Partage carte Lovelace Volets
Un petit partage de ma carte lovelace Volets
Merci pour le partage.
Pourrais tu mettre le code de ta carte? Je suis aussi en train de faire ça et je suis preneur de toute idée…
En particulier, à quoi te sert le bouton avec le soleil ?
Vincent
Oui je vais partager un extrait du code! Le soleil c’est environ 20% (en fonction du volet et de l’orientation) ouvert pour ne pas avoir le soleil dans la maison.
type: vertical-stack
cards:
  - type: grid
    cards:
      - type: button
        show_name: false
        icon: mdi:window-shutter
        entity: group.volets_rdc
        show_state: false
        show_icon: true
        hold_action:
          action: none
        tap_action:
          action: more-info
      - type: button
        tap_action:
          action: call-service
          service: cover.open_cover
          service_data: {}
            entity_id:
              - cover.rollercuisine
              - cover.rollersalon
              - cover.rollertable
        show_name: false
        icon: mdi:arrow-up-bold
      - type: button
        tap_action:
          service: cover.stop_cover
          service_data: {}
            entity_id:
              - cover.rollersalon
              - cover.rollertable
        show_name: false
        icon: mdi:pause
      - type: button
        tap_action:
          service: cover.close_cover
          service_data: {}
            entity_id:
              - cover.rollersalon
              - cover.rollertable
        show_name: false
        icon: mdi:arrow-down-bold
      - type: button
        tap_action:
          service: cover.set_cover_position
          service_data:
            position: 20
            entity_id:
              - cover.rollersalon
              - cover.rollertable
        show_name: false
        icon: mdi:weather-sunny
    columns: 6
    square: true
  - type: markdown
    content: Tous les volets, salon, …
  - type: grid
    cards:
      - type: button
        show_name: false
        show_icon: true
        icon: mdi:sofa-single-outline
        show_state: false
        tap_action:
          action: more-info
        entity: cover.rollersalon
        hold_action:
          action: none
      - type: button
        tap_action:
          service_data: {}
            entity_id: cover.rollersalon
        show_icon: true
        show_name: false
      - type: button
        tap_action:
          service_data: {}
        icon: mdi:pause
        show_name: false
      - type: button
        tap_action:
          service_data: {}
        show_name: false
      - type: button
        tap_action:
          service_data:
            position: 20
        icon: mdi:weather-sunset-up
        show_name: false
      - type: picture-elements
        image: /local/1px.png
        elements:
          - type: state-label
            attribute: current_position
            suffix: '%'
            tap_action:
              action: more-info
            style:
              top: 50%
              left: 50%
              font-size: 16px
              font-weight: bold
              color: '#44739E'
        view_layout:
          position: sidebar
    square: true
    columns: 6
Il faut créer une image d’1 pixel avec la bonne couleur pour le pourcentage du volet (cela permet de créer le carré).
L’image ici (agrandi pour pouvoir la récupérer) : 1px
Pour info j’ai des volets IO qui sont commandées grâce à la passerelle KLF200.
Pour le groupe : Group - Home Assistant
Merci pour l’astuce, pour le groupe de volets au rdc j’ai pris simplement Group
Celui que je t’ai mis est dédié aux VR et tu peux afficher le pourcentage sur le groupe et aussi les utiliser en entity …
Bonsoir @Placidy,
Merci beaucoup pour ton partage !
Malheureusement je ne comprends pas comment tu créer une image d’1 pixel ?
Quand je copie colle ton code (en modifiant mes entités) je n’ai pas le % du coup.
Merci par avance pour tes explications
Salut, l’image d’1 pixel te permet de faire un carré, du coup ton pourcentage est au centre !
Copie cette image dans le dossier www de ta config
Montre un imp écran de ton problème @Bastinou250
@Placidy merci pour ta réponse
Voici le résultat,
j’ai mis l’image tel quel dans le répertoire comme ci dessous :
Il faut mettre ton image dans le dossier www soit config/www et sur la cartelove le lien est bien /local/1px.png. Je sais c’est bizarre !
Ah effectivement en créant un dossier « www » ça marche ! Merci beaucoup @Placidy , mais c’est vrai que c’est bizarre XD
Bonjour a tous,
Nouveau sur ce super forum je me suis lance dans home assistant depuis quelques jours le sujet des volets m’intéresse et je me suis permis de prendre le code de Placidy que je remercie au passage pour sont travail il fonctionne très mais je m’ai qu’une fermeture de volet au lieu des quatre comme sur la photo lovelace Volets et je ne comprends pourquoi.
Si une personne pourrais m’aider a comprendre.
Merci d’avance
Cordialement
Salut @filtre , bienvenue sur ce forum.
Pour ta question : il faut adapter ton code à tes volets !
Pour chaques volets, tu auras au minima ce code, ou il faudra modifier les entity, les icon, les position.
C’est une grille (grid) avec 6 colonnes, soit 5 button et un picture-elements (à la fin) pour le pourcentage :
  - type: grid
    cards:
      - type: button
        show_name: false
        show_icon: true
        show_state: false
        tap_action:
          action: more-info
        hold_action:
          action: none
      - type: button
        tap_action:
          service_data: {}
        show_icon: true
        show_name: false
      - type: button
        tap_action:
          service_data: {}
        icon: mdi:pause
        show_name: false
      - type: button
        tap_action:
          service_data: {}
        show_name: false
      - type: button
        tap_action:
          service_data:
            position: 20
        show_name: false
        elements:
          - type: state-label
            suffix: '%'
            tap_action:
              action: more-info
            style:
              top: 50%
              left: 50%
              font-size: 16px
              font-weight: bold
              color: '#44739E'
        view_layout:
          position: sidebar
    square: true
    columns: 6
Bonjour Placidy merci de ta réponse
Bon c’est un peux du chinois pour moi mais si j’ai bien compris je dois faire un truc comme sa:
mais quand je veux rajouter un volet je le mais a la suite de ce script?
Désole je ne suis trop doué
type: grid
cards:
  • type: grid
    cards:
    • type: button
      show_name: false
      show_state: false
      show_icon: true
      hold_action:
      action: none
      tap_action:
      action: more-info
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_salon
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_salon
      show_name: false
      icon: mdi:pause
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_salon
      show_name: false
    • type: button
      tap_action:
      service_data:
      position: 20
      entity_id:
      - cover.volet_salon
      show_name: false
      columns: 6
      square: true
  • type: markdown
    content: Tous les volets de la Maison
  • type: grid
    cards:
    • type: button
      show_name: false
      show_icon: true
      show_state: false
      tap_action:
      action: more-info
      entity: cover.volet_salon
      hold_action:
      action: none
    • type: button
      tap_action:
      service_data: {}
      entity_id: cover.volet_salon
      show_icon: true
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      icon: mdi:pause
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      show_name: false
    • type: button
      tap_action:
      service_data:
      position: 20
      show_name: false
    • type: picture-elements
      elements:
      • type: state-label
        suffix: ‹ % ›
        tap_action:
        action: more-info
        style:
        top: 50%
        left: 50%
        font-size: 16px
        font-weight: bold
        color: ‹ #44739E ›
        view_layout:
        position: sidebar
        square: true
        columns: 6
Ou je dois faire comme un dèrriere l’autre?
type: grid
cards:
  • type: grid
    cards:
    • type: button
      show_name: false
      show_state: false
      show_icon: true
      hold_action:
      action: none
      tap_action:
      action: more-info
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_salon
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_salon
      show_name: false
      icon: mdi:pause
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_salon
      show_name: false
    • type: button
      tap_action:
      service_data:
      position: 20
      entity_id:
      - cover.volet_salon
      show_name: false
      columns: 6
      square: true
  • type: markdown
  • type: grid
    cards:
    • type: button
      show_name: false
      show_icon: true
      show_state: false
      tap_action:
      action: more-info
      hold_action:
      action: none
    • type: button
      tap_action:
      service_data: {}
      show_icon: true
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      icon: mdi:pause
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      show_name: false
    • type: button
      tap_action:
      service_data:
      position: 20
      show_name: false
      elements:
      • type: state-label
        suffix: ‹ % ›
        tap_action:
        action: more-info
        style:
        top: 50%
        left: 50%
        font-size: 16px
        font-weight: bold
        color: ‹ #44739E ›
        view_layout:
        position: sidebar
        square: true
        columns: 6
type: grid
cards:
  • type: grid
    cards:
    • type: button
      show_name: false
      show_state: false
      show_icon: true
      hold_action:
      action: none
      tap_action:
      action: more-info
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      - cover.volet_cuisine
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      show_name: false
      icon: mdi:pause
    • type: button
      tap_action:
      service_data: {}
      entity_id:
      show_name: false
    • type: button
      tap_action:
      service_data:
      position: 20
      entity_id:
      show_name: false
      columns: 6
      square: true
  • type: markdown
  • type: grid
    cards:
    • type: button
      show_name: false
      show_icon: true
      show_state: false
      tap_action:
      action: more-info
      hold_action:
      action: none
    • type: button
      tap_action:
      service_data: {}
      entity_id: cover.volet_cuisine
      show_icon: true
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      icon: mdi:pause
      show_name: false
    • type: button
      tap_action:
      service_data: {}
      show_name: false
    • type: button
      tap_action:
      service_data:
      position: 20
      show_name: false
      elements:
      • type: state-label
        entity: cover.volet_cuisine
        suffix: ‹ % ›
        tap_action:
        action: more-info
        style:
        top: 50%
        left: 50%
        font-size: 16px
        font-weight: bold
        color: ‹ #44739E ›
        view_layout:
        position: sidebar
        square: true
        columns: 6
Comme ceci (exemple avec deux boutons pour 2 lignes) :
cards:
# Début ligne 1
  - type: grid
    cards:
# Bouton avec état volet
      - type: button
        show_name: false
        show_icon: true
        show_state: false
        tap_action:
          action: more-info
        entity: cover.VOLET1
        hold_action:
          action: none
# Bouton ouvrir volet
      - type: button
        tap_action:
          service_data: {}
            entity_id: cover.VOLET1
        show_icon: true
        show_name: false
#METTRE ICI LES 4 AUTRES BOUTONS
#Fin pour créer les boutons carrés et 6 colonnes
    square: true
    columns: 6
# Fin ligne 1
# Début ligne 2
  - type: grid
    cards:
      - type: button
        show_name: false
        show_icon: true
        show_state: false
        tap_action:
          action: more-info
        entity: cover.VOLET2
        hold_action:
          action: none
      - type: button
        tap_action:
          service_data: {}
            entity_id: cover.VOLET2
        show_icon: true
        show_name: false
#Créer les boutons carrés et 6 colonnes
    square: true
    columns: 6
# Fin ligne 2
Je te remercie de ton aide je vais essaye de le faire et je te tiens au courant.
Encore grand merci
Re,
J’ai réussi a refaire ton model que tu as posté mais désolé pourquoi il me manque le reste?
Si j’essaye de rajouter un autre code pour mettre mes autres volets il me dit erreur.
il faut rajouté une autre grille dans la grille?
image_2022-01-27_231628
Perso, je préfère avoir quelques choses de plus uniforme ( j’aime pas les boutons séparer pour le même store)
Code au besoin :
state_color: true
type: entities
  - entity: cover.store
    secondary_info: last-changed
    type: custom:slider-entity-row
    step: 5
    min: 0
    max: 100
    grow: true
    full_row: true
Re enfin j’ai réussi grand merci Placidy de l’aide que tu portes et surtout de ta patience.
Salut roumano c’est gentil pour ton code.
@++ pour d’autre aide
