Bonjour, j’ai suivi ce tuto et après installation de tous les packages, home assistant ne se lance pas.
Voici les commandes utilisé lors de l’installation de la clé USB avec Ubuntu server tv box.img
/.install.sh
#2
sudo apt-get update && sudo apt-get upgrade -y
sudo apt-get install jq wget curl avahi-daemon udisks2 libglib2.0-bin network-manager dbus apparmor -y
sudo apt --fix-broken install
sudo reboot
#3 docker https://i12bretro.github.io/tutorials/0476.html
sudo apt update
sudo apt install apt-transport-https ca-certificates curl gnupg-agent software-properties-common
curl -fsSL https://download.docker.com/linux/debian/gpg | sudo apt-key add -
sudo add-apt-repository "deb [arch=arm64] https://download.docker.com/linux/debian $(lsb_release -cs) stable"
sudo apt update
sudo apt install docker-ce docker-ce-cli containerd.io
#erreur retour étape 4
# add docker GPG key
curl -fsSL https://download.docker.com/linux/ubuntu/gpg | sudo apt-key add -
# add docker software repository
sudo add-apt-repository "deb [arch=arm64] https://download.docker.com/linux/ubuntu $(lsb_release -cs) stable"
# étape 5
# install docker
sudo apt update
# start docker service
sudo systemctl start docker
# enable docker service on startup
sudo systemctl enable docker
# create a docker group
sudo groupadd docker
# add the current user to the docker group
sudo usermod -aG docker $USER
#4 Installer l’agent pour home assistant os
Dans notre cas
wget https://github.com/home-assistant/os-agent/releases/download/1.2.2/os-agent_1.2.2_linux_aarch64.deb
sudo dpkg -i os-agent_1.2.2_linux_aarch64.deb
#5 installation de Home assistant supervised
wget https://github.com/home-assistant/supervised-installer/releases/latest/download/homeassistant-supervised.deb
sudo dpkg -i homeassistant-supervised.deb
#6 dpkg: error processing package homeassistant-supervised (--install):
sudo touch /boot/cmdline.txt
sudo sed -i -e "1 s/$/ systemd.unified_cgroup_hierarchy=false/" /boot/cmdline.txt
sudo reboot
#7 correction des erreurs
#Package systemd-journal-remote is not installed
sudo apt-get install -y systemd-journal-remote
apt-get -f install'
x96
Essai celui-ci comme tuto
Merci pour vos réponses.
@ClassicRed j’ai déjà fait ce tuto, le firmware ne fonctionne pas pour moi à moins que je dois essayer un autre #
# aml s9xxx
#FDT /dtb/amlogic/meson-gxbb-p200.dtb
FDT /dtb/amlogic/meson-gxl-s905x-p212.dtb
#FDT /dtb/amlogic/meson-gxm-q200.dtb
#FDT /dtb/amlogic/meson-g12a-x96-max.dtb
#FDT /dtb/amlogic/meson-g12b-odroid-n2.dtb
APPEND root=LABEL=ROOTFS rootflags=data=writeback rw console=ttyAML0,115200n8 console=tty0 no_console_suspend consoleblank=0 fsck.fix=yes fsck.repair=yes net.ifnames=0
Lancement
@Pulpy-Luke
J’ai essayé ceci
wget https://github.com/home-assistant/os-agent/releases/download/1.4.1/os-agent_1.4.1_linux_aarch64.deb
sudo dpkg -i os-agent_1.4.1_linux_aarch64.deb
apt-get -f install
Toujours pareil.
re,
j ai vue qu’après en me baladant sur le site que tu avais fait une demande d’aide sur un ancien post …
tu as regarde sur ta box operateur si tu vois l’ IP 192.168.1.70 ?
Autre question
ton X96 est connecté en wifi ou Ethernet ?
Et il faut s’assurer qu’on est en HTTP et pas en HTTPS
Oui tu m’avais aidé sur 1 tuto et pour éviter de faire du HS j’avais dis que je ferai un fil de discussion dédié à mon problème et mes commandes.
Oui je suis en ethernet et http. J’ai essayé https pas mieux
re,
ok,
possible mais j’ai du oublié
Alors essai de faire un ping sur l’ip de on x96 ( exemple )
Sur ta box FAI bloque le port (redirige ) 8123 sur l’ip 192.168.1.70
Pas de DMZ activé sur la box FAI ?
si tu arrive avec winscp , essai de te connecté sur la box , si ca marche trouve les deux fichiers suivants:
home-assistant.log
home-assistant.log1
Il contienne toutes les erreurs , et on sera peut être pourquoi ca bloque
le ping fonctionne
DMZ jamais entendu parler donc je suppose que non
winscp j’ai lancé une recherche je n’ai rien trouvé
j’ai l’impression qu’il n’est pas installé dans la mémoire interne.
Quel est le chemin d’accès ?
Bonjour, je n’y suis toujours pas arrivé. J’ai suivi ce tuto, rien à faire.
⚠ This guide has been migrated from our website and might be outdated. Feel free to edit this guide to update it, and to remove this message after that. armbian runs on a wide variety of ARM development boards. Currently, there are around 50 boards...
Reading time: 1 mins 🕑
Likes: 3 ❤
Est-ce qu’il existe une plateforme qui s’installe en système d’exploitation ou un autre OS ?
Version core ? ???
C’est nettement plus pénible à installer que la version docker…
re,
j’ai cru voir différente version du x96 avec proco diffèrent
Cela peut venir de la le souci , non ??
@ClassicRed Je ne sais pas du moment ou j’ai un environnement qui fonctionne ça devrait être bon non?
@Pulpy-Luke as tu un tuto pour tester, pour le moment j’ai rien de fonctionnel.
Peut être tenter une installation sur la clé USB et non la mémoire interne
Dommage qu’il n’y a pas un utilitaire pour créer une clé USB bootable avec l’installation de home assistant sur cette clé
@chuppito
Connais tu la reference exact du proco que tu x96
PROCESSEUR Cortex-A53 CPU
CPU : Amlogic S905W
PROCESSEUR Cortex-A55 CPU
CPU S905X3
Je vais tenter de réinitialiser tout le système directement sur la clé USB dès fois que le problème vienne de la mémoire interne
re
1 Giga en ram , ca risque de devenir chotte par la suite …
D’ici là j’espère avoir réussi de l’installer
J’ai essayé une autre img :
Armbian_22.11.0_Aml_s905w_bullseye_5.10.155_server_2022.11.24.img
