Quel type de carte pour capteur température + humidité?
bonjour , merci btncrd pour votre aide , voici le code.
type: custom:button-card
entity: sensor.plant_sensor_cb67_temperature
icon: mdi:sofa
show_state: false
show_name: false
label: Salon
show_label: true
styles:
  card:
    - position: relative
  grid:
    - grid-template-areas: " \"i i\" \"l l\" \"temp temp\" \"hum hum\" \"update heure\" \"apex apex\" \"graph graph\""
    - grid-template-columns: 50% 50%
    - margin-top: 2%
    - padding-bottom: 0%
  label:
    - font-size: 11px
    - font-style: italic
    - opacity: 75%
  icon:
    - opacity: 75%
  custom_fields:
    temp:
      - font-size: 26px
    hum:
      - font-size: 13px
    link:
      - position: absolute
      - left: 15%
      - top: 5%
    battery:
      - left: 80%
      - top: 5%
    update:
      - justify-self: middle
      - align-self: middle
      - font-size: 12px
      - opacity: 60%
      - margin-top: 10%
    heure:
      - font-size: 12px
      - opacity: 60%
      - margin-top: 10%
    apex:
      - top: "-2%"
      - left: "-15%"
      - width: 100%
      - height: 100%
      - "--ha-card-border-width": 0
      - "--ha-card-background": transparent
    graph:
      - margin-top: 0%
custom_fields:
  temp: >
    [[[ var temp = states['sensor.plant_sensor_cb67_temperature' ].state; return
    `<ha-icon
      icon="mdi:thermometer"
      style="width: 18px; height: 18px; color: #7dc8ff ">
      </ha-icon>` + temp + '°'; ]]]
  hum: >
    [[[ var hum = states['sensor.plant_sensor_cb67_humidite' ].state;     return
    `<ha-icon
      icon="mdi:water"
      style="width: 15px; height: 15px; color: #7dc8ff ">
      </ha-icon>` + hum + '%'; ]]]
  update: |
      return `<ha-icon icon="mdi:progress-clock" style="width: 20px; height: 20px;"></ha-icon>` +
      ' Dernière M.A.J.';
  apex:
    card:
      type: custom:apexcharts-card
      chart_type: radialBar
      series:
        - entity: sensor.plant_sensor_cb67_temperature
          max: 40
          color: "#00FF00"
          show:
            legend_value: false
        - entity: sensor.plant_sensor_cb67_humidite
          max: 100
          color: "#FEFEFE"
          show:
            legend_value: false
      apex_config:
        plotOptions:
          radialBar:
            offsetY: 0
            hollow:
            dataLabels:
              name:
                show: false
              value:
                show: false
            track:
              dropShadow:
                enabled: true
                top: 3
                left: 0
                blur: 4
                opacity: 0.25
              strokeWidth: 75%
              margin: 3
        fill:
          type: gradient
          gradient:
            type: vertical
            gradientToColors:
              - "#E73E01"
              - "#0F9DE8"
            stops:
              - 0
              - 100
        legend:
          show: false
        chart:
          height: 100%
  graph:
    card:
      type: custom:mini-graph-card
      hours_to_show: 24
      points_per_hour: 1
      hour24: true
      line_width: 2
      decimals: 1
          color: "#ffc04c"
          color: "#2a75cf"
          show_line: true
          show_points: true
          show_legend: true
          y_axis: secondary
      show:
        fill: true
        graph: line
        icon: false
        state: false
        labels: false
        extrema: true
        average: true
        icon_adaptive_color: false
        labels_secondary: false
      align_icon: right
      align_state: left
Bonjour @droid
Pour régler ton problème tu dois changer les 2 valeurs suivantes :
  • Champs ligne 53 : “top: 0%” (au lieu de -2%) (Styles > Custom_fields > Apex > top) pour le positionnement vertical
  • Champs ligne 54 : “left: 0%” (au lieu de -15%) (Styles > Custom_fields > Apex > left) pour le positionnement horizontal
Cela devrait résoudre ton problème et recentrer la jauge.
    apex:
      - top: 0%    ### Tu peux jouer sur cette valeur pour descendre la jauge
      - left: 0%
Bonjour, @Sabjul33,
Tu as plusieurs options pour les mettre côte à côte :
  • Rajouter et adapter les options “grid" comme précisé par @Chris6729 :
section_mode: true
grid_options:
  columns: 4
  rows: 5
Dans la mesure où tu as des 3 sections, chacune doit faire 12 “columns” de large si je ne dis pas de bêtises donc si tu veux 3 cartes côte à côte : 12/3 = 4 columns (ou 12/2 = 6 columns pour 2 cartes côte à côte… etc.). Tu peux vérifier le nombre de colonnes par section dans l’onglet “Mise en page” quand tu crées une carte native de Home Assistant
  • 2ème solution tu contournes le problème en créant une carte de type “pile horizontale” et de là tu ajoutes autant de cartes que souhaité. Pas testé mais logiquement ça doit fonctionner
bonjour. il y avait déjà ces valeurs, c’est moi qui les ait modifier pour palier au décalage.
Je regarde ça et je posterai un code pour l’affichage en mode section dès que possible.
EDIT : j’avais pas vu ta réponse @Integra, désolé :wink:
@btncrd @Integra Merci je regarde ça, mais il me semble avoir tenter la pile horizontale.
Bonsoir,
Une version qui fonctionne avec le mode section avec ajout du changement de couleurs automatique en fonction du thème (clair ou sombre) :
J’ai fiabilisé les “if then else” en bornant les expressions (>= à valeur basse et < à valeur haute) et j’ai uniformisé les unités.
Code de la première carte (mode compact) :
section_mode: true
grid_options:
  rows: 2
  columns: 6
aspect_ratio: 1/1
custom_fields:
  apex:
    card:
      series:
        - entity: sensor.perron_thermometre_temperature
          max: 40
          color: "#00FF00"
          show:
            legend_value: false
        - entity: sensor.perron_thermometre_humidity
          max: 100
          color: "#FEFEFE"
          show:
            legend_value: false
      apex_config:
        plotOptions:
          radialBar:
            offsetY: 0
            hollow:
            dataLabels:
              name:
                show: false
              value:
                show: false
            track:
              dropShadow:
                enabled: true
                top: 3
                left: 0
                blur: 4
                opacity: 0.25
              strokeWidth: 75%
              margin: 3
        fill:
          type: gradient
          gradient:
            type: vertical
            gradientToColors:
              - "#E73E01"
              - "#0F9DE8"
            stops:
              - 0
              - 100
        legend:
          show: false
        chart:
          height: 120%
  room:
    card:
      icon: mdi:home-thermometer
      label: Perron
      show_label: true
      styles:
        card:
          - background: transparent
          - aspect-ratio: 2/1
          - width: 122px
          - border: none
          - border-radius: 0
          - transform: translate(-50%,-50%)
          - pointer-events: none
          - cursor: default
          - z-index: 0
        icon:
          - width: 23%
          - color: var(--primary-text-color)
          - opacity: 75%
          - padding-top: 5%
        label:
          - font-size: 0.8rem
          - opacity: 75%
          - padding-bottom: 8%
  temp:
    card:
      icon: mdi:thermometer
      show_state: true
      show_name: false
      state_display: |
          return parseFloat(states['sensor.perron_thermometre_temperature'].state).toFixed(1) + '°';
      layout: icon_state
      numeric_precision: 1
      styles:
        card:
          - width: 122px
          - border: none
          - border-radius: 0
        icon:
          - width: 50%
          - color: "#7dc8ff"
          - padding-left: 20%
        state:
          - opacity: 75%
          - font-size: 1.4rem
          - padding-right: 20%
  hum:
    card:
      icon: mdi:water
      show_state: true
      show_name: false
      state_display: |
          return parseFloat(states['sensor.perron_thermometre_humidity'].state).toFixed(1) + ' %';
      layout: icon_state
      styles:
        card:
          - width: 122px
          - border: none
          - border-radius: 0
        icon:
          - width: 40%
          - color: "#7dc8ff"
          - padding-left: 25%
        state:
          - opacity: 75%
          - font-size: 1.1rem
          - padding-right: 25%
          - padding-top: 2%
  link_quality:
    card:
      show_name: false
      icon: >-
        [[[ var link =
        states['sensor.allee_du_garage_thermometre_linkquality'].state;
          if (link >= 170)
            return "mdi:signal-cellular-3";
          else if (link >= 85 && link < 170)
            return "mdi:signal-cellular-2";
          else if (link >= 1 && link < 85)
            return "mdi:signal-cellular-1";
          else
            return "mdi:signal-cellular-outline";
      styles:
        card:
          - border: none
          - border-radius: 0
          - width: 30px
        icon:
          - width: 90%
          - color: "#7dc8ff"
  battery:
    card:
      show_name: false
      show_label: true
      layout: icon_label
      icon: |-
          var entity = states['sensor.perron_thermometre_battery'];
          if (!entity || entity.state === 'unavailable' || entity.state === 'unknown')
            return 'mdi:battery-alert-variant-outline';
          var battery = parseInt(entity.state);
          if (isNaN(battery) || battery < 1)
          else if (battery <= 10)
            return 'mdi:battery-10';
          else if (battery > 10 && battery <= 20)
          else if (battery > 20 && battery <= 70)
            return 'mdi:battery-50';
          else
            return 'mdi:battery';
      label: |
          if (entity && entity.state !== 'unavailable' && entity.state !== 'unknown') {
            return entity.state + '%';
          return '';
      styles:
        card:
          - border: none
          - aspect-ratio: 2/1
          - border-radius: 0
          - width: 50px
        icon:
          - color: |-
                  return 'lightgrey';
                  return 'lightgrey';
                  return 'darkred';
                  return 'red';
                  return 'orange';
                else
                  return 'green';
          - width: 100%
          - margin-left: 10%
        label:
          - font-size: 0.9rem
          - color: |-
                  return 'lightgrey';
                  return 'lightgrey';
                  return 'darkred';
                  return 'red';
                  return 'orange';
                else
                  return 'green';
          - padding-top: 6%
          - padding-right: 15%
styles:
  card:
    - background-color: var(--card-background-color, rgba(28,28,28,1.0))
    - box-shadow: |
          return (variables.theme === 'dark')
            ? '0 4px 12px rgba(0,0,0,0.3)'
            : '0 2px 8px rgba(0,0,0,0.1)';
    - cursor: default
  custom_fields:
    apex:
      - display: flex
      - justify-content: center
      - align-items: center
      - top: 50%
      - left: 50%
      - transform: translate(-50%, -50%)
      - overflow: visible
    room:
      - top: 30%
      - left: 50%
    temp:
      - top: 50%
      - left: 50%
    hum:
      - top: 65%
      - left: 50%
    link_quality:
      - left: 3%
      - top: 2%
    battery:
      - right: 1%
      - top: 2%
variables:
  theme: |
      return (window.matchMedia && window.matchMedia('(prefers-color-scheme: dark)').matches)
        ? 'dark' : 'light';
Code de la deuxième carte (mode étendu) :
section_mode: true
grid_options:
  rows: 2
  columns: 6
aspect_ratio: 1/1.6
custom_fields:
  apex:
    card:
      series:
          max: 40
          color: "#00FF00"
          show:
            legend_value: false
          max: 100
          color: "#FEFEFE"
          show:
            legend_value: false
      apex_config:
        plotOptions:
          radialBar:
            offsetY: 0
            hollow:
            dataLabels:
              name:
                show: false
              value:
                show: false
            track:
              dropShadow:
                enabled: true
                top: 3
                left: 0
                blur: 4
                opacity: 0.25
              strokeWidth: 75%
              margin: 3
        fill:
          type: gradient
          gradient:
            type: vertical
            gradientToColors:
              - "#E73E01"
              - "#0F9DE8"
            stops:
              - 0
              - 100
        legend:
          show: false
        chart:
          height: 100%
  room:
    card:
      label: Perron
      show_label: true
      styles:
        card:
          - aspect-ratio: 2/1
          - width: 122px
          - border: none
          - border-radius: 0
          - cursor: default
          - z-index: 0
        icon:
          - width: 23%
          - opacity: 75%
          - padding-top: 5%
        label:
          - font-size: 0.8rem
          - opacity: 75%
  temp:
    card:
      show_state: true
      show_name: false
      state_display: |
      layout: icon_state
      styles:
        card:
          - width: 122px
          - border: none
          - border-radius: 0
        icon:
          - width: 50%
          - color: "#7dc8ff"
          - padding-left: 20%
        state:
          - opacity: 75%
          - font-size: 1.4rem
  hum:
    card:
      icon: mdi:water
      show_state: true
      show_name: false
      state_display: |
      layout: icon_state
      styles:
        card:
          - width: 122px
          - border: none
          - border-radius: 0
        icon:
          - width: 40%
          - color: "#7dc8ff"
          - padding-left: 25%
        state:
          - opacity: 75%
          - font-size: 1.1rem
          - padding-top: 2%
  link_quality:
    card:
      show_name: false
      icon: >-
        [[[ var link =
          if (link >= 170)
          else
      styles:
        card:
          - border: none
          - border-radius: 0
          - width: 30px
        icon:
          - width: 90%
          - color: "#7dc8ff"
  battery:
    card:
      show_name: false
      show_label: true
      layout: icon_label
      icon: |-
          else
      label: |
          return '';
      styles:
        card:
          - border: none
          - aspect-ratio: 2/1
          - border-radius: 0
          - width: 50px
        icon:
          - color: |-
                  return 'lightgrey';
                  return 'lightgrey';
                  return 'darkred';
                  return 'red';
                  return 'orange';
                else
                  return 'green';
          - width: 100%
          - margin-left: 10%
        label:
          - font-size: 0.9rem
          - color: |-
                  return 'lightgrey';
                  return 'lightgrey';
                  return 'darkred';
                  return 'red';
                  return 'orange';
                else
                  return 'green';
          - padding-top: 6%
  update_text: |
    [[[ return 'Dernière M.A.J.'; ]]]
  update_time: >
    [[[ return
    helpers.relativeTime(states['sensor.allee_du_garage_thermometre_last_seen'].last_changed);
  graph:
    card:
      hours_to_show: 24
      points_per_hour: 1
      hour24: true
      line_width: 3
      decimals: 1
          color: "#2a75cf"
          y_axis: secondary
          color: "#ffc04c"
          y_axis: primary
      y_axis: secondary
      show:
        fill: true
        graph: line
        icon: false
        state: false
        labels: false
        extrema: true
        average: true
        align_icon: right
        align_state: left
      font_size: 82
      height: 170
styles:
  card:
    - box-shadow: |
    - cursor: default
  custom_fields:
    apex:
      - display: flex
      - top: 25%
      - left: 50%
      - overflow: visible
    room:
      - top: 16%
      - left: 50%
    temp:
      - top: 26%
      - left: 50%
    hum:
      - top: 33%
      - left: 50%
    link_quality:
      - left: 3%
      - top: 2%
    battery:
      - right: 1%
      - top: 2%
    update_text:
      - top: 48%
      - left: 4%
      - font-size: 0.85rem
    update_time:
      - top: 48%
      - right: 4%
    graph:
      - bottom: 0%
      - left: 0%
      - "--primary-text-color": var(--primary-text-color)
variables:
  theme: |
        ? 'dark' : 'light';
@Sabjul33 peux-tu me dire si ça fonctionne pour toi ? Je suis en largeur 4 pour la section :
@btncrd
Je viens de mettre le code de la seconde carte c’est top, par contre concernant la taille :
j’ai 3 sections
avec le code j’avais la carte qui dépassait en hauteur.
J’ai modifié le code
grid_options:
  rows: 2
  columns: 6
aspect_ratio: 1/1.6
par
grid_options:
  rows: null
  columns: 5
aspect_ratio: 1/1.6
et là c’est bon.
Donc je pense que pour moi c’est ok.
Merci à toi…:flexed_biceps:
Salut à tous,
Merci à tous pour le travail effectué et en particulier @herveaurel et @Integra. Je débute sur HA depuis quelques semaines et je me prends pas mal la tête sur mon panneau énergie (voir ici pour les plus motivés).
Je cherchais à me détendre et suis tombé sur ce topic. En me basant sur le message d’@integra N°170 et sa version “complète”, j’ai fait un peu d’adaptation pour coller à ma situation et tout parait limpide ou presque ! J’arrive à afficher une jolie carte, à la modifier un peu selon mes envies, ça remonte le moral ! :sweat_smile:
J’ai notamment inversé les couleurs des cercles (le bleu me parait plus adapté pour l’humidité) et mis l’icône du thermomètre en orange. C’est peut-être un détail pour vous, mais pour moi… :rofl:
Il me reste cependant quelques questions car je suis encore bien loin d’être un codeur…
  • Où trouver l’info “dernière vue du capteur” car je ne l’ai pas dans MQTT, là où j’ai trouvé les autres infos (T°, humidité, batterie) ?
  • Est-il possible d’avoir les données “Min/Avg/Max” sans avoir le graphique affiché ?
  • J’arrive à déplacer l’icone batterie et modifier sa taille, mais je ne trouve pas comment modifier la taille de la police du pourcentage ?
D’autres questions viendront sûrement…
Merci à tous.
entity: sensor.capteur_tdeg_salon_temperature
icon: mdi:sofa
show_state: false
show_name: false
label: Salon
show_label: true
styles:
  card:
  grid:
    - grid-template-areas: >-
        "link battery" "i i" "l l" "temp temp" "hum hum" "update heure" "apex
        apex" "graph graph"
    - margin-top: 2%
  label:
    - font-size: 11px
    - opacity: 75%
  icon:
    - opacity: 75%
  custom_fields:
    temp:
      - font-size: 26px
    hum:
      - font-size: 13px
    battery:
      - left: 62%
      - top: 10%
    update:
      - font-size: 12px
      - opacity: 60%
      - margin-top: 10%
    heure:
      - font-size: 12px
      - opacity: 60%
      - margin-top: 10%
    apex:
      - top: 0%
      - left: 0%
      - width: 100%
      - height: 100%
custom_fields:
  temp: >
    [[[ var temp = states['sensor.capteur_tdeg_salon_temperature' ].state;
    return `<ha-icon
      style="width: 18px; height: 18px; color: #ffd27f ">
  hum: >
    [[[ var hum = states['sensor.capteur_tdeg_salon_humidity' ].state;
    return `<ha-icon
      icon="mdi:water"
  battery: |
    [[[ var battery = states['sensor.capteur_tdeg_salon_battery'].state;
      if (battery >= 70)
        return `<ha-icon icon="mdi:battery" style="width: 20px; height: 20px; color: green"></ha-icon>` + battery + '%';
      else if (battery >= 20)
        return `<ha-icon icon="mdi:battery-50" style="width: 20px; height: 20px; color: orange"></ha-icon>` + battery + '%';
      else if (battery >= 1)
        return `<ha-icon icon="mdi:battery-10" style="width: 20px; height: 20px; color: red"></ha-icon>` + battery + '%';
      else
        return `<ha-icon icon="mdi:battery-alert-variant-outline" style="width: 20px; height: 20px; color: darkred"></ha-icon>` + battery + '%'; ]]]
  update: |
      ' Dernière M.A.J.';
  apex:
    card:
      series:
        - entity: sensor.capteur_tdeg_salon_temperature
          max: 40
          color: "#ffd27f"
          show:
            legend_value: false
        - entity: sensor.capteur_tdeg_salon_humidity
          max: 100
          color: "#7dc8ff"
          show:
            legend_value: false
      apex_config:
        plotOptions:
          radialBar:
            offsetY: 0
            hollow:
            dataLabels:
              name:
                show: false
              value:
                show: false
            track:
              dropShadow:
                enabled: true
                top: 3
                left: 0
                blur: 4
                opacity: 0.25
              strokeWidth: 75%
              margin: 3
        fill:
          type: gradient
          gradient:
            type: vertical
            gradientToColors:
              - "#ffc04c"
              - "#2a75cf"
            stops:
              - 0
              - 100
        legend:
          show: false
        chart:
          height: 100%
Bonjour @Ridingfree,
Ravi que la carte te plaises et que tu es pu la mettre en place sans trop de soucis !
Oui le code peut paraitre un peu barbare mais si on prend le temps de tester on finit par plus ou moins tout comprendre.
Si tu veux l’info “dernière vue” il te faut activer cette option dans Z2M. Dans le menu Paramètres du module Z2M, puis onglet Avancé, tu actives l’option last_seen avec la valeur ISO_8601 :
Ensuite dans l’intégration MQTT, là ou tu es allé chercher la T°, humidité et batterie, il te faudra activer l’entité Last seen en cliquant sur l’engrenage (paramètres) de l’entité, car elle est désactivée et masquée par défaut :
Oui tu peux masquer le graphique et gardé seulement “Min/Avg/Max”, pour ça dans le code de la carte Mini-graph-card, il te faut changer ça :
  • graph: line (ligne 177 de mon code initial) : remplace line par false et le graphique sera masqué
Tu peux également modifier la taille de police du pourcentage retourné en ajoutant la ligne font-size: 12px dans la partie styles: du custom_fields battery: (= au même endroit ou tu déplaces l‘icône) comme ça :
    battery:
      - left: 80%
      - top: 5%
      - font-size: 12px   ### Ajuste la valeur selon ton souhait
Voilà, je pense n’avoir rien oublié, si tu as d’autres questions n’hésite pas !
Merci pour ces infos, je testerai les modifs du code cet après-midi. :+1:
Pour ce qui est de l’option “last seen”, j’ai bien réussi à l’activer dans Z2M mais je ne trouve pas comment activer l’entité dans MQTT. Je ne la vois pas apparaitre…
Merci encore pour ton aide.
Fais une recherche parmis tes entités :
Le sensor doit apparaitre dans l’onglet diagnostic :
Regarde ce qu’il y a sous “+ 1 entité désactivée” :
@Ridingfree , le sensor last_seen est désactivé par défaut et caché. Il faut l’activer dans les entités de ton appareil dans l’intégration MQTT
Merci pour vos réponses à tous les deux.
@btncrd quand je recherche dans mes entités, je n’ai rien.
Et j’avais regardé le +1 dans l’onglet diagnostic, mais c’est le link quality…
@WarC0zes je n’ai que l’entité Link quality qui est dans les “désactivés” de mon capteur dans MQTT…
Peut-être que ce capteur Aliexpress ne fournit pas cette info car je ne la trouve pas non plus dans “cachée”, “non configurable”, “non fournie”…
Ce n’est pas le capteur qui fournit le last_seen mais zigbee2mqtt. Chaque message envoyé par le capteur remet à jour le last_seen.
Sélectionne “ISO_8601_local” à la place de “ISO_8601”.
Si ça ne fonctionne toujours pas, redémarre le module complémentaire.
Regarde le tuto :
il doit te manquer une configuration.
@btncrd Merci, je n’avais pas redémarré Z2M. Maintenant que je l’ai fait ça fonctionne parfaitement !
@WarC0zes Merci également, j’étais passé à côté de ce tuto que j’en ai profité pour lire attentivement. :wink:
Si c’est bon pour toi, mets ton sujet en résolu. La solution revient à @WarC0zes
Ce n’est pas lui qui a créé le sujet :wink:
Arfff oui, c’est un sujet qui date de Mathusalem et qui n’aura jamais de solution :rofl:
