Cool un nouveau model
voici la dernière version en ESPHome !
j ai réussi a contourné les pb de ralentissement du a l envois de donné a ha !
pour ceux que ca intéresse je stock les valeur dans des variables global !
j ai aussi créer un tableau pour savoir lesquelles ont été modifié , et je les envois a fur et a mesure des traitement ! résultat les valeurs remonte plus rapidement !
# JustSalt
substitutions:
mac_justsalt: "94:DE:B8:A1:1A:AC"
service_uuid: '09912756-7b32-4629-aeb1-b309d9a338ae'
characteristic_uuid: 'ef785c24-22bb-463d-b651-0b7445ba091c'
characteristic_uuid_write: '4d32c5e5-2bb5-45c6-8c89-6f59bb3930d2'
esphome:
friendly_name: ESPHome Web ecc470
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
baud_rate: 0
# Enable Home Assistant API
api:
encryption:
key: "bLk/RiUyxLzXjb42FYKAhRU9WmN3iuyB3uiKMbovaMo="
ota:
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Esphome-Web-Ecc470"
password: "eEzs1d6LU1bH"
captive_portal:
bluetooth_proxy:
active: true
globals:
- id: valforexport
type: bool[255]
- id: val01
type: float
- id: val02
type: float
- id: val03
type: float
- id: val06
type: float
- id: val08
type: float
- id: val09
type: float
- id: val0A
type: float
- id: val0B
type: float
- id: val0C
type: float
- id: val0D
type: float
- id: val0E
type: float
- id: val0F
type: float
- id: val10
type: float
- id: val11
type: float
- id: val12
type: String
- id: val13
type: String
- id: val1F
type: float
- id: val28
type: float
- id: val29
type: float
- id: val2A
type: float
- id: val30
type: float
- id: val31
type: float
- id: val32
type: float
- id: val33
type: float
- id: val35
type: float
- id: val37
type: float
- id: val39
type: float
- id: val50
type: float
- id: val51
type: float
- id: val5F
type: float
- id: val69
type: float
- id: val6A
type: float
- id: val8F
type: float
- id: val90
type: String
- id: val91
type: String
- id: val92
type: float
- id: val93
type: float
- id: val94
type: float
- id: val95
type: float
- id: val96
type: String
- id: val97
type: String
- id: val99
type: String
- id: val9A
type: String
- id: val9B
type: float
- id: val9C
type: float
- id: val9D
type: String
- id: valA3
type: String
- id: valB0
type: float
- id: valB1
type: String
- id: valD0
type: String
- id: valD1
type: float
- id: valE1
type: String
- id: valE2
type: String
- id: valE4
type: String
- id: valFE
type: float
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: /5
then:
- switch.turn_off: ble_switch_com
- delay: 20s
- switch.turn_on: ble_switch_com
ble_client:
- mac_address: ${mac_justsalt}
auto_connect: true
on_connect:
then:
- ble_client.numeric_comparison_reply:
accept: True
binary_sensor:
- platform: ble_presence
number:
name: "ORP Consigne"
icon: "mdi:flash-triangle-outline"
unit_of_measurement: "mV"
min_value: 200
max_value: 900
step: 10
optimistic: true
on_value:
then:
- ble_client.ble_write:
service_uuid: ${service_uuid}
characteristic_uuid: ${characteristic_uuid_write}
value: !lambda |-
ESP_LOGD("ORPconsigne", "Option consigne change: %f", id(orp_consigne).state);
uint8_t statehex = id(orp_consigne).state / 10;
return {0x00, 0x06, 0x03, 0x35, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "ORP Alarme Consigne"
icon: "mdi:alarm"
unit_of_measurement: "h"
min_value: 12
max_value: 96
step: 6
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("ORPalarmeconsigne", "Option consigne change: %f", id(orp_alarme_consigne).state);
uint8_t statehex = id(orp_alarme_consigne).state;
return {0x00, 0x06, 0x03, 0x37, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "PH Consigne"
icon: "mdi:ph"
unit_of_measurement: "ph"
min_value: 6.8
max_value: 7.6
step: 0.1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("PHconsigne", "Option consigne change: %f", id(ph_consigne).state);
uint8_t statehex = id(ph_consigne).state * 10;
return {0x00, 0x06, 0x03, 0x30, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "Volume Consigne"
icon: "mdi:cup-water"
unit_of_measurement: "m3"
min_value: 10
max_value: 200
step: 10
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("volconsigne", "Option consigne change: %f", id(vol_consigne).state);
uint8_t statehex = id(vol_consigne).state;
return {0x00, 0x06, 0x03, 0x11, 0x02, 0x00, statehex, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "acide Consigne"
icon: "mdi:skull-crossbones-outline"
unit_of_measurement: "%"
min_value: 5
max_value: 55
step: 1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("acideconsigne", "Option consigne change: %f", id(acide_consigne).state);
uint8_t statehex = id(acide_consigne).state;
return {0x00, 0x06, 0x03, 0x32, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "production Consigne"
icon: "mdi:cog-outline"
min_value: 10
max_value: 100
step: 1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("productionconsigne", "Option consigne change: %f", id(production_consigne).state);
uint8_t statehex = id(production_consigne).state;
return {0x00, 0x06, 0x03, 0x33, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
//return {0x00, 0x06, 0x03, 0x33, 0x01, 0x63, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
name: "inversion Consigne"
icon: "mdi:alarm"
min_value: 2
max_value: 24
step: 1
optimistic: true
on_value:
then:
value: !lambda |-
ESP_LOGD("inversionconsigne", "Option consigne change: %f", id(inversion_consigne).state);
uint8_t statehex = id(inversion_consigne).state;
return {0x00, 0x06, 0x03, 0x39, 0x01, statehex, 0xff, 0xff, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
text_sensor:
- platform: version
- platform: wifi_info
ssid:
- id: version_logiciel
name: "version logiciel"
platform: template
icon: "mdi:qrcode"
- id: slave
platform: template
icon: "mdi:qrcode-edit"
icon: "mdi:network-outline"
icon: "mdi:card-account-details-outline"
icon: "mdi:barcode"
name: "Date etalonage PH"
icon: "mdi:calendar-star-four-points"
name: "Date etalonage ORP"
- platform: wifi_signal
update_interval: 60s
- platform: uptime
accuracy_decimals: 0
on_value:
then:
- lambda: |-
if (id(sensor_state).state == 1) {
uint16_t temphex02 = id(JustSalt_temp02_sensor).raw_state;
//ESP_LOGD(" --- temp 02 str", "%d", temphex02);
id(InjPHM).publish_state((bool)((temphex02 & 0x000A) ));
id(InjPHP).publish_state((bool)((temphex02 & 0x000C) ));
- id: idcode
platform: template
icon: "mdi:barcode"
name: "Compteur Heure total de fonctionnement"
icon: "mdi:timer-sand"
name: "minutes de fonctionement"
unit_of_measurement: "min"
icon: "mdi:counter"
- platform: ble_rssi
unit_of_measurement: "°C"
accuracy_decimals: 1
state_class: measurement
device_class: temperature
unit_of_measurement: "pH"
icon: mdi:ph
device_class: voltage
unit_of_measurement: "g/L"
icon: mdi:water-opacity
- platform: ble_client
ble_client_id: JustSaltPro
service_uuid: ${service_uuid} #'09912756-7b32-4629-aeb1-b309d9a338ae'
characteristic_uuid: ${characteristic_uuid} #'ef785c24-22bb-463d-b651-0b7445ba091c'
type: characteristic
# update_interval: 2m
notify: True
lambda: |-
std::string value2(x.begin(), x.end());
std::string rawhex = format_hex_pretty((uint8_t *) value2.c_str(), value2.size()).c_str();
//ESP_LOGW("raw_hex_boucle", "-- Recep Debut --");
//ESP_LOGD("raw_hex", "%s", rawhex.c_str());
rawhex.erase(std::remove(rawhex.begin(), rawhex.end(), '.'), rawhex.end());
int index = 3;
while (index +2 < x.size()) {
uint8_t idvaleur = x[index];
int taillevaleur = x[index + 1 ];
//ESP_LOGW("recep", "-- Recep value -- %d", idvaleur);
switch (idvaleur) {
case 0x00: {
}break;
case 0x01: {
id(val01) = static_cast<float>( x[index + 2])/10;
id(valforexport)[idvaleur] = true;
}break;
case 0x02: {
id(val02) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x03: {
id(val03) = static_cast<float>( x[index + 2]);
}break;
case 0x06: {
id(val06) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x08: {
id(val08) = static_cast<float>( x[index + 2]);
}break;
case 0x09: {
id(val09) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]) /10;
}break;
case 0x0A: {
id(val0A) = static_cast<float>( x[index + 2])/10;
}break;
case 0x0B: {
id(val0B) = static_cast<float>( x[index + 2]);
}break;
case 0x0C: {
id(val0C) = static_cast<float>( x[index + 2]);
}break;
case 0x0D: {
id(val0D) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x0E: {
id(val0E) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x0F: {
id(val0F) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x10: {
id(val10) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x11: {
id(val11) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x12: {
uint8_t dayphex = (x[index + 3]);
uint8_t monthphex = (x[index + 4]);
uint8_t yearphex = (x[index +5]);
int dayf = static_cast<int>(dayphex);
int monthf = static_cast<int>(monthphex);
int yearf = static_cast<int>(yearphex);
std::string datestr = std::to_string(dayf) + "/" + std::to_string(monthf) + "/20" + std::to_string(yearf);
//id(JustSalt_temp12_textsensor ).publish_state(datestr);
id(val12) = datestr.c_str();
}break;
case 0x13: {
//id(JustSalt_temp13_textsensor ).publish_state(datestr);
id(val13) = datestr.c_str();
}break;
case 0x1F: {
//ESP_LOGW("1f", "-- taille -- %d", taillevaleur);
id(val1F) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x28: {
id(val28) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x29: {
id(val29) = static_cast<float>( x[index + 2] );
}break;
case 0x2A: {
id(val2A) = static_cast<float>( x[index + 2]);
}break;
case 0x30: {
id(val30) = static_cast<float>( x[index + 2])/10;
}break;
case 0x31: {
id(val31) = static_cast<float>( x[index + 2]);
}break;
case 0x32: {
id(val32) = static_cast<float>( x[index + 2]);
}break;
case 0x33: {
id(val33) = static_cast<float>( x[index + 2]);
}break;
case 0x35: {
id(val35) = static_cast<float>( x[index + 2])*10;
}break;
case 0x37: {
id(val37) = static_cast<float>( x[index + 2]);
}break;
case 0x39: {
id(val39) = static_cast<float>( x[index + 2]);
}break;
case 0x50: {
id(val50) = static_cast<float>( x[index + 2]);
}break;
case 0x51: {
id(val51) = static_cast<float>( x[index + 2]);
}break;
case 0x5F: {
id(val5F) = static_cast<float>( x[index + 2]);
}break;
case 0x69: {
id(val69) = static_cast<float>( x[index + 2]<< 24) + (x[index + 3]<< 16)+ (x[index + 4]<< 8) + (x[index +5]);
}break;
case 0x6A: {
id(val6A) = static_cast<float>( x[index + 2]);
}break;
case 0x8F: {
id(val8F) = static_cast<float>( x[index + 2]);
}break;
case 0x90: {
// 90.08.00.00.00.00.00.00.00.14.
std::string tempstring = rawhex.substr((index + 2 )* 2,taillevaleur * 2);
id(val90) = tempstring.c_str();
}break;
case 0x91: {
// 91.08.00.00.00.00.00.06.6F.C3.
id(val91) = tempstring.c_str();
}break;
case 0x92: {
id(val92) = static_cast<float>( x[index + 2]);
}break;
case 0x93: {
id(val93) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x94: {
id(val94) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x95: {
id(val95) = static_cast<float>( x[index + 2]<< 24) + (x[index + 3]<< 16)+ (x[index + 4]<< 8) + (x[index +5]);
}break;
case 0x96: {
std::string verlog = rawhex.substr((index + 2 )* 2, 2) + "." + rawhex.substr((index + 2 )* 2 + 2, 2);
id(val96) = verlog.c_str();
}break;
case 0x97: {
std::string slaveval = rawhex.substr((index + 2 )* 2, 2) + "." + rawhex.substr((index + 2 )* 2 + 2, 2);
id(val97) = slaveval.c_str();
}break;
case 0x99: {
//99.16.47.45.4E.5F.30.35.32.32.2D.30.34.33.39.35.33.2D.30.30.33.00.00.00.
std::string tempstring = value2.substr((index + 2 ), taillevaleur);
//id(JustSalt_nombt_textsensor).publish_state(tempstring.c_str());
id(val99) = tempstring.c_str();
}break;
case 0x9A: {
//9A.10.30.35.32.32.2D.30.34.33.39.35.33.2D.30.30.33.00.
//id(JustSalt_sn_textsensor).publish_state(tempstring.c_str());
id(val9A) = tempstring.c_str();
}break;
case 0x9B: {
id(val9B) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x9C: {
id(val9C) = static_cast<float>( x[index + 2]<< 8) + (x[index +3]);
}break;
case 0x9D: {
// 9D.08.00.00.00.00.00.00.01.FF
std::string tempstring = rawhex.substr((index + 2 )* 2, taillevaleur * 2);
//id(JustSalt_9d_textsensor).publish_state(tempstring);
id(val9D) = tempstring.c_str();
}break;
case 0xA3: {
// E1.0F.18.04.11.11.00.33.00.00.88.00.F8.00.00.00.00
//id(JustSalt_a3_textsensor).publish_state(tempstring);
id(valA3) = tempstring.c_str();
}break;
case 0xB0: {
id(valB0) = static_cast<float>( x[index + 2]);
}break;
case 0xB1: {
String tempstring; //= rawhex.substr((index + 2 )* 2, taillevaleur *2);
for ( int i = index + 2; i < index + 2 + taillevaleur ; i++ ) {
tempstring += String(x[i],HEX) ;
if (i != index + 1 + taillevaleur){
tempstring += ":" ;
tempstring.toUpperCase();
id(valB1) = tempstring.c_str();
}break;
case 0xD0: {
//D0.06.30.00.00.00.00.00
std::string tempstring = rawhex.substr((index + 2 )* 2, taillevaleur *2 );
//id(JustSalt_d0_textsensor).publish_state(tempstring);
id(valD0) = tempstring.c_str();
}break;
case 0xD1: {
id(valD1) = static_cast<float>( x[index + 2]);
}break;
case 0xE1: {
std::string tempstring = rawhex.substr((index + 2 )* 2, taillevaleur *2);
//id(JustSalt_e1_textsensor).publish_state(tempstring);
id(valE1) = tempstring.c_str();
}break;
case 0xE2: {
// E2.0F.18.04.16.0A.22.10.00.00.00.41.3E.DC.00.00.00
//id(JustSalt_e2_textsensor).publish_state(tempstring);
id(valE2) = tempstring.c_str();
}break;
case 0xE4: {
// E4.0F.18.04.12.15.00.00.46.00.0B.13.00.00.00.00.00
//id(JustSalt_e4_textsensor).publish_state(tempstring);
id(valE4) = tempstring.c_str();
}break;
case 0xFE: {
id(valFE) = static_cast<float>( x[index + 2]);
id(valforexport)[idvaleur] = true;;
}break;
default: {
ESP_LOGW("raw_hex_boucle", "idvaleur Non implementee %d", idvaleur);
index = index + 2 + taillevaleur ;
//ESP_LOGW("raw_hex_boucle", "-- Recep FIN --> debut export");
int i=1;
for ( i = 1; i<= 254; i++) {
// ESP_LOGW("SendValue", "value send: %i ", i );
if (id(valforexport)[i] == true){
//ESP_LOGI("SendValue", "value send: %d - %i", i,i);
switch (i) {
case 0x01: {
id(JustSalt_ph_sensor).publish_state(id(val01));
id(valforexport)[i] = "false";
}break;
case 0x02: {
id(JustSalt_temp02_sensor).publish_state(id(val02));
}break;
case 0x03: {
id(JustSalt_temp03_sensor).publish_state(id(val03));
}break;
case 0x06: {
id(JustSalt_orp_sensor).publish_state(id(val06));
}break;
case 0x08: {
id(JustSalt_temp08_sensor).publish_state(id(val08));
}break;
case 0x09: {
id(JustSalt_temperature_sensor).publish_state(id(val09));
}break;
case 0x0A: {
id(JustSalt_tds_sensor).publish_state(id(val0A));
}break;
case 0x0B: {
id(JustSalt_temp0b_sensor).publish_state(id(val0B));
}break;
case 0x0C: {
id(JustSalt_temp0c_sensor).publish_state(id(val0C));
}break;
case 0x0D: {
id(JustSalt_temp0d_sensor).publish_state(id(val0D));
}break;
case 0x0E: {
id(JustSalt_temp0e_sensor).publish_state(id(val0E));
}break;
case 0x0F: {
id(JustSalt_temp0f_sensor).publish_state(id(val0F));
}break;
case 0x10: {
id(JustSalt_temp10_sensor).publish_state(id(val10));
}break;
case 0x11: {
id(vol_consigne).publish_state(id(val11));
}break;
case 0x12: {
id(JustSalt_temp12_textsensor).publish_state(id(val12).c_str());
}break;
case 0x13: {
id(JustSalt_temp13_textsensor).publish_state(id(val13).c_str());
}break;
case 0x1F: {
id(JustSalt_temp1f_sensor).publish_state(id(val1F));
}break;
case 0x28: {
id(JustSalt_temp28_sensor).publish_state(id(val28));
}break;
case 0x29: {
id(JustSalt_temp29_sensor).publish_state(id(val29));
}break;
case 0x2A: {
id(JustSalt_temp2a_sensor).publish_state(id(val2A));
}break;
case 0x30: {
if(id(val30) != id(ph_consigne).state ){
ESP_LOGI("compPHC", "value= %d - consigne = %i", id(val30),id(ph_consigne).state);
id(ph_consigne).publish_state(id(val30));
}break;
case 0x31: {
id(JustSalt_temp31_sensor).publish_state(id(val31));
}break;
case 0x32: {
if(id(val32) != id(acide_consigne).state ){
ESP_LOGI("compAcideC", "value= %d - consigne = %i", id(val32),id(acide_consigne).state);
id(acide_consigne).publish_state(id(val32));
}break;
case 0x33: {
if(id(val33) != id(production_consigne).state ){
ESP_LOGI("compProdC", "value= %d - consigne = %i", id(val33),id(production_consigne).state);
id(production_consigne).publish_state(id(val33));
}break;
case 0x35: {
if(id(val35) != id(orp_consigne).state ){
ESP_LOGI("compORPC", "value= %d - consigne = %i", id(val35),id(orp_consigne).state);
id(orp_consigne).publish_state(id(val35));
}break;
case 0x37: {
if(id(val37) != id(orp_alarme_consigne).state ){
ESP_LOGI("compORPAlarmeC", "value= %d - consigne = %i", id(val37),id(orp_alarme_consigne).state);
id(orp_alarme_consigne).publish_state(id(val37));
}break;
case 0x39: {
if(id(val39) != id(inversion_consigne).state ){
ESP_LOGI("compinversionC", "value= %d - consigne = %i", id(val39),id(inversion_consigne).state);
id(inversion_consigne).publish_state(id(val39));
}break;
case 0x50: {
id(JustSalt_temp50_sensor).publish_state(id(val50));
}break;
case 0x51: {
id(JustSalt_temp51_sensor).publish_state(id(val51));
}break;
case 0x5F: {
id(JustSalt_temp5f_sensor).publish_state(id(val5F));
}break;
case 0x69: {
id(JustSalt_temp69_sensor).publish_state(id(val69));
}break;
case 0x6A: {
id(JustSalt_temp6a_sensor).publish_state(id(val6A));
}break;
case 0x8F: {
id(JustSalt_temp8f_sensor).publish_state(id(val8F));
}break;
case 0x90: {
id(JustSalt_90_textsensor).publish_state(id(val90).c_str());
}break;
case 0x91: {
id(JustSalt_91_textsensor).publish_state(id(val91).c_str());
}break;
case 0x92: {
id(JustSalt_temp92_sensor).publish_state(id(val92));
}break;
case 0x93: {
id(JustSalt_temp93_sensor).publish_state(id(val93));
}break;
case 0x94: {
id(JustSalt_temp94_sensor).publish_state(id(val94));
}break;
case 0x95: {
id(idcode).publish_state(id(val95));
}break;
case 0x96: {
id(version_logiciel).publish_state(id(val96).c_str());
}break;
case 0x97: {
id(slave).publish_state(id(val97).c_str());
}break;
case 0x99: {
id(JustSalt_nombt_textsensor).publish_state(id(val99).c_str());
}break;
case 0x9A: {
id(JustSalt_sn_textsensor).publish_state(id(val9A).c_str());
}break;
case 0x9B: {
id(JustSalt_temp9b_sensor).publish_state(id(val9B));
}break;
case 0x9C: {
id(JustSalt_temp9c_sensor).publish_state(id(val9C));
}break;
case 0x9D: {
id(JustSalt_9d_textsensor).publish_state(id(val9D).c_str());
}break;
case 0xA3: {
id(JustSalt_a3_textsensor).publish_state(id(valA3).c_str());
}break;
case 0xB0: {
id(JustSalt_tempb0_sensor).publish_state(id(valB0));
}break;
case 0xB1: {
id(JustSalt_macbt_textsensor).publish_state(id(valB1).c_str());
}break;
case 0xD0: {
id(JustSalt_d0_textsensor).publish_state(id(valD0).c_str());
}break;
case 0xD1: {
id(JustSalt_tempd1_sensor).publish_state(id(valD1));
}break;
case 0xE1: {
id(JustSalt_e1_textsensor).publish_state(id(valE1).c_str());
}break;
case 0xE2: {
id(JustSalt_e2_textsensor).publish_state(id(valE2).c_str());
}break;
case 0xE4: {
id(JustSalt_e4_textsensor).publish_state(id(valE4).c_str());
}break;
case 0xFE: {
id(JustSalt_tempfe_sensor).publish_state(id(valFE));
}break;
//ESP_LOGW("raw_hex_boucle", "-- send export Fin --");
return 1;
switch:
- platform: restart
name: "Enable com JustSalt"
