Sévère plantage cette nuit : quelle serait la raison possible?
Je ne peux pas la récupérer
Y en a partout :
Résumé
2024-04-25 01:57:10.783 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration meross_lan which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-25 01:57:10.785 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-25 01:57:10.787 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2024-04-25 01:57:15.734 DEBUG (MainThread) [custom_components.localtuya.discovery] Listening to broadcasts on UDP port 6666 and 6667
2024-04-25 01:57:15.735 INFO (MainThread) [custom_components.localtuya] Cloud API account not configured.
2024-04-25 01:57:17.773 DEBUG (MainThread) [custom_components.localtuya.discovery] Discovered device: {‹ ip ›: ‹ 192.168.0.221 ›, ‹ gwId ›: ‹ 07005783807d3a79d42a ›, ‹ active ›: 2, ‹ ability ›: 0, ‹ mode ›: 0, ‹ encrypt ›: True, ‹ productKey ›: ‹ zY4uzKMEbqCjexxB ›, ‹ version ›: ‹ 3.1 ›}
2024-04-25 01:57:17.862 DEBUG (MainThread) [custom_components.localtuya.discovery] Discovered device: {‹ ip ›: ‹ 192.168.0.222 ›, ‹ gwId ›: ‹ 24600057807d3a718afe ›, ‹ active ›: 2, ‹ ability ›: 0, ‹ mode ›: 0, ‹ encrypt ›: True, ‹ productKey ›: ‹ zY4uzKMEbqCjexxB ›, ‹ version ›: ‹ 3.1 ›}
2024-04-25 01:57:17.897 DEBUG (MainThread) [custom_components.localtuya.discovery] Discovered device: {‹ ip ›: ‹ 192.168.0.218 ›, ‹ gwId ›: ‹ 24600057807d3a719460 ›, ‹ active ›: 2, ‹ ability ›: 0, ‹ mode ›: 0, ‹ encrypt ›: True, ‹ productKey ›: ‹ zY4uzKMEbqCjexxB ›, ‹ version ›: ‹ 3.1 ›}
2024-04-25 01:57:17.911 ERROR (MainThread) [homeassistant.config] Platform error: device_tracker - No module named ‹ homeassistant.components.template.device_tracker ›
File « /usr/src/homeassistant/homeassistant/config.py », line 1437, in _async_load_and_validate_platform_integration
platform = await p_integration.integration.async_get_platform(domain)
File « /usr/src/homeassistant/homeassistant/loader.py », line 1070, in async_get_platform
platforms = await self.async_get_platforms((platform_name,))
File « /usr/src/homeassistant/homeassistant/loader.py », line 1145, in async_get_platforms
import_future.result()
File « /usr/src/homeassistant/homeassistant/loader.py », line 1133, in async_get_platforms
platforms.update(self._load_platforms(platform_names))
File « /usr/src/homeassistant/homeassistant/loader.py », line 1060, in _load_platforms
platform_name: self._load_platform(platform_name)
File « /usr/src/homeassistant/homeassistant/loader.py », line 1232, in _load_platform
cache[full_name] = self._import_platform(platform_name)
File « /usr/src/homeassistant/homeassistant/loader.py », line 1264, in _import_platform
return importlib.import_module(f"{self.pkg_path}.{platform_name}")
File « /usr/local/lib/python3.12/importlib/init.py », line 90, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File «  », line 1387, in _gcd_import
File «  », line 1360, in _find_and_load
File «  », line 1324, in _find_and_load_unlocked
ModuleNotFoundError: No module named ‹ homeassistant.components.template.device_tracker ›
2024-04-25 01:57:17.965 DEBUG (MainThread) [custom_components.localtuya.switch] Initialized switch [Sapin Prise connectée]
2024-04-25 01:57:17.965 DEBUG (MainThread) [custom_components.localtuya.switch] Initialized switch [Glaçon]
2024-04-25 01:57:17.965 DEBUG (MainThread) [custom_components.localtuya.switch] Initialized switch [Ventilo]
2024-04-25 01:57:17.977 INFO (MainThread) [custom_components.localtuya.common] [246…460] Trying to connect to 192.168.0.218…
2024-04-25 01:57:18.073 INFO (MainThread) [custom_components.localtuya.common] [246…afe] Trying to connect to 192.168.0.222…
2024-04-25 01:57:18.075 INFO (MainThread) [custom_components.localtuya.common] [070…42a] Trying to connect to 192.168.0.221…
2024-04-25 01:57:18.076 INFO (MainThread) [custom_components.localtuya.common] [bf4…ljk] Trying to connect to 192.168.0.121…
2024-04-25 01:57:18.079 INFO (MainThread) [custom_components.localtuya.common] [bf8…ni1] Trying to connect to 192.168.0.90…
2024-04-25 01:57:18.080 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Trying to connect to 192.168.0.6…
2024-04-25 01:57:18.224 INFO (MainThread) [custom_components.localtuya.common] [246…460] Successfully connected to 192.168.0.218
2024-04-25 01:57:18.294 INFO (MainThread) [custom_components.localtuya.common] [bf4…ljk] Successfully connected to 192.168.0.121
2024-04-25 01:57:18.299 INFO (MainThread) [custom_components.localtuya.common] [bf8…ni1] Successfully connected to 192.168.0.90
2024-04-25 01:57:18.299 INFO (MainThread) [custom_components.localtuya.common] [246…afe] Successfully connected to 192.168.0.222
2024-04-25 01:57:18.300 INFO (MainThread) [custom_components.localtuya.common] [070…42a] Successfully connected to 192.168.0.221
2024-04-25 01:57:18.305 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Successfully connected to 192.168.0.6
2024-04-25 01:57:19.239 DEBUG (MainThread) [custom_components.localtuya.discovery] Discovered device: {‹ ip ›: ‹ 192.168.0.90 ›, ‹ gwId ›: ‹ bf8ddf3e5ca43179c0cni1 ›, ‹ active ›: 2, ‹ ablilty ›: 0, ‹ encrypt ›: True, ‹ productKey ›: ‹ keytg5kq8gvkv9dh ›, ‹ version ›: ‹ 3.3 ›}
2024-04-25 01:57:20.476 DEBUG (MainThread) [custom_components.localtuya.discovery] Discovered device: {‹ ip ›: ‹ 192.168.0.121 ›, ‹ gwId ›: ‹ bf410e6e36dbbacf20uljk ›, ‹ active ›: 2, ‹ ablilty ›: 0, ‹ encrypt ›: True, ‹ productKey ›: ‹ keytg5kq8gvkv9dh ›, ‹ version ›: ‹ 3.3 ›}
2024-04-25 01:57:57.614 ERROR (MainThread) [homeassistant.components.google_assistant.http] Request for https://homegraph.googleapis.com/v1/devices:requestSync failed: 500
2024-04-25 01:59:11.959 INFO (MainThread) [custom_components.localtuya] Service localtuya.reload called: reloading integration
2024-04-25 01:59:12.455 INFO (MainThread) [custom_components.localtuya.common] [246…460] Closed connection with device Sapin.
2024-04-25 01:59:12.507 WARNING (MainThread) [custom_components.localtuya.common] [246…460] Disconnected - waiting for discovery broadcast
2024-04-25 01:59:12.514 INFO (MainThread) [custom_components.localtuya.common] [246…afe] Closed connection with device Prise connectée Glaçon.
2024-04-25 01:59:12.582 WARNING (MainThread) [custom_components.localtuya.common] [246…afe] Disconnected - waiting for discovery broadcast
2024-04-25 01:59:12.591 INFO (MainThread) [custom_components.localtuya.common] [070…42a] Closed connection with device Prise connectée Ventilo.
2024-04-25 01:59:13.116 WARNING (MainThread) [custom_components.localtuya.common] [070…42a] Disconnected - waiting for discovery broadcast
2024-04-25 01:59:13.141 INFO (MainThread) [custom_components.localtuya.common] [bf4…ljk] Closed connection with device Applique cuisine.
2024-04-25 01:59:13.146 WARNING (MainThread) [custom_components.localtuya.common] [bf4…ljk] Disconnected - waiting for discovery broadcast
2024-04-25 01:59:13.154 INFO (MainThread) [custom_components.localtuya.common] [bf8…ni1] Closed connection with device Plafonnier cuisine.
2024-04-25 01:59:13.157 WARNING (MainThread) [custom_components.localtuya.common] [bf8…ni1] Disconnected - waiting for discovery broadcast
2024-04-25 01:59:13.187 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Closed connection with device Lampe table.
2024-04-25 01:59:13.188 INFO (MainThread) [custom_components.localtuya] Cloud API account not configured.
2024-04-25 01:59:13.203 WARNING (MainThread) [custom_components.localtuya.common] [740…6cc] Disconnected - waiting for discovery broadcast
2024-04-25 01:59:13.625 DEBUG (MainThread) [custom_components.localtuya.discovery] Discovered device: {‹ ip ›: ‹ 192.168.0.6 ›, ‹ gwId ›: ‹ 74056717e868e75ae6cc ›, ‹ active ›: 2, ‹ ability ›: 0, ‹ mode ›: 0, ‹ encrypt ›: True, ‹ productKey ›: ‹ bSXSSFArVKtc4DyC ›, ‹ version ›: ‹ 3.3 ›}
2024-04-25 01:59:14.190 DEBUG (MainThread) [custom_components.localtuya.switch] Initialized switch [Sapin Prise connectée]
2024-04-25 01:59:14.191 DEBUG (MainThread) [custom_components.localtuya.switch] Initialized switch [Glaçon]
2024-04-25 01:59:14.191 DEBUG (MainThread) [custom_components.localtuya.switch] Initialized switch [Ventilo]
2024-04-25 01:59:14.210 INFO (MainThread) [custom_components.localtuya.common] [246…460] Trying to connect to 192.168.0.218…
2024-04-25 01:59:14.211 INFO (MainThread) [custom_components.localtuya.common] [246…afe] Trying to connect to 192.168.0.222…
2024-04-25 01:59:14.212 INFO (MainThread) [custom_components.localtuya.common] [070…42a] Trying to connect to 192.168.0.221…
2024-04-25 01:59:14.213 INFO (MainThread) [custom_components.localtuya.common] [bf4…ljk] Trying to connect to 192.168.0.121…
2024-04-25 01:59:14.214 INFO (MainThread) [custom_components.localtuya.common] [bf8…ni1] Trying to connect to 192.168.0.90…
2024-04-25 01:59:14.216 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Trying to connect to 192.168.0.6…
2024-04-25 01:59:14.249 INFO (MainThread) [custom_components.localtuya.common] [246…460] Successfully connected to 192.168.0.218
2024-04-25 01:59:14.256 INFO (MainThread) [custom_components.localtuya.common] [bf4…ljk] Successfully connected to 192.168.0.121
2024-04-25 01:59:14.262 INFO (MainThread) [custom_components.localtuya.common] [bf8…ni1] Successfully connected to 192.168.0.90
2024-04-25 01:59:14.262 INFO (MainThread) [custom_components.localtuya.common] [246…afe] Successfully connected to 192.168.0.222
2024-04-25 01:59:14.263 INFO (MainThread) [custom_components.localtuya.common] [070…42a] Successfully connected to 192.168.0.221
2024-04-25 01:59:14.272 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Successfully connected to 192.168.0.6
2024-04-25 02:09:56.050 WARNING (MainThread) [custom_components.localtuya.common] [740…6cc] Disconnected - waiting for discovery broadcast
2024-04-25 02:09:58.637 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Trying to connect to 192.168.0.6…
2024-04-25 02:09:58.654 INFO (MainThread) [custom_components.localtuya.common] [740…6cc] Successfully connected to 192.168.0.6
2024-04-25 03:01:16.955 ERROR (MainThread) [homeassistant.components.nut] Error fetching NUT resource status data: Error fetching UPS state: Error running: LIST VAR myups: ERR DATA-STALE
2024-04-25 03:02:14.254 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.257 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.258 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.259 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.261 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.263 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.264 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.265 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.266 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.266 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:02:14.267 ERROR (MainThread) [homeassistant.components.hassio.data] Error fetching hassio data: Error on Supervisor API:
2024-04-25 03:02:45.951 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Error stopping scanner: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.
2024-04-25 03:02:52.826 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
File « src/habluetooth/scanner.py », line 249, in habluetooth.scanner.HaScanner._async_start
File « src/habluetooth/scanner.py », line 250, in habluetooth.scanner.HaScanner._async_start
File « /usr/local/lib/python3.12/site-packages/bleak/init.py », line 198, in start
File « /usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/scanner.py », line 178, in start
File « /usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/manager.py », line 527, in passive_scan
File « /usr/local/lib/python3.12/site-packages/bleak/backends/bluezdbus/utils.py », line 22, in assert_reply
bleak.exc.BleakDBusError: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.
The above exception was the direct cause of the following exception:
File « src/habluetooth/scanner.py », line 381, in habluetooth.scanner.HaScanner._async_restart_scanner
File « src/habluetooth/scanner.py », line 333, in _async_start
habluetooth.scanner.ScannerStartError: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:03:20.723 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:03:50.775 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:04:20.764 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:04:50.732 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:05:20.741 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:05:50.765 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:06:20.764 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:06:50.730 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:07:17.229 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.231 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.232 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.233 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.234 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.235 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.236 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.237 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.238 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:17.239 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:07:20.938 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:07:50.743 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:08:20.751 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:08:50.741 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:09:20.735 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:09:50.744 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:10:20.742 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:10:50.738 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:11:20.780 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:11:50.740 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:12:13.612 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File « /usr/src/homeassistant/homeassistant/components/bluetooth/passive_update_processor.py », line 257, in _async_save_processor_data
File « /usr/src/homeassistant/homeassistant/helpers/storage.py », line 432, in async_save
File « /usr/src/homeassistant/homeassistant/helpers/storage.py », line 535, in _async_handle_write_data
File « /usr/src/homeassistant/homeassistant/helpers/storage.py », line 540, in _async_write_data
File « /usr/local/lib/python3.12/concurrent/futures/thread.py », line 58, in run
File « /usr/src/homeassistant/homeassistant/helpers/storage.py », line 544, in _write_data
File «  », line 225, in makedirs
OSError: [Errno 5] I/O error: ‹ /config/.storage ›
2024-04-25 03:12:20.237 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.239 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.240 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.241 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.242 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.243 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.245 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.245 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.246 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.248 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:12:20.955 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:12:22.265 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France alert for department 50 data: HTTPSConnectionPool(host=‹ webservice.meteofrance.com ›, port=443): Max retries exceeded with url: /v3/warning/currentphenomenons?token=Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8&domain=50&depth=0 (Caused by NewConnectionError(‹ <urllib3.connection.HTTPSConnection object at 0x7f676a4f20>: Failed to establish a new connection: [Errno -3] Try again ›))
2024-04-25 03:12:23.020 ERROR (MainThread) [homeassistant.components.meteo_france] Error requesting Météo-France forecast for city Saint-Jean-le-Thomas - Basse-Normandie (50) - FR data: HTTPSConnectionPool(host=‹ webservice.meteofrance.com ›, port=443): Max retries exceeded with url: /forecast?token=Wj7dVSTjV9YGu1guveLyDq0g7S7TfTjaHBTPTpO0kj8&lat=48.73&lon=-1.51694&lang=fr (Caused by NewConnectionError(‹ <urllib3.connection.HTTPSConnection object at 0x7f564b2de0>: Failed to establish a new connection: [Errno -3] Try again ›))
2024-04-25 03:12:29.040 ERROR (MainThread) [homeassistant.components.google_assistant.http] Could not contact https://homegraph.googleapis.com/v1/devices:reportStateAndNotification
2024-04-25 03:12:50.770 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:12:51.719 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
File « /usr/src/homeassistant/homeassistant/helpers/restore_state.py », line 235, in _async_dump_states
File « /usr/src/homeassistant/homeassistant/helpers/restore_state.py », line 221, in async_dump_states
2024-04-25 03:13:20.754 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:13:50.737 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:14:20.754 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:14:50.730 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:15:20.753 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:15:50.778 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:16:20.801 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:16:50.744 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:17:20.988 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:17:23.245 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.249 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.251 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.254 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.255 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.256 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.257 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.258 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.259 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:23.260 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:17:51.036 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:18:20.811 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:18:50.755 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:19:20.794 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:19:51.088 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:20:20.783 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:20:50.795 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:21:20.785 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:21:51.016 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:22:20.970 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:22:26.254 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.257 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.258 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.259 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.261 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.262 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.264 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.266 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.267 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:26.268 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:22:50.811 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:23:20.781 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:23:50.782 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:24:20.796 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:24:50.767 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:25:20.771 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:25:50.780 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:26:20.787 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:26:50.806 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:27:13.613 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-25 03:27:20.952 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:27:29.231 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.233 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.234 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.236 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.237 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.239 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /host/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.240 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /store request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.242 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /core/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.243 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /supervisor/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:29.244 ERROR (MainThread) [homeassistant.components.hassio.handler] Client error on /os/info request Cannot connect to host 172.30.32.2:80 ssl:default [Connect call failed (‹ 172.30.32.2 ›, 80)]
2024-04-25 03:27:50.808 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:27:51.714 ERROR (MainThread) [homeassistant] Error doing job: Task exception was never retrieved
2024-04-25 03:28:20.788 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:28:50.753 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:29:20.789 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:29:50.801 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:30:20.779 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
2024-04-25 03:30:50.789 ERROR (MainThread) [habluetooth.scanner] hci0 (D8:3A:DD:65:B5:1E): Failed to restart Bluetooth scanner: hci0 (D8:3A:DD:65:B5:1E): Failed to start Bluetooth: [org.freedesktop.DBus.Error.NameHasNoOwner] Could not activate remote peer: startup job failed.; Try power cycling the Bluetooth hardware.
c’est arrivé cette nuit.
Est-ce que c’est parce que j’ai collé ça dans mon fichier de config :
qui provoquait ce message :
Au final HA est KO, tous les services sont inaccessibles, accès réseau dont SSH inopérants, restauration via l’UI pareil.
Je commence à paniquer un peu.
hello
et si tu branches un ecran et un clavier en direct ? ça te retourne quoi ?
ça retourne que HA est gelé.
Hard reboot > Suppression capteurs de suivi d’appareil et surtout de l’add-on iBeacon que je soupçonne d’avoirs mis le boxon.
Retour à la case Opérationnel
sa sort d’ou ca lol
platform: template c’est dans la partir sensor:, qui a rien a faire dans device_tracker:.
quand ta vu ce message, ta pas supprimer ce bout de code ?
Si pourtant je l’avais même remplacé par :
### DETECTION WIFI ###
  sensors:
    device_tracker_wifi:
      value_template: >-
          {% if (states('sensor.jsn_l21_wifi_connection') == "Dark Vador") or ((states('sensor.jsn_l21_wifi_connection') == "R2D2")) %}}
                home
                not_home
    friendly_name: 'Philippe 4 Home'
qui ne fonctionnait pas non plus :
end of the stream or a document separator is expected (70:1)
67 | homeassistant.components.co
68 |
69 | ### DETECTION WIFI ###
70 | - platform: template
71 | sensors:
Du coup j’avais très certainement rétrogradé et le code incriminé était resté là (sans pour autant avoir redémarré HA).
Qu’est ce qui ne va pas dans le code de ### DETECTION WIFI ### ?
Je ne vois pas le problème dans l’indentation.
Ancien format de template sensor:
l’ancien format de template se mets dans la parti sensor:. Si ta pas sensor: dans ton fichier configuration.yaml, il ne comprends pas a quoi correspond la plateforme template.
# Example configuration.yaml entry
    sensors:
      solar_angle:
        friendly_name: "Sun angle"
        unit_of_measurement: "degrees"
        value_template: "{{ state_attr('sun.sun', 'elevation') }}"
      sunrise:
        value_template: "{{ state_attr('sun.sun', 'next_rising') }}"
Vu que tu débute, autant partir sur le nouveau format de template sensor.
le nouveau format ce trouve dans la partie template: maintenant.
template:
  - sensor:
      - name: "Sun State"
        state: >
          {% if is_state('sun.sun', 'above_horizon') %}
            up
            down
Ta déja plein de sujet qui en parle.
Je vois:
Donc je vais passer
de
version 1 :
binary_sensor:
  sensors:
      value_template: >-
                home
                not_home
à
version 2 :
template:
  sensors:
      value_template: >-
                home
                not_home
Mais dans version 1, j’avais déclaré un binary_sensor. Et dans la V2 j’en aurais plus besoin ?
C’est quand même pas simple…
Ta tout faux, la version 2 ( nouveau format ) , les noms d’options change. la stucture change.
exemple stucture pour sensor et binary_sensor:
template:
  - sensor:
      - name: "Sun State"
        state: >
            up
            down
      - name: "Sun"
        state: >
            up
            down
  - binary_sensor:
      - name: "Has Unavailable States"
        state: "{{ states | selectattr('state', 'in', ['unavailable', 'unknown', 'none']) | list | count }}"
      - name: "tartanpion"
les noms d’option changent entre ancien et nouveau:
value_template: deviens state:
friendly_name deviens name:
… lit bien la doc et regarde les exemple pour comprendres.
Pas mieux.
J’ai donc mis ce code dans le fichier de configuration :
template:
  - sensor:
     - name: "Philippe 4 Home"
    state: >
                home
                not_home
  - sensor:
     - name: "Corinne 4 Home"
    state: >
          {% if (states('sensor.pixel_6a_wifi_connection') == "Dark Vador") or ((states('sensor.pixel_6a_wifi_connection') == "R2D2")) %}}
                home
                not_home
syntaxe vérifiée dans HA.
Je redémarre.
Je coupe les smartphones du Wifi et v’lan :
Invalid config for ‹ template › at configuration.yaml, line 39: required key ‹ state › not provided Invalid config for ‹ template › at configuration.yaml, line 40: ‹ state › is an invalid option for ‹ template ›, check: state
Invalid config for ‹ template › at configuration.yaml, line 47: required key ‹ state › not provided Invalid config for ‹ template › at configuration.yaml, line 48: ‹ state › is an invalid option for ‹ template ›, check: state
Pourquoi l’app HA (Companion) me dit-elle ça ?
Regarde le code de warcoze et le tiens et dis nous l’erreur grâce au message
Et attention aux espaces, ils comptent par paire et tu peux pas en ajouter/supprimer plus que 2 d’une ligne à l’autre
L’indentation des « - name… » n’est pas bonne, il manque un espace et à priori, celles suivant tes « state:… » non plus
@ WarC0zes, cob94440, Pulpy-Luke, Cleya
vous êtes des chefs !
Merci d’avoir soutenu une telle brute intellectuelle.
Je vais y arriver !
J’sais pas quand, mais j’vais y arriver.
Comme il t’on tous dit, ta un problème d’indexion. Les espaces sont très important, fais comme mon exemple.
Eh bé nan.
Je me paye des erreurs de syntaxe :
  • Invalid config for ‹ template › at template.yaml, line 3: invalid template (TemplateSyntaxError: unexpected ‹ ) ›) for dictionary value ‹ sensor->0->state ›, got ‹ {% if is_state('sensor.jsn_l21_wifi_connection') == « Dark Vador ») or ((is_state('sensor.jsn_l21_wifi_connection') == « R2D2 »)) %}}\n home\n {% else %}\n not_home\n {% endif %}\n ›
J’en ai les yeux qui piquent :
  - sensor:
        state: >
          {% if is_state('sensor.jsn_l21_wifi_connection') == "Dark Vador") or ((is_state('sensor.jsn_l21_wifi_connection') == "R2D2")) %}}
                home
                not_home
  - sensor:
        state: >
          {% if is_state('sensor.pixel_6a_wifi_connection') == "Dark Vador") or ((is_state('sensor.pixel_6a_wifi_connection') == "R2D2")) %}}
                home
                not_home
encore un problème d’indentation ?
y’a une parentheses qui manque ou une en trop, non ?
exemple:
      - name: "Sun State"
        state: >
            up
            down
toi:
        state: >
                home
                not_home
exemple:
toi , je prends juste le IF , sans le OR.
C'est syntaxe te conviens pas ?
{% if is_state('sensor.jsn_l21_wifi_connection', 'Dark Vador')
avec le OR
{% if is_state('sensor.jsn_l21_wifi_connection', 'Dark Vador') or is_state('sensor.jsn_l21_wifi_connection', 'R2D2') %}
{% .... %} et non {%....%}}.
Déjà ne pas remettre sensor a chaque fois.
Le or je ne pense pas qu’il existe
Tu me mets le doute, j’ai balancer ce qu’il la écris s’en réfléchir lol.
edit:
si le or existe.
