Comment faire des "mode"
bonjour, je viens de jeedom et j’utilisais un plugin mode pour avoir dans le dashboard les boutons de selection de modes comment peut on faire sur HA
merci d’avance
[center]## System Information
version core-2025.2.3
python_version 3.13.1
os_version 6.6.73-haos
arch x86_64
Installed Version 2.0.5
Available Repositories 1536
Downloaded Repositories 6
host_os Home Assistant OS 14.2
supervisor_version supervisor-2025.02.1
agent_version 1.6.0
docker_version 27.2.0
disk_total 68.2 GB
disk_used 43.6 GB
virtualization kvm
board ova
installed_addons File editor (5.8.0), Terminal & SSH (9.16.0), Mosquitto broker (6.5.0), Samba Backup (5.2.0), SomfyProtect2MQTT (2025.2.1b), ESPHome Device Builder (2024.12.4), Linky (1.5.0)
dashboards 2
resources 12
views 12
Network Configuration
adapters lo (disabled), enp0s3 (enabled, default, auto), docker0 (disabled), hassio (disabled), veth0aa82f7 (disabled), vethd9fbbd2 (disabled), veth55bb3b8 (disabled), veth094d0aa (disabled), veth8351ed3 (disabled), veth9a1a5c3 (disabled), veth26b4a78 (disabled), veth5f417bc (disabled)
ipv4_addresses lo (127.0.0.1/8), enp0s3 (192.168.1.101/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), veth0aa82f7 (), vethd9fbbd2 (), veth55bb3b8 (), veth094d0aa (), veth8351ed3 (), veth9a1a5c3 (), veth26b4a78 (), veth5f417bc ()
ipv6_addresses lo (::1/128), enp0s3 (fda1:900e:6b9b:a878:5ad4:35b:bb74:8b1f/64, fe80::9682:7a57:4f01:784f/64), docker0 (fe80::42:ceff:fe78:6aac/64), hassio (fe80::42:3cff:fe71:ca90/64), veth0aa82f7 (fe80::4804:72ff:fed6:7446/64), vethd9fbbd2 (fe80::bc25:69ff:fe32:4e05/64), veth55bb3b8 (fe80::607e:5dff:fea4:ae9f/64), veth094d0aa (fe80::6848:1bff:fee8:a5c5/64), veth8351ed3 (fe80::149d:c5ff:feaa:28fe/64), veth9a1a5c3 (fe80::d013:feff:fe6d:a890/64), veth26b4a78 (fe80::a8fe:3ff:fe18:1d03/64), veth5f417bc (fe80::3b:56ff:fe35:affb/64)
announce_addresses 192.168.1.101, fda1:900e:6b9b:a878:5ad4:35b:bb74:8b1f, fe80::9682:7a57:4f01:784f
oldest_recorder_run 1 février 2025 à 08:42
current_recorder_run 14 février 2025 à 13:10
estimated_db_size 515.11 MiB
database_version 3.47.1
[/center]
Bonjour, regardes ces 2 liens, ils sont vraiment bien et devrait repondre à ta demande
Merci j’ai reussi a creer les cartes de mode
par contre quel est le plus simple pour faire une action quand elle switch de mode?
Plusieurs écoles se valent c’est suivant les affinités de chacun ou plutôt, pour moi, les possibles réutilisations.
pour mon ballon j’ai créé des scènes que j’appelle dans la button card.
Sinon tu peux faire des scripts que tu peux réutiliser soit dans des automatismes ou dans d’autres cartes. tu peux aussi appeler directement l’appareil par switch turn on ou off.
en fait chaque cas est différent suivant l’appareil sollicité. il n’y a pas de meiileurs ou de plus mauvais (les scripts ont un avantage car on peut leur demander de continuer meme si un appareil est défaillant)
En phase avec les explications de @Patrick44fr .
Il y a par contre un détail : dans le plugin mode il y avait les notions d’entrée/sortie des modes. Sous HA, ce n’est similaire que dans les automatisations (from/to) avec une entité de type input_select ou select. Autrement le choix est effectivement libre
Merci pour ces précisions du coup je vais le faire en automation
