Avec la grid ou la position(absolute, bottom: 10px, left: 10px)
Bon jâai bien avancĂ© grĂące Ă lâaide de @BarTouZ .
La position du volet je lâas rĂ©cupĂšre via mqtt:
- platform: mqtt
state_topic: "nodered/volet/fixe_jardin/get"
unit_of_measurement: '%'
jâai pas rĂ©ussi Ă lâajouter au sensor directement:
volet_fixe_jardin:
friendly_name: "Fixe Jardin"
open_cover:
service: mqtt.publish
data_template:
topic: 'nodered/volet/fixe_jardin/set'
payload: 'up'
close_cover:
data_template:
payload: 'down'
stop_cover:
data_template:
payload: 'stop'
set_cover_position:
data_template:
payload: "{{position}}"
Comment je peux mettre a jour via le template cette donnée?
cover:
tap_action:
action: more-info
icon: |
var icon = 'mdi:window-shutter';
if (entity.attributes.current_position == 0){
} else
var icon = 'mdi:window-shutter-open';
return icon ;
label: |-
var etat = "";
if (entity.attributes.current_position == 100)
etat = 'Ouvert';
else if (entity.attributes.current_position == 0)
etat = "Fermé";
else
etat = "Ouvert" + ' âą ' + (entity.attributes.current_position) + '%' ;
return etat ;
state:
- operator: template
value: |
return entity.attributes.current_position != 0;
styles:
icon:
- color: rgba(var(--couleur-bleu),1)
img_cell:
- background-color: rgba(var(--couleur-bleu),0.2)
Il faut passer par cette clĂ© â
Hum @Clemalex,
Je tâavoue que jâai fait un gros copiĂ© / collĂ© du code template pour la PS4âŠ
ps4:
label: >-
[[[ if (entity.state =='unknown'){
return "Off";
}else if (entity.state =='standby'){
return "En veille";
}else{
return "On";
styles:
icon:
- color: 'rgba(var(--couleur-theme),0.2)'
img_cell:
- background-color: 'rgba(var(--couleur-theme),0.05)'
state:
- value: 'idle'
styles:
icon:
- color: 'rgba(var(--couleur-bleu),1)'
img_cell:
- background-color: 'rgba(var(--couleur-bleu), 0.2)'
- value: 'standby'
styles:
icon:
img_cell:
value: >
return entity.state !='unknown'
return entity.attributes.media_title;
label: >
return entity.attributes.friendly_name;
styles:
label:
- color: white
- filter: opacity(100%)
img_cell:
- background-color: 'none'
icon:
- color: white
name:
- color: white
card:
- background-blend-mode: multiply
- background: >
var image = entity.attributes.entity_picture;
return 'center / cover url(' + image + ') rgba(0, 0, 0, 0.15)';
Il ma manquait :
position: absolute
Câest parfait ! Merci ![]()
La position_template ?
Jâai essayĂ© mes pas marchĂ©, je met le topic mqtt dedans?
Tu ouvres un sujet dédié pour ce⊠sujet⊠![]()
Merci pour la carte
quand vous donnée des bout de code/config/template essayer de metre une image qui représente ce que sa donne/fait
Merci a tous ![]()
Bonjour @Clemalex
As-tu trouvĂ© le temps de nettoyer ton script pour lâaspirateur? Jâavoue que cette petite carte donne bien envie et nâayant pas encore touchĂ©e la partir script de HA jâai aucune idĂ©e de comment terminer ça seul.
Merci dâavance!
NonâŠ
Jâessaierai de le faire ce soir ![]()
Edit:
Pour obtenir cette carte :
Câest une concatĂ©nation (Ă lâaide de la carte personnelle custom-card Stack-in-Card) de cette carte :
#carte
type: custom:button-card
template: card_1_line_4_actions_select_vacuum_fan_speed
triggers_update:
- sensor.aspiro_fan
variables:
item1_background_entity: sensor.aspiro_fan
item1_background_state: GENTLE
item1_icon: mdi:water
item2_background_entity: sensor.aspiro_fan
item2_background_state: SILENT
item2_icon: mdi:fan
item2_icon_scale: 0.75
item3_background_entity: sensor.aspiro_fan
item3_background_state: STANDARD
item3_icon: mdi:fan
item3_icon_scale: 1.3
item4_background_entity: sensor.aspiro_fan
item4_background_state: TURBO
item4_icon: mdi:fan
item4_icon_scale: 2
#templates:
button_card_templates:
card_1_line_4_actions_select_vacuum_fan_speed:
variables:
items_background_color: white
item1_icon: mdi:numeric-1-circle
item1_icon_scale: 1
item1_background_entity: default
item1_background_state: default
item2_icon: mdi:numeric-2-circle
item2_icon_scale: 1
item2_background_entity: default
item2_background_state: default
item3_icon: mdi:numeric-3-circle
item3_icon_scale: 1
item3_background_entity: default
item3_background_state: default
item4_icon: mdi:numeric-4-circle
item4_icon_scale: 1
item4_background_entity: default
item4_background_state: default
styles:
card:
- border-radius: 20px
- box-shadow: none
- padding: 12px
- background: transparent
grid:
- grid-template-areas: '"4items"'
- grid-template-columns: 1fr
- grid-template-rows: min-content min-content
- row-gap: 12px
custom_fields:
4items:
card:
template: list_items_1_line_4_actions
custom_fields:
item1:
card:
icon: '[[[ return variables.item1_icon ]]]'
styles:
card:
- background-color: |
if (states[variables.item1_background_entity].state.toUpperCase() == variables.item1_background_state){
return variables.items_background_color;
}else{
return 'transparent';
icon:
- transform: >-
[[[ return 'scale(' + variables.item1_icon_scale + ')'
tap_action:
action: call-service
service: input_select.select_option
service_data:
entity_id: input_select.vacuum_aspiro_speed_set
option: Gentle
template:
- widget_icon_action
item2:
card:
icon: '[[[ return variables.item2_icon ]]]'
styles:
card:
if (states[variables.item2_background_entity].state.toUpperCase() == variables.item2_background_state){
}else{
icon:
- transform: >-
[[[ return 'scale(' + variables.item2_icon_scale + ')'
tap_action:
service_data:
option: Silent
template:
item3:
card:
icon: '[[[ return variables.item3_icon ]]]'
styles:
card:
if (states[variables.item3_background_entity].state.toUpperCase() == variables.item3_background_state){
}else{
icon:
- transform: >-
[[[ return 'scale(' + variables.item3_icon_scale + ')'
tap_action:
service_data:
option: Standard
template:
item4:
card:
icon: '[[[ return variables.item4_icon ]]]'
styles:
card:
if (states[variables.item4_background_entity].state.toUpperCase() == variables.item4_background_state){
}else{
icon:
- transform: >-
[[[ return 'scale(' + variables.item4_icon_scale + ')'
tap_action:
service_data:
option: Turbo
template:
list_items_1_line_4_actions:
styles:
card:
- box-shadow: none
- padding: 0px
- border-radius: 21px
- pointer-events: none
- background-color: rgba(var(--couleur-gris),0.2
- justify-items: center
grid:
- grid-template-areas: '"item1 item2 item3 item4"'
- grid-template-columns: 1fr 1fr 1fr 1fr
- column-gap: 7px
img_cell:
widget_icon_action:
show_icon: true
show_name: false
styles:
card:
- box-shadow: none
- padding: 0px
- border-radius: 50%
- place-self: center
- height: 42px
- width: 42px
- pointer-events: auto
grid:
- grid-template-areas: '"i"'
icon:
- color: rgba(var(--couleur-theme),0.9)
Le modĂšle (template) card_1_line_4_actions_select_vacuum_fan_speed contient en dur les actions des 4 icones. Le reste est âč variabilisĂ© âș.
items_background_color (requis): correspond Ă la couleur de fond lorsque de lâĂ©tat deitem[1,2,3,4]_background_entity (requis)correspond Ă la valeur deitem[1,2,3,4]_background_state (requis, en MAJUSCULE)item[1,2,3,4]_iconcorrespond Ă lâicone Ă afficher (optionnel)item1_icon_scalecorrespond Ă la taille de lâicone (optionnel)
#carte
template: vacuum
variables:
entity: vacuum.xiaomi_vacuum_cleaner
et le modĂšle :
vacuum:
variables:
entity: vacuum.default
styles:
card:
- box-shadow: var(--box-shadow)
- padding: 12px
grid:
- grid-template-areas: '"item1" "item2"'
- row-gap: 12px
custom_fields:
item1:
card:
template: list_items_only_one
custom_fields:
item1:
card:
entity: '[[[ return variables.entity ]]]'
name: '[[[ return variables.name ]]]'
tap_action:
action: more-info
template:
- icon_info
- vacuum_info
item2:
card:
custom_fields:
item1:
card:
icon: mdi:pause
tap_action:
service: script.turn_on
service_data:
entity_id: script.aspiro_stop
template: widget_icon
item2:
card:
icon: mdi:battery-charging
tap_action:
service_data:
entity_id: script.aspiro_charge
item3:
card:
icon: mdi:map-marker-path
tap_action:
service: persistent_notification.create
service_data:
message: 2eme ligne - 3eme Bouton
title: Debug Carte Aspirateur
notification_id: '{{ (range(1, 9999)|random) }}'
list_items_only_one:
styles:
card:
- box-shadow: none
- padding: 0px
grid:
- grid-template-areas: '"item1"'
- column-gap: 7px
vacuum_info:
tap_action:
action: none
icon: mdi:robot-vacuum
label: |-
if (entity.state.toUpperCase() == 'DOCKED' && entity.attributes.battery_level == '100'){
return 'Sur sa base';
else if (entity.attributes.status.toUpperCase() == 'CHARGING'){
return 'En charge';
else if (entity.state.toUpperCase() == 'CLEANING'){
return 'Nettoyage en cours';
else if (entity.attributes.status.toUpperCase() == 'RETURNING HOME'){
return 'Retour vers sa base';
else if (entity.attributes.status.toUpperCase() == 'PAUSED'){
return 'En pause';
else{
return 'â Inconnu â' ;
styles:
icon:
- color: |-
return 'rgba(var(--couleur-gris),1)';
return 'rgba(var(--couleur-vert),1)';
return 'rgba(var(--couleur-jaune),1)';
return 'rgba(var(--couleur-violet),1)';
return 'rgba(var(--couleur-bleu),1)';
else{
img_cell:
- background-color: |-
return 'rgba(var(--couleur-gris),0.2)';
return 'rgba(var(--couleur-vert),0.2)';
return 'rgba(var(--couleur-jaune),0.2)';
return 'rgba(var(--couleur-violet),0.2)';
return 'rgba(var(--couleur-bleu),0.2)';
else{
Ce qui donne donc en concaténant les deux :
#carte
type: custom:stack-in-card
mode: vertical
style: |
ha-card{
border-radius: 21px;
cards:
- type: custom:button-card
template: vacuum
variables:
triggers_update:
- sensor.aspiro_fan
variables:
item2_icon: mdi:fan
item3_icon: mdi:fan
item4_icon: mdi:fan
item4_icon_scale: 2
Pour lâutilisation de lâaspirateur, jâai un input_select contenant les vitesses dâaspiration et une automatisation qui sur changement, envoie la consigne.
Jâai des scripts pour chaque action de lâaspirateur (start, pause, retour , nettoyage de zone1, 2, etc.)
et aussi
câest au dessus ![]()
câest pas super super nettoyĂ©, mais bon⊠au moins câest partagĂ© ![]()
Je partagerai Ă©galement bientĂŽt (1 Ă 2 semaines) le boulot que jâai fait avec @barto_95 afin dâafficher une carte et un lien cliquable lançant google maps ou waze en mode itinĂ©raire (afin dâaller retrouver sa moitiĂ© quand elle est perdue en mode GPS plutĂŽt quâen mode âč lâautre droite âș
La conversation sur discord: Discord
un aperçu :
@barto_95 et les autres :
Ăa arrive ce soir (tard) ![]()
Déjà la carte :
template:
- icon_info_bg
- personnes
- popup_map
entity: person.clemalex
show_entity_picture: true
entity_picture: /local/images/person/clemalex.png
variables:
gps: google_maps #mettre 'waze' pour redirection vers l'application Waze
#les modĂšles (templates)
personnes:
show_label: true
label: |
if (entity.state == 'home'){
return "Domicile";
else if (entity.state == 'not_home'){
return "En Balade";
}else{
return entity.state; //dans une zone
styles:
entity_picture:
- transform: scale(2)
custom_fields:
notification:
- transform: scale(1.3)
- position: absolute
- right: 8px
- top: 8px
- height: 16px
- width: 16px
- border: 2px solid var(--card-background-color)
- font-size: 12px
- line-height: 14px
return "rgba(var(--couleur-bleu),1)";
}else{
return "rgba(var(--couleur-vert),1)";
custom_fields:
notification: |
var icon = "" ;
icon="mdi:home-variant"
}else{
icon="mdi:pine-tree"
return `<ha-icon icon="${icon}" style="width: 10px; height: 10px; color: white;"></ha-icon>`
popup_map:
variables:
gps: google_maps
tap_action:
action: fire-dom-event
browser_mod:
command: call-service
service: browser_mod.popup
service_data:
deviceID:
- this
title: '[[[ return( "Position de " + entity.attributes.friendly_name); ]]]'
style:
.mdc-dialog {
backdrop-filter: blur(5px) !important;
-webkit-backdrop-filter: blur(5px) !important;
mwc-icon-button ha-icon {
font-size: 0;
.content{padding: 0 10px 10px 10px}
card:
type: vertical-stack
cards:
- template:
- map_card
entity: '[[[ return entity.entity_id ]]]'
- type: entities
show_header_toggle: false
- type: weblink
if (variables.gps.toUpperCase() == 'GOOGLE_MAPS'){
var gps = "(via Google Maps)"
else if (variables.gps.toUpperCase() == 'WAZE'){
var gps = "(via Waze)"
return('Itinéraire vers ' + entity.attributes.friendly_name + ' ' + gps);
url: |
return('https://maps.google.com/maps?q='+entity.attributes.latitude+','+entity.attributes.longitude+'&t=&z=15');
return('waze://?ll='+entity.attributes.latitude+','+entity.attributes.longitude+'&z=15&navigate=yes');
map_card:
show_name: false
show_icon: false
styles:
card:
- padding: 12px
grid:
- row-gap: 12px
custom_fields:
item1:
card:
type: iframe
url: |-
var lat = entity.attributes.latitude
var long = entity.attributes.longitude
return `https://maps.google.com/maps?q=${lat},${long}&t=&z=13&ie=UTF8&iwloc=&output=embed`
aspect_ratio: 96%
#Présent de base
icon_info_bg:
color: var(--google-grey-500)
show_icon: true
show_name: true
show_label: true
custom_fields:
notification: |
if (entity.state =='unavailable'){
return `<ha-icon icon="mdi:exclamation" style="width: 12px; height: 12px; color: white;"></ha-icon>`
state:
- styles:
custom_fields:
notification:
- left: 38px
- top: 8px
- height: 16px
- width: 16px
- font-size: 12px
- line-height: 14px
return "rgba(var(--couleur-rouge),1)";
value: unavailable
styles:
card:
- padding: 12px
grid:
- grid-template-areas: '"i n" "i l"'
- grid-template-columns: min-content auto
icon:
- color: rgba(var(--couleur-theme),0.2)
img_cell:
- background-color: rgba(var(--couleur-theme),0.05)
- width: 42px
- height: 42px
name:
- align-self: end
- justify-self: start
- font-weight: bold
- font-size: 14px
- margin-left: 12px
label:
- align-self: start
- font-weight: bolder
- font-size: 12px
- filter: opacity(40%)
- margin-left: 12px
state:
- align-self: start
- font-size: 12px
- margin-left: 12px
La popup utilise lâintĂ©gration browser-mod .
Il faut juste renseigner dans la carte une entitĂ© comprenant comme attributs latitude et longitude. LâĂ©tat de lâentitĂ© est repris en libellĂ© (home renvoie Domicile, not_home renvoie En Balade, sinon lâĂ©tat (pour une entitĂ© du domaine person ça correspondra au nom dâune zone.
Le lien redirigeant vers Google Maps ou Waze se dĂ©finit via la variable gps. Si elle nâest pas prĂ©sente (ou contient google_maps) le lien redirigera vers Google Maps. Pour lâapplication Waze, il faut renseigner gps: waze.
PS: Oui, je suis en vacance dans les Landes
@barto_95 la redirection vers lâapplication Waze fonctionne sur Android.
Tu me diras pour iOSâŠ
Jâai fait la carte pour les gars comme toi
, pas besoin de rentrer dans le code (si ce nâest pour modifiĂ© les libellĂ©s Ă©crit en dur et donc facilement repĂ©rable et modifiable) ![]()
Merci mec ![]()
je test de suites ![]()
je confirme que tous fonctionne nikel chrome:
Juste a modifier entity par les personne dans mon HA et entity_picture avec les photos des personne de mon HA
Modification de gps par waze (je préfÚre) et sa fonctionne trÚs bien ![]()
Câest parfais ça ![]()
On est bon quand on veut ![]()
Merci pour votre travail
ça mériterait une branche sur le GitHub
voici le template mise Ă jours pour aller avec mĂ©tĂ©o-france (au lieu dâutiliser DarkSKy qui dans quelque mois ne fonctionnera plus et pour les nouveau compte lâinscription est fermer
Nous allons nous basĂ© sur mĂ©tĂ©o france et avec lâaide de @Clemalex nous avons utiliser des variables pour les sensors Ă utiliser dans la card
Voici le template :
pilule_temperature:
variables:
weather: weather.default
outside: sensor.default
inside: sensor.default
template: pilule
tap_action:
action: navigate
navigation_path: /light-mobile/temperature
label: |
var inter = Math.round(states[variables.inside].state* 10) / 10;
var exter = Math.round(states[variables.outside].state* 10) / 10;
if (states[variables.weather].state == 'clear-night'){
var icon = 'đ';
} else if(states[variables.weather].state == 'rainy'){
var icon = 'đ§ïž';
} else if(states[variables.weather].state == 'snowy'){
var icon = 'đšïžïž';
} else if(states[variables.weather].state == 'snowy-rainy'){
} else if(states[variables.weather].state == 'windy'){
var icon = 'đš';
} else if(states[variables.weather].state == 'windy-variant'){
var icon = 'đš';
} else if(states[variables.weather].state == 'fog'){
var icon = 'đ«ïž';
} else if(states[variables.weather].state == 'cloudy'){
var icon = 'âïž';
} else if(states[variables.weather].state == 'partlycloudy'){
var icon = 'â
ïž';
} else if(states[variables.weather].state == 'hail'){
} else if(states[variables.weather].state == 'lightning'){
var icon = 'đ©ïž';
} else if(states[variables.weather].state == 'lightning-rainy'){
var icon = 'âïž';
} else if(states[variables.weather].state == 'pouring'){
} else if(states[variables.weather].state == 'sunny'){
var icon = 'âïž';
} else {
var icon = 'âïž';
return icon + ' ' + inter + '° / ' + exter + '°' ;
Explications :
Jâai ajouter tous les Ă©tats que HA peut prendre pour la mĂ©tĂ©o, je me suis basĂ© sur cette liste disponible sur le DEV HA : Status Sensor MĂ©tĂ©o HA DEV
Jâai donc ajouter des icĂŽnes qui se rapproche le plus de lâĂ©tat, les icons vienne du site emojipedia
si jamais les icĂŽnes ne sont pas bonne ou il en manque nâhĂ©sitĂ© pas Ă le faire savoir
Remplacement de lâicĂŽne par default ,si jamais une icĂŽne ou un status nâexiste pas dans le template remplacement par
(je trouve plus parlant que dâutiliser
Ajout des variables :
qui permet de renseigner dans les cards les entity que lâon souhaite utiliser ainsi cela permet dâavoir un template gĂ©nĂ©ral pour tous les utilisateurs qui souhaite lâutiliser et personnaliser les entitĂ©s dans la card directement.
Voici le code de la carte :
template: pilule_temperature
variables:
weather: weather.herblay
inside: sensor.thermostat_nest_temperature
outside: sensor.herblay_temperature
Ne pas oublier dâindiquer vos sensor pour les variables weather, inside, outside
Voici le résultat
dans mon cas la température intérieur ce base sur le sensor de mon thermostat NEST, la température extérieur sur le sensor météo france, et les icÎnes match les noms du status du sensor de météo france
correction sur la ligne clear-night qui ne sâaffichait pas code mise Ă jour ![]()
