for homeassistant.handicarauto.com
  Domain: homeassistant.xxxxxx.com
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "Fpb9AbYBxgYQPIECs79qYX0Jx4JL6AjU8uvtUTs2Pm8.DtYtklcMRwSgadmYzYkhJQbL2ahs1F2nYUHD3rBmpUM" (got "Fpb9AbYBxgYQPIECs79qYX0Jx4JL6AjU8uvtUTs2Pm8.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8")
c’est ma fois original
le port 80 de ta box est pas deja utilisé pat quelque chose genre un accès distant a la box activé ou quelque chose comme ça ??
A priori non, c’est moi qui l’ai ajouté directement dans le NAT/PAD de Bouygues
redemarre tout pour voir et avant tu peux coller ta config de let’s encrypt et regarde tout en bas si ton port 80 est bien activé ?
domains:
  - homeassistant.xxxxxx.com
email: taxxxxxx@gmail.com
keyfile: privkey.pem
certfile: fullchain.pem
challenge: http
dns: {}
J’ai redémarré ma machine virtuelle, mais toujours rien dans ssl
les logs toujours les logs :wink:
Ceux de Home assistant ?
Non de let’s encrypt.
A moins que tu est activer lancer au démarrage let’s encrypt, sinon il faut le faire manuellement.
[10:55:23] INFO: Selected http verification
[10:55:23] INFO: Detecting existing certificate type for homeassistant.xxxxxxxxx.com
[10:55:24] INFO: No certificate found - using 'ecdsa' key type.
Requesting a certificate for homeassistant.xxxxxxxxx.com
  Domain: homeassistant.xxxxxxxxx.com
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "57wWDpNIc68YepgnKkQQnnRfPp59aZbBBuh4R0Hqk_s.DtYtklcMRwSgadmYzYkhJQbL2ahs1F2nYUHD3rBmpUM" (got "57wWDpNIc68YepgnKkQQnnRfPp59aZbBBuh4R0Hqk_s.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8")
[10:57:35] INFO: Selected http verification
[10:57:35] INFO: Detecting existing certificate type for homeassistant.xxxxxxxxx.com
[10:57:37] INFO: No certificate found - using 'ecdsa' key type.
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "-Q9-eNhkNasysBQUX6w5i-QN-X0W8WSFeObSe28rmPo.DtYtklcMRwSgadmYzYkhJQbL2ahs1F2nYUHD3rBmpUM" (got "-Q9-eNhkNasysBQUX6w5i-QN-X0W8WSFeObSe28rmPo.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8")
[11:04:23] INFO: Selected http verification
[11:04:23] INFO: Detecting existing certificate type for homeassistant.xxxxxxxxx.com
[11:04:24] INFO: No certificate found - using 'ecdsa' key type.
  Type:   unauthorized
  Detail: The key authorization file from the server did not match this challenge. Expected "VzZlgLIP3xZ2YEjRYfZXDptox-aHOjE1xJU3KcTTABE.DtYtklcMRwSgadmYzYkhJQbL2ahs1F2nYUHD3rBmpUM" (got "VzZlgLIP3xZ2YEjRYfZXDptox-aHOjE1xJU3KcTTABE.4E3VCTFsySjUrqnCg0ooULx-3kbdPBygi0aWkvg5Gd8")
s6-rc: info: service s6rc-oneshot-runner successfully stoppe
On dirait un souci avec le port 80.
Je viens de regarder sur mon terminal, et le port semble ouvert
C’est 192.168.1.254 ou 192.168.1.185 , l’ip de ton HA ?
mon HA c’est 192.168.1.185
192.168.1.254 c’est mon panel bouygue de ma box
ca donne quoi la même commande mais avec l’ip de HA ?
Voila le problème !
tu dois avoir le port 80 utiliser pour ta box. il faudrais le désactiver, mais je ne sais pas comment.
Moi j’avais configuré comme ça
Est-ce que j’enlève les deux configurations pour voir ?
Non, un service de ta box utilise la 80. un accès a distance activer ?
je connais pas la box bouygues .
