Mon hassio Raspberry Pi 3 arrêté de fonctionner
impossible de me connecter dans barre recherche sur safari depuis mise à jour
Renseigner votre problème
Depuis la dernière mise à jour impossible de me connecter et pourtant j’ai accès aux fichiers. J’ai esayé par homeassistant/ 192… et hassio mais impossible.
Dois je tout réinstaller? Merci de vos réponses
Partage ton log et ton type d’installation
Je ne comprend pas partager le long plus rien ne s’affiche
La première ligne tu ne peux pas, mais la seconde oui vu que tu as accès aux fichiers…
Et ton type d’installation c’est ici :
https://forum.hacf.fr/t/conseils-sur-le-choix-methode-ou-type-dinstallation/2068#un-petit-rsum-6
2021-12-16 17:36:48 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration favicon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration weatherbit which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration mqtt_discoverystream which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration toshiba_ac which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration prixCarburant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration myEnedis which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 ERROR (SyncWorker_0) [homeassistant.loader] The custom integration 'myEnedis' does not have a version key in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-12-16 17:36:48 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration myEnedis which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration homewizard_energy which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_4) [homeassistant.loader] We found a custom integration zigbee2mqtt_networkmap which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_2) [homeassistant.loader] We found a custom integration livebox which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_6) [homeassistant.loader] We found a custom integration bureau_of_meteorology which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_3) [homeassistant.loader] We found a custom integration xiaomi_cloud_map_extractor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_5) [homeassistant.loader] We found a custom integration remote_homeassistant which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration groupme which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:48 ERROR (SyncWorker_0) [homeassistant.loader] The custom integration 'groupme' does not have a version key in the manifest file and was blocked from loading. See https://developers.home-assistant.io/blog/2021/01/29/custom-integration-changes#versions for more details
2021-12-16 17:36:48 WARNING (SyncWorker_6) [homeassistant.loader] We found a custom integration weatheralerts which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2021-12-16 17:36:51 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2021-12-16 17:36:51 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=288 from 2021-12-15 18:32:30.258098)
2021-12-16 17:36:56 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_core_duckdns is not running
2021-12-16 17:37:03 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:37:03 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:37:03 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Pi-Hole' for pi_hole integration not ready yet: Can not load data from *hole: 192.168.1.254:80; Retrying in background
2021-12-16 17:37:05 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6fbc23b8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:37:05 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Salles - Aquitaine (33) - FR' for meteo_france integration not ready yet: None; Retrying in background
2021-12-16 17:37:08 WARNING (MainThread) [homeassistant.config_entries] Config entry 'SpeedTest' for speedtestdotnet integration not ready yet: <urlopen error [Errno -3] Try again>; Retrying in background
2021-12-16 17:37:10 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 187, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 147, in _async_update_data
    return await self.update_method()
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 253, in update_async
    return await execute_update()
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 248, in execute_update
    state = await hass.async_add_executor_job(update)
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 222, in update
    timer = device.timer()
  File "/usr/local/lib/python3.9/site-packages/miio/click_common.py", line 186, in _wrap
    self._fetch_info()
  File "/usr/local/lib/python3.9/site-packages/miio/integrations/vacuum/roborock/vacuum.py", line 209, in _fetch_info
    info = super()._fetch_info()
  File "/usr/local/lib/python3.9/site-packages/miio/device.py", line 149, in _fetch_info
    devinfo = DeviceInfo(self.send("miIO.info"))
  File "/usr/local/lib/python3.9/site-packages/miio/device.py", line 103, in send
    return self._protocol.send(
  File "/usr/local/lib/python3.9/site-packages/miio/miioprotocol.py", line 161, in send
    self.send_handshake()
  File "/usr/local/lib/python3.9/site-packages/miio/miioprotocol.py", line 65, in send_handshake
    m = MiIOProtocol.discover(self.ip)
  File "/usr/local/lib/python3.9/site-packages/miio/miioprotocol.py", line 116, in discover
    s.sendto(helobytes, (addr, 54321))
OSError: [Errno 101] Network unreachable
2021-12-16 17:37:10 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Boby' for xiaomi_miio integration not ready yet: [Errno 101] Network unreachable; Retrying in background
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.myenedis_16137047652806 (<class 'myEnedis.myEnedisSensorCoordinator'>) implements device_state_attributes. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+myEnedis%22
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.myenedis_history_16137047652806_all (<class 'myEnedis.myEnedisSensorCoordinatorHistory'>) implements device_state_attributes. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+myEnedis%22
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.myenedis_history_16137047652806_hp (<class 'myEnedis.myEnedisSensorCoordinatorHistory'>) implements device_state_attributes. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+myEnedis%22
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.myenedis_history_16137047652806_hc (<class 'myEnedis.myEnedisSensorCoordinatorHistory'>) implements device_state_attributes. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+myEnedis%22
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.helpers.entity] Entity sensor.myenedis_cost_yesterday_16137047652806 (<class 'myEnedis.myEnedisSensorYesterdayCostCoordinator'>) implements device_state_attributes. Please create a bug report at https://github.com/home-assistant/core/issues?q=is%3Aopen+is%3Aissue+label%3A%22integration%3A+myEnedis%22
2021-12-16 17:37:15 ERROR (MainThread) [homeassistant.components.updater] Error requesting Home Assistant update data: Cannot connect to host www.home-assistant.io:443 ssl:default [Try again]
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.setup] Setup of zone is taking over 10 seconds.
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.components.binary_sensor] Setup of binary_sensor platform rpi_power is taking over 10 seconds.
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.config_entries] Config entry 'HP OfficeJet 8010 series [92C4D1]' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.config_entries] Config entry 'HP OfficeJet 8010 series @ nanoulagrave@live.fr' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.config_entries] Config entry 'HP OfficeJet Pro 8720 [4932B6]' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.config_entries] Config entry 'HP OfficeJet Pro 8720 @ iMac de Imac' for ipp integration not ready yet: Invalid response from API: Error occurred while communicating with IPP server.; Retrying in background
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Z-Wave JS' for zwave_js integration not ready yet: None; Retrying in background
2021-12-16 17:37:15 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform myEnedis is taking over 10 seconds.
2021-12-16 17:37:15 ERROR (MainThread) [metno] Access to https://aa015h6buqvih86i1.api.met.no/weatherapi/locationforecast/2.0/complete returned error 'ClientConnectorError'
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.config_entries] Config entry '192.168.1.65' for synology_dsm integration not ready yet: ConnectionError = <urllib3.connection.HTTPSConnection object at 0x6cbb6ec8>: Failed to establish a new connection: [Errno 101] Network unreachable; Retrying in background
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Philips hue' for hue integration not ready yet: Error connecting to the Hue bridge at 192.168.2.138; Retrying in background
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.config_entries] Config entry 'admin - EC:71:DB:0F:62:04' for onvif integration not ready yet: None; Retrying in background
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Didou - EC:71:DB:3B:CC:1A' for onvif integration not ready yet: None; Retrying in background
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fe80::ed04:556c:73e3:6489: [Errno -2] Name does not resolve
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fe80::42:e4ff:fe92:d166: [Errno -2] Name does not resolve
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fe80::42:28ff:fee5:ec07: [Errno -2] Name does not resolve
2021-12-16 17:37:16 WARNING (MainThread) [homeassistant.components.ssdp] Failed to setup listener for fdf8:2f65:5151:eb00:e87d:8c31:927b:8054: [Errno -2] Name does not resolve
2021-12-16 17:37:21 WARNING (MainThread) [homeassistant.config_entries] Config entry 'eric.ducos7@orange.fr' for tuya integration not ready yet: HTTPSConnectionPool(host='openapi.tuyaeu.com', port=443): Max retries exceeded with url: /v1.0/iot-01/associated-users/actions/authorized-login (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x6cb93040>: Failed to establish a new connection: [Errno -3] Try again')); Retrying in background
2021-12-16 17:37:23 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1154, in _create_direct_connection
    hosts = await asyncio.shield(host_resolved)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 880, in _resolve_host
    addrs = await self._resolver.resolve(host, port, family=self._family)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/resolver.py", line 33, in resolve
    infos = await self._loop.getaddrinfo(
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 856, in getaddrinfo
    return await self.run_in_executor(
  File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.9/site-packages/aiogithubapi/client.py", line 100, in async_call_api
    result = await self._session.request(**request_arguments)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 535, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 542, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 907, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1166, in _create_direct_connection
    raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.github.com:443 ssl:default [Try again]
  File "/config/custom_components/hacs/base.py", line 253, in async_can_update
    response = await self.githubapi.rate_limit()
  File "/usr/local/lib/python3.9/site-packages/aiogithubapi/github.py", line 184, in rate_limit
    response = await self._client.async_call_api(endpoint="/rate_limit", **kwargs)
  File "/usr/local/lib/python3.9/site-packages/aiogithubapi/client.py", line 102, in async_call_api
    raise GitHubConnectionException(
aiogithubapi.exceptions.GitHubConnectionException: Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 17:37:28 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Orange Livebox' for upnp integration not ready yet; Retrying in background
2021-12-16 17:37:28 WARNING (MainThread) [homeassistant.config_entries] Config entry '华为4G路由3 Pro' for upnp integration not ready yet; Retrying in background
2021-12-16 17:37:33 WARNING (SyncWorker_7) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=2, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x6b2625c8>: Failed to establish a new connection: [Errno -3] Try again')': /bot1998230154:AAGYe_lgdPV0DDKMgp7PySKaOmYzZVnJ_6M/getMe
2021-12-16 17:37:34 ERROR (SyncWorker_0) [myEnedis] myEnedis err HTTPSConnectionPool(host='enedisgateway.tech', port=443): Max retries exceeded with url: /api (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x6d53c358>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:37:34 ERROR (SyncWorker_0) [myEnedis] Traceback (most recent call last):
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 174, in _new_conn
    conn = connection.create_connection(
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py", line 73, in create_connection
    for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 699, in urlopen
    httplib_response = self._make_request(
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 382, in _make_request
    self._validate_conn(conn)
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 1010, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 358, in connect
    conn = self._new_conn()
  File "/usr/local/lib/python3.9/site-packages/urllib3/connection.py", line 186, in _new_conn
    raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0x6d53c358>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 439, in send
    resp = conn.urlopen(
  File "/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py", line 755, in urlopen
    retries = retries.increment(
  File "/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py", line 574, in increment
    raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='enedisgateway.tech', port=443): Max retries exceeded with url: /api (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x6d53c358>: Failed to establish a new connection: [Errno -3] Try again'))
  File "/config/custom_components/myEnedis/myClientEnedis.py", line 193, in getData
    self.updateContract()
  File "/config/custom_components/myEnedis/myClientEnedis.py", line 253, in updateContract
    data = self._contract.updateContract(data)
  File "/config/custom_components/myEnedis/myContrat.py", line 71, in updateContract
    if (data == None): data = self.CallgetDataContract()
  File "/config/custom_components/myEnedis/myContrat.py", line 41, in CallgetDataContract
    return self.myCalli.getDataContract()
  File "/config/custom_components/myEnedis/myCall.py", line 170, in getDataContract
    dataAnswer = self.post_and_get_json(self._serverName, data=payload, headers=headers)
  File "/config/custom_components/myEnedis/myCall.py", line 54, in post_and_get_json
    response = session.post(url, params=params, data=json.dumps(data), headers=headers, timeout=30)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 590, in post
    return self.request('POST', url, data=data, json=json, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 542, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 655, in send
    r = adapter.send(request, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/adapters.py", line 516, in send
    raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host='enedisgateway.tech', port=443): Max retries exceeded with url: /api (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x6d53c358>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:37:34 ERROR (SyncWorker_0) [myEnedis] ------------------------------------------------------------
2021-12-16 17:37:34 WARNING (SyncWorker_0) [myEnedis] (<class 'requests.exceptions.ConnectionError'>, ConnectionError(MaxRetryError("HTTPSConnectionPool(host='enedisgateway.tech', port=443): Max retries exceeded with url: /api (Caused by NewConnectionError('<urllib3.connection.HTTPSConnection object at 0x6d53c358>: Failed to establish a new connection: [Errno -3] Try again'))")), <traceback object at 0x670898c8>)
2021-12-16 17:37:34 ERROR (SyncWorker_0) [myEnedis] LastMethodCall : updateContract
2021-12-16 17:37:38 WARNING (SyncWorker_7) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=1, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x6d1401a8>: Failed to establish a new connection: [Errno -3] Try again')': /bot1998230154:AAGYe_lgdPV0DDKMgp7PySKaOmYzZVnJ_6M/getMe
2021-12-16 17:37:40 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6b3c2da8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:37:40 ERROR (MainThread) [homeassistant.components.hassio.handler] Timeout on /addons/core_zwave_js/info request
2021-12-16 17:37:40 ERROR (MainThread) [homeassistant.components.zwave_js] Failed to get the Z-Wave JS add-on info:
2021-12-16 17:37:40 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:37:40 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:37:40 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:37:40 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:37:43 WARNING (MainThread) [homeassistant.helpers.frame] Detected integration that accessed discovery_info['properties'] instead of discovery_info.properties; this will fail in version 2022.6. Please report issue to the custom component author for remote_homeassistant using this method at custom_components/remote_homeassistant/config_flow.py, line 117: properties = info["properties"]
2021-12-16 17:37:43 WARNING (SyncWorker_7) [telegram.vendor.ptb_urllib3.urllib3.connectionpool] Retrying (Retry(total=0, connect=None, read=None, redirect=None)) after connection broken by 'NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x669b04d8>: Failed to establish a new connection: [Errno -3] Try again')': /bot1998230154:AAGYe_lgdPV0DDKMgp7PySKaOmYzZVnJ_6M/getMe
2021-12-16 17:37:45 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/repos/hacs/default/contents/removed' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 17:37:48 ERROR (MainThread) [homeassistant] Error doing job: Future exception was never retrieved
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connection.py", line 140, in _new_conn
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/util/connection.py", line 60, in create_connection
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connectionpool.py", line 614, in urlopen
    httplib_response = self._make_request(conn, method, url,
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connectionpool.py", line 360, in _make_request
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connectionpool.py", line 857, in _validate_conn
    super(HTTPSConnectionPool, self)._validate_conn(conn)
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connectionpool.py", line 289, in _validate_conn
    conn.connect()
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connection.py", line 284, in connect
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connection.py", line 149, in _new_conn
telegram.vendor.ptb_urllib3.urllib3.exceptions.NewConnectionError: <telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x6675bd00>: Failed to establish a new connection: [Errno -3] Try again
  File "/usr/local/lib/python3.9/site-packages/telegram/utils/request.py", line 252, in _request_wrapper
    resp = self._con_pool.request(*args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/request.py", line 68, in request
    return self.request_encode_body(method, url, fields=fields,
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/request.py", line 148, in request_encode_body
    return self.urlopen(method, url, **extra_kw)
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/poolmanager.py", line 244, in urlopen
    response = conn.urlopen(method, u.request_uri, **kw)
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connectionpool.py", line 691, in urlopen
    return self.urlopen(method, url, body, headers, retries,
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/connectionpool.py", line 665, in urlopen
    retries = retries.increment(method, url, error=e, _pool=self,
  File "/usr/local/lib/python3.9/site-packages/telegram/vendor/ptb_urllib3/urllib3/util/retry.py", line 376, in increment
telegram.vendor.ptb_urllib3.urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='api.telegram.org', port=443): Max retries exceeded with url: /bot1998230154:AAGYe_lgdPV0DDKMgp7PySKaOmYzZVnJ_6M/getMe (Caused by NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x6675bd00>: Failed to establish a new connection: [Errno -3] Try again'))
  File "/usr/src/homeassistant/homeassistant/components/telegram_bot/polling.py", line 23, in _start_bot
    pol.start_polling()
  File "/usr/src/homeassistant/homeassistant/components/telegram_bot/polling.py", line 91, in start_polling
    self.updater.start_polling()
  File "/usr/local/lib/python3.9/site-packages/telegram/ext/updater.py", line 285, in start_polling
    self._init_thread(self.dispatcher.start, "dispatcher", ready=dispatcher_ready)
  File "/usr/local/lib/python3.9/site-packages/telegram/ext/updater.py", line 225, in _init_thread
    name=f"Bot:{self.bot.id}:{name}",
  File "/usr/local/lib/python3.9/site-packages/telegram/bot.py", line 117, in decorator
    self.get_me()
  File "/usr/local/lib/python3.9/site-packages/decorator.py", line 232, in fun
    return caller(func, *(extras + args), **kw)
  File "/usr/local/lib/python3.9/site-packages/telegram/bot.py", line 135, in decorator
    result = func(*args, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/telegram/bot.py", line 392, in get_me
    result = self._post('getMe', timeout=timeout, api_kwargs=api_kwargs)
  File "/usr/local/lib/python3.9/site-packages/telegram/bot.py", line 245, in _post
    return self.request.post(f'{self.base_url}/{endpoint}', data=data, timeout=timeout)
  File "/usr/local/lib/python3.9/site-packages/telegram/utils/request.py", line 349, in post
    result = self._request_wrapper(
  File "/usr/local/lib/python3.9/site-packages/telegram/utils/request.py", line 258, in _request_wrapper
    raise NetworkError(f'urllib3 HTTPError {error}') from error
telegram.error.NetworkError: urllib3 HTTPError HTTPSConnectionPool(host='api.telegram.org', port=443): Max retries exceeded with url: /bot1998230154:AAGYe_lgdPV0DDKMgp7PySKaOmYzZVnJ_6M/getMe (Caused by NewConnectionError('<telegram.vendor.ptb_urllib3.urllib3.connection.VerifiedHTTPSConnection object at 0x6675bd00>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:37:50 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:37:50 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:37:50 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:38:09 ERROR (MainThread) [homeassistant.components.zwave_js] Failed to connect: Cannot connect to host core-zwave-js:3000 ssl:default [Connect call failed ('172.30.33.4', 3000)]
2021-12-16 17:38:10 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6d4903e8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:38:10 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 117, in _initialize
    await watcher.async_start()
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 323, in async_start
    await self.hass.async_add_executor_job(self._start)
  File "/usr/src/homeassistant/homeassistant/components/dhcp/__init__.py", line 332, in _start
    from scapy.layers.dhcp import DHCP  # pylint: disable=import-outside-toplevel
  File "/usr/local/lib/python3.9/site-packages/scapy/layers/dhcp.py", line 20, in <module>
    from scapy.ansmachine import AnsweringMachine
  File "/usr/local/lib/python3.9/site-packages/scapy/ansmachine.py", line 20, in <module>
    from scapy.sendrecv import send, sniff
  File "/usr/local/lib/python3.9/site-packages/scapy/sendrecv.py", line 61, in <module>
    import scapy.route  # noqa: F401
  File "/usr/local/lib/python3.9/site-packages/scapy/route.py", line 221, in <module>
    conf.ifaces.reload()
  File "/usr/local/lib/python3.9/site-packages/scapy/interfaces.py", line 238, in reload
    self._reload_provs()
  File "/usr/local/lib/python3.9/site-packages/scapy/interfaces.py", line 234, in _reload_provs
    self._load(prov.reload(), prov)
  File "/usr/local/lib/python3.9/site-packages/scapy/interfaces.py", line 53, in reload
    return self.load()
  File "/usr/local/lib/python3.9/site-packages/scapy/arch/linux.py", line 417, in load
    ifflags = struct.unpack("16xH14x", get_if(i, SIOCGIFFLAGS))[0]
  File "/usr/local/lib/python3.9/site-packages/scapy/arch/common.py", line 65, in get_if
    return ioctl(sck, cmd, struct.pack("16s16x", iff.encode("utf8")))
OSError: [Errno 19] No such device
2021-12-16 17:38:10 ERROR (MainThread) [custom_components.hacs] Timeout of 20 reached while waiting for https://api.github.com/rate_limit
  File "/usr/local/lib/python3.9/site-packages/aiogithubapi/client.py", line 108, in async_call_api
aiogithubapi.exceptions.GitHubConnectionException: Timeout of 20 reached while waiting for https://api.github.com/rate_limit
2021-12-16 17:38:10 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:38:10 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:38:10 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:38:11 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:38:11 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:38:26 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 17:38:37 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x658869e8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:38:44 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:38:44 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:38:50 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:38:51 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:38:51 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:39:12 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: 'dict object' has no attribute 'linkquality' when rendering '{{ value_json.linkquality }}'
2021-12-16 17:39:23 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x66a45f10>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:39:35 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:39:35 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:40:10 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:40:11 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:40:11 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:40:48 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x670d7280>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:41:00 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:41:00 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:41:30 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:41:31 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:41:31 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:42:00 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 17:42:13 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x65922718>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:42:26 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:42:26 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:42:50 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:42:51 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:42:51 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:43:38 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6ce466b8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:43:51 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:43:52 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:44:10 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:44:11 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:44:11 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:45:03 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6d9e4c10>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:45:16 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:45:16 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:45:30 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:45:31 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:45:31 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:46:28 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x64d17208>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:46:42 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:46:42 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:46:50 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:46:51 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:46:51 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:47:03 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 17:47:53 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x67085298>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:48:07 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:48:07 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:48:10 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:48:11 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:48:11 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:48:15 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 17:49:18 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6698ab98>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:49:32 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:49:32 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:49:32 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:49:32 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:49:32 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:50:43 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x66e02430>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:50:52 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:50:52 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:50:52 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:50:58 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:50:58 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:52:08 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x65c1c8f8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:52:12 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:52:12 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:52:12 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:52:23 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:52:23 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:53:32 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:53:32 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:53:32 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:53:33 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6588ffa0>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:53:48 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:53:48 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:54:52 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:54:52 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:54:52 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:54:58 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6d146718>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:55:14 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:55:14 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:56:12 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:56:12 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:56:12 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:56:23 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6ce44a30>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:56:39 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:56:39 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:57:12 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 17:57:32 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:57:32 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:57:32 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:57:48 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x64cd62c8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:58:03 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:58:03 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 17:58:15 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 17:58:52 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 17:58:52 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:58:52 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 17:59:13 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x65c73538>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 17:59:29 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 17:59:29 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:00:12 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:00:12 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:00:12 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:00:38 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6460f688>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:00:54 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:00:54 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:01:32 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:01:32 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:01:32 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:02:03 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x64226550>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:02:20 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 18:02:20 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:02:20 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:02:52 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:02:52 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:02:52 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:03:28 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x646288c8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:03:44 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:03:44 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:04:12 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:04:12 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:04:12 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:04:53 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x64c986e8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:05:10 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:05:10 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:05:32 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:05:32 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:05:32 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:06:18 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x65bf2100>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:06:36 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:06:36 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:06:52 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:06:52 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:06:52 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:07:24 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 18:07:43 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6ca165e0>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:08:01 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:08:01 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:08:12 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:08:13 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:08:13 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:08:15 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 18:09:08 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6466b838>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:09:26 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:09:26 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:09:32 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:09:33 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:09:33 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:10:33 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x65e4c3d0>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:10:51 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:10:51 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:10:52 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:10:53 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:10:53 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:11:58 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6cb2a8f8>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:12:17 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:12:17 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:12:17 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:12:17 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:12:17 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:12:28 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 18:13:23 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x6d0b7538>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:13:37 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 187, in _async_refresh
    self.data = await self._async_update_data()
  File "/usr/src/homeassistant/homeassistant/helpers/update_coordinator.py", line 147, in _async_update_data
    return await self.update_method()
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 253, in update_async
    return await execute_update()
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 248, in execute_update
    state = await hass.async_add_executor_job(update)
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 52, in run
    result = self.fn(*self.args, **self.kwargs)
  File "/usr/src/homeassistant/homeassistant/components/xiaomi_miio/__init__.py", line 222, in update
    timer = device.timer()
  File "/usr/local/lib/python3.9/site-packages/miio/click_common.py", line 186, in _wrap
    self._fetch_info()
  File "/usr/local/lib/python3.9/site-packages/miio/integrations/vacuum/roborock/vacuum.py", line 209, in _fetch_info
    info = super()._fetch_info()
  File "/usr/local/lib/python3.9/site-packages/miio/device.py", line 149, in _fetch_info
    devinfo = DeviceInfo(self.send("miIO.info"))
  File "/usr/local/lib/python3.9/site-packages/miio/device.py", line 103, in send
    return self._protocol.send(
  File "/usr/local/lib/python3.9/site-packages/miio/miioprotocol.py", line 161, in send
    self.send_handshake()
  File "/usr/local/lib/python3.9/site-packages/miio/miioprotocol.py", line 65, in send_handshake
    m = MiIOProtocol.discover(self.ip)
  File "/usr/local/lib/python3.9/site-packages/miio/miioprotocol.py", line 116, in discover
    s.sendto(helobytes, (addr, 54321))
OSError: [Errno 101] Network unreachable
2021-12-16 18:13:37 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:13:37 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:13:43 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:13:43 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:14:48 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x64d1c550>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:14:57 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:14:57 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:14:57 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:15:07 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:15:07 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:16:13 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Salles - Aquitaine (33) - FR data: HTTPConnectionPool(host='webservice.meteofrance.com', port=80): Max retries exceeded with url: /forecast?token=__Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8__&lat=44.5518&lon=-0.8686&lang=fr (Caused by NewConnectionError('<urllib3.connection.HTTPConnection object at 0x64c93a00>: Failed to establish a new connection: [Errno -3] Try again'))
2021-12-16 18:16:17 ERROR (MainThread) [homeassistant.components.xiaomi_miio] Unexpected error fetching Boby data: [Errno 101] Network unreachable
    self._fetch_info()
2021-12-16 18:16:17 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:16:17 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:16:33 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:16:33 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:17:31 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 18:17:37 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:17:37 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:18:05 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:18:06 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:18:15 ERROR (MainThread) [custom_components.hacs] Request exception for 'https://api.github.com/rate_limit' with - Cannot connect to host api.github.com:443 ssl:default [Try again]
2021-12-16 18:18:57 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:18:57 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:19:31 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:19:31 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:20:17 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:20:17 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:20:56 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:20:56 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:21:37 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:21:37 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:22:21 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:22:21 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:22:57 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:22:57 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:23:47 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:23:47 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:24:17 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:24:17 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:25:11 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:25:11 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:25:37 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:25:37 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:26:37 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:26:37 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:26:57 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:26:57 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:27:42 WARNING (MainThread) [homeassistant.components.hassio] Can't read Supervisor data: Container addon_db21ed7f_enedisgateway2mqtt is not running
2021-12-16 18:28:03 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'admin', but will retry later. Error: All connection attempts failed
2021-12-16 18:28:03 WARNING (MainThread) [homeassistant.components.onvif] Couldn't connect to camera 'Didou', but will retry later. Error: All connection attempts failed
2021-12-16 18:28:18 ERROR (MainThread) [hole] Can not load data from *hole: 192.168.1.254:80
2021-12-16 18:28:18 WARNING (MainThread) [homeassistant.components.pi_hole] Failed to connect: Can not load data from *hole: 192.168.1.254:80
Et mon type installation OS
