Et question alimentation, tu utilise quoi ? C’est bien un Rpi que tu utilise ?
Page 31 tu parle de ton config.yaml donc j’ai juste ajusté le code
Oui c’est un ODROID-N2 alim 12v 2A 24w
J’ai modifier mais toujours l’éternel probléme
MQTT fonctionne je pense mais pas Z2M
Aprés les ajustements conseillés voici mon journal
Zigbee2MQTT
cont-init: info: running /etc/cont-init.d/socat.sh
[22:13:00] INFO: Socat not enabled, marking service as down
cont-init: info: /etc/cont-init.d/socat.sh exited 0
cont-init: info: running /etc/cont-init.d/zigbee2mqtt.sh
cont-init: info: /etc/cont-init.d/zigbee2mqtt.sh exited 0
services-up: info: copying legacy longrun socat (no readiness notification)
services-up: info: copying legacy longrun zigbee2mqtt (no readiness notification)
[22:13:01] INFO: Handing over control to Zigbee2MQTT Core ...
> zigbee2mqtt@1.26.0 start
> node index.js
Zigbee2MQTT:info 2022-07-04 22:13:05: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-04.22-13-05' filename: log.txt
Zigbee2MQTT:info 2022-07-04 22:13:05: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
Zigbee2MQTT:info 2022-07-04 22:13:05: Starting zigbee-herdsman (0.14.40)
Zigbee2MQTT:info 2022-07-04 22:13:05: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2022-07-04 22:13:05: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
Zigbee2MQTT:info 2022-07-04 22:13:05: Currently 0 devices are joined:
Zigbee2MQTT:info 2022-07-04 22:13:05: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2022-07-04 22:13:06: Connecting to MQTT server at 192.168.1.73:1883
Essai de mettre que ces lignes dans ton configuration.yaml de Ha et efface le reste puis redémarre Ha.
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
# Text to speech
tts:
- platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
Effectuer même chose il y a peut de différence avec ce que j’ai déja:
default_config:
# Text to speech
tts:
Attention : config.yaml et configuration.yaml c’est pas exactement le même fichier.
D’ailleurs la gestion du broker mqtt est faisable avec l’ui désormais
Si ça peut aider, chez moi j’ai donc juste installé Mosquito Broker et juste lancé sans aucune modif dans sa config. Ensuite j’ai installé Zigbee2MQTT et voici comment je l’ai configuré
J’utilise le Sonoff Zigbee 3.0 plus.
Je te conseille d’utiliser le nom long pour ton device:
en cas de déplacement de la clef USB, de branchement d’une autre clef, tu risque de voir ta clef /dev/ttyUSB0 passer en /dev/ttyUSB1 et là, il faudra reparamétrer les applications…
le nom long en /dev/serial/by-id/… ne changera pas tant que la clef USB ne sera pas changée.
Bonjour je n’ai trouver que configuration.yaml et /config/zigbee2mqtt/configuration.yaml
Bonjour merci, je souhaitais le configurer avec un utilisateur unique pour cette configuration d’aprés plus sur, mais je ne connais pas vraiment la raison. Je finirais peut être de faire comme toi si cela fonctionne.
Bonjour, merci pour ces informations intéresssante j’ai modifier avec le nom long, je comprend mieux pourquoi maintenant.
Est que mon journal Z2M vous parrait correct s’il vous plaît. Il indique 0 device (je l’ai grisé ci dessous) voit il ma clef Sonoff d’aprés vous?
Zigbee2MQTT
[10:06:03] INFO: Socat not enabled, marking service as down
[10:06:04] INFO: Handing over control to Zigbee2MQTT Core ...
> node index.js
Zigbee2MQTT:info 2022-07-05 10:06:08: Logging to console and directory: '/config/zigbee2mqtt/log/2022-07-05.10-06-08' filename: log.txt
Zigbee2MQTT:info 2022-07-05 10:06:08: Starting Zigbee2MQTT version 1.26.0 (commit #unknown)
Zigbee2MQTT:info 2022-07-05 10:06:08: Starting zigbee-herdsman (0.14.40)
Zigbee2MQTT:info 2022-07-05 10:06:08: zigbee-herdsman started (resumed)
Zigbee2MQTT:info 2022-07-05 10:06:08: Coordinator firmware version: '{"meta":{"maintrel":1,"majorrel":2,"minorrel":7,"product":1,"revision":20210708,"transportrev":2},"type":"zStack3x0"}'
[color=#]Zigbee2MQTT:info 2022-07-05 10:06:08: Currently 0 devices are joined:[/color]
Zigbee2MQTT:info 2022-07-05 10:06:08: Zigbee: disabling joining new devices.
Zigbee2MQTT:info 2022-07-05 10:06:09: Connecting to MQTT server at 192.168.1.73:1883
oui … =>Zigbee2MQTT:info 2022-07-05 10:06:08: Coordinator firmware version: '{« meta »:{« maintrel »:1,« majorrel »:2,« minorrel »:7,« product »:1,« revision »:20210708,« transportrev »:2},« type »:« zStack3x0 »}
As-tu fait au moins 1 appairage ?
A super je ne savais pas c’est une bonne chose qu’il voit ma clef, je ne peut pas appairé car je n’ai pas accés l’interface Z2M, je ne dois pas installé l’intégration qu’il me propose?
Non. Tu peux utilise z2m OU ZHA (le truc que HA te propose) mais pas les 2 en même temps
Toujours 502 ? tu as relancé l’addon ?
Merci pour l’info, je vais passer sous NUC d’ici quelques jour, faudra donc peut-être pas adapter vu que je garde le dongle
Les derniers logs que tu transmets s’arrêtent tous à l’étape de connexion au broker. Donc on ne sait même pas si le broker réussi à se connecter, ce qui était le problème à la base.
L’erreur 502 est tout à fait normale au démarrage de Z2M. Il faut patienter un peu, et elle disparait lorsque tout c’est bien passé dans le processus de démarrage de Z2M.
Actuellement, ton log ne donne pas d’erreur, mais si tu ne patientes pas assez, il ne termine pas la procédure et donc ne rencontre pas d’erreur.
Ok effectivement le but est d’utiliser Z2M mais oui j’ai toujours 502
