Dashboard - đŸŒ» Minimalist
Voici une petite correction afin de centrer le label :
  graph_with_card_one_item:
    variables:
      entity_carte_gauche: sensor.default
      entity_graph: sensor.default
      color: var(--info-color)
      name_carte_gauche: Default name
      show_icon_carte_gauche: 'false'
      show_name_carte_gauche: 'false'
      icon_carte_gauche: null
      show_label_up: false
      show_label_down: false
      label: label.default
    show_label: |
      [[[ if (variables.show_label_up) return 'true'; return 'false' ]]]
    label: >
      [[[ if (variables.show_label_up || variables.show_label_down ) return
      variables.label; return '' ]]]
    styles:
      card:
        - border-radius: 20px
        - box-shadow: var(--box-shadow)
        - padding: 0px
      grid:
        - grid-template-areas: |
            [[[ if (variables.show_label_up) return '"l" "item1" "item2"';
                if (variables.show_label_down) return '"item1" "l" "item2" ';
                return '"item1" "item2"'
        - grid-template-columns: 1fr
        - grid-template-rows: min-content  min-content
      label:
        - font-weight: bold
        - font-size: 14px
        - padding-top: >
            [[[ if (variables.show_label_up ) return '20px'; if
            (variables.show_label_down ) return '0' ]]]
        - filter: opacity(100%)
      custom_fields:
        item2:
          - padding-top: |
              [[[ if (!variables.show_name_carte_gauche) return '13px';]]]
    custom_fields:
      item1:
        card:
          type: custom:button-card
          entity: '[[[ return variables.entity_carte_gauche ]]]'
          name: '[[[ return variables.name_carte_gauche ]]]'
          template:
            - icon_info
            - generique
          show_icon: '[[[ return variables.show_icon_carte_gauche ]]]'
          show_name: '[[[ return variables.show_name_carte_gauche ]]]'
          label: |
              if (variables.icon_carte_gauche ) return (variables.icon_carte_gauche + " " + states[variables.entity_carte_gauche].state+ " " + states[variables.entity_carte_gauche].attributes.unit_of_measurement);
              return states[variables.entity_carte_gauche].state + " " + states[variables.entity_carte_gauche].attributes.unit_of_measurement;
          styles:
            card:
              - '--padding-mobile': >
                  [[[ if (!variables.show_icon_carte_gauche) return '2px 5px
                  14px 0px'; if (variables.show_icon_carte_gauche) return '3px 0
                  0px 10px'; return '10px 0 9px 10px'; ]]]
              - '--padding-computer': >
                  [[[ if (!variables.show_icon_carte_gauche) return '23px 0 12px
                  0'; return '2px'; ]]]
              - padding: var(--padding-computer)
            label:
              - place-self: auto
          extra_styles: |
            #label {
              white-space: nowrap;
            /* telephone */
            @media screen and (max-width: 800px) {
              #label {
                white-space: pre-line;
              #card {
                padding: var(--padding-mobile) !important;
      item2:
        card:
          type: custom:mini-graph-card
            - entity: '[[[ return variables.entity_graph ]]]'
          line_color: '[[[ return variables.color ]]]'
          show:
            icon: false
            legend: false
            state: false
          style: |
            ha-card {
              box-shadow: none;
              border-radius: var(--border-radius);
Partage ton code de carte :+1:
Idem ton code :+1: (avec les autres pillules car c’est Ă©tonnant)
Merci!!
Tu pourrais m’aiguiller sur l’origine de ce pb d’affichage sur telephone:
Il te faut le code de toute la view?
Merci pour l’info :slight_smile:
J’ai 2 problùmes :
J’ai ça qui me retourne lorsque je clique sur la personne pour voir oĂč elle est :
Custom element doesn't exist: iframe.
Et l’icone de maison n’est pas entourĂ© en bleu, donc quand je passe en mode clair, je ne vois plus l’icĂŽne. Je ne sais pas pourquoi car j’ai repris exactement le mĂȘme code que j’ai mis dans le fichier de template x)
Bon j’ai trouvĂ© mais c’est bizarre, si j’ajoute une carte de type iframe dans un autre lovelace, ma carte s’affiche bien. Mais si je le supprime, ça ne l’affiche plus.
Je souhaiterais bien ajouter cette card mais je n’ai pas la position GPS directement liĂ© aux personnes (car la position GPS ne se met pas toujours Ă  jour et fausse la prĂ©sence dans la maison)
Mais j’ai bien une entitĂ© ou j’ai les postions GPS, j’ai essayĂ© de modifier le code moi mĂȘme mais ca ne marche pas et cela me rend dingue.
Du coup si tu pouvais m’aider pour ca @Clemalex ca serais top.
Un grand kiff pour toutes les card que tu à fait pour ce design j’adore siple et efficace :wink:
Autre question je n’arrive pas Ă  faire fonctionner la carte lumiĂšres qui utilise custom:slider-card, je prĂ©sume que c’est un frontend de hacs mais je n’arrive pas Ă  le trouver
L’auteur a rĂ©cemment archivĂ© le dĂ©pot donc HACS ne l’affiche plus (il me semble
). Il donne un lien vers le nouveau dĂ©pot. (peut ĂȘtre faut-il l’ajouter Ă  HACS via le menu)
Non merci :wink:
Mais quelle est la structure ? (une vertical-stack ou grid avec d’autre ou toutes les cartes les une à la suites, etc
 :thinking:
Oui mets le code de la vue :sweat_smile: :upside_down_face: :smirk:
Ensuite, crée une vue temporaire et envoie une a une les cartes sur la nouvelle vue. Cela permettra peut etre de mettre en evidence une carte qui affecte le rendu. :face_with_monocle:
Commence par la tuile de la consommation Ă©lectrique
Si c’est elle peut etre utiliser Lovelace: Swiper card - Dashboards & Frontend - Home Assistant Community sur la premiere ligne
J’ai dĂ©jĂ  observĂ© ce comportement et je l’avais rĂ©solu d’une façon trĂšs barbare. Je te passe le code ce soir. Je regarderais pourquoi ça ne me le fait plus : Tu as la derniĂšre version de HA ?
Le principe consiste à afficher une iframe et de la masquer à l’aide de card-mod
Tu as bien pris le thÚme associé à Minimalist ?
Tu mets juste l’entitĂ© contenant les attributs latitude et longitude en lieu et place de l’entitĂ© person.
template:
  - icon_info_bg
  - personnes
  - popup_map
entity: sensor.gps #<----------ICI, l'entitĂ© doit contenir les attributs lat et long pour ĂȘtre affichĂ© sur la carte)
show_entity_picture: true
entity_picture: /local/images/person/clemalex.png
variables:
  gps: google_maps #mettre 'waze' pour redirection vers l'application Waze
Salut @Clemalex,
Résolu en changeant le nom des variables correspondant aux couleurs en les passants en Anglais.
Ce que je ne comprends toujours pas, c’est que le contenu iframe de la carte ne s’affiche pas. Aurais-tu une idĂ©e ?
D’ailleurs si j’utilise le thĂšme â€č desktop â€ș ou â€č mobile â€ș, ça ne change rien, je reste sur un affichage type mobile. Hors je vois que ça s’affiche bien en colonne sĂ©parĂ©e sur ton rendu PC, chose que je ne comprends pas non plus.
Alors voici le code de cette view:
cards:
  - cards:
      - template: return_button
      - template: pilule_temperature
      - template: pilule_consommation_prix
    type: horizontal-stack
  - type: custom:button-card
    template: titre
  - cards:
      - type: weather-forecast
        style: |
          ha-card {
            box-shadow: var(--box-shadow);
            border-radius: 20px;
            padding: 12px !important;
          .icon-image{
            min-width: 42px !important;
            margin-right: 12px !important;
          .icon-image > *{
            height: 42px !important;
            width: 42px;
            flex: 0 0 42px !important;
          .state {
            font-size: 14px !important;
            font-weight: bold;
          .name{
            font-weight: bolder;
            font-size: 12px !important;
            filter: opacity(40%);
            color: #333333 !important;
          .temp{
            font-weight: bold;
            margin-right: 14px !important;
          .attribute{
          span{
            font-weight: bold;
        entity: weather.nersac
        show_forecast: false
    label: Intérieur
    template: titre
  - type: grid
    columns: 2
    square: false
    cards:
        template: graph_with_card
        variables:
          entity_carte_gauche: sensor.netatmo_galahome_galastation_temperature
          entity_carte_droite: sensor.netatmo_galahome_galastation_humidity
          entity_graph: sensor.netatmo_galahome_galastation_temperature
          name_carte_gauche: Température
          name_carte_droite: Humidité
          color: var(--google-blue-500)
          show_icon_carte_droite: false
          show_icon_carte_gauche: false
          show_name_carte_droite: false
          show_name_carte_gauche: false
          icon_carte_gauche: đŸŒĄïž
          icon_carte_droite: 💧
          show_label_up: true
          label: Salon
        custom_fields:
          item2:
            card:
              hours_to_show: 24
              hour24: true
              show:
                extrema: true
        variables:
          entity_carte_gauche: sensor.sensor_suitep_temperature
          entity_carte_droite: sensor.sensor_suitep_humidity
          entity_graph: sensor.sensor_suitep_temperature
          show_label_up: true
          label: Suite Parentale
        custom_fields:
          item2:
            card:
              hours_to_show: 24
              hour24: true
              show:
                extrema: true
        variables:
          entity_carte_gauche: sensor.sensor_chbjardin_temperature
          entity_carte_droite: sensor.sensor_chbjardin_humidity
          entity_graph: sensor.sensor_chbjardin_temperature
          show_label_up: true
          label: Chambre Jardin
        custom_fields:
          item2:
            card:
              hours_to_show: 24
              hour24: true
              show:
                extrema: true
        variables:
          entity_carte_gauche: sensor.sensor_chbterrasse_temperature
          entity_carte_droite: sensor.sensor_chbterrasse_humidity
          entity_graph: sensor.sensor_chbterrasse_temperature
          show_label_up: true
          label: Chambre Terrasse
        custom_fields:
          item2:
            card:
              hours_to_show: 24
              hour24: true
              show:
                extrema: true
        variables:
          entity_carte_gauche: sensor.sensor_cellier_temperature
          entity_carte_droite: sensor.sensor_cellier_humidity
          entity_graph: sensor.sensor_cellier_temperature
          show_label_up: true
          label: Cellier
        custom_fields:
          item2:
            card:
              hours_to_show: 24
              hour24: true
              show:
                extrema: true
        variables:
          entity_carte_gauche: sensor.sensor_garage_temperature
          entity_carte_droite: sensor.sensor_garage_humidity
          entity_graph: sensor.sensor_garage_temperature
          show_label_up: true
          label: Garage
        custom_fields:
          item2:
            card:
              hours_to_show: 24
              hour24: true
              show:
                extrema: true
    label: Extérieur
    template: titre
  - type: grid
    columns: 2
    square: false
    cards:
        variables:
          entity_carte_gauche: sensor.netatmo_galahome_galastation_galamodule_temperature
          entity_carte_droite: sensor.netatmo_galahome_galastation_galamodule_humidity
          entity_graph: sensor.netatmo_galahome_galastation_galamodule_temperature
          color: var(--google-green-500)
          show_label_up: true
          label: Jardin
        custom_fields:
          item2:
            card:
              hours_to_show: 48
              hour24: true
              show:
                extrema: true
        template: graph_with_card_one_item
        variables:
          entity_carte_gauche: sensor.sonde_piscine
          entity_graph: sensor.sonde_piscine
          show_label_up: true
          label: Piscine
        custom_fields:
          item2:
            card:
              hours_to_show: 48
              hour24: true
              show:
                extrema: true
type: vertical-stack
Pour comparer voici une autre vue:
et son code:
cards:
  - cards:
      - template: bordures
      - card:
          entity: input_boolean.mode_vacances
          template: pilule
          tap_action:
            action: navigate
            navigation_path: /lovelace/localisation
          label: ⛱
        conditions:
          - entity: input_boolean.mode_vacances
            state_not: 'off'
        type: conditional
      - card:
          entity: input_boolean.invite_present
          template: pilule
          tap_action:
            action: navigate
          label: 😃
        conditions:
          - entity: input_boolean.invite_present
            state_not: 'off'
        type: conditional
  - type: grid
    cards:
        template: titre
      - type: grid
        cards:
            variables:
              show_label_up: true
              label: Piscine
            custom_fields:
              item2:
                card:
                  hours_to_show: 48
                  hour24: true
                  show:
                    extrema: true
        columns: 1
        square: false
      - type: grid
        cards: []
        columns: 2
        square: false
      - type: grid
        cards:
          - entity: input_boolean.light_pool
            template:
              - icon_info_bg
              - light
            variables:
              image: /local/images/backgrounds/lamp_v2.jpg
            styles:
              card:
                - padding-top: 10px
                - padding-bottom: 10px
                - background-blend-mode: multiply
                - background: |
                        if (variables.image != null) {
                          return 'center / cover url(' + variables.image + ') rgba(0, 0, 0, 0.3)';
                        return '';
          - entity: input_boolean.winter_pool
            template:
              - icon_info_bg
              - bleu
            label: |-
                  var etat = '';
                  if (entity.state == 'on')
                    etat = "On ";
                  else
                    etat = "Off";
                  return etat;
            variables:
              image: /local/images/backgrounds/snow.jpg
            styles:
              card:
                - background: |
                        return '';
          - entity: input_select.pool_pump
            name: Mode filtration
            variables:
              cycle: sensor.cycle_filtration
              image: /local/images/backgrounds/clean.jpg
            template:
              - icon_info_bg
              - sensor_piscine
            styles:
              card:
                - padding-top: 10px
                - background: |
                        return '';
          - entity: input_datetime.pool_filter_date
            name: Clean filtration dans
            template:
              - icon_info_bg
              - sensor_date
            variables:
              nbJours: 15
              image: /local/images/backgrounds/calendar.jpg
            styles:
              card:
                - padding-top: 10px
                - background: |
                          return 'center / cover url(' + variables.image + ') rgba(0, 0, 0, 0.7)';
                        return '';
        columns: 2
        square: false
    columns: 1
    square: false
Re,
Merci pour ton aide. Voici les codes :
Pour les cameras :
      - type: 'custom:button-card'
        template: titre
      - cards:
          - type: grid
            columns: 2
            square: false
            cards:
              - entity: camera.cam_garage
                template:
                  - tuile_neutre
                camera_image: camera.cam_garage
                show_name: false
                show_live_stream: true
                camera_view: live
                tap_action:
                  action: toggle
                hold_action:
                  action: more-info
              - entity: camera.camera_buanderie
                template:
                  - tuile_neutre
                camera_image: camera.camera_buanderie
                show_name: false
                camera_view: live
                tap_action:
                  action: toggle
Le template:
tuile_neutre:
    tap_action:
      action: more-info
    show-name: false
    styles:
      card:
        - padding: 12px
Maintenant pour le chips :
Les templates
pilule_localisation:
    template: pilule
    show_icon: true
    label: |
        var personnes_presentes = states['sensor.people_count_present'].state;
        return '🏠' +  personnes_presentes;
    styles:
      grid:
        - grid-template-areas: '"i"'
    tap_action:
      action: navigate
pilule:
    tap_action:
      action: more-info
    show_icon: false
    show_name: false
    show_state: false
    show_label: true
    styles:
      img_cell:
        - width: 24px
      card:
        - border-radius: 30px
        - height: 36px
        - width: auto
        - padding-left: 6px
        - padding-right: 6px
      grid:
        - grid-template-areas: '"l"'
      label:
        - justify-self: center
        - padding: 0px 6px
        - font-weight: bold
        - font-size: 14px
Je sais pas si c’est bien lisible, dis moi si tu as besoin d’un truc plus clair :slight_smile:
Il manque le code de la carte.
Je soupçonne l’ordonnancement des templates
Dans le code de la carte je pense que tu dois avoir mis :
template:
  - pillule
  - pillule_localisation
Si tel est le cas, essaie dans l’ordre inverse :
template:
  - pillule
Et de toute façon, je pense que dans le code de pillule_localisation, la dĂ©finition des zones de la grille n’est pas correcte. Elle affiche seulement l’icone ('"i"') au lieu du label ('"l"').
Il faudrait enlever la définition de la grille dans le modÚle pillule_localisation ce qui donnerais :
    template: pilule
    show_icon: true
    label: |
    styles:
      grid:
        - grid-template-areas: '"l"'   #<-- l en lieu et place de i
    tap_action:
      action: navigate
:expressionless: :expressionless:
:grin:
En te donnant la correction du modele pilule_localisation, je viens de m’apercevoir qu’il utilisait le modùle pillule
Du coup, tu as donc dans ta carte :
template:
  - pilule_localisation
Ce qui revient Ă  ce que j’ai soupçonnĂ© plus haut.
Du coup, il faut juste corriger le modÚle comme décrit juste au dessus.
PS: j’ai laissĂ© volontairement tout l’angle de rĂ©flexion pour aider Ă  la comprĂ©hension de l’utilisation des modĂšles :wink:
Que veut dire :
Dans un autre lovelace
Dans un autre tableau de bord ? Dans une autre vue du mĂȘme tableau de bord ? Dans une autre carte dans la vue du tableau de bord ? :wink:
Je viens de tester de mettre ce code sur mon instance de test dédiée HACF et cela fonctionne :
type: iframe
url: >-
  https://maps.google.com/maps?q=48.858370,2.294481&t=&z=17&ie=UTF8&iwloc=&output=embed
aspect_ratio: 50%
En ajoutant cette carte dans un tableau de bord, est que la carte google map s’affiche avec comme position la Tour Eiffel ?
La seule diffĂ©rence notable c’est :
Aprùs, il faut y aller par dichotomie afin de savoir qu’elle carte est responsable.
A votre service :wink:
animate
Le code de la carte :
entity: camera.demo_camera #entity_id de la caméra à afficher
template:
  - camera_live
  - tuile_neutre
les modĂšles :
button_card_templates:
  camera_live:  #Affiche la camera dans une picture-entity
    show_label: false
    show_icon: false
    show_name: false
    styles:
      grid:
        - grid-template-areas: '"item1"'
    custom_fields:
      item1:
        card:
          camera_image: '[[[ return entity.entity_id ]]]'
          camera_view: live
          entity: '[[[ return entity.entity_id ]]]'
          show_name: false
          show_state: false
          type: picture-entity
  tuile_neutre:
    tap_action:
      action: more-info
    show-name: false
    styles:
      card:
        - padding: 12px
Je le prĂ©sente au passage car je ne l’ai pas encore rencontrĂ© :
Le modùle a ajouter lors de l’utilisation du modùle titre (ou title) quand on veut simplement le label et non le nom
:expressionless:
En image c’est plus parlant :grin:
De base, ca donnerai ça :
Oh le vilain décalage !
Du coup en ajoutant un petit modÚle, on arrive à ça :
Mieux non ?!
Donc voici le code de la carte utilisant le titre sans le nom :
name: lorem #requis !!! Un seul caractĂšre suffit. NE DOIS PAS ETRE VIDE ""
label: Caméra Jardin
template:
  - titre
  - titre_no_name  #le modele supplémentaire en question
Le modĂšle :
  titre_no_name:
    styles:
      name:
        - visibility: hidden
Fais nous un retour en image :+1:
MĂȘme pas besoin de demander c’est gĂ©nial ^^
Moi j’ai mes cameras sur mon Syno, je passe donc par l’entitĂ© créé par l’intĂ©gration Syno.
Je n’ai pas d’affichage, c’est noir. J’ai rechargĂ© l’intĂ©gration mais rien non plus.
Pour mon soucis de dĂ©calage, je ne vois pas de « trou » dans le code de mon lovelace
