FREDERIC_DURAND:
- platform: schedule_state
default_state: "eco"
events:
- start: "08:00"
end: "10:00"
state: "confort"
condition:
- condition: time
weekday: [mon, tue, wed, thu, fri]
- start: "18:00"
end: "23:00"
state: "boost"
Peznse à corriger l’indentation qui n’est pas bonne
events:
- start: "08:00"
end: "10:00"
state: "confort"
condition:
- condition: time
- start: "18:00"
end: "23:00"
state: "boost
@FREDERIC_DURAND ça fonctionne au final ?
oui merci cela fonctionne reste plus qu’a faire mes planning correct
avec ce sensor :
events:
- start: "08:00"
end: "10:00"
state: "confort"
condition:
- condition: time
- start: "18:00"
end: "23:00"
state: "boost"
voici ce que j’obtient
et le log
2025-12-15 17:30:21.590001 WARNING schedule_parser: Error loading global YAML (likely due to !include/secrets or indentation): automations.yaml is not a valid yaml file. Attempting extraction of sensor section...
2025-12-15 17:30:21.653323 ERROR schedule_parser: Skipping invalid sensor block #1: sensor block is not a mapping
2025-12-15 17:30:21.656626 ERROR schedule_parser: Skipping invalid sensor block #2: sensor block is not a mapping
2025-12-15 17:30:21.660143 ERROR schedule_parser: Skipping invalid sensor block #3: sensor block is not a mapping
2025-12-15 17:30:22.058625 INFO schedule_parser: Sensor 'sensor.schedule_tarif_actuel_ttc': 7 events - Unit: ''
2025-12-15 17:30:22.131507 INFO schedule_parser: Sensor 'sensor.schedule_test_chauf': 7 events - Unit: ''
2025-12-15 17:30:22.505247 INFO schedule_parser: Sensor 'sensor.schedule_chauffage_du_salon': 7 events - Unit: ''
2025-12-15 17:30:22.508271 INFO schedule_parser: Parsing completed: 3/3 sensors processed successfully
Bonsoir;
Pour info, j’ai directement intégré l’équivalent du code AppDaemon dans une version modifiée de schedule_state :
Home Assistant (HA) sensor that returns a string based on a defined schedule, enabling further automations
Si tout fonctionne correctement (je suis en train de tester, aucun souci pour l’instant), je ferai une PR sur le dépôt d’origine.
Du coup, les sensor.schedule_* disparaissent : il faudra utiliser directement les sensor.*.
Ça permet aussi de simplifier l’installation et de se passer complètement d’AppDaemon.
@FREDERIC_DURAND et @bemo47 si vous avez le courage de basculer et de me faire une retour, je suis preneur
Je veux bien tenter la bascule. Si tu me dis ce qu’il faut faire pour basculer pas de soucis de mon côté.
bemo47
Décembre 16, 2025, 10:36
48
je viens de faire la désinstalaltion de mon dépot actuel schedule_state de HACS, mais quand je veur réinstaller on dirait que je retombe sur le même, quoique il y a marqué version 0.19.5, est-ce bien le bon ?
C’est pas la bonne,
J’ai fait les changement minimaux dans le repo, pour me simplifier la vie avec le futur PR, mais du coup, c’est moins facile à distinguer coté HACS
bemo47
Décembre 16, 2025, 10:45
50
ah j’ai pas compris comment la trouver alors
filtre sur le nom schedule s => 0 étoiles, activité récente
Evidement il faut avoir ajouté le repo avant
bemo47
Décembre 16, 2025, 10:49
52
oui c’est le repo que je trouve pas, j’ai cliqué sur le lien que tu as mis dans le 1er message mais je tombe sur le mauvais
C’est bon, pour moi tous a l’air fonctionnel
merci
bemo47
Décembre 16, 2025, 10:57
56
C’est ce nom de dépot que je ne voyait pas dans les messages, je ne sais ou il était…
Sinon après redémarrage mon sensor.chauffage_du_salon a récupéré tous ça, je vérifie la suite :
states: boost, frost, comfort, eco
next_state: frost
start: 00:00:00
end: 23:59:59.999999
friendly_start: 00:00:00
friendly_end: midnight
errors:
layers:
mon:
- condition_key: default
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
original_start: '00:00'
original_end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
raw_state_template: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
is_default_bg: false
z_index: 2
is_dynamic_color: false
- event_idx: 1
start: '01:30'
end: '11:00'
original_start: '01:30'
original_end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
raw_state_template: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
original_start: '11:00'
original_end: '19:00'
wraps_start: false
wraps_end: false
state_value: comfort
raw_state_template: comfort
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
original_start: '19:00'
original_end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
is_default_layer: false
- condition_key: |
- !!python/object/new:annotatedyaml.objects.NodeDictClass
dictitems:
condition: state
entity_id:
- binary_sensor.f_salon_g_contact
match: all
state: 'on'
condition_text: '[''binary_sensor.f_salon_g_contact''] = on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
raw_state_template: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
- input_boolean.presence
match: all
state: 'off'
condition_text: '[''input_boolean.presence''] = off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
condition_text: default
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
tooltip: Default state
description: ''
icon: mdi:calendar-check
is_default_bg: true
z_index: 1
is_default_layer: true
tue:
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 1
start: '01:30'
end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
wraps_start: false
wraps_end: false
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
description: ''
is_default_bg: true
z_index: 1
wed:
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 1
start: '01:30'
end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
wraps_start: false
wraps_end: false
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
description: ''
is_default_bg: true
z_index: 1
thu:
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 1
start: '01:30'
end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
wraps_start: false
wraps_end: false
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
description: ''
is_default_bg: true
z_index: 1
fri:
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 1
start: '01:30'
end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
wraps_start: false
wraps_end: false
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
description: ''
is_default_bg: true
z_index: 1
sat:
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 1
start: '01:30'
end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
wraps_start: false
wraps_end: false
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
description: ''
is_default_bg: true
z_index: 1
sun:
condition_text: ''
blocks:
- event_idx: 0
start: '00:00'
end: '01:30'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 1
start: '01:30'
end: '11:00'
wraps_start: false
wraps_end: false
state_value: eco
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 2
start: '11:00'
end: '19:00'
wraps_start: false
wraps_end: false
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- event_idx: 3
start: '19:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: boost
unit: ''
raw_conditions: []
condition_text: ''
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'on'
blocks:
- event_idx: 4
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'on'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
- condition_key: |
dictitems:
condition: state
entity_id:
match: all
state: 'off'
blocks:
- event_idx: 5
start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions:
- condition: state
entity_id:
state: 'off'
match: all
tooltip: ''
description: ''
icon: mdi:calendar
z_index: 2
blocks:
- start: '00:00'
end: '23:59'
wraps_start: false
wraps_end: false
state_value: frost
unit: ''
raw_conditions: []
description: ''
is_default_bg: true
z_index: 1
events:
- start: '00:00:00'
end: '01:30:00'
state: boost
- start: '01:30:00'
end: '11:00:00'
state: eco
- start: '11:00:00'
end: '19:00:00'
state: comfort
- start: '19:00:00'
end: '23:59:00'
state: boost
- state: frost
condition:
- condition: state
entity_id:
state: 'on'
match: all
- state: frost
condition:
- condition: state
entity_id:
state: 'off'
match: all
total_events: 28
last_update: 2025-12-16T11:55:58.594616+01:00
default_state: frost
friendly_name: Chauffage du Salon
bemo47
Décembre 16, 2025, 10:59
57
mais ma carte fonctionne toujours pareil sans aucune modification, je n’ai pas changé le sensor, est-ce normal ?
oui, si appdaemon tourne encore et/ou que les entités sensors.schedule_* sont toujours là …
bemo47
Décembre 16, 2025, 11:02
59
mais donc il me faut désactiver schedule_parser maintenant ? ça se fait comment ?
Désinstallation de l’app AppDaemon ScheduleParser
1. Supprimer la configuration AppDaemon
Ouvre le fichier /config/apps/apps.yaml
Supprime ou commente le bloc suivant :
schedule_parser:
module: schedule_parser
class: ScheduleParser
config_file: /homeassistant/configuration.yaml
secrets_file: /homeassistant/secrets.yaml
2. Efface le fichier et répertoire
/config/apps/schedule_parser/schedule_parser.py
3. Redémarrer AppDaemon
Add-on Home Assistant : Paramètres → Add-ons → AppDaemon → Redémarrer
bemo47
Décembre 16, 2025, 11:13
61
uhh c’est bon
j’avais pas vu la nuance entre sensor.schedule_chauffage… et sensor.chauffage_…
Donc je l’ai changé dans la carte
Schedule_parser.py supprimé, apps.yaml mis à jour, appdaemon redémarré, et ça fonctionne toujours donc c’est ok
Mais le appdaemon, il faut le garder pour le schedule_state je suppose ?
