Oui Patron ^^
Ci-dessous.
Mais aussi… d’accord si la carte sd est foutu, maintenant prenons l’exemple dans lequel les entités zigbee sont coincés, comment faire à distance? Est-ce possible vers des entités à batterie de forcer un ping? ou de demander une reinitialisation sans devoir être physiquement présent?
MQTT
cont-init: info: running /etc/cont-init.d/mosquitto.sh
[09:21:09] INFO: SSL is not enabled
cont-init: info: /etc/cont-init.d/mosquitto.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
services-up: info: copying legacy longrun mosquitto (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[09:21:14] INFO: Starting NGINX for authentication handling...
[09:21:14] INFO: Starting mosquitto MQTT broker...
2025-01-18 09:21:15: Warning: Mosquitto should not be run as root/administrator.
2025-01-18 09:21:15: mosquitto version 2.0.20 starting
2025-01-18 09:21:15: Config loaded from /etc/mosquitto/mosquitto.conf.
2025-01-18 09:21:15: Loading plugin: /usr/share/mosquitto/go-auth.so
2025-01-18 09:21:15: ├── Username/password checking enabled.
2025-01-18 09:21:15: ├── TLS-PSK checking enabled.
2025-01-18 09:21:15: └── Extended authentication not enabled.
2025-01-18 09:21:15: Opening ipv4 listen socket on port 1883.
2025-01-18 09:21:15: Opening ipv6 listen socket on port 1883.
2025-01-18 09:21:15: Opening websockets listen socket on port 1884.
2025-01-18 09:21:15: mosquitto version 2.0.20 running
2025-01-18 09:21:16: New connection from ::1:48192 on port 1883.
2025-01-18 09:21:16: Client <unknown> disconnected due to protocol error.
[09:21:22] INFO: Successfully send discovery information to Home Assistant.
[09:21:25] INFO: Successfully send service information to the Supervisor.
2025-01-18 09:22:15: New connection from 172.30.32.1:34081 on port 1883.
2025-01-18 09:22:15: New client connected from 172.30.32.1:34081 as 05HqEq39o4RGsl1ZXcl8SO (p2, c1, k60, u'mqtt').
2025-01-18 09:23:04: New connection from 172.30.33.3:54248 on port 1883.
2025-01-18 09:23:04: New client connected from 172.30.33.3:54248 as mqttjs_d49c9311 (p2, c1, k60, u'mqtt').
2025-01-18 09:25:07: New connection from 172.30.32.2:55242 on port 1883.
2025-01-18 09:25:07: Client <unknown> closed its connection.
Z2M
[09:22:38] INFO: Preparing to start...
[09:22:39] INFO: Socat not enabled
[09:22:40] INFO: Starting Zigbee2MQTT...
[2025-01-18 09:23:00] info: z2m: Logging to console, file (filename: log.log)
[2025-01-18 09:23:00] info: z2m: Starting Zigbee2MQTT version 2.0.0 (commit #unknown)
[2025-01-18 09:23:00] info: z2m: Starting zigbee-herdsman (3.2.1)
[2025-01-18 09:23:01] info: zh:ember: Using default stack config.
[2025-01-18 09:23:01] info: zh:ember: ======== Ember Adapter Starting ========
[2025-01-18 09:23:01] info: zh:ember:ezsp: ======== EZSP starting ========
[2025-01-18 09:23:01] info: zh:ember:uart:ash: ======== ASH Adapter reset ========
[2025-01-18 09:23:01] info: zh:ember:uart:ash: RTS/CTS config is off, enabling software flow control.
[2025-01-18 09:23:01] info: zh:ember:uart:ash: Serial port opened
[2025-01-18 09:23:01] info: zh:ember:uart:ash: ======== ASH starting ========
[2025-01-18 09:23:03] info: zh:ember:uart:ash: ======== ASH connected ========
[2025-01-18 09:23:03] info: zh:ember:uart:ash: ======== ASH started ========
[2025-01-18 09:23:03] info: zh:ember:ezsp: ======== EZSP started ========
[2025-01-18 09:23:03] info: zh:ember: Adapter EZSP protocol version (13) lower than Host. Switched.
[2025-01-18 09:23:03] info: zh:ember: Adapter version info: {"ezsp":13,"revision":"7.4.5 [GA]","build":0,"major":7,"minor":4,"patch":5,"special":0,"type":170}
[2025-01-18 09:23:03] info: zh:ember: [STACK STATUS] Network up.
[2025-01-18 09:23:03] info: zh:ember: [INIT TC] Adapter network matches config.
[2025-01-18 09:23:03] info: zh:ember: [CONCENTRATOR] Started source route discovery. 1246ms until next broadcast.
[2025-01-18 09:23:03] info: z2m: zigbee-herdsman started (resumed)
[2025-01-18 09:23:03] info: z2m: Coordinator firmware version: '{"meta":{"build":0,"ezsp":13,"major":7,"minor":4,"patch":5,"revision":"7.4.5 [GA]","special":0,"type":170},"type":"EmberZNet"}'
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Kot-2 (0x0ceff6fffe5c3d55): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Cuisine (0x0ceff6fffe5c4aee): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Kot-3 (0x0ceff6fffe58cee5): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Kot-4 (0x0ceff6fffe590736): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Kot-5 (0x842712fffe1a26b1): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Annexe-1 (0x0ceff6fffe173a9b): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Capteur-Presence-Annexe-2 (0x0ceff6fffe5c3ab7): SNZB-06P - SONOFF Zigbee occupancy sensor (Router)
[2025-01-18 09:23:03] info: z2m: Detecteur-Porte-Cave (0x881a14fffeedef17): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Detecteur-Fenetre-Kot-2 (0x881a14fffeeddd32): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Detecteur-Fenetre-Kot-3 (0x0ceff6fffe3c6d13): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Detecteur-Fenetre-Kot-4 (0x0ceff6fffe644a03): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Detecteur-Fenetre-Kot-5 (0x0ceff6fffe64517d): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Detecteur-Fenetre-Annexe-1 (0x881a14fffeed0703): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Detecteur-Fenetre-Annexe-2 (0x0ceff6fffe644a06): SNZB-04P - SONOFF Contact sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Kot-1 (0x842712fffe50d21c): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Kot-2 (0x842712fffe50f027): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Kot-3 (0x0cae5ffffeda31b4): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Cuisine (0x842712fffe516cfd): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Kot-4 (0x048727fffefd1778): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Kot-5 (0x842712fffe50925f): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Capteur-Temperature-Annexe (0x0cae5ffffedc73e5): SNZB-02P - SONOFF Temperature and humidity sensor (EndDevice)
[2025-01-18 09:23:03] info: z2m: Currently 21 devices are joined.
[2025-01-18 09:23:03] info: z2m: Connecting to MQTT server at mqtt://core-mosquitto:1883
[2025-01-18 09:23:05] info: z2m: Connected to MQTT server
[2025-01-18 09:23:05] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kot-1/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kot-2/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kot-3/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kot-4/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Kot-5/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Annexe/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Cuisine/availability', payload '{"state":"online"}'
[2025-01-18 09:23:06] info: z2m: Started frontend on port 8099
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Kot-2', payload '{"illumination":null,"linkquality":216,"occupancy":null,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":4102,"latest_version":4102,"state":"idle"}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Cuisine', payload '{"illumination":"bright","linkquality":168,"occupancy":true,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":4102,"latest_version":4102,"state":"idle"}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Kot-3', payload '{"illumination":"bright","linkquality":156,"occupancy":true,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":4102,"latest_version":4102,"state":"idle"}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Kot-4', payload '{"illumination":"bright","linkquality":168,"occupancy":true,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":-1,"latest_version":-1,"state":null}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Kot-5', payload '{"illumination":"bright","linkquality":220,"occupancy":true,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":-1,"latest_version":-1,"state":null}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Annexe-1', payload '{"illumination":"bright","linkquality":236,"occupancy":true,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":-1,"latest_version":-1,"state":null}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Presence-Annexe-2', payload '{"illumination":"bright","linkquality":232,"occupancy":true,"occupancy_sensitivity":null,"occupancy_timeout":null,"update":{"installed_version":4102,"latest_version":4102,"state":"idle"}}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Porte-Cave', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":224,"tamper":true,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Fenetre-Kot-2', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":196,"tamper":true,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Fenetre-Kot-3', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":204,"tamper":true,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Fenetre-Kot-4', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":196,"tamper":true,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Fenetre-Kot-5', payload '{"battery":100,"battery_low":false,"contact":true,"linkquality":180,"tamper":null,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Fenetre-Annexe-1', payload '{"battery":100,"battery_low":false,"contact":false,"linkquality":224,"tamper":true,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Detecteur-Fenetre-Annexe-2', payload '{"battery":100,"battery_low":false,"contact":false,"linkquality":180,"tamper":true,"update":{"installed_version":8704,"latest_version":8704,"state":"idle"},"voltage":3100}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Kot-1', payload '{"battery":100,"humidity":44.7,"linkquality":140,"temperature":19.3}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Kot-2', payload '{"battery":100,"humidity":50.2,"linkquality":168,"temperature":19.4}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Kot-3', payload '{"battery":100,"humidity":42.7,"linkquality":136,"temperature":19.3}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Cuisine', payload '{"battery":100,"humidity":45.2,"linkquality":116,"temperature":20.3}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Kot-4', payload '{"battery":100,"humidity":46.4,"linkquality":192,"temperature":19.5}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Kot-5', payload '{"battery":100,"humidity":45.7,"linkquality":168,"temperature":20.3}'
[2025-01-18 09:23:07] info: z2m:mqtt: MQTT publish: topic 'zigbee2mqtt/Capteur-Temperature-Annexe', payload '{"battery":100,"humidity":45.2,"linkquality":188,"temperature":20.5}'
[2025-01-18 09:23:07] info: z2m: Zigbee2MQTT started!
[2025-01-18 09:23:12] info: z2m:mqtt: MQTT publish: topic 'homeassistant/binary_sensor/1221051039810110150109113116116_0x0ceff6fffeca97fd/connection_state/config', payload '{"device":{"hw_version":"EmberZNet 7.4.5 [GA]","identifiers":["zigbee2mqtt_bridge_0x0ceff6fffeca97fd"],"manufacturer":"Zigbee2MQTT","model":"Bridge","name":"Zigbee2MQTT Bridge","sw_version":"2.0.0"},"device_class":"connectivity","entity_category":"diagnostic","name":"Connection state","object_id":"zigbee2mqtt_bridge_connection_state","origin":{"name":"Zigbee2MQTT","sw":"2.0.0","url":"https://www.zigbee2mqtt.io"},"payload_off":"offline","payload_on":"online","state_topic":"zigbee2mqtt/bridge/state","unique_id":"bridge_0x0ceff6fffeca97fd_connection_state_zigbee2mqtt","value_template":"{{ value_json.state }}"}'
NOTE: Suite au redemarrage de la PI (en hard reset pour voir) Plus aucun capteur ne change d’état de nouveau/…
NOTE 2: La PI3 est à 30cm d’une PI5 avec une clé dongle Zigbee également (Mais où les capteurs fonctionnent parfaitement pour celle-là)
Tous les capteurs sont empilés dans leurs boites et donc à proximité.
Le modem wifi est à 30cm des PI…
Interference? mais pas de souci sur la pi5 (qui est aussi en SD)
