Je viens de me rendre compte, que j’ai des icônes et états qui ne s’affiche plus sur la carte météo france.
et qu’il as des états en français, alors qu’ils ont en anglais d’habitude.
Tous les états écrient en français, ne remonte plus d’icône.
Avez vous remarquer la même chose ?
| version | core-2025.4.2 |
| dev | false |
| hassio | true |
| docker | true |
| user | root |
| virtualenv | false |
| python_version | 3.13.2 |
| os_name | Linux |
| os_version | 6.6.74-haos-raspi |
| arch | aarch64 |
| timezone | Europe/Paris |
| config_dir | /config |
| GitHub API | ok |
| GitHub Content | ok |
| GitHub Web | ok |
| HACS Data | ok |
| GitHub API Calls Remaining | 4901 |
| Installed Version | 2.0.5 |
| Stage | running |
| Available Repositories | 1675 |
| Downloaded Repositories | 80 |
| logged_in | false |
| can_reach_cloud_auth | ok |
| can_reach_cloud | ok |
| host_os | Home Assistant OS 15.1 |
| update_channel | stable |
| supervisor_version | supervisor-2025.04.0 |
| agent_version | 1.7.2 |
| docker_version | 28.0.4 |
| disk_total | 109.3 GB |
| disk_used | 18.3 GB |
| healthy | true |
| supported | true |
| host_connectivity | true |
| supervisor_connectivity | true |
| ntp_synchronized | true |
| virtualization | |
| board | rpi4-64 |
| supervisor_api | ok |
| version_api | ok |
| installed_addons | Samba share (12.5.0), Terminal & SSH (9.16.0), File editor (5.8.0), Mosquitto broker (6.5.0), Zigbee2MQTT (2.2.1-1), Home Assistant Google Drive Backup (0.112.1), ESPHome Device Builder (2025.3.3), NGINX Home Assistant SSL proxy (3.11.1), MyElectricalData (0.13.2), openWakeWord (1.10.0), Piper (1.5.2), vosk (1.6.1), porcupine (1.1.0), Let’s Encrypt (5.4.4), pigpio (1.5.3) |
| dashboards | 4 |
| resources | 55 |
| views | 44 |
| mode | storage |
Network Configuration
| adapters | lo (disabled), end0 (enabled, default, auto), docker0 (disabled), hassio (disabled), vethdd57f5b (disabled), vethd7ce787 (disabled), veth520da94 (disabled), vethef12673 (disabled), veth3bd918d (disabled), veth487bc0a (disabled), veth7357db7 (disabled), veth140b9c2 (disabled), veth30ebf5b (disabled), veth44738af (disabled), veth0afa964 (disabled), vethf7fcf4b (disabled), veth9dc362f (disabled), veth0a0bc71 (disabled), veth870585f (disabled), veth637a9ea (disabled), veth9d3edc3 (disabled), vethda5db22 (disabled) |
| ipv4_addresses | lo (127.0.0.1/8), end0 (192.168.1.137/24), docker0 (172.30.232.1/23), hassio (172.30.32.1/23), vethdd57f5b (), vethd7ce787 (), veth520da94 (), vethef12673 (), veth3bd918d (), veth487bc0a (), veth7357db7 (), veth140b9c2 (), veth30ebf5b (), veth44738af (), veth0afa964 (), vethf7fcf4b (), veth9dc362f (), veth0a0bc71 (), veth870585f (), veth637a9ea (), veth9d3edc3 (), vethda5db22 () |
| ipv6_addresses | lo (::1/128), end0 (fe80::ae4:f212:1808:7384/64), docker0 (fe80::b869:1cff:feb8:ca8/64), hassio (fe80::f4:a2ff:fe48:cb92/64), vethdd57f5b (fe80::dc2f:d3ff:febc:9f/64), vethd7ce787 (fe80::8c81:60ff:fe68:ba05/64), veth520da94 (fe80::f035:aeff:fe5c:b1a5/64), vethef12673 (fe80::20b1:6fff:fe0b:224e/64), veth3bd918d (fe80::a466:e2ff:fe83:66e0/64), veth487bc0a (fe80::4cef:e3ff:feba:a0de/64), veth7357db7 (fe80::5410:8cff:fe38:47a1/64), veth140b9c2 (fe80::1428:5cff:fe26:6157/64), veth30ebf5b (fe80::f024:5aff:fef6:4338/64), veth44738af (fe80::b874:4bff:fe07:2d0a/64), veth0afa964 (fe80::d84f:b1ff:fe4b:5714/64), vethf7fcf4b (fe80::7c28:51ff:fec1:7120/64), veth9dc362f (fe80::3036:5fff:fe58:cb04/64), veth0a0bc71 (fe80::c8a9:95ff:fe97:3ff1/64), veth870585f (fe80::c4c:42ff:fe4c:82cf/64), veth637a9ea (fe80::9080:c9ff:fec7:2abe/64), veth9d3edc3 (fe80::9874:6aff:fef5:5561/64), vethda5db22 (fe80::d85f:bbff:fe15:602/64) |
| announce_addresses | 192.168.1.137, fe80::ae4:f212:1808:7384 |
| oldest_recorder_run | 12 avril 2025 à 16:06 |
| current_recorder_run | 14 avril 2025 à 09:33 |
| estimated_db_size | 209.55 MiB |
| database_engine | sqlite |
| database_version | 3.48.0 |
Spotify
| api_endpoint_reachable | ok |
Xiaomi Miot Auto
| component_version | 1.0.16 |
| can_reach_server | ok |
| can_reach_spec | ok |
| logged_accounts | 0 |
| total_devices | 0 |
