Merci c’est sympa, j’ai commandé. Pourrais-tu mettre le code en entier stp ? Merci
Oui je te colle ça dans la sem qd je serai chez moi le copier coller avce le smartphone c pas très pratique.
Pour info mon esp fait proxy pour les sondes plantes xiaomi ça marche très bien. Et ça permet aussi de piloter l’arrosage du jardin
esphome:
friendly_name: ESP-ETH
#platform: ESP32
##oard: esp-wrover-kit
esp32:
board: esp-wrover-kit
framework:
type: esp-idf
#version: recommended
#sdkconfig_options:
# COMPILER_OPTIMIZATION_SIZE: y
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO0_IN
phy_addr: 1
power_pin: GPIO16
manual_ip:
static_ip: 192.168.8.8
gateway: 192.168.8.1
subnet: 255.255.255.0
dns1: 192.168.8.1
# Enable logging
logger:
level: WARN
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: *
ota:
platform: esphome
password:*
#wifi:
# ssid: !secret wifi_ssid
# password: !secret wifi_password
# manual_ip:
# static_ip: !secret wifi_espeth_ip
# gateway: !secret wifi_gtw
# subnet: !secret wifi_sub
# dns1: !secret wifi_dns1
# ap:
# ssid: "Esp-Eth Fallback Hotspot"
# password:*
#captive_portal:
web_server:
port: 80
# JustSalt
substitutions:
mac_justsalt: "*"
service_uuid: '09912756-7b32-4629-aeb1-b309d9a338ae'
characteristic_uuid: 'ef785c24-22bb-463d-b651-0b7445ba091c'
characteristic_uuid_write: '4d32c5e5-2bb5-45c6-8c89-6f59bb3930d2'
bluetooth_proxy:
active: true
esp32_ble_tracker:
scan_parameters:
#interval: 1100ms
#window: 1100ms
active: true
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: /5
then:
- switch.turn_off: ble_switch_com
- delay: 20s
- switch.turn_on: ble_switch_com
ble_client:
- mac_address: ${mac_justsalt}
auto_connect: true
on_connect:
then:
- ble_client.numeric_comparison_reply:
accept: True
binary_sensor:
# - platform: gpio
## pin: GPIO14
## name: "Compteur Deblit piscine"
## internal: true
## filters:
# - delayed_off: 10ms
- platform: ble_presence
number:
name: "ORP Consigne"
icon: "mdi:flash-triangle-outline"
unit_of_measurement: "mV"
min_value: 200
max_value: 900
step: 10
optimistic: true
on_value:
then:
- ble_client.ble_write:
service_uuid: ${service_uuid}
characteristic_uuid: ${characteristic_uuid_write}
value: !lambda |-
//float state = std::stof(id(orp_consigne_new).state);
ESP_LOGD("ORPconsigne", "Option consigne change: %f", id(orp_consigne_new).state);
uint8_t statehex = id(orp_consigne_new).state / 10;
return {0x00, 0x06, 0x03, 0x35, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "ORP Alarme Consigne"
icon: "mdi:alarm"
unit_of_measurement: "h"
min_value: 12
max_value: 96
step: 6
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("ORPalarmeconsigne", "Option consigne change: %f", id(orp_alarme_consigne).state);
uint8_t statehex = id(orp_alarme_consigne).state;
return {0x00, 0x06, 0x03, 0x37, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "PH Consigne"
icon: "mdi:ph"
unit_of_measurement: "ph"
min_value: 6.8
max_value: 7.6
step: 0.1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("PHconsigne", "Option consigne change: %f", id(ph_consigne).state);
uint8_t statehex = id(ph_consigne).state * 10;
return {0x00, 0x06, 0x03, 0x30, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "Volume Consigne"
icon: "mdi:cup-water"
unit_of_measurement: "m3"
min_value: 10
max_value: 200
step: 10
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("volconsigne", "Option consigne change: %f", id(vol_consigne).state);
uint8_t statehex = id(vol_consigne).state;
return {0x00, 0x06, 0x03, 0x11, 0x02, 0x00, statehex, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "acide Consigne"
icon: "mdi:skull-crossbones-outline"
unit_of_measurement: "%"
min_value: 5
max_value: 55
step: 1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("acideconsigne", "Option consigne change: %f", id(acide_consigne).state);
uint8_t statehex = id(acide_consigne).state;
return {0x00, 0x06, 0x03, 0x32, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "production Consigne"
icon: "mdi:cog-outline"
min_value: 10
max_value: 100
step: 1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("productionconsigne", "Option consigne change: %f", id(production_consigne).state);
uint8_t statehex = id(production_consigne).state;
return {0x00, 0x06, 0x03, 0x33, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "inversion Consigne"
icon: "mdi:alarm"
min_value: 2
max_value: 24
step: 1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("inversionconsigne", "Option consigne change: %f", id(inversion_consigne).state);
uint8_t statehex = id(inversion_consigne).state;
return {0x00, 0x06, 0x03, 0x39, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
text_sensor:
- platform: version
# - platform: wifi_info
# ssid:
# name: WiFi
- id: ble_name2
platform: template
- id: version_logiciel
name: "version logiciel"
platform: template
- id: slave
platform: template
- id: idcode
platform: template
name: "Date etalonage PH"
name: "Date etalonage ORP"
# - platform: wifi_signal
# name: Wifi signal
# update_interval: 60s
- platform: uptime
# Débit d'eau instantané (0 après 10s)
#- platform: pulse_meter
# name: "Debit piscine"
# pin:
# number: GPIO14
# inverted: true
# mode:
# input: true
# pullup: true
# internal_filter: 10ms
# icon: mdi:water
# timeout: 60s
# unit_of_measurement: 'l/mn'
# filters:
# - multiply: 0.104895 # Conversion factor to L/min (1 pulse per second = 0.104895 L/min) Calculé à partir de 572 impulsions par litre,
accuracy_decimals: 0
on_value:
then:
- lambda: |-
if (id(sensor_state).state == 1) {
uint16_t temphex02 = id(JustSalt_temp02_sensor).raw_state;
//ESP_LOGD(" --- temp 02 str", "%d", temphex02);
id(InjPHM).publish_state((bool)((temphex02 & 0x000A) ));
id(InjPHP).publish_state((bool)((temphex02 & 0x000C) ));
name: "Compteur Heure total de fonctionnement"
name: "minutes de fonctionement"
unit_of_measurement: "min"
- platform: ble_rssi
unit_of_measurement: "°C"
accuracy_decimals: 1
state_class: measurement
device_class: temperature
unit_of_measurement: "pH"
icon: mdi:ph
device_class: voltage
unit_of_measurement: "g/L"
icon: mdi:water-opacity
- platform: ble_client
ble_client_id: JustSaltPro
service_uuid: ${service_uuid} #'09912756-7b32-4629-aeb1-b309d9a338ae'
characteristic_uuid: ${characteristic_uuid} #'ef785c24-22bb-463d-b651-0b7445ba091c'
type: characteristic
# update_interval: 2m
notify: True
lambda: |-
std::string value2(x.begin(), x.end());
std::string rawhex = format_hex_pretty((uint8_t *) value2.c_str(), value2.size()).c_str();
//ESP_LOGW("raw_hex_boucle", "-- Recep Debut --");
//ESP_LOGD("raw_hex", "%s", rawhex.c_str());
rawhex.erase(std::remove(rawhex.begin(), rawhex.end(), '.'), rawhex.end());
int index = 3;
while (index +2 < x.size()) {
uint8_t idvaleur = x[index];
int taillevaleur = x[index + 1 ];
switch (idvaleur) {
case 0x00: {
}break;
case 0x01: {
uint8_t phhex = x[index + 2];
float ph = static_cast<float>(phhex)/10;
id(JustSalt_ph_sensor).publish_state(ph);
}break;
case 0x02: {
uint16_t temphex = ((x[index + 2]<< 8) + (x[index +3]));
float temp = static_cast<float>(temphex);
id(JustSalt_temp02_sensor).publish_state(temp);
}break;
case 0x03: {
uint8_t temphex = x[index + 2];
id(JustSalt_temp03_sensor).publish_state(temp);
}break;
case 0x06: {
uint16_t orphex = ((x[index + 2]<< 8) + (x[index +3]));
float orp = static_cast<float>(orphex);
id(JustSalt_orp_sensor).publish_state(orp);
}break;
case 0x08: {
id(JustSalt_temp08_sensor).publish_state(temp);
}break;
case 0x09: {
uint16_t tempeauhex = ((x[index + 2]<< 8) + (x[index +3]));
float tempeau = static_cast<float>(tempeauhex)/10;
id(JustSalt_temperature_sensor).publish_state(tempeau);
}break;
case 0x0A: {
uint8_t selhex = x[index + 2] ;
float sel = static_cast<float>(selhex)/10;
id(JustSalt_tds_sensor).publish_state(sel);
}break;
case 0x0B: {
id(JustSalt_temp0b_sensor).publish_state(temp);
}break;
case 0x0C: {
id(JustSalt_temp0c_sensor).publish_state(temp);
}break;
case 0x0D: {
id(JustSalt_temp0d_sensor).publish_state(temp);
}break;
case 0x0E: {
id(JustSalt_temp0e_sensor).publish_state(temp);
}break;
case 0x0F: {
uint8_t temphex = ((x[index + 2]<< 8) + (x[index +3]));
id(JustSalt_temp0f_sensor).publish_state(temp);
}break;
case 0x10: {
id(JustSalt_temp10_sensor).publish_state(temp);
}break;
case 0x11: {
uint16_t volhex = ((x[index + 2]<< 8) + (x[index +3]));
float vol = static_cast<float>(volhex);
id(vol_consigne).publish_state(vol);
}break;
case 0x12: {
uint8_t dayphex = (x[index + 3]);
uint8_t monthphex = (x[index + 4]);
uint8_t yearphex = (x[index +5]);
int dayf = static_cast<int>(dayphex);
int monthf = static_cast<int>(monthphex);
int yearf = static_cast<int>(yearphex);
std::string datestr = std::to_string(dayf) + "/" + std::to_string(monthf) + "/20" + std::to_string(yearf);
id(JustSalt_temp12_textsensor ).publish_state(datestr);
}break;
case 0x13: {
id(JustSalt_temp13_textsensor ).publish_state(datestr);
}break;
case 0x1F: {
id(JustSalt_temp1f_sensor).publish_state(temp);
}break;
case 0x28: {
id(JustSalt_temp28_sensor).publish_state(temp);
}break;
case 0x29: {
id(JustSalt_temp29_sensor).publish_state(temp);
}break;
case 0x2A: {
id(JustSalt_temp2a_sensor).publish_state(temp);
}break;
case 0x30: {
uint8_t phchex = x[index + 2] ;
float phc = static_cast<float>(phchex)/10;
auto phcstr = value_accuracy_to_string (phc,1);
id(ph_consigne).publish_state(phc);
}break;
case 0x31: {
id(JustSalt_temp31_sensor).publish_state(temp);
}break;
case 0x32: {
uint8_t acidehex = x[index + 2] ;
float acide = static_cast<float>(acidehex);
id(acide_consigne).publish_state(acide);
}break;
case 0x33: {
uint8_t prodhex = x[index + 2] ;
float prod = static_cast<float>(prodhex);
id(production_consigne).publish_state(prod);
}break;
case 0x35: {
uint8_t orpchex = x[index + 2] ;
float orpc = static_cast<float>(orpchex)*10;
id(orp_consigne_new).publish_state(orpc);
}break;
case 0x37: {
uint8_t alarmeorphex = x[index + 2] ;
float alarmeorp = static_cast<float>(alarmeorphex);
id(orp_alarme_consigne).publish_state(alarmeorp);
}break;
case 0x39: {
uint8_t inversionhex = x[index + 2] ;
float inversionval = static_cast<float>(inversionhex);
id(inversion_consigne).publish_state(inversionval);
}break;
case 0x50: {
id(JustSalt_temp50_sensor).publish_state(temp);
}break;
case 0x51: {
id(JustSalt_temp51_sensor).publish_state(temp);
}break;
case 0x5F: {
id(JustSalt_temp5f_sensor).publish_state(temp);
}break;
case 0x69: {
uint32_t temphex = (x[index + 2]<< 24) + (x[index + 3]<< 16)+ (x[index + 4]<< 8) + (x[index +5]);
id(JustSalt_temp69_sensor).publish_state(temp);
}break;
case 0x6A: {
id(JustSalt_temp6a_sensor).publish_state(temp);
}break;
case 0x8F: {
id(JustSalt_temp8f_sensor).publish_state(temp);
}break;
case 0x90: {
// 90.08.00.00.00.00.00.00.00.14.
std::string tempstring = value2.substr((index + 2 ), taillevaleur);
id(JustSalt_90_textsensor).publish_state(tempstring.c_str());
}break;
case 0x91: {
// 91.08.00.00.00.00.00.06.6F.C3.
id(JustSalt_91_textsensor).publish_state(tempstring.c_str());
}break;
case 0x92: {
id(JustSalt_temp92_sensor).publish_state(temp);
}break;
case 0x93: {
id(JustSalt_temp93_sensor).publish_state(temp);
}break;
case 0x94: {
id(JustSalt_temp94_sensor).publish_state(temp);
}break;
case 0x95: {
uint32_t idcodehex = (x[index + 2]<< 24) + (x[index + 3]<< 16)+ (x[index + 4]<< 8) + (x[index +5]);
float idcodefloat = static_cast<float>(idcodehex);
std::string idcodestr = value_accuracy_to_string (idcodefloat,0);
id(idcode).publish_state(idcodestr);
}break;
case 0x96: {
std::string verlog = rawhex.substr((index + 2 )* 2, 2) + "." + rawhex.substr((index + 2 )* 2 + 2, 2);
id(version_logiciel).publish_state(verlog);
}break;
case 0x97: {
std::string slaveval = rawhex.substr((index + 2 )* 2, 2) + "." + rawhex.substr((index + 2 )* 2 + 2, 2);
id(slave).publish_state(slaveval);
}break;
case 0x99: {
//99.16.47.45.4E.5F.30.35.32.32.2D.30.34.33.39.35.33.2D.30.30.33.00.00.00.
id(JustSalt_nombt_textsensor).publish_state(tempstring.c_str());
}break;
case 0x9A: {
//9A.10.30.35.32.32.2D.30.34.33.39.35.33.2D.30.30.33.00.
id(JustSalt_sn_textsensor).publish_state(tempstring.c_str());
}break;
case 0x9B: {
id(JustSalt_temp9b_sensor).publish_state(temp);
}break;
case 0x9C: {
id(JustSalt_temp9c_sensor).publish_state(temp);
}break;
case 0x9D: {
// 9D.08.00.00.00.00.00.00.01.FF
std::string tempstring = rawhex.substr((index + 2 )* 2, 8);
id(JustSalt_9d_textsensor).publish_state(tempstring);
}break;
case 0xA3: {
// E1.0F.18.04.11.11.00.33.00.00.88.00.F8.00.00.00.00
std::string tempstring = rawhex.substr((index + 2 )* 2, 15);
id(JustSalt_a3_textsensor).publish_state(tempstring);
}break;
case 0xB0: {
id(JustSalt_tempb0_sensor).publish_state(temp);
}break;
case 0xB1: {
std::string tempstring = rawhex.substr((index + 2 )* 2, 12);
id(JustSalt_macbt_textsensor).publish_state(tempstring);
}break;
case 0xD0: {
//D0.06.30.00.00.00.00.00
std::string tempstring = rawhex.substr((index + 2 )* 2, 6);
id(JustSalt_d0_textsensor).publish_state(tempstring);
}break;
case 0xD1: {
id(JustSalt_tempd1_sensor).publish_state(temp);
}break;
case 0xFE: {
id(JustSalt_tempfe_sensor).publish_state(temp);
}break;
case 0xE1: {
std::string tempstring = rawhex.substr((index + 2 )* 2, 30);
id(JustSalt_e1_textsensor).publish_state(tempstring);
}break;
case 0xE2: {
// E2.0F.18.04.16.0A.22.10.00.00.00.41.3E.DC.00.00.00
id(JustSalt_e2_textsensor).publish_state(tempstring);
}break;
case 0xE4: {
// E4.0F.18.04.12.15.00.00.46.00.0B.13.00.00.00.00.00
id(JustSalt_e4_textsensor).publish_state(tempstring);
}break;
default: {
ESP_LOGW("raw_hex_boucle", "idvaleur Non implementee %d", idvaleur);
index = index + 2 + taillevaleur ;
//ESP_LOGW("raw_hex_boucle", "-- Recep FIN --");
return 1;
switch:
- platform: restart
name: "Enable com JustSalt"
Merci je teste ça quand j’aurai reçu la « chose »
Bonjour, alors j’ai reçu ESP eth, je l’ai branché sur mon switch Poe mais rien ne s’allume. Qu’est ce que j’ai oublié ?? Comment on injecte du coup le code ?
Ce modèle n’est pas poe
Ah, comment on l’alimente du coup ?
Je l alimente avec ça PL2303 PL2303HX/PL2303TA USB Zu RS232 TTL Konverter Adapter Modul mit Staub-proof Abdeckung PL2303HX für arduino download kabel - AliExpress 502
Bien en version 5v
Tu dois pouvoir trouver sur Amazon aussi.
C est indispensable si tu en as pas Ca te permet d’injecter le code aussi. Une fois le code injecté les mises à jour peuvent être fait par réseau
Ah d’accord merci
j’ai pris ça Amazon.fr
j’espère que ça conviendra
oui je pense c’est équivalent, pour info pour le cablage j’ai suivi ce tuto:
oui c’est aussi sur ce tuto que je me suis basé pour commander sur amazon
bonjour
voici mon code :
substitutions:
mac_justsalt: "18:C2:93:03:CC:FB"
# EF785C24-22BB-463D-B651-0B7445BA091C
esphome:
friendly_name: EST-PoE-32
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
api:
ota:
password: "b8ca7d114e2ae67004c035e7cea8c7ff"
platform: esphome
# wifi: #WiFi cannot be active at the same time as Ethernet, but useful to keep as a fallback
# # Enable fallback hotspot (captive portal) in case wifi connection fails
# ap:
# ssid: "Est-Poe-32 Fallback Hotspot"
# password: "taHUFO8DGHVi"
web_server:
port: 80
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
power_pin: GPIO12
manual_ip:
static_ip: 192.168.1.162
gateway: 192.168.1.254
bluetooth_proxy:
active: true
time:
on_time:
- seconds: 0
minutes: /5
then:
- delay: 20s
esp32_ble_tracker:
on_ble_advertise:
- mac_address:
- ${mac_justsalt}
then:
- lambda: |-
ESP_LOGD("ble_adv", "New BLE device");
ESP_LOGD("ble_adv", " address: %s", x.address_str().c_str());
ESP_LOGD("ble_adv", " name: %s", x.get_name().c_str());
id(ble_name2).publish_state(x.get_name().c_str());
ble_client:
auto_connect: true
on_connect:
then:
accept: True
i2c:
- id: bus_a
sda: 13
scl: 14
scan: true
- platform: bme280_i2c
temperature:
name: "BME280 Temperature"
oversampling: 16x
force_update: true
pressure:
name: "BME280 Pressure"
force_update: true
humidity:
name: "BME280 Humidity"
force_update: true
address: 0x76
- platform: pulse_counter
pin: 5
force_update: true
unit_of_measurement: 'km/h'
filters:
- multiply: 0.173
update_interval: 5s
- platform: uptime
name: "JustSalt Temperature"
name: "JustSalt Temperature Int"
accuracy_decimals: 2
icon: mdi:ph
name: "JustSalt pH consigne"
icon: mdi:ph
service_uuid: '1800' # Generic Access Profile
characteristic_uuid: '2a00' # Device Name
lambda: |-
std::string data_string(x.begin(), x.end());
id(ble_name).publish_state(data_string.c_str());
return (float)x.size();
update_interval: 30s
notify: true
lambda: |-
//ESP_LOGD("ble_client.receive", "start - value received with %d bytes: [%.*s]", x.size(), x.size(), &x[0]);
//ESP_LOGD("raw_hex_stripped", "value received with %d bytes: [%.*s]", rawhex.size(), rawhex.c_str());
switch (x.size()) {
// case 71: {
// std::string temppart3 = rawhex.substr(30, 4);
// ESP_LOGD("chaine 71", "version : %s", temppart3.c_str());
// id(version_logiciel).publish_state(temppart3);
// }break;
//case 76:{
// std::string temppart2 = rawhex.substr(10, 2);
// ESP_LOGD("chaine 76", "%s", temppart2.c_str());
// uint8_t phhex = x[5];
// float ph = static_cast<float>(phhex)/10;
// id(JustSalt_ph_sensor).publish_state(ph);
// std::string temppart3 = rawhex.substr(44, 4);
// ESP_LOGD("chaine 76", "%s", temppart3.c_str());
// uint16_t tempeauhex = (x[22]<< 8) + x[23];
// ESP_LOGD("chaine 76", "%x", tempeauhex);
// float tempeau = static_cast<float>(tempeauhex)/10;
// id(JustSalt_temperature_sensor).publish_state(tempeau);
// std::string temppart1 = rawhex.substr(52, 2);
// ESP_LOGD("chaine 76", "%s", temppart1.c_str());
// uint8_t selhex = x[26] ;
// float sel = static_cast<float>(selhex)/10;
// id(JustSalt_tds_sensor).publish_state(sel);
// std::string temppart4 = rawhex.substr(104, 2);
// ESP_LOGD("chaine 76", "%s", temppart4.c_str());
// uint8_t volhex = x[52] ;
// float vol = static_cast<float>(volhex);
// id(JustSalt_volume_sensor).publish_state(vol);
// }break;
//case 78:{
// std::string temppart2 = rawhex.substr(24, 2);
// ESP_LOGD("chaine 78", "%s", temppart2.c_str());
// uint8_t phhex = x[12];
// id(JustSalt_ph_consigne_sensor).publish_state(ph);
// }break;//
case 245:{
std::string mystring = rawhex.substr(18,4);
ESP_LOGD(">>>>> ... >>>> chaine 245", "%s", mystring.c_str());
uint16_t tempeauhex = (x[18]<< 8) + x[19];
ESP_LOGD(">>>>> ... >>>> valeur", "%x", tempeauhex);
uint8_t selhex = x[22] ;
uint16_t orphex = (x[8] << 8) + x[9];
ESP_LOGD("TAUX ORP", "%x", orphex);
}break;
return 1;
binary_sensor:
- platform: gpio
pin:
number: 32
mode: input
# inverted: true
- platform: gpio
pin:
number: 33
mode: input
# inverted: true
- platform: gpio
pin:
number: 34
mode: input
# inverted: true
- platform: gpio
pin:
number: 36
mode: input
# inverted: true
switch:
- platform: gpio
pin: 16
- platform: gpio
pin: 4
- platform: gpio
pin: 0
- platform: gpio
pin: 2
- platform: gpio
pin: 15
- platform: restart
text_sensor:
- platform: version
#- platform: wifi_info
# ssid:
# name: WiFi
- id: ble_name
platform: template
- id: ble_name2
platform: template
platform: template
- id: Slave
platform: template
cela fonctionnait pendant plusieures semaines et maintenant apres une mise a jour esphome (sans modif de code) ca marche plus , mon ph tds sont tous a NaN
voici les logs
[18:14:30][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:14:30][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:14:30][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:14:30][W][component:237]: Component esp32_ble_tracker took a long time for an operation (56 ms).
[18:14:30][W][component:238]: Components should block for at most 30 ms.
[18:14:30][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:14:30][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:14:30][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:14:30][I][ble_sensor:031]: [traitement] Connected successfully!
[18:14:30][I][ble_sensor:031]: [device_name] Connected successfully!
[18:14:30][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:14:30][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:14:30][W][ble_sensor:037]: [traitement] Disconnected!
[18:14:30][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:14:31][W][ble_sensor:037]: [device_name] Disconnected!
[18:14:31][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:14:31][W][component:237]: Component esp32_ble took a long time for an operation (60 ms).
[18:14:31][W][component:238]: Components should block for at most 30 ms.
[18:14:31][D][esp32_ble_tracker:270]: Starting scan...
[18:14:31][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:14:31][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:14:34][W][ble_sensor:123]: [traitement] Cannot poll, not connected
[18:14:36][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:14:36][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:14:38][D][sensor:094]: 'JustSalt RSSI': Sending state -61.00000 dBm with 0 decimals of accuracy
[18:14:38][D][ble_adv:071]: New BLE device
[18:14:38][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:14:38][D][ble_adv:073]: name: GEN_0323-047091-009
[18:14:38][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:14:38][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:14:38][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-61
[18:14:38][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:14:38][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:14:38][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:14:38][W][component:237]: Component esp32_ble_tracker took a long time for an operation (59 ms).
[18:14:38][W][component:238]: Components should block for at most 30 ms.
[18:14:38][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:14:38][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:14:38][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:14:38][I][ble_sensor:031]: [traitement] Connected successfully!
[18:14:38][I][ble_sensor:031]: [device_name] Connected successfully!
[18:14:38][D][esp32_ble_tracker:270]: Starting scan...
[18:14:39][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:14:39][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:14:39][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:14:39][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:14:39][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:14:39][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:14:39][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:14:39][D][ble_client:058]: All clients established, services released
[18:14:39][W][component:237]: Component esp32_ble took a long time for an operation (52 ms).
[18:14:39][W][component:238]: Components should block for at most 30 ms.
[18:14:39][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:14:41][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:14:41][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:14:44][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:14:44][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:14:44][W][ble_sensor:037]: [traitement] Disconnected!
[18:14:44][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:14:44][W][ble_sensor:037]: [device_name] Disconnected!
[18:14:44][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:14:44][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:14:44][D][ble_adv:071]: New BLE device
[18:14:44][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:14:44][D][ble_adv:073]: name: GEN_0323-047091-009
[18:14:44][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:14:44][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:14:44][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:14:44][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:14:44][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:14:44][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:14:44][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:14:44][W][component:238]: Components should block for at most 30 ms.
[18:14:44][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:14:44][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:14:44][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:14:44][I][ble_sensor:031]: [traitement] Connected successfully!
[18:14:44][I][ble_sensor:031]: [device_name] Connected successfully!
[18:14:44][D][esp32_ble_tracker:270]: Starting scan...
[18:14:45][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:14:46][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:14:46][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:14:51][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:14:51][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:14:51][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:14:51][D][ble_adv:071]: New BLE device
[18:14:51][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:14:51][D][ble_adv:073]: name: GEN_0323-047091-009
[18:14:51][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:14:51][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:14:51][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:14:51][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:14:51][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:14:51][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:14:51][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:14:51][W][component:238]: Components should block for at most 30 ms.
[18:14:51][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:14:52][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:14:52][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:14:52][I][ble_sensor:031]: [traitement] Connected successfully!
[18:14:52][I][ble_sensor:031]: [device_name] Connected successfully!
[18:14:52][D][esp32_ble_tracker:270]: Starting scan...
[18:14:52][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:14:52][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:14:52][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:14:52][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:14:52][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:14:52][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:14:52][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:14:52][D][ble_client:058]: All clients established, services released
[18:14:52][W][component:237]: Component esp32_ble took a long time for an operation (51 ms).
[18:14:52][W][component:238]: Components should block for at most 30 ms.
[18:14:52][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:14:53][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_READ_CHAR_EVT
[18:14:53][W][component:170]: Component ble_client.sensor cleared Warning flag
[18:14:53][D][text_sensor:064]: 'Name BLE': Sending state 'ePool Device'
[18:14:53][D][sensor:094]: 'device_name': Sending state 14.00000 with 0 decimals of accuracy
[18:14:56][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:14:56][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:14:57][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:14:57][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:14:57][W][ble_sensor:037]: [traitement] Disconnected!
[18:14:57][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:14:57][W][ble_sensor:037]: [device_name] Disconnected!
[18:14:57][W][component:157]: Component ble_client.sensor set Warning flag: unspecified
[18:14:57][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:14:57][D][sensor:094]: 'Uptime': Sending state 1131.08997 s with 0 decimals of accuracy
[18:14:59][D][sensor:094]: 'JustSalt RSSI': Sending state -57.00000 dBm with 0 decimals of accuracy
[18:14:59][D][ble_adv:071]: New BLE device
[18:14:59][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:14:59][D][ble_adv:073]: name: GEN_0323-047091-009
[18:14:59][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:14:59][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:14:59][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-57
[18:14:59][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:14:59][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:14:59][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:14:59][W][component:237]: Component esp32_ble_tracker took a long time for an operation (58 ms).
[18:14:59][W][component:238]: Components should block for at most 30 ms.
[18:14:59][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:14:59][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:14:59][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:14:59][I][ble_sensor:031]: [traitement] Connected successfully!
[18:14:59][I][ble_sensor:031]: [device_name] Connected successfully!
[18:14:59][D][esp32_ble_tracker:270]: Starting scan...
[18:15:00][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:15:00][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:15:00][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:15:00][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:15:00][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:15:00][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:15:00][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:15:00][D][ble_client:058]: All clients established, services released
[18:15:00][W][component:237]: Component esp32_ble took a long time for an operation (52 ms).
[18:15:00][W][component:238]: Components should block for at most 30 ms.
[18:15:00][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:15:00][D][switch:016]: 'Enable com JustSalt' Turning OFF.
[18:15:00][I][ble_client:043]: [18:C2:93:03:CC:FB] Disabling BLE client.
[18:15:00][I][esp32_ble_client:084]: [0] [18:C2:93:03:CC:FB] Disconnecting.
[18:15:00][D][switch:055]: 'Enable com JustSalt': Sending state OFF
[18:15:00][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:15:00][W][ble_sensor:037]: [traitement] Disconnected!
[18:15:00][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:15:00][W][ble_sensor:037]: [device_name] Disconnected!
[18:15:00][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:15:00][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 22
[18:15:01][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:01][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:01][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:01][D][ble_adv:071]: New BLE device
[18:15:01][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:01][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:01][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:02][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:15:02][D][ble_adv:071]: New BLE device
[18:15:02][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:02][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:02][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:02][D][sensor:094]: 'JustSalt RSSI': Sending state -55.00000 dBm with 0 decimals of accuracy
[18:15:02][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:03][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:03][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:03][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:03][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:03][D][ble_adv:071]: New BLE device
[18:15:04][D][sensor:094]: 'BME280 Temperature': Sending state 32.36828 °C with 1 decimals of accuracy
[18:15:04][D][sensor:094]: 'BME280 Pressure': Sending state 1004.31946 hPa with 1 decimals of accuracy
[18:15:04][D][sensor:094]: 'BME280 Humidity': Sending state 38.33984 % with 1 decimals of accuracy
[18:15:04][W][ble_sensor:123]: [traitement] Cannot poll, not connected
[18:15:06][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:06][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:08][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:15:08][D][ble_adv:071]: New BLE device
[18:15:08][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:08][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:08][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:09][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:09][D][ble_adv:071]: New BLE device
[18:15:09][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:09][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:09][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:09][D][sensor:094]: 'JustSalt RSSI': Sending state -61.00000 dBm with 0 decimals of accuracy
[18:15:09][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:15:10][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:10][D][ble_adv:071]: New BLE device
[18:15:10][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:10][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:10][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:11][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:11][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:15][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:15][D][ble_adv:071]: New BLE device
[18:15:15][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:15][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:15][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:15][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:15:15][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:16][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:16][D][ble_adv:071]: New BLE device
[18:15:16][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:16][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:16][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:16][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:16][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:16][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:15:16][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:17][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:17][D][ble_adv:071]: New BLE device
[18:15:17][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:17][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:17][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:20][D][switch:012]: 'Enable com JustSalt' Turning ON.
[18:15:20][D][switch:055]: 'Enable com JustSalt': Sending state ON
[18:15:21][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:21][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:21][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:21][D][ble_adv:071]: New BLE device
[18:15:21][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:21][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:21][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:21][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:15:21][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:15:21][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:15:21][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:15:21][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:15:21][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:15:21][W][component:238]: Components should block for at most 30 ms.
[18:15:21][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:15:22][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:15:22][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:15:22][I][ble_sensor:031]: [traitement] Connected successfully!
[18:15:22][I][ble_sensor:031]: [device_name] Connected successfully!
[18:15:22][D][esp32_ble_tracker:270]: Starting scan...
[18:15:22][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:15:22][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:15:22][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:15:22][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:15:22][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:15:22][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:15:22][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:15:22][D][ble_client:058]: All clients established, services released
[18:15:22][W][component:237]: Component esp32_ble took a long time for an operation (51 ms).
[18:15:22][W][component:238]: Components should block for at most 30 ms.
[18:15:22][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:15:26][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:26][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:27][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:15:27][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:15:27][W][ble_sensor:037]: [traitement] Disconnected!
[18:15:27][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:15:27][W][ble_sensor:037]: [device_name] Disconnected!
[18:15:27][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:15:30][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:30][D][ble_adv:071]: New BLE device
[18:15:30][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:30][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:30][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:30][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:15:30][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-56
[18:15:30][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:15:30][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:15:30][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:15:30][W][component:237]: Component esp32_ble_tracker took a long time for an operation (56 ms).
[18:15:30][W][component:238]: Components should block for at most 30 ms.
[18:15:30][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:15:30][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:15:30][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:15:30][I][ble_sensor:031]: [traitement] Connected successfully!
[18:15:30][I][ble_sensor:031]: [device_name] Connected successfully!
[18:15:30][D][esp32_ble_tracker:270]: Starting scan...
[18:15:31][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:31][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:31][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:15:31][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:15:31][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:15:31][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:15:31][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:15:31][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:15:31][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:15:31][D][ble_client:058]: All clients established, services released
[18:15:31][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:15:34][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_READ_CHAR_EVT
[18:15:34][W][ble_sensor:078]: Error reading char at handle 19, status=15
[18:15:35][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:15:35][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:15:35][W][ble_sensor:037]: [traitement] Disconnected!
[18:15:35][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:15:35][W][ble_sensor:037]: [device_name] Disconnected!
[18:15:35][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:15:36][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:36][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:40][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:15:40][D][ble_adv:071]: New BLE device
[18:15:40][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:40][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:40][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:40][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:15:40][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-56
[18:15:40][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:15:40][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:15:40][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:15:40][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:15:40][W][component:238]: Components should block for at most 30 ms.
[18:15:40][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:15:40][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:15:40][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:15:40][I][ble_sensor:031]: [traitement] Connected successfully!
[18:15:40][I][ble_sensor:031]: [device_name] Connected successfully!
[18:15:40][D][esp32_ble_tracker:270]: Starting scan...
[18:15:41][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:15:41][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:15:41][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:15:41][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:15:41][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:15:41][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:15:41][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:15:41][D][ble_client:058]: All clients established, services released
[18:15:41][W][component:237]: Component esp32_ble took a long time for an operation (51 ms).
[18:15:41][W][component:238]: Components should block for at most 30 ms.
[18:15:41][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:15:41][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:41][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:45][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:15:45][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:15:45][W][ble_sensor:037]: [traitement] Disconnected!
[18:15:45][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:15:45][W][ble_sensor:037]: [device_name] Disconnected!
[18:15:45][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:15:46][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:46][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:49][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:49][D][ble_adv:071]: New BLE device
[18:15:49][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:49][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:49][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:49][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:15:49][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:15:49][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:15:49][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:15:49][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:15:49][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:15:49][W][component:238]: Components should block for at most 30 ms.
[18:15:49][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:15:49][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:15:49][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:15:49][I][ble_sensor:031]: [traitement] Connected successfully!
[18:15:49][I][ble_sensor:031]: [device_name] Connected successfully!
[18:15:49][D][esp32_ble_tracker:270]: Starting scan...
[18:15:50][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:15:50][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:15:50][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:15:50][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:15:50][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:15:50][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:15:50][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:15:50][D][ble_client:058]: All clients established, services released
[18:15:50][W][component:237]: Component esp32_ble took a long time for an operation (53 ms).
[18:15:50][W][component:238]: Components should block for at most 30 ms.
[18:15:50][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:15:51][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:51][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:53][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_READ_CHAR_EVT
[18:15:53][W][component:170]: Component ble_client.sensor cleared Warning flag
[18:15:53][D][text_sensor:064]: 'Name BLE': Sending state 'ePool Device'
[18:15:53][D][sensor:094]: 'device_name': Sending state 14.00000 with 0 decimals of accuracy
[18:15:55][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:15:55][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:15:55][W][ble_sensor:037]: [traitement] Disconnected!
[18:15:55][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:15:55][W][ble_sensor:037]: [device_name] Disconnected!
[18:15:55][W][component:157]: Component ble_client.sensor set Warning flag: unspecified
[18:15:55][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:15:56][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:15:56][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:15:56][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:15:56][D][ble_adv:071]: New BLE device
[18:15:56][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:15:56][D][ble_adv:073]: name: GEN_0323-047091-009
[18:15:56][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:15:56][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:15:56][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:15:56][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:15:57][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:15:57][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:15:57][W][component:237]: Component esp32_ble_tracker took a long time for an operation (56 ms).
[18:15:57][W][component:238]: Components should block for at most 30 ms.
[18:15:57][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:15:57][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:15:57][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:15:57][I][ble_sensor:031]: [traitement] Connected successfully!
[18:15:57][I][ble_sensor:031]: [device_name] Connected successfully!
[18:15:57][D][esp32_ble_tracker:270]: Starting scan...
[18:15:57][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:15:57][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:15:57][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:15:57][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:15:57][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:15:57][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:15:57][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:15:57][D][ble_client:058]: All clients established, services released
[18:15:57][W][component:237]: Component esp32_ble took a long time for an operation (53 ms).
[18:15:57][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:15:57][D][sensor:094]: 'Uptime': Sending state 1191.08704 s with 0 decimals of accuracy
[18:16:01][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:01][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:02][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:02][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:02][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:02][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:02][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:02][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:02][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:16:02][D][ble_adv:071]: New BLE device
[18:16:02][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:02][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:02][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:02][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:02][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:16:02][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:02][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:02][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:02][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:16:02][W][component:238]: Components should block for at most 30 ms.
[18:16:02][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:03][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:03][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:03][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:03][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:03][D][esp32_ble_tracker:270]: Starting scan...
[18:16:03][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:03][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:03][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:03][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:03][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:03][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:04][D][sensor:094]: 'BME280 Temperature': Sending state 32.35070 °C with 1 decimals of accuracy
[18:16:04][D][sensor:094]: 'BME280 Pressure': Sending state 1004.34711 hPa with 1 decimals of accuracy
[18:16:04][D][sensor:094]: 'BME280 Humidity': Sending state 38.40527 % with 1 decimals of accuracy
[18:16:04][W][ble_sensor:123]: [traitement] Cannot poll, not connected
[18:16:06][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:06][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:06][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:16:06][D][ble_adv:071]: New BLE device
[18:16:06][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:06][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:06][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:06][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:06][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-56
[18:16:06][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:06][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:06][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:06][W][component:237]: Component esp32_ble_tracker took a long time for an operation (58 ms).
[18:16:06][W][component:238]: Components should block for at most 30 ms.
[18:16:06][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:06][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:06][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:06][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:06][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:06][D][esp32_ble_tracker:270]: Starting scan...
[18:16:07][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:16:07][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:16:07][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:16:07][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:16:07][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:16:07][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:16:07][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:16:07][D][ble_client:058]: All clients established, services released
[18:16:07][W][component:237]: Component esp32_ble took a long time for an operation (52 ms).
[18:16:07][W][component:238]: Components should block for at most 30 ms.
[18:16:07][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:16:11][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:11][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:12][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:12][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:12][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:12][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:12][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:12][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:15][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:16:15][D][ble_adv:071]: New BLE device
[18:16:15][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:15][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:15][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:15][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:15][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-64
[18:16:15][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:15][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:15][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:15][W][component:237]: Component esp32_ble_tracker took a long time for an operation (58 ms).
[18:16:15][W][component:238]: Components should block for at most 30 ms.
[18:16:15][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:15][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:15][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:15][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:15][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:15][D][esp32_ble_tracker:270]: Starting scan...
[18:16:16][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:16:16][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:16:16][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:16:16][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:16:16][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:16:16][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:16:16][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:16:16][D][ble_client:058]: All clients established, services released
[18:16:16][W][component:237]: Component esp32_ble took a long time for an operation (52 ms).
[18:16:16][W][component:238]: Components should block for at most 30 ms.
[18:16:16][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:16:16][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:16][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:20][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:20][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:20][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:20][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:20][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:20][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:21][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:21][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:23][D][sensor:094]: 'JustSalt RSSI': Sending state -57.00000 dBm with 0 decimals of accuracy
[18:16:23][D][ble_adv:071]: New BLE device
[18:16:23][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:23][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:23][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:23][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:23][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-57
[18:16:23][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:23][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:23][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:23][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:16:23][W][component:238]: Components should block for at most 30 ms.
[18:16:23][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:23][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:23][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:23][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:23][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:23][D][esp32_ble_tracker:270]: Starting scan...
[18:16:24][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:16:24][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:16:24][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:16:24][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:16:24][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:16:24][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:16:24][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:16:24][D][ble_client:058]: All clients established, services released
[18:16:24][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:16:26][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:26][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:28][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:28][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:28][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:28][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:28][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:28][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:31][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:31][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:31][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:16:31][D][ble_adv:071]: New BLE device
[18:16:31][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:31][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:31][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:31][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:31][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-64
[18:16:31][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:31][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:31][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:32][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:16:32][W][component:238]: Components should block for at most 30 ms.
[18:16:32][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:32][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:32][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:32][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:32][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:32][D][esp32_ble_tracker:270]: Starting scan...
[18:16:32][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:16:32][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:16:32][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:16:32][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:16:32][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:16:32][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:16:32][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:16:32][D][ble_client:058]: All clients established, services released
[18:16:32][W][component:237]: Component esp32_ble took a long time for an operation (51 ms).
[18:16:32][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:16:34][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_READ_CHAR_EVT
[18:16:34][W][ble_sensor:078]: Error reading char at handle 19, status=15
[18:16:36][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:36][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:37][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:37][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:37][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:37][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:37][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:37][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:37][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:16:37][D][ble_adv:071]: New BLE device
[18:16:37][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:37][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:37][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:37][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:37][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:16:37][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:37][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:37][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:37][W][component:237]: Component esp32_ble_tracker took a long time for an operation (58 ms).
[18:16:37][W][component:238]: Components should block for at most 30 ms.
[18:16:37][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:38][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:38][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:38][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:38][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:38][D][esp32_ble_tracker:270]: Starting scan...
[18:16:38][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:38][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:38][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:38][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:38][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:38][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:41][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:41][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:42][D][sensor:094]: 'JustSalt RSSI': Sending state -62.00000 dBm with 0 decimals of accuracy
[18:16:42][D][ble_adv:071]: New BLE device
[18:16:42][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:42][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:42][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:42][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:42][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-62
[18:16:42][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:42][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:42][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:42][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:16:42][W][component:238]: Components should block for at most 30 ms.
[18:16:42][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:42][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:42][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:42][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:42][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:42][D][esp32_ble_tracker:270]: Starting scan...
[18:16:43][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:16:43][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:16:43][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:16:43][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:16:43][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:16:43][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:16:43][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:16:43][D][ble_client:058]: All clients established, services released
[18:16:43][W][component:237]: Component esp32_ble took a long time for an operation (52 ms).
[18:16:43][W][component:238]: Components should block for at most 30 ms.
[18:16:43][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_WRITE_DESCR_EVT
[18:16:46][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:46][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:47][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:47][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:47][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:47][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:47][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:47][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:48][D][sensor:094]: 'JustSalt RSSI': Sending state -64.00000 dBm with 0 decimals of accuracy
[18:16:48][D][ble_adv:071]: New BLE device
[18:16:48][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:48][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:48][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:48][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:48][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-64
[18:16:48][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:48][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:48][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:48][W][component:237]: Component esp32_ble_tracker took a long time for an operation (57 ms).
[18:16:48][W][component:238]: Components should block for at most 30 ms.
[18:16:48][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:48][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:48][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:48][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:48][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:48][D][esp32_ble_client:172]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_DISCONNECT_EVT, reason 19
[18:16:48][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CLOSE_EVT
[18:16:48][W][ble_sensor:037]: [traitement] Disconnected!
[18:16:48][D][sensor:094]: 'traitement': Sending state nan with 0 decimals of accuracy
[18:16:48][W][ble_sensor:037]: [device_name] Disconnected!
[18:16:48][D][sensor:094]: 'device_name': Sending state nan with 0 decimals of accuracy
[18:16:48][W][component:237]: Component esp32_ble took a long time for an operation (67 ms).
[18:16:48][D][esp32_ble_tracker:270]: Starting scan...
[18:16:51][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:51][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:53][W][ble_sensor:123]: [device_name] Cannot poll, not connected
[18:16:55][D][sensor:094]: 'JustSalt RSSI': Sending state -56.00000 dBm with 0 decimals of accuracy
[18:16:55][D][ble_adv:071]: New BLE device
[18:16:55][D][ble_adv:072]: address: 18:C2:93:03:CC:FB
[18:16:55][D][ble_adv:073]: name: GEN_0323-047091-009
[18:16:55][D][text_sensor:064]: 'Name': Sending state 'GEN_0323-047091-009'
[18:16:55][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] Found device
[18:16:55][D][esp32_ble_tracker:669]: Found device 18:C2:93:03:CC:FB RSSI=-56
[18:16:55][D][esp32_ble_tracker:690]: Address Type: PUBLIC
[18:16:55][D][esp32_ble_tracker:692]: Name: 'GEN_0323-047091-009'
[18:16:55][D][esp32_ble_tracker:219]: Pausing scan to make connection...
[18:16:55][W][component:237]: Component esp32_ble_tracker took a long time for an operation (56 ms).
[18:16:55][W][component:238]: Components should block for at most 30 ms.
[18:16:55][I][esp32_ble_client:067]: [0] [18:C2:93:03:CC:FB] 0x00 Attempting BLE connection
[18:16:55][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_CONNECT_EVT
[18:16:55][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_OPEN_EVT
[18:16:55][I][ble_sensor:031]: [traitement] Connected successfully!
[18:16:55][I][ble_sensor:031]: [device_name] Connected successfully!
[18:16:55][D][esp32_ble_tracker:270]: Starting scan...
[18:16:56][D][pulse_counter:174]: 'vitesse vent': Retrieved counter: 0.00 pulses/min
[18:16:56][D][sensor:094]: 'vitesse vent': Sending state 0.00000 km/h with 2 decimals of accuracy
[18:16:56][D][esp32_ble_client:306]: [0] [18:C2:93:03:CC:FB] Event 46
[18:16:56][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_SEARCH_CMPL_EVT
[18:16:56][I][esp32_ble_client:227]: [0] [18:C2:93:03:CC:FB] Connected
[18:16:56][D][esp32_ble_client:188]: [0] [18:C2:93:03:CC:FB] cfg_mtu status 0, mtu 250
[18:16:56][D][esp32_ble_client:110]: [0] [18:C2:93:03:CC:FB] ESP_GATTC_REG_FOR_NOTIFY_EVT
[18:16:56][D][esp32_ble_client:296]: Wrote notify descriptor 2, properties=46
[18:16:56][D][ble_sensor:103]: Register for notify on EF785C24-22BB-463D-B651-0B7445BA091C complete
[18:16:56][D][ble_client:058]: All clients established, services released
[18:16:56][W][component:237]: Component esp32_ble took a long time for an operation (51 ms).
[18:16:56][W][component:238]: Components should block for at most 30 ms.
si quelqu’un pouvait m’aider a comprendre ?
merci
Tu as. re appairer ?
Bonjour ,
comme Cyber Chris là dit , essai de ré appairer le module avec l’électrolyseur .
J’ai fais plusieurs modification du programme pour l’adapter à mon matériel , je me suis rendu compte que cela ne fonctionnais pas . J’ai cherché , re -modifier . Il fallait simplement relancer l’appairage .
L’appairage a résolu mon soucis
Bon, je me suis décidé à injecter le code mais à la compilation, j’ai cette erreur
NFO ESPHome 2024.6.6
INFO Reading configuration /config/esphome/esp-eth.yaml...
INFO Detected timezone 'Europe/Paris'
INFO Generating C++ source...
INFO Compiling app...
Processing esp-eth (board: esp-wrover-kit; framework: espidf; platform: platformio/espressif32@5.4.0)
HARDWARE: ESP32 240MHz, 320KB RAM, 4MB Flash
- framework-espidf @ 3.40407.0 (4.4.7)
- tool-cmake @ 3.16.4
- tool-ninja @ 1.7.1
- toolchain-esp32ulp @ 2.35.0-20220830
- toolchain-xtensa-esp32 @ 8.4.0+2021r2-patch5
Removing an oudated IDF virtual environment
Error: Cannot remove an outdated IDF virtual environment. Please remove the `/root/.platformio/penv/.espidf-4.4.7` folder manually!
========================== [FAILED] Took 2.88 seconds ==========================
Et je ne sais pas comment la supprimer. Merci de votre aide
si j’essaie d’installer en direct j’ai ça
AssertionError: Error: Missing Python executable file `/root/.platformio/penv/.esp idf-4.4.7/bin/python`:
je me réponds, en installant la dernière Maj d’ESPHome, l’erreur a disparu
Génial, ça fonctionne nickel en ethernet. Encore merci Cyber_Chris pour les pistes et le code
Cool, c’est super stable en ethernet tu verras.
Juste une dernière question, est-ce que le code que tu m’as donné permet aussi de faire proxy bluetooth ? Merci
