J’ai 2 module de chez IKEA (détecteur de présence et un interrupteur à 5 boutons) qui sont repris dans la liste des modules zigbee compatibles.
mais Zigbee2mqtt ne voit pas mais nouveaux modules?
Pouvez-vous m’aider??
voici mon fichier config zigbee2mqtt
[20:30:54] INFO: Handing over control to Zigbee2mqtt Core ...
> zigbee2mqtt@1.18.1 start /app
> node index.js
Zigbee2MQTT:info 2021-07-25 20:30:58: Logging to console and directory: '/config/zigbee2mqtt/log/2021-07-25.20-30-57' filename: log.txt
Zigbee2MQTT:info 2021-07-25 20:30:58: Starting Zigbee2MQTT version 1.18.1 (commit #1.18.1)
Zigbee2MQTT:info 2021-07-25 20:30:58: Starting zigbee-herdsman (0.13.71)
CREATED DECONZ ADAPTER
Zigbee2MQTT:info 2021-07-25 20:30:59: zigbee-herdsman started
Zigbee2MQTT:info 2021-07-25 20:30:59: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":102,"product":0,"revision":"0x26660700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:info 2021-07-25 20:30:59: Currently 0 devices are joined:
Zigbee2MQTT:info 2021-07-25 20:30:59: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2021-07-25 20:30:59: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2021-07-25 20:30:59: Connecting to MQTT server at addon_core_mosquitto
(node:24084) UnhandledPromiseRejectionWarning: Error: Missing protocol
at Object.connect (/app/node_modules/mqtt/lib/connect/index.js:71:13)
at /app/lib/mqtt.js:74:32
at new Promise (<anonymous>)
at MQTT.connect (/app/lib/mqtt.js:73:16)
at Controller.start (/app/lib/controller.js:142:25)
at async start (/app/index.js:42:5)
(Use `node --trace-warnings ...` to show where the warning was created)
(node:24084) UnhandledPromiseRejectionWarning: Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). To terminate the node process on unhandled promise rejection, use the CLI flag `--unhandled-rejections=strict` (see https://nodejs.org/api/cli.html#cli_unhandled_rejections_mode). (rejection id: 2)
(node:24084) [DEP0018] DeprecationWarning: Unhandled promise rejections are deprecated. In the future, promise rejections that are not handled will terminate the Node.js process with a non-zero exit code.
bonjour golfvert,
j’ai suis le mode d’emploi des modules IKEA .
4x appuis sur le bouton programme, suit alors un clignotement rapide , puis clignotement lent pulsé puis quand pairé s’éteint.
donc normalement cela devrait dire que le module est reconnu par ma clé Conbee ll.
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] socat.sh: executing...
[22:43:57] INFO: Socat not enabled, marking service as down
[cont-init.d] socat.sh: exited 0.
[cont-init.d] zigbee2mqtt.sh: executing...
[22:43:58] INFO: MQTT available, fetching server detail ...
[22:43:58] INFO: Previous config file found, checking backup
[22:43:58] INFO: Creating backup config in '/config/zigbee2mqtt/.configuration.yaml.bk'
[22:43:58] INFO: Adjusting Zigbee2mqtt core yaml config with add-on quirks ...
[cont-init.d] zigbee2mqtt.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
[22:43:59] INFO: Handing over control to Zigbee2mqtt Core ...
> node index.js
Zigbee2MQTT:info 2021-07-25 22:44:04: Logging to console and directory: '/config/zigbee2mqtt/log/2021-07-25.22-44-02' filename: log.txt
Zigbee2MQTT:info 2021-07-25 22:44:04: Starting Zigbee2MQTT version 1.18.1 (commit #1.18.1)
Zigbee2MQTT:info 2021-07-25 22:44:04: Starting zigbee-herdsman (0.13.71)
Zigbee2MQTT:info 2021-07-25 22:44:04: zigbee-herdsman started
Zigbee2MQTT:info 2021-07-25 22:44:04: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":102,"product":0,"revision":"0x26660700","transportrev":0},"type":"ConBee2/RaspBee2"}'
Zigbee2MQTT:info 2021-07-25 22:44:04: Currently 0 devices are joined:
Zigbee2MQTT:info 2021-07-25 22:44:04: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2021-07-25 22:44:04: Started frontend on port 0.0.0.0:8099
Zigbee2MQTT:info 2021-07-25 22:44:04: Connecting to MQTT server at mqtt://192.168.0.172:1883
Zigbee2MQTT:error 2021-07-25 22:44:14: Not connected to MQTT server!
Zigbee2MQTT:error 2021-07-25 22:44:24: Not connected to MQTT server!
Zigbee2MQTT:error 2021-07-25 22:44:34: Not connected to MQTT server!
je ne sais pas si c’est mieux ?
J’avoue ne pas savoir comment interpréter ce charabia!
Faut-il supprimer les 3 lignes (server, user et password ) ???
Car dans les différentes installations de zigbee2mqtt que j’ai suivit sur youtub il doit-être relié à un utilisateur (chez moi : mqtt_user) ???
Oui mais pas parfait … ça coince encore à la connexion
J’espère que tu n’as pas pris la configuration au hasard quand même ?
A mon avis, c’est carrément à faire
S’il faut un compte pour se connecter au broker mqtt l’info est dispo dans la config du broker
Mais même ça j’en ai pas besoin pour zigbee2mqtt
non.
j’ai relancé le serveur HA mais toujours pareil, rien dans la fenêtre zigbee2mqtt
faut-il supprimer l’utilisateur mqtt?
ou peut-être tout réinstaller ( mqtt et zigbee2mqtt )
Les logs de la configuration ont l’air bon. La connexion au broker mosquitto est bien là.
Donc, rapprocher l’appareil à appairer de la clé USB, mettre le switch permit_join: true, faire l’opération d’appairage sur le bouton ikéa par exemple.
Normalement, un dialogue s’établit entre zigbee2mqtt et l’appareil. Le log est assez verbeux. Ca se « voit » quand ça marche dans le log.
cela fonctionne toujours pas je crois qu’une bonne nuit me fera du bien.
Merci et à demain pour la suite.
Je verrai si le log est juste avec vous si vous êtes d’accord
bonjour je reviens chez-vous car le problème persiste.
j’ai eu l’idée de voir le log de mosquitto broker et voilà ce que j’ai :
1627293281: New connection from 172.30.32.1 on port 1883.
1627293281: Socket error on client <unknown>, disconnecting.
1627293401: New connection from 172.30.32.1 on port 1883.
1627293401: Socket error on client <unknown>, disconnecting.
1627293521: New connection from 172.30.32.1 on port 1883.
401: Unauthorized1627293522: Socket error on client <unknown>, disconnecting.
1627293642: New connection from 172.30.32.1 on port 1883.
1627293642: Socket error on client <unknown>, disconnecting.
1627293762: New connection from 172.30.32.1 on port 1883.
1627293762: Socket error on client <unknown>, disconnecting.
1627293882: New connection from 172.30.32.1 on port 1883.
401: Unauthorized1627293882: Socket error on client <unknown>, disconnecting.
1627294002: New connection from 172.30.32.1 on port 1883.
1627294002: Socket error on client <unknown>, disconnecting.
1627294122: New connection from 172.30.32.1 on port 1883.
1627294122: Socket error on client <unknown>, disconnecting.
1627294242: New connection from 172.30.32.1 on port 1883.
401: Unauthorized1627294243: Socket error on client <unknown>, disconnecting.
1627294363: New connection from 172.30.32.1 on port 1883.
1627294363: Socket error on client <unknown>, disconnecting.
Oups j’ai oublié de préciser que mon rapsberry pi4 est branché via un câble éthernet à un ampli wifi car j’ai des problème avec mon wifi au rez-de-chaussée, signal faible
Si tout est sur le même PI, ça ne change pas grand chose…
Il faudra faire les choses dans l’ordre et s’assurer que chaque morceau marche avant d’avancer à la suite.
Je suppose même si ce n’est pas dit, c’est une installation avec superviseur (soit Hassos soit version sur debian).
Il faudrait virer les addon zigbee2matt et mosquitto, rebooter et recommencer de zéro en suivant la doc officielle .
Commencer par mosquitto. Vérifier qu’il marche avec un outils comme mqtt explorer https://mqtt-explorer.com/. Tu dois pouvoir envoyer et recevoir des messages avec cet outil. Une fois que tu es sur et certain que mosquitto marche; passe à la suite.
A nouveau avec mqtt explorer vérifier que le dialogue s’établit bien entre les deux addon. Même sans capteur, ils dialoguent et on le voit sur mqtt explorer.
Une fois que là aussi, c’est sur et certain que ça marche, chercher à inclure un équipement.
Là, vu ce que tu as dit, on (en tout cas) je ne sais pas dire quel(x) morceau(x) coince(nt).
Par exemple, hier soir la connexion de zigbee2mtt vers mosquitto marchait (?) et là vu de mosquitto ça ne marche pas… Quel morceau est en cause?
merci golfvert,
je vais suivre ton conseil.
petite parenthèse, lorsqu’on utilise l’image haos_rpi4-64-6.0.rc1.img pour l’installation soit Hassos comme tu dis, est-il normal que je ne puisse plus dialoguer avec mon rapberry pi via putty.
Je te tiens au courant de mes avancements.
